Audio 5.1 W Fedorze 4
jaras
Zmiany w kmix nic nie daja totalnie. Poza tym regulacja glosnosci w xmms, kmix (suwakami) tez nic nie daje :/
Oto co daje te polecenia
[jaras@jaras ~]$ /sbin/lspci
00:00.0 Host bridge: Silicon Integrated Systems [siS] 746 Host (rev 10)
00:01.0 PCI bridge: Silicon Integrated Systems [siS] SG86C202
00:02.0 ISA bridge: Silicon Integrated Systems [siS] SiS963 [MuTIOL Media IO] (rev 25)
00:02.1 SMBus: Silicon Integrated Systems [siS] SiS961/2 SMBus Controller
00:02.5 IDE interface: Silicon Integrated Systems [siS] 5513 [iDE]
00:02.7 Multimedia audio controller: Silicon Integrated Systems [siS] Sound Controller (rev a0)
00:03.0 USB Controller: Silicon Integrated Systems [siS] USB 1.0 Controller (rev 0f)
00:03.1 USB Controller: Silicon Integrated Systems [siS] USB 1.0 Controller (rev 0f)
00:03.2 USB Controller: Silicon Integrated Systems [siS] USB 2.0 Controller
00:04.0 Ethernet controller: Silicon Integrated Systems [siS] SiS900 PCI Fast Ethernet (rev 90)
00:0c.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
00:0c.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
01:00.0 VGA compatible controller: nVidia Corporation NV36 [GeForce FX 5700LE] (rev a1)
[jaras@jaras ~]$ /sbin/lsmod
Module Size Used by
parport_pc 28933 1
lp 13001 0
parport 40585 2 parport_pc,lp
autofs4 29253 2
rfcomm 42333 0
l2cap 30661 5 rfcomm
bluetooth 56133 4 rfcomm,l2cap
sunrpc 167813 1
ipt_REJECT 5569 1
ipt_state 1857 1
ip_conntrack 41497 1 ipt_state
iptable_filter 2881 1
ip_tables 19521 3 ipt_REJECT,ipt_state,iptable_filter
nls_utf8 2113 3
ntfs 183440 2
dm_mod 58101 0
video 15941 0
button 6609 0
battery 9413 0
ac 4805 0
md5 4033 1
ipv6 268097 12
ohci_hcd 26849 0
ehci_hcd 41037 0
bt878 10457 0
tuner 27121 0
bttv 161393 1 bt878
video_buf 23749 1 bttv
i2c_algo_bit 9289 1 bttv
v4l2_common 5825 1 bttv
btcx_risc 4937 1 bttv
tveeprom 13017 1 bttv
videodev 9537 1 bttv
shpchp 94405 0
i2c_sis96x 5445 0
i2c_core 21569 5 tuner,bttv,i2c_algo_bit,tveeprom,i2c_sis96x
snd_intel8x0 34689 3
snd_ac97_codec 75961 1 snd_intel8x0
snd_seq_dummy 3653 0
snd_seq_oss 37057 0
snd_seq_midi_event 9153 1 snd_seq_oss
snd_seq 62289 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi_event
snd_seq_device 8781 3 snd_seq_dummy,snd_seq_oss,snd_seq
snd_pcm_oss 51185 0
snd_mixer_oss 17857 1 snd_pcm_oss
snd_pcm 100169 4 snd_intel8x0,snd_ac97_codec,snd_pcm_oss
snd_timer 33605 3 snd_seq,snd_pcm
snd 57157 13 snd_intel8x0,snd_ac97_codec,snd_seq_oss,snd_seq,snd_seq_device,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer
soundcore 10913 1 snd
snd_page_alloc 9669 2 snd_intel8x0,snd_pcm
sis900 21697 0
floppy 65269 0
ext3 132553 1
jbd 86233 1 ext3
Zrobilem jak mowiles. Teraz mam bledy przy odpalaniu:
xmms -> nie mozna odtworzyc wyjscia dzwieku
mplayera -> audio_setp: can't open audio device /dev/dsp. urzadzene lub zasoby zajete:
Nie dziala mi suwak, ani opcja mute gdy zmieniam to w kmix, czy na pasku zadan w glosniczku :/
co teraz?
hmmm...
Wygląda na to że ten modulik raczej nie jest potrzebny, trza wrócić do punktu wyjścia. Usówa się go poleceniem
modprobe -r snd-bt87x
Nie napisałeś, czy z tamtymi ustawieniam masz jakikolwiek dzwięk, czy nie masz go w ogóle.
W xmms'ie ustaw w zakładce wtyczki we/wy dzwięku:
wtyczka wyjściowa ALSA, czy coś w tym stylu.
W kmix'ie masz wszystkie suwaki na max ? Nawet te VIA DX, czy coś tam :)
Teoretycznie wszystko masz co Ci potrzeba, kurcze...
W Kmix masz nad suwakami zielone kółeczka, jak je wciśniesz to się podświetla, zrób żeby się wszystkie świeciły - chyba że już się świecą :]
Kurcze, jak to nie pomoże(pewnie tak), to jak narazie pomysłów brak. agrhgh
EDIT
A dobrze masz podłączone te głośniki ?
Ja mam podobny problem, tyle, że z kartą SB Live! Musiałem wszystkie wskaźniki w mixerze dać na maksymalną wartość, a i tak satelity nie grają z taką samą głośnością... Oczywiście suwak głośności Master też nie ma większego wpływu, jedyne co wycisza to subwoofer :) No ale już się z tym pogodziłem...
  • 2 weeks later...
