Mplayer I Błędy ...
MitS
Witam!
Miałem zainstalowanego mplayera jeszcze tydzień temu przed formatem i działał bez problemowo a teraz po formacie i ponownym zainstalowaniu mplayera, gdy próbuje właczyć film to wywala mi:
[mits@ozyrys Filmy]$ mplayer mits.avi -fs
Using GNU internationalization
Original domain: messages
Original dirname: /usr/share/locale
Current domain: mplayer
Current dirname: /usr/share/locale
MPlayer 1.0pre7-4.0.0 © 2000-2005 MPlayer Team
CPU: Advanced Micro Devices Athlon MP/XP Thoroughbred (Family: 6, Stepping: 1)
Detected cache-line size is 64 bytes
CPUflags:  MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
Linux RTC init error in ioctl (rtc_irqp_set 1024): Permission denied
Try adding "echo 1024 > /proc/sys/dev/rtc/max-user-freq" to your system startup scripts.
Opening joystick device /dev/input/js0
Can't open joystick device /dev/input/js0 : No such file or directory
Can't init input joystick
Setting up LIRC support...
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support.
You will not be able to use your remote control.
Playing mits.avi.
AVI file format detected.
VIDEO:  [MP42]  320x240  24bpp  25.000 fps  725.6 kbps (88.6 kbyte/s)
Clip info:
Software: VirtualDubMod 1.5.10.1 (build 2366/release)
Opening audio decoder: [pcm] Uncompressed PCM audio decoder
AUDIO: 44100 Hz, 2 ch, s16le, 1411.2 kbit/100.00% (ratio: 176400->176400)
Selected audio codec: [pcm] afm:pcm (Uncompressed PCM)
vo: X11 running at 1280x1024 with depth 24 and 32 bpp (":0.0" => local display)
vo_xvmc: X-Video extension 2.2
vo_xvmc: X-Video MotionCompensation Extension version 1.0
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffmp42] vfm:ffmpeg (FFmpeg M$ MPEG-4 v2)
Checking audio filter chain for 44100Hz/2ch/s16le -> 44100Hz/2ch/s16le...
AF_pre: 44100Hz/2ch/s16le
AO: [oss] 44100Hz 2ch s16le (2 bps)
Building audio filter chain for 44100Hz/2ch/s16le -> 44100Hz/2ch/s16le...
Starting playback...
VDec: vo config request - 320 x 240 (preferred csp: Planar YV12)
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
The selected video_out device is incompatible with this codec.
mplayer: vf.c:250: vf_get_image: Assertion `vf->w > 0' failed.
MPlayer interrupted by signal 6 in module: decode_video
- MPlayer crashed. This shouldn't happen.
  It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
  gcc version. If you think it's MPlayer's fault, please read
  DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
  won't help unless you provide this information when reporting a possible bug.
[mits@ozyrys Filmy]$ echo 1024 > /proc/sys/dev/rtc/max-user-freq
bash: /proc/sys/dev/rtc/max-user-freq: Brak dostępu
[mits@ozyrys Filmy]$ su
Password:
[root@ozyrys Filmy]# echo 1024 > /proc/sys/dev/rtc/max-user-freq
[root@ozyrys Filmy]# mplayer mits.avi -fs
Creating config file: /root/.mplayer/config
Playing mits.avi.
Clip info:
jak to naprawić ??
Kodeki mam wgrane :]
Ciebie powinna interesowac ta czesc:
oznacza ze wyjscie video nie jest kompatybilne z kodekiem i nie mozna przeprowadzic poprawnego skalowania,
zmien sterownik wyswietlania na np. gl oraz sprobuj czy w filmach z inna rozdzielczoscia np. 640x480 jest podobnie
Dzięki za jakąś odpowiedź, ale niestety to co ty mówisz to narazie jest dla mnie czarną magią.
To znaczy jak zmienić ten sterownik wyświetlania ???
A jeśli chodzi o rozdzielczość w filmach to próbowałem zmniejszyć i to samo wyskakuje
chodzilo mi bardziej o to zeby wyedytowal plik konfiguracyjny ;) (bo z tego co widze uruchamia filmy z konsoli nie uzywajac nakladki graficznej)
globalny plik konfiguracyjny dla wszystkich uzytkownikow to /etc/mplayer/mplayer.conf.rpmsave; konfiguracja dla uzytkownikow (zastepujaca poszczegolne ustawienia z wczesniejszej konfiguracji globalnej) to ~/.mplayer/config
interesujace Ci ustawienia to:
# Ustawienie standardowego sterownika wyswietlania obrazu (zobacz -vo help aby uzyskac pelna liste).
vo=gl
# Tryb fullscreen
fs=yes
# Jezeli chesz uzywac w trybie fullscreen innego sterownika
# (dga, x11, sdl ustawienia tylko dla kart z wyjsciem video).
vm=no
Oto tryby pracy mplayera:
Available video output drivers:
       xvmc    XVideo Motion Compensation
       xv      X11/Xv
       x11     X11 ( XImage/Shm )
       xover   General X11 driver for overlay capable video output drivers
       gl      X11 (OpenGL)
       gl2     X11 (OpenGL) - multiple textures version
       dga     DGA ( Direct Graphic Access V2.0 )
       sdl     SDL YUV/RGB/BGR renderer (SDL v1.1.7+ only!)
       aa      AAlib
       caca    libcaca
       vesa    VESA VBE 2.0 video output
       xvidix  X11 (VIDIX)
       cvidix  console VIDIX
       null    Null video output
       mpegpes Mpeg-PES file
       yuv4mpeg        yuv4mpeg output for mjpegtools
       png     PNG file
       jpeg    JPEG file
       gif89a  animated GIF output
       tga     Targa output
       pnm     PPM/PGM/PGMYUV file
       md5sum  md5sum of each frame
poprobuj z tymi ustawieniami, niestety nie wiem jaki masz sprzet wiec za bardzo nie moge Ci doradzic
karta graficzna: intel440i
nie slyszalem o takiej karcie graficznej :unsure: moze chodzilo Ci o i810?
nie testowalem na takim sprzecie odtwarzania filmow, faktem jest jednak ze zintegrowana karta tego typu jest wolna (obecne zintegrowane karty intela sa o niebo lepsze),
na Twoim miejscu poprobowalby z tymi trybami, jezeli masz poprawnie wykryta karte, to nawet sprobuj wlaczyc gl (bo ta karta oferuje prowizoryczny "tryb 3D" - OpenGL; tylko nie wiem jak ze sprzetowymi instrukcjami, bo software'wo to bedzie slabo), ale najlepsze rezultaty pownienes uzyskac na domyslnym xv + wlaczony framedrop
ponadto widzac po procesorze radzilbym uruchamiac filmy z konsoli, waro zebys rowniez zainteresowal sie projektem (paczka dla Fedory do pobrania) eMovix
