ky7en Napisano Wrzesień 21, 2005 Zgłoszenie Share Napisano Wrzesień 21, 2005 Witam OS: 2.6.12-1.1398_FC4 x86-64 WM: GNOME 2.10.1 Fedora lubi czesto pasc, dzieje sie tak: Klepie bicika na hydrogen, w tle pare konsol (ssh z bsd,wspa), a tu nagle dysk zaczyna intensywnie pracowac (mam raptora wiec zaczyna drapac glosnio) i myszka ledwo co sie rusza, nastepne 10sec i nic sie nie da zrobic (crtl+alt+f1 - nie dziala) Fedora zwisła Juz 4 raz tak sie stalo. Przegladajc logi nic dziwnego nie zauwazylem, ale wkleje, moze ktos zauwazny czemu tak sie dzieje (ehh...szkoda ze BSD na desktop nie jest tak rozwiniete jak liny, pewnie by stabliniej chodzilo...) %cat /etc/var/log/message Sep 21 15:20:01 gnu crond(pam_unix)[21984]: session opened for user root by (uid=0) Sep 21 15:20:02 gnu crond(pam_unix)[21984]: session closed for user root Sep 21 15:22:16 gnu su(pam_unix)[22037]: session opened for user root by (uid=500) Sep 21 15:22:23 gnu su(pam_unix)[22037]: session closed for user root Sep 21 15:25:01 gnu crond(pam_unix)[22090]: session opened for user root by (uid=0) Sep 21 15:25:09 gnu crond(pam_unix)[22090]: session closed for user root Sep 21 15:29:23 gnu syslogd 1.4.1: restart. Sep 21 15:29:23 gnu kernel: klogd 1.4.1, log source = /proc/kmsg started. Sep 21 15:29:23 gnu kernel: Bootdata ok (command line is ro root=LABEL=/ rhgb quiet) Sep 21 15:29:23 gnu kernel: Linux version 2.6.12-1.1398_FC4 ([email protected]) (gcc version 4.0.0 20050519 (Red Hat 4.0.0-8)) #1 Fri Jul 15 00:51:38 EDT 2005 Sep 21 15:29:23 gnu kernel: BIOS-provided physical RAM map: Sep 21 15:29:23 gnu kernel: BIOS-e820: 0000000000000000 - 000000000009f800 (usable) Sep 21 15:29:23 gnu kernel: BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved) Sep 21 15:29:23 gnu kernel: BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved) Sep 21 15:29:23 gnu kernel: BIOS-e820: 0000000000100000 - 000000003fff0000 (usable) Sep 21 15:29:23 gnu kernel: BIOS-e820: 000000003fff0000 - 000000003fff3000 (ACPI NVS) Sep 21 15:29:23 gnu kernel: BIOS-e820: 000000003fff3000 - 0000000040000000 (ACPI data) Sep 21 15:29:23 gnu kernel: BIOS-e820: 00000000d0000000 - 00000000e0000000 (reserved) Sep 21 15:29:23 gnu kernel: BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved) Sep 21 15:29:23 gnu kernel: Nvidia board detected. Ignoring ACPI timer override. Sep 21 15:29:23 gnu kernel: ACPI: PM-Timer IO Port: 0x1008 Sep 21 15:29:23 gnu kernel: ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled) Sep 21 15:29:23 gnu kernel: Processor #0 15:15 APIC version 16 Sep 21 15:29:23 gnu kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled) Sep 21 15:29:23 gnu kernel: ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1]) Sep 21 15:29:23 gnu kernel: ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1]) Sep 21 15:29:23 gnu kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0]) Sep 21 15:29:23 gnu kernel: IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23 Sep 21 15:29:23 gnu kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) Sep 21 15:29:23 gnu kernel: ACPI: BIOS IRQ0 pin2 override ignored. Sep 21 15:29:23 gnu kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) Sep 21 15:29:23 gnu kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge) Sep 21 15:29:23 gnu kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge) Sep 21 15:29:23 gnu kernel: Setting APIC routing to flat Sep 21 15:29:23 gnu kernel: Using ACPI (MADT) for SMP configuration information Sep 21 15:29:23 gnu kernel: Allocating PCI resources starting at 40000000 (gap: 40000000:90000000) Sep 21 15:29:23 gnu kernel: Checking aperture... Sep 21 15:29:23 gnu kernel: CPU 0: aperture @ 25fc000000 size 32 MB Sep 21 15:29:23 gnu kernel: Aperture from northbridge cpu 0 too small (32 MB) Sep 21 15:29:23 gnu kernel: No AGP bridge found Sep 21 15:29:23 gnu kernel: Built 1 zonelists Sep 21 15:29:23 gnu kernel: Kernel command line: ro root=LABEL=/ rhgb quiet Sep 21 15:29:23 gnu kernel: Initializing CPU#0 Sep 21 15:29:23 gnu kernel: PID hash table entries: 4096 (order: 12, 131072 bytes) Sep 21 15:29:23 gnu kernel: time.c: Using 3.579545 MHz PM timer. Sep 21 15:29:23 gnu kernel: time.c: Detected 2010.323 MHz processor. Sep 21 15:29:23 gnu kernel: time.c: Using PIT/TSC based timekeeping. Sep 21 15:29:23 gnu kernel: Console: colour VGA+ 80x25 Sep 21 15:29:23 gnu kernel: Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) Sep 21 15:29:23 gnu kernel: Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) Sep 21 15:29:23 gnu kernel: Memory: 1023880k/1048512k available (2822k kernel code, 23728k reserved, 1265k data, 196k init) Sep 21 15:29:23 gnu kernel: Security Framework v1.0.0 initialized Sep 21 15:29:23 gnu kernel: SELinux: Initializing. Sep 21 15:29:23 gnu kernel: SELinux: Starting in permissive mode Sep 21 15:29:23 gnu kernel: selinux_register_security: Registering secondary module capability Sep 21 15:29:23 gnu kernel: Capability LSM initialized as secondary Sep 21 15:29:23 gnu kernel: Mount-cache hash table entries: 256 Sep 21 15:29:23 gnu kernel: CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line) Sep 21 15:29:23 gnu kernel: CPU: L2 Cache: 512K (64 bytes/line) Sep 21 15:29:23 gnu kernel: CPU: AMD Athlon(tm) 64 Processor 3200+ stepping 00 Sep 21 15:29:23 gnu kernel: Using local APIC timer interrupts. Sep 21 15:29:23 gnu kernel: Detected 12.564 MHz APIC timer. Sep 21 15:29:23 gnu kernel: testing NMI watchdog ... OK. Sep 21 15:29:23 gnu kernel: checking if image is initramfs... it is Sep 21 15:29:23 gnu kernel: NET: Registered protocol family 16 Sep 21 15:29:23 gnu kernel: PCI: Using configuration type 1 Sep 21 15:29:23 gnu kernel: mtrr: v2.0 (20020519) Sep 21 15:29:23 gnu kernel: ACPI: Subsystem revision 20050309 Sep 21 15:29:23 gnu kernel: ACPI: Interpreter enabled Sep 21 15:29:23 gnu kernel: ACPI: Using IOAPIC for interrupt routing Sep 21 15:29:23 gnu kernel: ACPI: PCI Root Bridge [PCI0] (0000:00) Sep 21 15:29:23 gnu kernel: PCI: Probing PCI hardware (bus 00) Sep 21 15:29:23 gnu kernel: PCI: Transparent bridge - 0000:00:09.0 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 *5 7 9 10 11 12 14 15) Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LNK2] (IRQs 3 4 5 7 9 10 11 *12 14 15) Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LNK3] (IRQs 3 4 5 7 9 10 *11 12 14 15) Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LNK4] (IRQs 3 4 5 7 9 10 11 *12 14 15) Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LNK5] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LUBA] (IRQs 3 4 5 7 9 *10 11 12 14 15) Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LUBB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LMAC] (IRQs 3 4 *5 7 9 10 11 12 14 15) Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LACI] (IRQs 3 4 5 7 9 *10 11 12 14 15) Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LMCI] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LSMB] (IRQs 3 4 5 7 9 10 11 *12 14 15) Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LUB2] (IRQs 3 4 5 7 9 10 *11 12 14 15) Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LIDE] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LSID] (IRQs 3 4 5 7 9 *10 11 12 14 15) Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LFID] (IRQs 3 4 5 7 9 10 *11 12 14 15) Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [LPCA] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APC1] (IRQs 16) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APC2] (IRQs 17) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APC3] (IRQs 18) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APC4] (IRQs 19) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APC5] (IRQs *16), disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22 23) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APCG] (IRQs 20 21 22 23) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22 23) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22 23) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22 23) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APCS] (IRQs 20 21 22 23) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22 23) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22 23) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APSI] (IRQs 20 21 22 23) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APSJ] (IRQs 20 21 22 23) *0, disabled. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APCP] (IRQs 20 21 22 23) *0, disabled. Sep 21 15:29:23 gnu kernel: Linux Plug and Play Support v0.97 (c) Adam Belay Sep 21 15:29:23 gnu kernel: pnp: PnP ACPI init Sep 21 15:29:23 gnu kernel: pnp: PnP ACPI: found 13 devices Sep 21 15:29:23 gnu kernel: usbcore: registered new driver usbfs Sep 21 15:29:23 gnu kernel: usbcore: registered new driver hub Sep 21 15:29:23 gnu kernel: PCI: Using ACPI for IRQ routing Sep 21 15:29:23 gnu kernel: PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report Sep 21 15:29:23 gnu kernel: PCI-DMA: Disabling IOMMU. Sep 21 15:29:23 gnu kernel: pnp: 00:00: ioport range 0x1000-0x107f could not be reserved Sep 21 15:29:23 gnu kernel: pnp: 00:00: ioport range 0x1080-0x10ff has been reserved Sep 21 15:29:23 gnu kernel: pnp: 00:00: ioport range 0x1400-0x147f has been reserved Sep 21 15:29:23 gnu kernel: pnp: 00:00: ioport range 0x1480-0x14ff could not be reserved Sep 21 15:29:23 gnu kernel: pnp: 00:00: ioport range 0x1800-0x187f has been reserved Sep 21 15:29:23 gnu kernel: pnp: 00:00: ioport range 0x1880-0x18ff has been reserved Sep 21 15:29:23 gnu kernel: IA32 emulation $Id: sys_ia32.c,v 1.32 2002/03/24 13:02:28 ak Exp $ Sep 21 15:29:23 gnu kernel: audit: initializing netlink socket (disabled) Sep 21 15:29:23 gnu kernel: audit(1127316525.291:1): initialized Sep 21 15:29:23 gnu kernel: Total HugeTLB memory allocated, 0 Sep 21 15:29:23 gnu kernel: VFS: Disk quotas dquot_6.5.1 Sep 21 15:29:23 gnu kernel: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) Sep 21 15:29:23 gnu kernel: SELinux: Registering netfilter hooks Sep 21 15:29:23 gnu kernel: Initializing Cryptographic API Sep 21 15:29:23 gnu kernel: ksign: Installing public key data Sep 21 15:29:23 gnu kernel: Loading keyring Sep 21 15:29:23 gnu kernel: - Added public key 8977494790D08EB3 Sep 21 15:29:23 gnu kernel: - User ID: Red Hat, Inc. (Kernel Module GPG key) Sep 21 15:29:23 gnu kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5 Sep 21 15:29:23 gnu kernel: pcie_portdrv_probe->Dev[005d:10de] has invalid IRQ. Check vendor BIOS Sep 21 15:29:23 gnu kernel: assign_interrupt_mode Found MSI capability Sep 21 15:29:23 gnu kernel: pcie_portdrv_probe->Dev[005d:10de] has invalid IRQ. Check vendor BIOS Sep 21 15:29:23 gnu kernel: assign_interrupt_mode Found MSI capability Sep 21 15:29:23 gnu kernel: pcie_portdrv_probe->Dev[005d:10de] has invalid IRQ. Check vendor BIOS Sep 21 15:29:23 gnu kernel: assign_interrupt_mode Found MSI capability Sep 21 15:29:23 gnu kernel: pcie_portdrv_probe->Dev[005d:10de] has invalid IRQ. Check vendor BIOS Sep 21 15:29:23 gnu kernel: assign_interrupt_mode Found MSI capability Sep 21 15:29:23 gnu kernel: Real Time Clock Driver v1.12 Sep 21 15:29:23 gnu kernel: Linux agpgart interface v0.101 (c) Dave Jones Sep 21 15:29:23 gnu kernel: PNP: PS/2 controller doesn't have AUX irq; using default 0xc Sep 21 15:29:23 gnu kernel: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 112 Sep 21 15:29:23 gnu kernel: serio: i8042 AUX port at 0x60,0x64 irq 12 Sep 21 15:29:23 gnu kernel: serio: i8042 KBD port at 0x60,0x64 irq 1 Sep 21 15:29:23 gnu kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 76 ports, IRQ sharing enabled Sep 21 15:29:23 gnu kernel: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A Sep 21 15:29:23 gnu kernel: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A Sep 21 15:29:23 gnu kernel: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A Sep 21 15:29:23 gnu kernel: io scheduler noop registered Sep 21 15:29:23 gnu kernel: io scheduler anticipatory registered Sep 21 15:29:23 gnu kernel: io scheduler deadline registered Sep 21 15:29:23 gnu kernel: io scheduler cfq registered Sep 21 15:29:23 gnu kernel: RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize Sep 21 15:29:23 gnu kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2 Sep 21 15:29:23 gnu kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx Sep 21 15:29:23 gnu kernel: NFORCE-CK804: IDE controller at PCI slot 0000:00:06.0 Sep 21 15:29:23 gnu kernel: NFORCE-CK804: chipset revision 162 Sep 21 15:29:23 gnu kernel: NFORCE-CK804: not 100% native mode: will probe irqs later Sep 21 15:29:23 gnu kernel: NFORCE-CK804: BIOS didn't set cable bits correctly. Enabling workaround. Sep 21 15:29:23 gnu kernel: NFORCE-CK804: 0000:00:06.0 (rev a2) UDMA133 controller Sep 21 15:29:23 gnu kernel: ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:DMA Sep 21 15:29:23 gnu kernel: ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:DMA, hdd:DMA Sep 21 15:29:23 gnu kernel: hdc: HL-DT-STDVD-ROM GDR8162B, ATAPI CD/DVD-ROM drive Sep 21 15:29:23 gnu kernel: hdd: LITE-ON DVDRW SOHW-1653S, ATAPI CD/DVD-ROM drive Sep 21 15:29:23 gnu kernel: ide1 at 0x170-0x177,0x376 on irq 15 Sep 21 15:29:23 gnu kernel: hdc: ATAPI 48X DVD-ROM drive, 256kB Cache, UDMA(33) Sep 21 15:29:23 gnu kernel: Uniform CD-ROM driver Revision: 3.20 Sep 21 15:29:23 gnu kernel: hdd: ATAPI 48X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache Sep 21 15:29:23 gnu kernel: ide-floppy driver 0.99.newide Sep 21 15:29:23 gnu kernel: usbcore: registered new driver hiddev Sep 21 15:29:23 gnu kernel: usbcore: registered new driver usbhid Sep 21 15:29:23 gnu kernel: drivers/usb/input/hid-core.c: v2.01:USB HID core driver Sep 21 15:29:23 gnu kernel: mice: PS/2 mouse device common for all mice Sep 21 15:29:23 gnu kernel: md: md driver 0.90.1 MAX_MD_DEVS=256, MD_SB_DISKS=27 Sep 21 15:29:23 gnu kernel: NET: Registered protocol family 2 Sep 21 15:29:23 gnu kernel: IP: routing cache hash table of 1024 buckets, 56Kbytes Sep 21 15:29:23 gnu kernel: TCP established hash table entries: 262144 (order: 9, 2097152 bytes) Sep 21 15:29:23 gnu kernel: TCP bind hash table entries: 65536 (order: 9, 3670016 bytes) Sep 21 15:29:23 gnu kernel: TCP: Hash tables configured (established 262144 bind 65536) Sep 21 15:29:23 gnu kernel: Initializing IPsec netlink socket Sep 21 15:29:23 gnu auditd[2218]: Init complete, audit pid set to: 2218 Sep 21 15:29:23 gnu kernel: NET: Registered protocol family 1 Sep 21 15:29:23 gnu kernel: NET: Registered protocol family 17 Sep 21 15:29:23 gnu kernel: powernow-k8: Found 1 AMD Athlon 64 / Opteron processors (version 1.40.2) Sep 21 15:29:23 gnu kernel: powernow-k8: 0 : fid 0xc (2000 MHz), vid 0x6 (1400 mV) Sep 21 15:29:23 gnu kernel: powernow-k8: 1 : fid 0xa (1800 MHz), vid 0x8 (1350 mV) Sep 21 15:29:23 gnu kernel: powernow-k8: 2 : fid 0x2 (1000 MHz), vid 0x12 (1100 mV) Sep 21 15:29:23 gnu kernel: cpu_init done, current fid 0xc, vid 0x6 Sep 21 15:29:23 gnu kernel: ACPI wakeup devices: Sep 21 15:29:23 gnu kernel: HUB0 XVR0 XVR1 XVR2 XVR3 USB0 USB2 MMAC MMCI UAR1 Sep 21 15:29:23 gnu kernel: ACPI: (supports S0 S1 S4 S5) Sep 21 15:29:23 gnu kernel: Freeing unused kernel memory: 196k freed Sep 21 15:29:23 gnu kernel: SCSI subsystem initialized Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APC2] enabled at IRQ 17 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt 0000:01:09.0[A] -> Link [APC2] -> GSI 17 (level, low) -> IRQ 217 Sep 21 15:29:23 gnu kernel: ata1: SATA max UDMA/100 cmd 0xFFFFC20000002080 ctl 0xFFFFC2000000208A bmdma 0xFFFFC20000002000 irq 217 Sep 21 15:29:23 gnu kernel: ata2: SATA max UDMA/100 cmd 0xFFFFC200000020C0 ctl 0xFFFFC200000020CA bmdma 0xFFFFC20000002008 irq 217 Sep 21 15:29:23 gnu kernel: ata3: SATA max UDMA/100 cmd 0xFFFFC20000002280 ctl 0xFFFFC2000000228A bmdma 0xFFFFC20000002200 irq 217 Sep 21 15:29:23 gnu kernel: ata4: SATA max UDMA/100 cmd 0xFFFFC200000022C0 ctl 0xFFFFC200000022CA bmdma 0xFFFFC20000002208 irq 217 Sep 21 15:29:23 gnu kernel: input: AT Translated Set 2 keyboard on isa0060/serio0 Sep 21 15:29:23 gnu kernel: ata1: dev 0 ATA, max UDMA/133, 72303840 sectors: lba48 Sep 21 15:29:23 gnu kernel: ata1: dev 0 configured for UDMA/100 Sep 21 15:29:23 gnu kernel: scsi0 : sata_sil Sep 21 15:29:23 gnu kernel: ata2: dev 0 ATA, max UDMA/133, 156301488 sectors: lba48 Sep 21 15:29:23 gnu kernel: ata2(0): applying Seagate errata fix Sep 21 15:29:23 gnu kernel: ata2: dev 0 configured for UDMA/100 Sep 21 15:29:23 gnu kernel: scsi1 : sata_sil Sep 21 15:29:23 gnu kernel: ata3: dev 0 ATA, max UDMA/133, 234441648 sectors: lba48 Sep 21 15:29:23 gnu kernel: ata3(0): applying Seagate errata fix Sep 21 15:29:23 gnu kernel: ata3: dev 0 configured for UDMA/100 Sep 21 15:29:23 gnu kernel: scsi2 : sata_sil Sep 21 15:29:23 gnu kernel: ata4: no device found (phy stat 00000000) Sep 21 15:29:23 gnu kernel: scsi3 : sata_sil Sep 21 15:29:23 gnu kernel: Vendor: ATA Model: WDC WD360GD-00FL Rev: 27.0 Sep 21 15:29:23 gnu kernel: Type: Direct-Access ANSI SCSI revision: 05 Sep 21 15:29:23 gnu kernel: SCSI device sda: 72303840 512-byte hdwr sectors (37020 MB) Sep 21 15:29:23 gnu kernel: SCSI device sda: drive cache: write back Sep 21 15:29:23 gnu kernel: SCSI device sda: 72303840 512-byte hdwr sectors (37020 MB) Sep 21 15:29:23 gnu kernel: SCSI device sda: drive cache: write back Sep 21 15:29:23 gnu kernel: sda: sda1 sda2 Sep 21 15:29:23 gnu kernel: sda1: <bsd: sda5 sda6 sda7 sda8 sda9 sda10 sda11 > Sep 21 15:29:23 gnu kernel: Attached scsi disk sda at scsi0, channel 0, id 0, lun 0 Sep 21 15:29:23 gnu kernel: Vendor: ATA Model: ST380013AS Rev: 3.05 Sep 21 15:29:23 gnu kernel: Type: Direct-Access ANSI SCSI revision: 05 Sep 21 15:29:23 gnu kernel: SCSI device sdb: 156301488 512-byte hdwr sectors (80026 MB) Sep 21 15:29:23 gnu kernel: SCSI device sdb: drive cache: write back Sep 21 15:29:23 gnu kernel: SCSI device sdb: 156301488 512-byte hdwr sectors (80026 MB) Sep 21 15:29:23 gnu kernel: SCSI device sdb: drive cache: write back Sep 21 15:29:23 gnu kernel: sdb: sdb1 sdb2 sdb3 sdb4 < sdb5 sdb6 sdb7 > Sep 21 15:29:23 gnu kernel: Attached scsi disk sdb at scsi1, channel 0, id 0, lun 0 Sep 21 15:29:23 gnu kernel: Vendor: ATA Model: ST3120026AS Rev: 3.05 Sep 21 15:29:23 gnu kernel: Type: Direct-Access ANSI SCSI revision: 05 Sep 21 15:29:23 gnu kernel: SCSI device sdc: 234441648 512-byte hdwr sectors (120034 MB) Sep 21 15:29:23 gnu kernel: SCSI device sdc: drive cache: write back Sep 21 15:29:23 gnu kernel: SCSI device sdc: 234441648 512-byte hdwr sectors (120034 MB) Sep 21 15:29:23 gnu kernel: SCSI device sdc: drive cache: write back Sep 21 15:29:23 gnu kernel: sdc: sdc1 sdc2 Sep 21 15:29:23 gnu kernel: sdc1: <bsd: > Sep 21 15:29:23 gnu kernel: Attached scsi disk sdc at scsi2, channel 0, id 0, lun 0 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APSI] enabled at IRQ 23 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt 0000:00:07.0[A] -> Link [APSI] -> GSI 23 (level, low) -> IRQ 225 Sep 21 15:29:23 gnu kernel: ata5: SATA max UDMA/133 cmd 0x9F0 ctl 0xBF2 bmdma 0xCC00 irq 225 Sep 21 15:29:23 gnu kernel: ata6: SATA max UDMA/133 cmd 0x970 ctl 0xB72 bmdma 0xCC08 irq 225 Sep 21 15:29:23 gnu kernel: ata5: no device found (phy stat 00000000) Sep 21 15:29:23 gnu kernel: scsi4 : sata_nv Sep 21 15:29:23 gnu kernel: ata6: no device found (phy stat 00000000) Sep 21 15:29:23 gnu kernel: scsi5 : sata_nv Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APSJ] enabled at IRQ 22 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt 0000:00:08.0[A] -> Link [APSJ] -> GSI 22 (level, low) -> IRQ 233 Sep 21 15:29:23 gnu kernel: ata7: SATA max UDMA/133 cmd 0x9E0 ctl 0xBE2 bmdma 0xE000 irq 233 Sep 21 15:29:23 gnu kernel: ata8: SATA max UDMA/133 cmd 0x960 ctl 0xB62 bmdma 0xE008 irq 233 Sep 21 15:29:23 gnu kernel: ata7: no device found (phy stat 00000000) Sep 21 15:29:23 gnu kernel: scsi6 : sata_nv Sep 21 15:29:23 gnu kernel: ata8: no device found (phy stat 00000000) Sep 21 15:29:23 gnu kernel: scsi7 : sata_nv Sep 21 15:29:23 gnu kernel: EXT3-fs: INFO: recovery required on readonly filesystem. Sep 21 15:29:23 gnu kernel: EXT3-fs: write access will be enabled during recovery. Sep 21 15:29:23 gnu kernel: kjournald starting. Commit interval 5 seconds Sep 21 15:29:23 gnu kernel: EXT3-fs: recovery complete. Sep 21 15:29:23 gnu kernel: EXT3-fs: mounted filesystem with ordered data mode. Sep 21 15:29:23 gnu kernel: security: 3 users, 6 roles, 764 types, 87 bools Sep 21 15:29:23 gnu kernel: security: 55 classes, 180131 rules Sep 21 15:29:23 gnu kernel: SELinux: Completing initialization. Sep 21 15:29:23 gnu kernel: SELinux: Setting up existing superblocks. Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev sdb1, type ext3), uses xattr Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev mqueue, type mqueue), not configured for labeling Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev hugetlbfs, type hugetlbfs), not configured for labeling Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev devpts, type devpts), uses transition SIDs Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev eventpollfs, type eventpollfs), uses genfs_contexts Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev futexfs, type futexfs), uses genfs_contexts Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev pipefs, type pipefs), uses task SIDs Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev sockfs, type sockfs), uses task SIDs Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev proc, type proc), uses genfs_contexts Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev bdev, type bdev), uses genfs_contexts Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts Sep 21 15:29:23 gnu kernel: SELinux: initialized (dev usbfs, type usbfs), uses genfs_contexts Sep 21 15:29:23 gnu kernel: Floppy drive(s): fd0 is 1.44M Sep 21 15:29:23 gnu kernel: FDC 0 is a post-1991 82077 Sep 21 15:29:23 gnu kernel: 8139too Fast Ethernet driver 0.9.27 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APC1] enabled at IRQ 16 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt 0000:01:08.0[A] -> Link [APC1] -> GSI 16 (level, low) -> IRQ 50 Sep 21 15:29:23 gnu kernel: eth0: RealTek RTL8139 at 0x8400, 00:40:f4:73:f0:bc, IRQ 50 Sep 21 15:29:23 gnu kernel: forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.32. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APCH] enabled at IRQ 21 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt 0000:00:0a.0[A] -> Link [APCH] -> GSI 21 (level, low) -> IRQ 58 Sep 21 15:29:23 gnu kernel: eth1: forcedeth.c: subsystem: 01458:e000 bound to 0000:00:0a.0 Sep 21 15:29:23 gnu kernel: snd: no version for "struct_module" found: kernel tainted. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APC4] enabled at IRQ 19 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt 0000:01:07.0[A] -> Link [APC4] -> GSI 19 (level, low) -> IRQ 66 Sep 21 15:29:23 gnu kernel: ALSA /var/tmp/bach-build/BUILD/alsa-driver-1.0.9b/pci/ac97/../../alsa-kernel/pci/ac97/ac97_codec.c:1892: AC'97 0 does not respond - RESET Sep 21 15:29:23 gnu kernel: ALSA /var/tmp/bach-build/BUILD/alsa-driver-1.0.9b/pci/ac97/../../alsa-kernel/pci/ac97/ac97_codec.c:1901: AC'97 0 access is not valid [0x0], removing mixer. Sep 21 15:29:23 gnu kernel: EMU10K1_Audigy: probe of 0000:01:07.0 failed with error -5 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APCJ] enabled at IRQ 20 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt 0000:00:04.0[A] -> Link [APCJ] -> GSI 20 (level, low) -> IRQ 74 Sep 21 15:29:23 gnu kernel: intel8x0_measure_ac97_clock: measured 49359 usecs Sep 21 15:29:23 gnu kernel: intel8x0: clocking to 46761 Sep 21 15:29:23 gnu kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4 Sep 21 15:29:23 gnu kernel: i2c_adapter i2c-0: nForce2 SMBus adapter at 0x1c00 Sep 21 15:29:23 gnu kernel: i2c_adapter i2c-1: nForce2 SMBus adapter at 0x1c40 Sep 21 15:29:23 gnu kernel: nvidia: module license 'NVIDIA' taints kernel. Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APC3] enabled at IRQ 18 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt 0000:05:00.0[A] -> Link [APC3] -> GSI 18 (level, low) -> IRQ 82 Sep 21 15:29:23 gnu kernel: NVRM: loading NVIDIA Linux x86_64 NVIDIA Kernel Module 1.0-7676 Fri Jul 29 13:15:16 PDT 2005 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APCL] enabled at IRQ 23 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [APCL] -> GSI 23 (level, low) -> IRQ 225 Sep 21 15:29:23 gnu kernel: ehci_hcd 0000:00:02.1: EHCI Host Controller Sep 21 15:29:23 gnu kernel: ehci_hcd 0000:00:02.1: debug port 1 Sep 21 15:29:23 gnu kernel: ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 1 Sep 21 15:29:23 gnu kernel: ehci_hcd 0000:00:02.1: irq 225, io mem 0xfeb00000 Sep 21 15:29:23 gnu kernel: ehci_hcd 0000:00:02.1: USB 2.0 initialized, EHCI 1.00, driver 10 Dec 2004 Sep 21 15:29:23 gnu kernel: hub 1-0:1.0: USB hub found Sep 21 15:29:23 gnu kernel: hub 1-0:1.0: 10 ports detected Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt Link [APCF] enabled at IRQ 22 Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [APCF] -> GSI 22 (level, low) -> IRQ 233 Sep 21 15:29:23 gnu kernel: ohci_hcd 0000:00:02.0: OHCI Host Controller Sep 21 15:29:23 gnu kernel: ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2 Sep 21 15:29:23 gnu kernel: ohci_hcd 0000:00:02.0: irq 233, io mem 0xf4001000 Sep 21 15:29:23 gnu kernel: hub 2-0:1.0: USB hub found Sep 21 15:29:23 gnu kernel: hub 2-0:1.0: 10 ports detected Sep 21 15:29:23 gnu kernel: ohci1394: $Rev: 1250 $ Ben Collins <[email protected]> Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt 0000:01:07.2[B] -> Link [APC1] -> GSI 16 (level, low) -> IRQ 50 Sep 21 15:29:23 gnu kernel: ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[50] MMIO=[f1009000-f10097ff] Max Packet=[2048] Sep 21 15:29:23 gnu kernel: ACPI: PCI Interrupt 0000:01:0a.0[A] -> Link [APC3] -> GSI 18 (level, low) -> IRQ 82 Sep 21 15:29:23 gnu kernel: ohci1394: fw-host1: OHCI-1394 1.1 (PCI): IRQ=[82] MMIO=[f100a000-f100a7ff] Max Packet=[4096] Sep 21 15:29:24 gnu kernel: usb 2-8: new low speed USB device using ohci_hcd and address 2 Sep 21 15:29:24 gnu kernel: input: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:02.0-8 Sep 21 15:29:24 gnu kernel: ACPI: Power Button (FF) [PWRF] Sep 21 15:29:24 gnu kernel: ibm_acpi: ec object not found Sep 21 15:29:24 gnu kernel: md: Autodetecting RAID arrays. Sep 21 15:29:24 gnu kernel: md: autorun ... Sep 21 15:29:24 gnu kernel: md: ... autorun DONE. Sep 21 15:29:24 gnu kernel: device-mapper: 4.4.0-ioctl (2005-01-12) initialised: [email protected] Sep 21 15:29:24 gnu kernel: EXT3 FS on sdb1, internal journal Sep 21 15:29:24 gnu kernel: SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs Sep 21 15:29:24 gnu kernel: kjournald starting. Commit interval 5 seconds Sep 21 15:29:24 gnu kernel: EXT3 FS on sdb5, internal journal Sep 21 15:29:24 gnu kernel: EXT3-fs: mounted filesystem with ordered data mode. Sep 21 15:29:24 gnu kernel: SELinux: initialized (dev sdb5, type ext3), uses xattr Sep 21 15:29:24 gnu kernel: kjournald starting. Commit interval 5 seconds Sep 21 15:29:24 gnu kernel: EXT3 FS on sdb3, internal journal Sep 21 15:29:24 gnu kernel: EXT3-fs: mounted filesystem with ordered data mode. Sep 21 15:29:24 gnu kernel: SELinux: initialized (dev sdb3, type ext3), uses xattr Sep 21 15:29:24 gnu kernel: kjournald starting. Commit interval 5 seconds Sep 21 15:29:24 gnu kernel: EXT3 FS on sdb6, internal journal Sep 21 15:29:24 gnu kernel: EXT3-fs: mounted filesystem with ordered data mode. Sep 21 15:29:24 gnu kernel: SELinux: initialized (dev sdb6, type ext3), uses xattr Sep 21 15:29:24 gnu kernel: SELinux: initialized (dev ramfs, type ramfs), uses genfs_contexts Sep 21 15:29:24 gnu kernel: NET: Registered protocol family 10 Sep 21 15:29:24 gnu kernel: Disabled Privacy Extensions on device ffffffff804b7100(lo) Sep 21 15:29:24 gnu kernel: IPv6 over IPv4 tunneling driver Sep 21 15:29:24 gnu kernel: SELinux: initialized (dev binfmt_misc, type binfmt_misc), uses genfs_contexts Sep 21 15:29:24 gnu kernel: ip_tables: (C) 2000-2002 Netfilter core team Sep 21 15:29:24 gnu kernel: ip_conntrack version 2.1 (4095 buckets, 32760 max) - 384 bytes per conntrack Sep 21 15:29:24 gnu kernel: SELinux: initialized (dev autofs, type autofs), uses genfs_contexts Sep 21 15:29:24 gnu kernel: SELinux: initialized (dev autofs, type autofs), uses genfs_contexts Sep 21 15:29:26 gnu kernel: parport: PnPBIOS parport detected. Sep 21 15:29:26 gnu kernel: parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE] Sep 21 15:29:26 gnu kernel: lp0: using parport0 (interrupt-driven). Sep 21 15:29:26 gnu kernel: lp0: console ready Sep 21 15:29:27 gnu amd[2494]: switched to logfile "syslog" Sep 21 15:29:27 gnu amd[2494]: AM-UTILS VERSION INFORMATION: Sep 21 15:29:27 gnu amd[2494]: Copyright (c) 1997-2003 Erez Zadok Sep 21 15:29:27 gnu amd[2494]: Copyright (c) 1990 Jan-Simon Pendry Sep 21 15:29:27 gnu amd[2494]: Copyright (c) 1990 Imperial College of Science, Technology & Medicine Sep 21 15:29:27 gnu amd[2494]: Copyright (c) 1990 The Regents of the University of California. Sep 21 15:29:27 gnu amd[2494]: am-utils version 6.0.9 (build 1). Sep 21 15:29:27 gnu amd[2494]: Built by [email protected] on date Thu Mar 24 04:08:24 EST 2005. Sep 21 15:29:27 gnu amd[2494]: cpu=x86_64 (little-endian), arch=x86_64, karch=x86_64. Sep 21 15:29:27 gnu amd[2494]: full_os=linux, os=linux, osver=2.4.21-27.EL, vendor=redhat. Sep 21 15:29:27 gnu amd[2494]: Map support for: root, passwd, hesiod, ldap, union, nisplus, nis, ndbm, file, error. Sep 21 15:29:27 gnu amd[2494]: AMFS: nfs, link, nfsx, nfsl, host, linkx, program, union, inherit, ufs, Sep 21 15:29:27 gnu amd[2494]: lofs, cdfs, pcfs, auto, direct, toplvl, error. Sep 21 15:29:27 gnu amd[2494]: FS: iso9660, lofs, nfs, nfs3, vfat, tmpfs, ext2. Sep 21 15:29:27 gnu amd[2494]: Network: wire="192.168.1.0" (netnumber=192.168.1). Sep 21 15:29:27 gnu amd[2494]: My ip addr is 192.168.1.7 Sep 21 15:29:27 gnu amd[2495]: released controlling tty using setsid() Sep 21 15:29:27 gnu amd[2495]: file server localhost, type local, state starts up Sep 21 15:29:27 gnu amd[2495]: /dev/sdb1 restarted fstype link on / Sep 21 15:29:27 gnu amd[2495]: /dev/proc restarted fstype link on /proc Sep 21 15:29:27 gnu amd[2495]: /dev/sys restarted fstype link on /sys Sep 21 15:29:27 gnu amd[2495]: /dev/devpts restarted fstype link on /dev/pts Sep 21 15:29:27 gnu amd[2495]: /dev/shm restarted fstype link on /dev/shm Sep 21 15:29:27 gnu amd[2495]: /dev/sdb5 restarted fstype link on /tmp Sep 21 15:29:27 gnu amd[2495]: /dev/sdb3 restarted fstype link on /usr Sep 21 15:29:27 gnu amd[2495]: /dev/sdb6 restarted fstype link on /var Sep 21 15:29:27 gnu amd[2495]: none restarted fstype link on /proc/sys/fs/binfmt_misc Sep 21 15:29:27 gnu amd[2495]: automount(pid2373) restarted fstype link on /net Sep 21 15:29:27 gnu amd[2495]: automount(pid2333) restarted fstype link on /misc Sep 21 15:29:27 gnu amd[2495]: automount(pid2373) referenced fstype link on /net Sep 21 15:29:27 gnu amd[2495]: unable to register (AMQ_PROGRAM=300019, AMQ_VERSION, tcp) Sep 21 15:29:27 gnu amd[2495]: Finishing with status 3 Sep 21 15:29:27 gnu gpm[2503]: *** info [startup.c(95)]: Sep 21 15:29:27 gnu gpm[2503]: Started gpm successfully. Entered daemon mode. Sep 21 15:29:27 gnu gpm[2503]: *** info [mice.c(1766)]: Sep 21 15:29:27 gnu gpm[2503]: imps2: Auto-detected intellimouse PS/2 Sep 21 15:29:30 gnu kernel: hald-probe-smbi[2589] trap stack segment rip:4010d0 rsp:7fffffd4f630 error:0 Sep 21 15:29:30 gnu fstab-sync[2591]: removed all generated mount points Sep 21 15:29:31 gnu fstab-sync[2599]: added mount point /media/floppy for /dev/fd0 Sep 21 15:29:32 gnu fstab-sync[2623]: added mount point /media/cdrecorder for /dev/hdd Sep 21 15:29:32 gnu fstab-sync[2627]: added mount point /media/cdrom for /dev/hdc Sep 21 15:29:44 gnu gdm(pam_unix)[2863]: session opened for user subwoofer by (uid=0) Sep 21 15:29:45 gnu gconfd (subwoofer-2966): uruchamianie (wersja 2.10.0), pid 2966, użytkownik "subwoofer" Sep 21 15:29:45 gnu gconfd (subwoofer-2966): Uzyskano adres "xml:readonly:/etc/gconf/gconf.xml.mandatory" do źródła konfiguracji tylko do odczytu na pozycji 0 Sep 21 15:29:45 gnu gconfd (subwoofer-2966): Uzyskano adres "xml:readwrite:/home/subwoofer/.gconf" do zapisywalnego źródła konfiguracji na pozycji 1 Sep 21 15:29:45 gnu gconfd (subwoofer-2966): Uzyskano adres "xml:readonly:/etc/gconf/gconf.xml.defaults" do źródła konfiguracji tylko do odczytu na pozycji 2Sep 21 15:29:50 gnu gconfd (subwoofer-2966): Uzyskano adres "xml:readwrite:/home/subwoofer/.gconf" do zapisywalnego źródła konfiguracji na pozycji 0 Sep 21 15:30:01 gnu crond(pam_unix)[3069]: session opened for user root by (uid=0) Sep 21 15:30:02 gnu crond(pam_unix)[3069]: session closed for user root Sep 21 15:30:10 gnu su(pam_unix)[3096]: session opened for user root by (uid=500) Mial ktos takie zwisy ? POZDRAWIAM Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
asasyn Napisano Wrzesień 21, 2005 Zgłoszenie Share Napisano Wrzesień 21, 2005 Ja bym postawił na brak pamięci oraz ilość uruchomionych procesów. Popatrz co mówi top, spróbuj zbędne usługi powyłączać, na forum jest art o tym.Ile masz swapu???, czy swap jest aktywny???. Następnym razem odpal top i na bieżąco obserwuj wskazania. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ky7en Napisano Wrzesień 21, 2005 Autor Zgłoszenie Share Napisano Wrzesień 21, 2005 Dobry Wieczor Dziekuje za odpowiedz, sluszna uwaga, tez sadze ze to moze byc brak pamieci, poniweaz przewaznie jak obserwuje procesy w top to z 1GB ramu, zostaje z 200mb albo i mniej ;/ Swap byl wlaczony. Nastepnym razem zapuszcze top, tak ja mowisz :-) Pozdrawiam && thx Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
asasyn Napisano Wrzesień 21, 2005 Zgłoszenie Share Napisano Wrzesień 21, 2005 Poczytaj sobie man top Szybciej to wszystko ogarniesz Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Wrzesień 26, 2005 Zgłoszenie Share Napisano Wrzesień 26, 2005 szkoda ze BSD na desktop nie jest tak rozwiniete jak liny, pewnie by stabliniej chodzilo... A czy pod *BSD używasz zamkniętych, binarnych, źle napisanych sterowników? Sep 21 15:29:23 gnu kernel: nvidia: module license 'NVIDIA' taints kernel. [ciach] Sep 21 15:29:23 gnu kernel: NVRM: loading NVIDIA Linux x86_64 NVIDIA Kernel Module 1.0-7676 Fri Jul 29 13:15:16 PDT 2005 Wywal tego śmiecia. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
