Speed Touch 330 I System-config-network
mysio
Po instalcji modemu Speed Touch 330 tym sposobem http://forum.fedora.pl/index.php?showtopic=6830 w wywala mi taki błąd.
Component: system-config-network
Version: 1.3.26
Summary: TB40cc7661 ConfPAP.py:86:initvars:IndexError: list index out of range
  File "/usr/sbin/system-config-network-gui", line 166, in main
    window = mainDialog()
  File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/gui/maindialog.py", line 262, in __init__
  File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/gui/maindialog.py", line 294, in load
  File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/gui/maindialog.py", line 302, in loadDevices
  File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/NCDeviceList.py", line 294, in getDeviceList
  File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/NCDeviceList.py", line 80, in load
  File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/plugins/NCDevADSL.py", line 35, in load
  File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/NCDialup.py", line 199, in load
  File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/NCDialup.py", line 127, in load
  File "/usr/src/build/556832-noarch/install/usr/share/system-config-network/netconfpkg/NC_functions.py", line 297, in getPAPConf
  File "/usr/lib64/python2.4/site-packages/rhpl/ConfPAP.py", line 33, in __init__
    Conf.Conf.__init__(self, filename, '#', ' \t', ' \t')
  File "/usr/lib64/python2.4/site-packages/rhpl/Conf.py", line 181, in __init__
    self.read()
  File "/usr/lib64/python2.4/site-packages/rhpl/ConfPAP.py", line 38, in read
    self.initvars()
  File "/usr/lib64/python2.4/site-packages/rhpl/ConfPAP.py", line 86, in initvars
    self.vars[var[0]][var[1]] = var[2]
Local variables in innermost frame:
var: ['PEERDNS=yes']
self: <rhpl.ConfPAP.ConfPAP instance at 0x2aaab0167560>
Wiem ze to jest po insytalcji modemu bo przed instalacją (_niema_ → nie ma) ORT takiego błędu.
Jeżeli jest to dla Ciebie dośc istotne to:
zrezygnuj z definiowania zmiennej PEERDNS w pliku /etc/sysconfig/network-scripts/ifcfg-ppp0.
W takiej sytuacji możesz "statycznie" dokonać wpisy w pliku /etc/resolv.conf. W przypadku NEO:
nameserver 194.204.152.34
nameserver 217.98.63.164
Jeżeli np. używasz serwera proxy (SQUID) lepszym rozwiązaniem jest dodanie serwerów proxy w pliku konfiguracyjnym: /etc/squid/squid.conf.
Pozdrawiam.
Wg mnie komunikat powinien się różnić przynajmniej o linie:
Będąc na Twoim miejscu nie upatrywałbym problemu w konfiguracji speedtouch-a.
Prosty test - polegający na chwilowym backupie i usuninięciu pliku:
równoznaczny będzie z usunięciem konfiguracji interfejsu ppp z FC4 (a tym samym z system-config-network)
powinien spowodować prawidłowe uruchomienie: system-config-network (WG mnie NIE).
Pozdrawiam.
