Wolfenstein Et
m4d3j
Siema nie działa mi wolfenstein et, sciągnałem go specjalnie pod fedore , steroniki chyba mam ok bo tez sciagalem nowe lecz gdy wpisuje pod terminalem et otrzymuje takie coś :
ET 2.60 linux-i386 Mar 10 2005
----- FS_Startup -----
Current search path:
/home/madej/.etwolf/etmain/lemapcycle.pk3 (2 files)
/usr/local/games/enemy-territory/etmain/pak2.pk3 (22 files)
/usr/local/games/enemy-territory/etmain/pak1.pk3 (10 files)
/usr/local/games/enemy-territory/etmain/pak0.pk3 (3725 files)
/usr/local/games/enemy-territory/etmain/mp_bin.pk3 (6 files)
3765 files in pk3 files
^3WARNING: profile.pid found for profile 'm4d3j' - system settings will revert to defaults
execing default.cfg
couldn't exec language.cfg
execing profiles/m4d3j/etconfig.cfg
r_smp is unsafe. Check com_crashed.
r_mode is unsafe. Check com_crashed.
r_depthbits is unsafe. Check com_crashed.
r_stencilbits is unsafe. Check com_crashed.
r_stereo is unsafe. Check com_crashed.
r_colorbits is unsafe. Check com_crashed.
r_texturebits is unsafe. Check com_crashed.
r_clampToEdge is unsafe. Check com_crashed.
r_ext_texture_env_add is unsafe. Check com_crashed.
r_nv_fogdist_mode is unsafe. Check com_crashed.
r_ext_NV_fog_dist is unsafe. Check com_crashed.
r_ext_texture_filter_anisotropic is unsafe. Check com_crashed.
r_ati_fsaa_samples is unsafe. Check com_crashed.
r_ati_truform_pointmode is unsafe. Check com_crashed.
r_ati_truform_normalmode is unsafe. Check com_crashed.
r_ati_truform_tess is unsafe. Check com_crashed.
r_ext_ATI_pntriangles is unsafe. Check com_crashed.
r_glIgnoreWicked3D is unsafe. Check com_crashed.
r_ext_compiled_vertex_array is unsafe. Check com_crashed.
r_ext_multitexture is unsafe. Check com_crashed.
r_ext_gamma_control is unsafe. Check com_crashed.
r_ext_compressed_textures is unsafe. Check com_crashed.
r_allowExtensions is unsafe. Check com_crashed.
r_glDriver is unsafe. Check com_crashed.
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
------- Input Initialization -------
Joystick is not active.
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
...loading libGL.so.1: Initializing OpenGL display
...setting mode 4: 800 600
Using XFree86-VidModeExtension Version 2.2
XF86DGA Mouse (Version 2.0) initialized
XFree86-VidModeExtension Activated at 800x600
Using 8/8/8 Color bits, 24 depth, 0 stencil display.
GL_RENDERER: Mesa GLX Indirect
You are using software Mesa (no hardware acceleration)!
Driver DLL used: libGL.so.1
If this is intentional, add
      "+set r_allowSoftwareGL 1"
to the command line when starting the game.
...WARNING: could not set the given mode (4)
...setting mode 3: 640 480
XFree86-VidModeExtension Activated at 640x480
Received signal 11, exiting...
Moze jakies porady ?
Na moj gust to masz 2 wyjscia:
1. dodac "+set r_allowSoftwareGL 1" jako parametr do polecenia uruchamiajacego gre i 'cieszyc oko' programowa akceleracja
lub
2. zrobic porzadek ze sterownikami, bo mimo ze je (ponoc) masz zainstalowane, to najwyrazniej nie tak jak trzeba - brak sprzetowej akceleracji...
Jak sprawdzic czy dziala sprzetowa akceleracja czyli czy stery sa zainstalowane poprawnie - bylo na forum co najmniej 3 razy w ciagu ostatnich kilku dni.
Powodzenia zycze
Nie wiem co masz źle z partycjami, ale na twoim miejscu z ET walczył bym do końca. Pamiętaj to nie windows, że jak coś nie działa to da się tylko to "naprawić" reinstalką. Poszukaj, poszperaj nauczysz się czegoś i w przyszłości sam będziesz rozwiązywał takie problemy.
Mogę ci tylko powiedzieć, że jak nie miałem sterowników to wyskakiwał ten sam błąd w ET. smile.gif Pozdro.
  • 3 weeks later...
Ja mam to samo sterowniki ATI instalowalem wszedzie pisalo completed bez zadnych bledow
odpalam zwykla komende ET i jest w konsoli to samo co kolega u gory
jak dodam do ET +set r_allowSoftwareGL 1
et sie odpali ale dziala jak krew z nosa
[root@localhost ET]# et +set r_allowSoftwareGL 1
/root/.etwolf/etmain
3763 files in pk3 files
execing default.cfg
Bypassing CD checks
----- R_Init -----
Using 8/8/8 Color bits, 16 depth, 0 stencil display.
Xlib: extension "XFree86-DRI" missing on display ":0.0".
...using software Mesa (r_allowSoftwareGL==1).
Initializing OpenGL extensions
...GL_S3_s3tc not found
...ignoring GL_EXT_texture_env_add
...using GL_ARB_multitexture
...GL_EXT_compiled_vertex_array not found
...GL_NV_fog_distance not found
... GL_EXT_texture_filter_anisotropic not found
Initializing GLX extensions
... GLX_SGI_swap_control not found
... GLX_SGI_video_sync not found
XF86 Gamma extension initialized
GL_VENDOR: Mesa project: www.mesa3d.org
GL_VERSION: 1.2 (1.5 Mesa 6.2.1)
GL_EXTENSIONS: GL_ARB_imaging GL_ARB_multitexture GL_ARB_texture_border_clamp GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_transpose_matrix GL_EXT_abgr GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_lod_bias
GLX_EXTENSIONS: GLX_EXT_visual_info GLX_EXT_visual_rating GLX_EXT_import_context GLX_ARB_multisample
GL_MAX_TEXTURE_SIZE: 2048
GL_MAX_ACTIVE_TEXTURES_ARB: 8
PIXELFORMAT: color(24-bits) Z(16-bit) stencil(0-bits)
MODE: 4, 800 x 600 fullscreen hz:N/A
GAMMA: hardware w/ 0 overbright bits
CPU:
rendering primitives: multiple glArrayElement
texturemode: GL_LINEAR_MIPMAP_NEAREST
picmip: 1
texture bits: 0
multitexture: enabled
compiled vertex arrays: disabled
texenv add: disabled
compressed textures: disabled
anisotropy: 1.0
NV distance fog: disabled
Initializing Shaders
----- finished R_Init -----
------- sound initialization -------
----- Sound Info -----
sound system is muted
1 stereo
32768 samples
16 samplebits
1 submission_chunk
22050 speed
0x0xb7f93000 dma buffer
No background file.
Sound memory manager started
Sys_LoadDll(/root/.etwolf/etmain/ui.mp.i386.so)...
Sys_LoadDll(/root/.etwolf/etmain/ui.mp.i386.so) failed:
"/root/.etwolf/etmain/ui.mp.i386.so: cannot open shared object file: No such file or directory"
Sys_LoadDll(/usr/local/games/enemy-territory/etmain/ui.mp.i386.so)... ok
Sys_LoadDll(ui) found **vmMain** at 0x3c9af40
Sys_LoadDll(ui) succeeded!
Found high quality video and fast CPU
--- Common Initialization Complete ---
Opening IP socket: localhost:27960
Hostname: localhost.localdomain
Alias: localhost
IP: 127.0.0.1
Started tty console (use +set ttycon 0 to disable)
execing preset_high.cfg
r_colorbits will be changed upon restarting.
r_depthbits will be changed upon restarting.
r_picmip will be changed upon restarting.
r_mode will be changed upon restarting.
r_texturebits will be changed upon restarting.
RE_Shutdown( 1 )
----- R_Init -----
...setting mode 6: 1024 768
XFree86-VidModeExtension Activated at 1024x768
Using 4/4/4 Color bits, 16 depth, 0 stencil display.
PIXELFORMAT: color(32-bits) Z(16-bit) stencil(0-bits)
MODE: 6, 1024 x 768 fullscreen hz:N/A
CPU:
texturemode: GL_LINEAR_MIPMAP_LINEAR
picmip: 0
texture bits: 32
anisotropy: 1.0
Resolving etmaster.idsoftware.com
etmaster.idsoftware.com resolved to 192.246.40.60:27951
execing preset_normal_ui.cfg
execing preset_high_ui.cfg
----- CL_Shutdown -----
RE_Shutdown( 1 )
Shutdown tty console
No toz przeciez u Ciebie tez widac jak byk ze nie masz sprzetowej akceleracji...
Po raz kolejny - zle zainstalowane sterowniki / brak sprzetowej akceleracji.
Poszukaj, na forum jest kilka opisow, niektore rozwiazania nawet dzialaja ;-)
Powodzenia
