dradol Napisano Luty 17, 2006 Zgłoszenie Share Napisano Luty 17, 2006 Niby jest wszystko zainstalowane jak potrezba jednak brak jest 3D może to wina chipsetu gdyż mam płytę główna na SIS-ie.Bardzo proszę o jakieś sugestje. Zawartość pliku xorg.conf Xorg configuration created by system-config-display Section "ServerLayout" Identifier "single head configuration" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" # RgbPath is the location of the RGB database. Note, this is the name of the # file minus the extension (like ".txt" or ".db"). There is normally # no need to change the default. # Multiple FontPath entries are allowed (they are concatenated together) # By default, Red Hat 6.0 and later now use a font server independent of # the X server to render fonts. RgbPath "/usr/X11R6/lib/X11/rgb" FontPath "unix/:7100" EndSection Section "Module" Load "dbe" Load "extmod" Load "fbdevhw" Load "glx" Load "record" Load "freetype" Load "type1" Load "dri" EndSection Section "InputDevice" # Specify which keyboard LEDs can be user-controlled (eg, with xset(1)) # Option "Xleds" "1 2 3" # To disable the XKEYBOARD extension, uncomment XkbDisable. # Option "XkbDisable" # To customise the XKB settings to suit your keyboard, modify the # lines below (which are the defaults). For example, for a non-U.S. # keyboard, you will probably want to use: # Option "XkbModel" "pc102" # If you have a US Microsoft Natural keyboard, you can use: # Option "XkbModel" "microsoft" # # Then to change the language, change the Layout setting. # For example, a german layout can be obtained with: # Option "XkbLayout" "de" # or: # Option "XkbLayout" "de" # Option "XkbVariant" "nodeadkeys" # # If you'd like to switch the positions of your capslock and # control keys, use: # Option "XkbOptions" "ctrl:swapcaps" # Or if you just want both to be control, use: # Option "XkbOptions" "ctrl:nocaps" # Identifier "Keyboard0" Driver "kbd" Option "XkbModel" "pc105" Option "XkbLayout" "pl" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "IMPS/2" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "yes" EndSection Section "Monitor" Identifier "Monitor0" VendorName "Monitor Vendor" ModelName "Unknown monitor" DisplaySize 310 230 HorizSync 30.0 - 70.0 VertRefresh 50.0 - 135.0 Option "dpms" EndSection Section "Device" Identifier "Videocard0" Driver "fglrx" Option "UseInternalAGPGART" "no" VendorName "Videocard vendor" BoardName "ATI Radeon 9500" Option "VideoOverlay" "on" EndSection Section "Screen" Identifier "Screen0" Device "Videocard0" Monitor "Monitor0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 16 Modes "800x600" "640x480" EndSubSection SubSection "Display" Viewport 0 0 Depth 24 Modes "1024x768" "800x600" "640x480" EndSubSection EndSection Section "DRI" Group 0 Mode 0666 EndSection ************************************************************************************************************************* lsmod : Module Size Used by parport_pc 28933 1 lp 13001 0 parport 40585 2 parport_pc,lp autofs4 29253 2 rfcomm 42333 0 l2cap 30661 5 rfcomm bluetooth 56133 4 rfcomm,l2cap sunrpc 167813 1 ipt_REJECT 5569 1 ipt_state 1857 1 ip_conntrack 41497 1 ipt_state iptable_filter 2881 1 ip_tables 19521 3 ipt_REJECT,ipt_state,iptable_filter dm_mod 58101 0 video 15941 0 button 6609 0 battery 9413 0 ac 4805 0 fglrx 444256 0 md5 4033 1 ipv6 268097 10 ohci_hcd 26849 0 ehci_hcd 41037 0 shpchp 94405 0 i2c_sis96x 5445 0 i2c_core 21569 1 i2c_sis96x snd_intel8x0 34689 1 snd_ac97_codec 75961 1 snd_intel8x0 snd_seq_dummy 3653 0 snd_seq_oss 37057 0 snd_seq_midi_event 9153 1 snd_seq_oss snd_seq 62289 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi_event snd_seq_device 8781 3 snd_seq_dummy,snd_seq_oss,snd_seq snd_pcm_oss 51185 0 snd_mixer_oss 17857 1 snd_pcm_oss snd_pcm 100169 3 snd_intel8x0,snd_ac97_codec,snd_pcm_oss snd_timer 33605 2 snd_seq,snd_pcm snd 57157 11 snd_intel8x0,snd_ac97_codec,snd_seq_oss,snd_seq,snd_seq_device,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer soundcore 10913 1 snd snd_page_alloc 9669 2 snd_intel8x0,snd_pcm ndiswrapper 171724 0 sis900 21697 0 floppy 65269 0 ext3 132553 1 jbd 86233 1 ext3 czy da sie coś z tym zrobić? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
wklaczynski Napisano Luty 18, 2006 Zgłoszenie Share Napisano Luty 18, 2006 U mnie także był problem, mimo zainstalowania sterów nadal była mesa, ale już nie pamiętam kolejności, chyba te z livny mają problem, bo pomogło odpalenie instalatora proponowanego przez producenta www.ati.com. Grzebanie w xorg.con na wiele się nie zdaje, jedena z bibliotek OpenGL źle wchodzi w system. Ściągnij stery z ati, zmień nazwę z bin na run i daj uprawnienia do uruchamiania, uruchom go na uprawnieniach root. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dradol Napisano Luty 20, 2006 Autor Zgłoszenie Share Napisano Luty 20, 2006 Niestety nie pomaga.Brak jest modułu agpgart i chyba dlatego własnie (_niedziała_ → nie działa) ORT.Płyta główna to asrock na chipsecie sisa.Widzę ze tu chyba jest problem.Pozostaje chyba tylko zmiana płyty głównej a to zawsze wydatek. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Other Napisano Luty 20, 2006 Zgłoszenie Share Napisano Luty 20, 2006 A ja widzę inny problem. Pewnie masz stare jądro i nowe sterowniki nie działają Ci ze starym jądrem =] Zresztą nawet na Livna nie ma modułów do starych kerneli do najnowszych sterowników =] Radzę zaktualizować system i jeszcze raz wgrać sterowniki Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dradol Napisano Luty 20, 2006 Autor Zgłoszenie Share Napisano Luty 20, 2006 Także tak myslałem wiec zaktualizowałem jądro do 2.6.15 ale niestety problem pozostał..... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
