Kocurkiewicz Napisano Marzec 3, 2006 Zgłoszenie Share Napisano Marzec 3, 2006 Witam! Skompilowalem superkarambe 0.37. Po uruchomieniu i probie zaladowania pliku "lwp-10.1.skz" wszystko konczy sie pieknym bledem wygladajacym nastepujaco: KCrash: (no debugging symbols found) Using host libthread_db library "/lib/libthread_db.so.1". (no debugging symbols found) `shared object read from target memory' has disappeared; keeping its symbols. (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) [Thread debugging using libthread_db enabled] [New Thread -1209091904 (LWP 17773)] (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) [KCrash handler] #6 0x01549a4e in QGDict::hashKeyString () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #7 0x0154ab0d in QGDict::look_string () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #8 0x004c5bb6 in KArchiveDirectory::entry () from /usr/lib/libkio.so.4 #9 0x004c5c44 in KArchiveDirectory::entry () from /usr/lib/libkio.so.4 #10 0x080a957f in ThemeFile::fileExists () #11 0x080a98ad in ThemeFile::parseXml () #12 0x080aa642 in ThemeFile::set () #13 0x080ad521 in ThemesDlg::openLocalTheme () #14 0x080ab27e in ThemesDlg::qt_invoke () #15 0x0125faf4 in QObject::activate_signal () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #16 0x0125ffaa in QObject::activate_signal () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #17 0x015e006e in QButton::clicked () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #18 0x012ffcd3 in QButton::mouseReleaseEvent () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #19 0x0129db50 in QWidget::event () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #20 0x011fab6d in QApplication::internalNotify () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #21 0x011fba9f in QApplication::notify () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #22 0x00925dad in KApplication::notify () from /usr/lib/libkdecore.so.4 #23 0x011905d1 in QETWidget::translateMouseEvent () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #24 0x0118edd6 in QApplication::x11ProcessEvent () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #25 0x011a34a8 in QEventLoop::processEvents () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #26 0x012131eb in QEventLoop::enterLoop () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #27 0x012130f6 in QEventLoop::exec () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #28 0x011fa539 in QApplication::exec () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #29 0x08076ad7 in main () Z pod konsoli: [kocurkiewicz@kocurkiewicz ~]$ superkaramba Unable to open '/home/kocurkiewicz/Desktop/lwp-10.1.skz' for reading. KCrash: Application 'superkaramba' crashing.. Plik ma chmod 777. Z braku doswiadczenia - prosze o pomoc w rozwiazaniu problemu. Pozdrawiam, Jakub Kramarz PS. Czy moglby ktos wylaczyc skroty klawiatorowe bbcode? Nie da sie pisac polskich krzaczkow, bo sa pod nimi skroty... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
uosiu Napisano Marzec 3, 2006 Zgłoszenie Share Napisano Marzec 3, 2006 su - yum update yum install superkaramba to co kompilowales wywal Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kocurkiewicz Napisano Marzec 3, 2006 Autor Zgłoszenie Share Napisano Marzec 3, 2006 Uosiu - tylko, ze na repo jest tylko wersja .36, przynajmniej na oficialach + kde + linva. [root@kocurkiewicz superkaramba]# yum info superkaramba Setting up repositories kde 100% |=========================| 951 B 00:00 livna 100% |=========================| 951 B 00:00 updates-released 100% |=========================| 951 B 00:00 kde-all 100% |=========================| 951 B 00:00 base 100% |=========================| 1.1 kB 00:00 livna-testing 100% |=========================| 951 B 00:00 extras 100% |=========================| 1.1 kB 00:00 Reading repository metadata in from local files primary.xml.gz 100% |=========================| 235 kB 00:09 livna : ################################################## 868/868 Added 32 new packages, deleted 0 old in 1.10 seconds Available Packages Name : superkaramba Arch : i386 Version: 0.36 Release: 4.fc4 Size : 238 k Repo : extras Summary: Custom content on the desktop Description: SuperKaramba is a KDE add-on that allows for custom content on the desktop. Some examples include the weather, calendars, or whatever you can code in python EDIT: Mam KDE 3.5 z repo redhat-kde Kolejny EDIT: Mam już 0.37 - jest włączony do paczki "kdeutils". Problem pozostaje. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
uosiu Napisano Marzec 3, 2006 Zgłoszenie Share Napisano Marzec 3, 2006 to ty masz cos zrypane bo ja mam 0.38 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kocurkiewicz Napisano Marzec 3, 2006 Autor Zgłoszenie Share Napisano Marzec 3, 2006 Dziękuję za fachową poradę. Z jakiego repozytorium? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
uosiu Napisano Marzec 3, 2006 Zgłoszenie Share Napisano Marzec 3, 2006 zebym ja to teraz wiedzial na pewno zadne testing czy unstable dolaczony do kde-3.5.1 uzywam base, extras, updates-relaesed livna, jpackage, kadu, skype i macromedia Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kocurkiewicz Napisano Marzec 3, 2006 Autor Zgłoszenie Share Napisano Marzec 3, 2006 Ok - zrobiłem update tego kdeutils. Mam SuperKarambę 0.38. Dalej szlag trafia tego LWP, ale używam chwilowo starszej wersji i nie narzekam. Co do błędu - to siedzi on gdzieś głębiej - Amarok przy pierwszych uruchomieniach też krzaczył się tym samym błędem. W każdym razie - temat możn uważać za zamknięty. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
InIrudeBwoy Napisano Marzec 3, 2006 Zgłoszenie Share Napisano Marzec 3, 2006 też mam problemy z LWP, od wersji 8 czy jakoś tak. Jak się sypie to nie używam i czekam na poprawkę z reguły po kilku dniach poprawia sie wersja działająca. Miałem problemy z wersją 10.0 a z 10.1 już nie Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
