dalmatyn Napisano Marzec 22, 2006 Zgłoszenie Share Napisano Marzec 22, 2006 Witam Po wydaniu komendy xsane otrzymuję komunikat: [gt68xx] Couldn't open firmware file (`/usr/share/sane/gt68xx/A1fw.usb'): Nie ma takiego pliku ani katalogu [pinio@intek ~]$ sane-config --libs -lsane -lusb -lpthread -lm -ljpeg -lieee1284 -lgphoto2 -lgphoto2_port -lm -ldl [root@intek ~]# yum install lsane lusb lpthread lm ljpeg lgphoto2 lgphoto2_port lm ldl Setting up Install Process Setting up repositories Reading repository metadata in from local files Parsing package install arguments No Match for argument: lsane No Match for argument: lusb No Match for argument: lpthread No Match for argument: lm No Match for argument: ljpeg No Match for argument: lgphoto2 No Match for argument: lgphoto2_port No Match for argument: lm No Match for argument: ldl Nothing to do [pinio@intek ~]$ sane-find-scanner # sane-find-scanner will now attempt to detect your scanner. If the # result is different from what you expected, first make sure your # scanner is powered up and properly connected to your computer. # No SCSI scanners found. If you expected something different, make sure that # you have loaded a kernel SCSI driver for your SCSI adapter. # Also you need support for SCSI Generic (sg) in your operating system. # If using Linux, try "modprobe sg". found USB scanner (vendor=0x0df7, product=0x0620) at libusb:002:004 found USB scanner (vendor=0x055f, product=0x021e [uSB Scanner], chip=GT-6816) at libusb:002:003 # Your USB scanner was (probably) detected. It may or may not be supported by # SANE. Try scanimage -L and read the backend's manpage. # Not checking for parallel port scanners. # Most Scanners connected to the parallel port or other proprietary ports # can't be detected by this program. # You may want to run this program as root to find all devices. Once you # found the scanner devices, be sure to adjust access permissions as # necessary. Jakieś pomysły? Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
