marcini Napisano Kwiecień 13, 2006 Zgłoszenie Share Napisano Kwiecień 13, 2006 WItam! Mecze sie z VMware Workstation 5.0 pod FC5. Ruszylo to komus? Oto co zrobilem: 1. Uaktualnilem kernel i kernel-source do 2.6.16-1.2080_FC5 2. Zaaplikowalem poprawke vmware-any-any-update101 3. Nawet z braku pomyslow wylaczylem SELinux No i jak odpalam vmware-config.pl to prawie na poczatku kompilacji dostaje blad: What is the location of the directory of C header files that match your running kernel? [/lib/modules/2.6.16-1.2080_FC5/build/include] Extracting the sources of the vmmon module. Building the vmmon module. Building for VMware Workstation 5.0.0. Using 2.6.x kernel build system. make: Entering directory `/tmp/vmware-config2/vmmon-only' make -C /lib/modules/2.6.16-1.2080_FC5/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules make[1]: Entering directory `/usr/src/kernels/2.6.16-1.2080_FC5-i686' CC [M] /tmp/vmware-config2/vmmon-only/linux/driver.o CC [M] /tmp/vmware-config2/vmmon-only/linux/hostif.o CC [M] /tmp/vmware-config2/vmmon-only/common/cpuid.o CC [M] /tmp/vmware-config2/vmmon-only/common/hash.o CC [M] /tmp/vmware-config2/vmmon-only/common/memtrack.o CC [M] /tmp/vmware-config2/vmmon-only/common/phystrack.o CC [M] /tmp/vmware-config2/vmmon-only/common/task.o gcc: error trying to exec 'cc1plus': execvp: Nie ma takiego pliku ani katalogu make[2]: *** [/tmp/vmware-config2/vmmon-only/common/task.o] Błąd 1 make[1]: *** [_module_/tmp/vmware-config2/vmmon-only] Błąd 2 make[1]: Leaving directory `/usr/src/kernels/2.6.16-1.2080_FC5-i686' make: *** [vmmon.ko] Błąd 2 make: Leaving directory `/tmp/vmware-config2/vmmon-only' Unable to build the vmmon module. For more information on how to troubleshoot module-related problems, please visit our Web site at "http://www.vmware.com/download/modules/modules.html" and "http://www.vmware.com/support/reference/linux/prebuilt_modules_linux.html". Execution aborted. Jak moge to uruchomic? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
...>>udzior<<... Napisano Kwiecień 13, 2006 Zgłoszenie Share Napisano Kwiecień 13, 2006 Zainstaluj gcc-c++*.rpm Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Kwiecień 13, 2006 Zgłoszenie Share Napisano Kwiecień 13, 2006 Mecze sie z VMware Workstation 5.0 pod FC5. Ruszylo to komus? Też się męczyłem Zapomnij o 5.0 - musisz zrobić update do 5.5. Update jest darmowy. Nie pamiętam dokładnie co robiłem, ale chyba jeszcze musiałem instalować pakiecik vmware-any-any-update99 Oczywiście to co napisał ...>>udzior<<... też jest aktualne No i źródła odpowiednie do zainstalowanego jajka. [Edit] Ja jak zwykle z opóźnieniem widzę, że any-to-any masz. Pewnie źródła też, więc najlepszą radą pozostaje update do workstation 5.5 Pozdr, W. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
marcini Napisano Kwiecień 14, 2006 Autor Zgłoszenie Share Napisano Kwiecień 14, 2006 Po zainstalowaniu gcc-c++ kompilacja przeszla bezproblemowo. Dzieki Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Kwiecień 15, 2006 Zgłoszenie Share Napisano Kwiecień 15, 2006 Po zainstalowaniu gcc-c++ kompilacja przeszla bezproblemowo. Poszło Ci na VMware 5.0? Na jakim kernelu? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
