Przydatne Skrypty
broda
skrypcik Renegade do oblugi sieci ala automat by koralm:
#!/bin/bash
echo "+---------------------------------+"
echo "| KONFIGURATOR SIECI LINUX FEDORA |"
echo "Jako parametr podaj nazwe karty sieciowej (eth0, eth1, wlan0... itp.)"
echo "------------------------------"
while [ "$1" != "" ]
do
echo ""
echo "OBECNE USTAWIENIA KARTY $1"
echo ""
ifconfig $1
read
read -p "Podaj adres IP dla karty $1: " ip
read -p "Podaj maske dla sieci: " maska
read -p "Podaj brame sieci: " brama
read -p "Podaj podstawowy serwer DNS: " dns1
read -p "Podaj zapasowy serwer DNS: " dns2
ifconfig $1 down
ifconfig $1 $ip netmask $maska
route add default gw $brama
echo "nameserver $dns1" > /etc/resolv.conf
echo "nameserver $dns2" >> /etc/resolv.conf
echo "DEVICE=$1" > /etc/sysconfig/network-scripts/ifcfg-$1
echo "BOOTPROTO=static" >> /etc/sysconfig/network-scripts/ifcfg-$1
echo "ONBOOT=yes" >> /etc/sysconfig/network-scripts/ifcfg-$1
echo "TYPE=Ethernet" >> /etc/sysconfig/network-scripts/ifcfg-$1
echo "USERCTL=no" >> /etc/sysconfig/network-scripts/ifcfg-$1
echo "PEERDNS=yes" >> /etc/sysconfig/network-scripts/ifcfg-$1
echo "IPV6INIT=no" >> /etc/sysconfig/network-scripts/ifcfg-$1
echo "IPADDR=$ip" >> /etc/sysconfig/network-scripts/ifcfg-$1
echo "NETMASK=$maska" >> /etc/sysconfig/network-scripts/ifcfg-$1
echo "GATEWAY=$brama" >> /etc/sysconfig/network-scripts/ifcfg-$1
export mac=`ifconfig $karta |grep -e HWaddr | cut -d"r" -f3`
echo "HWADDR=$mac" >> /etc/sysconfig/network-scripts/ifcfg-$1
ifconfig $1 up
shift
done
skrypt do zamazywania dyskow
#!/bin/bash
KONIEC="\033[0m"
ZIEL="\033[01;32m"
#uzycie ./kasujdysk
if [ $EUID = 0 ]; then
read -p "Podaj nazwe dysku do wymazania: " dysk
echo -e "Dostepne warianty:
1) /dev/zero
2) /dev/urandom"
read -p "Wpisz jeden z plików, ktore beda sluzyc do zamazywania: " metoda
read -p "Ile cykli zamazywania m,a sie odbyc? :" ile
echo -e "+-------------------------------+
Twoje ustawienia to:
dysk $dysk bedzie zamazywany z $metoda w $ile cyklach.
read -p "Czy to sie zgadza? (t/n) :" zgadza
if [ $zgadza = t ]
then  umount $dysk
until [ $ile = 0 ]; do cat $metoda > $dysk
ile=`echo "$ile-1" | bc -l`; done
else echo "Anulowano zamazywanie"
fi
echo -e "$ZIEL zakonczono zamazywanie $KONIEC"
else
echo -e  "$ZIEL nie masz wystarczajacych uprawnien do uruchomienia skryptu. zaloguj sie n konto roota $KONIEC"
fi
skrypt testowalem przez uzycie echo "$metoda > $dysk" a nie cat, wynik byl poprawny :)
jezeli ktos zdecyduje sie go uzyc to poprosze o danie cynku o tym :)
Zamiast `polecenie` powinno stosowac sie $(polecenie) - nie jest odpalany nowy shell, przez co szybciej wykonywana jest komenda. Jeszcze zamiast bc uzylbym expr (uruchamiany jest tylko jeden program, a nie dwa):
[d*pa@X ~]$ ile=34
[d*pa@X ~]$ ile=$(expr $ile - 1)
[d*pa@X ~]$ echo $ile
33
[d*pa@X ~]$
  • 2 weeks later...
Zamiast `polecenie` powinno stosować się $(polecenie) - nie jest odpalany nowy shell, przez co szybciej wykonywana jest komenda. Jeszcze zamiast bc użyłbym expr (uruchamiany jest tylko jeden program, a nie dwa):
[d*pa@X ~]$ ile=34
33
[d*pa@X ~]$
gajownik masz ciekawego prompt'a :)
Dobra wrzuce cos od siebie.
Skrypt do sprawdzania pogody dla swojego miasta w danej chwili. Bardzo fajny jak siedzi sie dlugo pod konsola a nie chce sie wyjzec przez okno ;)
#!/usr/bin/perl
$miejsce = "Warszawa";
$www = "http://weather.yahoo.com/forecast/PLXX0028_c.html";
$tmp = "/tmp/.pogoda_tmp";
system("lynx -accept_all_cookies -dump $www >$tmp");
open(file, $tmp) or die "Pogoda: Could not open file $tmp\n";
$size  = (stat(file))[7]; #calkowity rozmiar pliku
sysread(file, $pom, $size);
close(file);
$pom =~ s/CEST..(.*?)>>/$1/sm;
$pom = ${1};
@tab = split(/\n/, $pom);
$tab[3] =~ s/ *//;
$tab[6] =~ s/ *//;
$tab[9] =~ s/ *//;
$tab[12] =~ s/ *//;
$tab[15] =~ s/ *//;
$tab[18] =~ s/ *//;
$tab[21] =~ s/ *//;
$tab[24] =~ s/ *//;
print "Weather in $miejsce is $tab[0]\n\t$tab[2] $tab[3]\n\t$tab[5] $tab[6]\n\t$tab[8] $tab[9]\n\t$tab[11] $tab[12]\n\t$tab[14] $tab[15]\n\t$tab[17] $tab[18]\n\t$tab[20] $tab[21]\n\t$tab[23] $tab[24]\n";
unlink($tmp);
Wszelkie uwagi co do ulepszenia mile widziane ale perl-only.
ps. dla innego miasta niz Warszawa wstawiamy odpowiedni link do $www pobrany z http://weather.yahoo.com.
a sie kurde pochwale... moj pierwszy skrypt w dla basha :)
nazwalem go "wylacz_za_X_minut"
#!/bin/bash
echo -e "za ile minut ma sie wylaczyc komputer?\n"
read czas
sudo /sbin/shutdown -h +$czas Wylacz za $czas minut&
read
echo komputer sie wylaczy za $czas minut
tym samym dolaczylem do grona tworcow opensource ;)
moze nastepne skrypty beda bardziej pojechane, w sensie skomplikowane :)
uzyj curl
#!/bin/bash
read czas
read
#!/bin/bash
read -p "za ile minut ma sie wylaczyc komputer?" minuty
sekundy=$(echo "$minuty*60" | bc -l)
echo komputer sie wylaczy za $minuty minut
read -p czy to sie zgada? [t/n] zgadza
[ $zgadza = t ] && sleep $sekundy; poweroff || echo "nie wyrazono zgody"
