sonic.pb Napisano Wrzesień 17, 2006 Zgłoszenie Share Napisano Wrzesień 17, 2006 Mam problem z ustawieniem rozdzielczosci 1024x768 Na windowsie moglem bez problemu a tutaj maxymala opcje mam 800x600 mój konfig xorg.conf # XFree86 4 configuration created by pyxf86config Section "ServerLayout" Identifier "Default Layout" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" # Multiple FontPath entries are allowed (they are concatenated together) # By default, a font server independent of the X server is # used to render fonts. FontPath "unix/:7100" EndSection Section "Module" Load "dbe" Load "extmod" Load "fbdevhw" Load "glx" Load "record" Load "freetype" Load "type1" Load "dri" EndSection Section "InputDevice" # Specify which keyboard LEDs can be user-controlled (eg, with xset(1)) # Option "Xleds" "1 2 3" # To disable the XKEYBOARD extension, uncomment XkbDisable. # Option "XkbDisable" # To customise the XKB settings to suit your keyboard, modify the # lines below (which are the defaults). For example, for a non-U.S. # keyboard, you will probably want to use: # Option "XkbModel" "pc102" # If you have a US Microsoft Natural keyboard, you can use: # Option "XkbModel" "microsoft" # # Then to change the language, change the Layout setting. # For example, a german layout can be obtained with: # Option "XkbLayout" "de" # or: # Option "XkbLayout" "de" # Option "XkbVariant" "nodeadkeys" # # If you'd like to switch the positions of your capslock and # control keys, use: # Option "XkbOptions" "ctrl:swapcaps" # Or if you just want both to be control, use: # Option "XkbOptions" "ctrl:nocaps" # Identifier "Keyboard0" Driver "kbd" Option "XkbModel" "pc105" Option "XkbLayout" "pl" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "IMPS/2" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "yes" EndSection Section "Monitor" ### Comment all HorizSync and VertSync values to use DDC: Identifier "Monitor0" VendorName "Monitor Vendor" ModelName "Unknown monitor" ### Comment all HorizSync and VertSync values to use DDC: HorizSync 31.5 - 37.9 VertRefresh 50.0 - 70.0 Option "dpms" EndSection Section "Device" Identifier "Videocard0" Driver "nv" VendorName "Videocard vendor" BoardName "nVidia Corporation NV11DDR [GeForce2 MX 100 DDR/200 DDR]" EndSection Section "Screen" Identifier "Screen0" Device "Videocard0" Monitor "Monitor0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 16 Modes "800x600" "640x480" EndSubSection SubSection "Display" Viewport 0 0 Depth 24 Modes "1024x768" EndSubSection EndSection Section "DRI" Group 0 Mode 0666 EndSection plz help pozdro Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
rzabcio Napisano Wrzesień 17, 2006 Zgłoszenie Share Napisano Wrzesień 17, 2006 W Xorgu zostaw tylko wymaganą rozdzielczość. Poza tym: man xrandr Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Ponury Napisano Wrzesień 17, 2006 Zgłoszenie Share Napisano Wrzesień 17, 2006 Section "Monitor" Identifier "Monitor0" VendorName "Monitor Vendor" ModelName "Unknown monitor" HorizSync 31.5 - 37.9 VertRefresh 50.0 - 70.0 Option "dpms" Sekcje Device i Screen wygladaja dobrze, to chyba przez "Unknown monitor" i cos male sa te zakresy w HorizSync i VertRefresh Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sonic.pb Napisano Wrzesień 17, 2006 Autor Zgłoszenie Share Napisano Wrzesień 17, 2006 jestem nowicjuszem w sprawie (_linuxa_ → Linuksa) ORT (3 dzień) mam monitor belinea, jak już mówiłem wcześniej pod win chodził normalnie ;/ rzabol mógłbyś powiedzieć coś więcej o tej komendzie ? gdy wpisałem xrandr -s 1024/768 nic sie nie stalo ;/ plz help Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Wrzesień 17, 2006 Zgłoszenie Share Napisano Wrzesień 17, 2006 Wszystko już powiedzieli przedmówcy. Trzeba trochę poczytać. Instalacja sterowników nvidia też chyba w Twoim przypadku jest nie od rzeczy. A to co pisał rzabcio to będzie chyba dodanie w Section "Screen" (...) DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 16 Modes "800x600" "640x480" EndSubSection w linii Modes "800x600" "640x480" rozdzielczości "1024x768" przed "800x600". Ewentualnie innych (1280x1024 itp), ale bez przesady, żeby Ci się monitor nie "rozpuknął" Przynajmniej ja tak robię jak mi się coś rozwali i jak na razie wszystko działa. Pozdr, W. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sonic.pb Napisano Wrzesień 18, 2006 Autor Zgłoszenie Share Napisano Wrzesień 18, 2006 zrobiłem tak jak napisałeś WalDo i po zresetowaniu trybu graficznego ( CTRL + ALT + BACKSPACE ) wyłączył się monitor i go nie rusza ;( musiałem usunąc plik xorg.conf żebym mógł się znowu zalogować ;( Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
rzabcio Napisano Wrzesień 18, 2006 Zgłoszenie Share Napisano Wrzesień 18, 2006 Po zabiciu serwera Xksów nie mogles sie zalogowac? Pezechodziles na konsole? Próbowales uruchomic gdm? (lub kdm) Czesto mialem problemy z rozdzielczosciami. Xfce do dzis NIE pokazuje mi 1024x768 mimo, ze w takiej jest uruchomiony. Dlatego korzystam z xrandr. W Xorgu dodaj pozadana rozdzielczosc i usun pozostale. Kiedy jeszcze siedzialem na Fedorce - tylko taka czynnosc pomogla pomoglo. xrandr -s 1024x768 Odswiezanie ekranu nie powinno miec wielkiego znaczenia - najwyzej uruchomi sie w kiepskiej jakosci. Ale oczywiscie rada byl sluszna i mozesz zwiekszyc górne zakresy kHz - zajrzyj do dokumentacji monitora. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sonic.pb Napisano Wrzesień 18, 2006 Autor Zgłoszenie Share Napisano Wrzesień 18, 2006 zostawiłem tylko 1024x768 w xorgu i znowu musiałem kasować plik ;f zarówno w gnume jak i w kde jest ten problem niestety nie wiem jak się uruchamia gdm / kdm :/ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
swiatex Napisano Wrzesień 18, 2006 Zgłoszenie Share Napisano Wrzesień 18, 2006 a co sie dzieje gdy wpiszesz startx ?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Wrzesień 18, 2006 Zgłoszenie Share Napisano Wrzesień 18, 2006 musialem usunac plik xorg.conf zebym mógl sie znowu zalogowac ;(Sorki, nie napisalem, zeby zrobic kopie xorg.conf przed akcja. Wydawlo mi sie to oczywiste, wiec nawet Twoja uwaga, ze jestes nowicjuszem nie podzialala na mnie Tak na przyszlosc warto zrobic zawsze kopie pliku konfiguracyjnego który chcesz zmieniac. Swoja droga to dziwne, ze wpis zadzialal w ten sposób CO do uruchamiania gdm/kdm to odpala on sie automatycznie po kombinacji Alt-Ctrl-Backspace - widoczna oznaka jego dzialania jest graficzny ekran logowania (no i oczywiscie procesy w systemie - ps -ef | grep gdm) A móglbys jeszcze napisac cos wiecej nt. tego, ze nie mozesz sie zalogowac? Masz ekran logowania czy nie dostajesz go w ogóle? Czy zostajesz w trybie konsoli tekstowej? Moze spróbuj odczekac jakis czas po Alt-Ctrl-Backspace (restart Xów trwa chwile - u mnie ok.10-15 sek.) i potem wcisnij Alt-F7 (przejscie na konsole graficzna. Chociaz u mnie dzieje sie to automatycznie. I jeszcze jedno: czy typ Twojego monitora jest rozpoznany przez system? Sprawdz w /etc/sysconfig/hwconf czy masz go w sekcji (klasie ) class: MONITOR. U mnie ten wpis wyglada tak class: MONITOR bus: DDC detached: 0 desc: "Samsung SyncMaster 753DF(X)/703DF(X)/783DF(X)/CD173A(T)" id: SAM0022 horizSyncMin: 30 horizSyncMax: 71 vertRefreshMin: 50 vertRefreshMax: 160 mode: 640x480 mode: 640x480 mode: 800x600 mode: 1024x768 mode: 1280x1024 Mam SyncMaster 753DFX wiec u Ciebie to oczywiscie bedzie inaczej. No i moze zainstaluj stery nvidia (yumem!!! nie z binarek ze strony nvidii), bo z tego co piszesz to masz karte na tym chipsecie chyba. To tez moze wiele rozwiazac. [Edit]A no wlasnie! Ja dopiero po zainstalowaniu sterów moglem ustawic rozdzielczosc 1152x864 (nietypowa ale taka mi akurat jakos przypasowala) Chociaz podobnie jak pisal rzabcio tez w XFCE mam max.1024x768 Pozdr, W. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sonic.pb Napisano Wrzesień 18, 2006 Autor Zgłoszenie Share Napisano Wrzesień 18, 2006 Gdy ustawiłem w xorg.conf opcje 1024x768 po zapisaniu wcisąłem CTRL + ALT + BACKSPACE i w tym momencie wyłączył mi się monitor, jakby nie wiedział co zrobić ;/ czekałem ponad 5 min i nic, po resecie pojawił się tryb textowy i gdy miał pojawić się tryb graficzny monitor zaś zgasł, właśnie ściągam sterowniki do nvidni zobaczymy co będzie Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Wrzesień 18, 2006 Zgłoszenie Share Napisano Wrzesień 18, 2006 Tak na marginesie - monitor Ci sie nie przelacza w tryb graficzny nie ze wzgledu na rozdzielczosc a ze wzgledu na czestotliwosc odswiezania... Wymus odswiezanie 60Hz a zobaczysz, ze rozdzielczosc 1024x768 pojdzie bez problemu... Tak czy inaczej - instalacja sterownikow nVidii to bardzo dobry pomysl... yum install kmod-nvidia-legacy sprawdz tylko czy znajdzie odpowiednia (dla Twojego kernela) wersje. Pozdro Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sonic.pb Napisano Wrzesień 18, 2006 Autor Zgłoszenie Share Napisano Wrzesień 18, 2006 dziala, dziekuje wszystkim za pomoc zainstalowalem sterowniki nvidnii tzn. http://faq.fedora.pl/#nvidia potem ustawilem monitor (wczesniej byl unknow) i powtorzylem kroki od init 3 =] Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Ponury Napisano Wrzesień 18, 2006 Zgłoszenie Share Napisano Wrzesień 18, 2006 dziala, dziekuje wszystkim za pomoc jeszcze napisz dla potomnych co zrobiłeś, zainstalowałeś kmoda czy wymusiłeś odświeżanie. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
rzabcio Napisano Wrzesień 19, 2006 Zgłoszenie Share Napisano Wrzesień 19, 2006 Kurcze, caly czas widze "Ctrl+Alt+Backspace" i milion innych skrótów bez wyjasniania. Trzeba wiedziec co sie dzieje! Jesli cos jest nie tak przechodzisz na konsole Ctrl+Alt+F1 (co prawda to kolejny skrót, ale te podstawowe trzeba znac!). Logujesz sie na superuzytkownika i nasŧepnie: # killall gdm Tudziez oczywiscie kdm. Zmieniasz, co potrzeba w Xksach i uruchamiasz: # gdm (startx nie ma co uruchamiac - nie zawsze system jest poprawnie skonfigurowany, natomiast gdm - zawsze!) Trudne? Jak wcisniesz Ctrl+Alt+Backspace mozesz czekac do smierci az "cos sie pojawi"! Nadal jestes podlaczony do Xksów ("konsola" Ctrl+Alt+F7) - nic nie widzisz bo przed chwila je zabiles! Jednak konsole od F1 do F6 czekaja! I sa gotowe do poprawki konfigu i ponownego uruchomienia Xksów za ich pomoca. Nie trzeba od razu restartowac! Bez urazy dla nikogo. Kraze po kilku forach Linuksowych i widze, ze ten system staje sie coraz bardziej jak Windows. Wsród userów jest coraz mniejsze zrozumienie tego, co sie w systemie dzieje. Podobnie z kasowaniem pliku Xorga. Po co? To nie XP! Nalezy zajrzec do logów i poprawic konfig Xorga. Co ciekawe, kolejna rzecz, o której nikt z Was nie wspomnial. Logi Xksów to plik: /var/log/Xorg.0.log (czy cos takiego). Dziwie sie tez, ze monitor nie pokazywal Ci, ze przekroczona zostala czestotliwosc (jesli tak bylo). Mam 10-letniego gruchota i ma taka opcje. Podobnie jak automatyczne wylacznie w przypadku zbyt wielu kHz - to juz ma chyba kazdy monitor... Wybaczcie ze marudze. Jest pólnoc - przede mna jeszcze z 2 godzinki zakuwania durnowatego przedmiotu - Teoria Gier. Ble... I jutro exam u najgorszego goscia na uczelni... Cale szczescie, ze ostatni na studiach! Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
