etz257 Napisano Wrzesień 24, 2006 Zgłoszenie Share Napisano Wrzesień 24, 2006 Witam! Mam problem z kasowaniem plyt CDRW i DVDRW tych które wczesniej byly zapisane w Nero. Po skasowaniu w Nero nie ma praktycznie problemów z wypalaniem plyt. Pózniej po nagraniu w K3B tez mozna skasowac. Robilem aktualizacje, ale nie pomoglo. Po nacisnieciu ikonki kasuj CDRW (DVDRW) wyskakuje cos takiego: System ----------------------- K3b Version: 0.12.15 KDE Version: 3.5.4-0.1.fc5 Fedora-Core QT Version: 3.3.6 Kernel: 2.6.16-1.2080_FC5 Devices ----------------------- _NEC DVD_RW ND-3540A 1.01 (/dev/hdd, ) at [CD-R; CD-RW; CD-ROM; DVD-ROM; DVD-R; DVD-RW; DVD-R dwuwarstwowa; DVD+R; DVD+RW; DVD+R dwuwarstwowa] [DVD-ROM; DVD-R sekwencyjna; DVD-R dwuwarstwowa sekwencyjna; DVD-RW w trybie ograniczonego zastepowania; DVD-RW sekwencyjny; DVD+RW; DVD+R; DVD+R dwuwarstwowa; CD-ROM; CD-R; CD-RW] [sesja naraz (SAO); TAO; RAW; SAO/R96R; Surowe/R96R; Ograniczone zastepowanie] Used versions ----------------------- cdrecord: 2.1.1a03 cdrecord command: ----------------------- /usr/bin/cdrecord -v gracetime=2 dev=/dev/hdd speed=10 -tao driveropts=burnfree -eject blank=fast -force cdrecord ----------------------- /usr/bin/cdrecord: Cannot allocate memory. WARNING: Cannot do mlockall(2). /usr/bin/cdrecord: WARNING: This causes a high risk for buffer underruns. /usr/bin/cdrecord: Operation not permitted. WARNING: Cannot set RR-scheduler /usr/bin/cdrecord: Permission denied. WARNING: Cannot set priority using setpriority(). /usr/bin/cdrecord: WARNING: This causes a high risk for buffer underruns. scsidev: '/dev/hdd' devname: '/dev/hdd' scsibus: -2 target: -2 lun: -2 Error trying to open /dev/hdd exclusively ... retrying in 1 second. Error trying to open /dev/hdd exclusively ... retrying in 1 second. Error trying to open /dev/hdd exclusively ... retrying in 1 second. Error trying to open /dev/hdd exclusively ... retrying in 1 second. Error trying to open /dev/hdd exclusively ... retrying in 1 second. Error trying to open /dev/hdd exclusively ... retrying in 1 second. Error trying to open /dev/hdd exclusively ... retrying in 1 second. Error trying to open /dev/hdd exclusively ... retrying in 1 second. Error trying to open /dev/hdd exclusively ... retrying in 1 second. Error trying to open /dev/hdd exclusively ... retrying in 1 second. /usr/bin/cdrecord: Device or resource busy. Cannot open '/dev/hdd'. Cannot open SCSI driver. /usr/bin/cdrecord: For possible targets try 'cdrecord -scanbus'. Make sure you are root. /usr/bin/cdrecord: For possible transport specifiers try 'cdrecord dev=help'. Cdrecord-Clone 2.01.01a03-dvd (i686-pc-linux-gnu) Copyright Š 1995-2005 JĂśrg Schilling NOTE: This version contains the OSS DVD extensions for cdrtools and thus may have bugs related to DVD issues that are not present in the original cdrtools. Please send bug reports or support requests to http://bugzilla.redhat.com/bugzilla The original cdrtools author should not be bothered with problems in this version. TOC Type: 1 = CD-ROM Próbowalem takze jako root i tez to samo. Pozdrawiam uzywaj codebox do dlugich listingow- uosiu Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Rasp Napisano Wrzesień 24, 2006 Zgłoszenie Share Napisano Wrzesień 24, 2006 Spróbuj przed kasowaniem RW odmontować płytę z napędu... Nie analizowałem dokładnie komunikatów, ale wiem że to najczęstszy problem z kasowaniem RW w k3b... Po prostu płyta z danymi jest automatycznie montowana w systemie, a k3b takowej kasować nie może. Co do samego odmontowywania to w konsoli: umount /dev/hdd o ile nie pomyliłem napędów.. Pozdrawiam Rasp.. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Wrzesień 24, 2006 Zgłoszenie Share Napisano Wrzesień 24, 2006 Kernel: 2.6.16-1.2080_FC5 Zaktualizuj najpierw system... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
etz257 Napisano Wrzesień 24, 2006 Autor Zgłoszenie Share Napisano Wrzesień 24, 2006 Spróbuj przed kasowaniem RW odmontować płytę z napędu... Nie analizowałem dokładnie komunikatów, ale wiem że to najczęstszy problem z kasowaniem RW w k3b... Po prostu płyta z danymi jest automatycznie montowana w systemie, a k3b takowej kasować nie może. Co do samego odmontowywania to w konsoli: CODE umount /dev/hdd o ile nie pomyliłem napędów.. Pozdrawiam Rasp.. Dzięki wielkie!!! Twoja odpowiedź była trafiona!!! Teraz już mi kasuje i jest ok Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
etz257 Napisano Październik 24, 2006 Autor Zgłoszenie Share Napisano Październik 24, 2006 Witam wszystkich ponownie. Jak napisałem wcześniej wszystko śmiga, tylko apetyt rośnie w miare jedzenia i pytanie jest czy jest jakś możliwość żeby zwykły uzytkownik mógł odmontowac płytę? Bo w tej sytuacji tylko root może nagrywac płyty a nie o to chodzi. Pewnie jest jakaś możliwość tylko ja nie wiem jaka:( Z góry wilekie dzieki za odpowiedź. Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
uosiu Napisano Październik 24, 2006 Zgłoszenie Share Napisano Październik 24, 2006 do /etc/fstab dodaj opcje user w linice z cdromem Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
etz257 Napisano Październik 24, 2006 Autor Zgłoszenie Share Napisano Październik 24, 2006 kłopot w tym że ja nie mam takiej linijki Próbowałem dopisać dev/dvd /mnt/dvd udf.iso9660 noauto,owner,kudzu,ro 0 0 Ale to nie pomogło Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Październik 25, 2006 Zgłoszenie Share Napisano Październik 25, 2006 pokaz swojego fstaba i co to jest udf.iso9660 ? I gdzie Ci wessalo poczatkowy / przed dev/dvd ? powinienes miec w fstab cos w ten desen /dev/hdd /media/dvdrecorder auto pamconsole,exec,noauto,users,managed 0 0 auto ewentualnie mozna zastapic iso9660 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
etz257 Napisano Październik 25, 2006 Autor Zgłoszenie Share Napisano Październik 25, 2006 LABEL=/1 / ext3 defaults 1 1 devpts /dev/pts devpts gid=5,mode=620 0 0 tmpfs /dev/shm tmpfs defaults 0 0 proc /proc proc defaults 0 0 sysfs /sys sysfs defaults 0 0 LABEL=SWAP-hda8 swap swap defaults 0 0 /dev/hda1 /mnt/c vfat umask=000,users 1 0 /dev/hda5 /mnt/d vfat umask=000,users 1 0 /dev/hda6 /mnt/e vfat umask=000,users 1 0 /dev/hdd /media/dvdrecorder auto pamconsole,exec,noauto,users,managed 0 0 To mam w /etc/fstab ale niestety wywala bład: You are not privileged to mount the volume 'K3b data project'. I nie moge podmontować Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Październik 25, 2006 Zgłoszenie Share Napisano Październik 25, 2006 hmmm...używasz gnome'a ? http://www.redhat.com/archives/fedora-test...y/msg02002.html Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
etz257 Napisano Październik 26, 2006 Autor Zgłoszenie Share Napisano Październik 26, 2006 Tak używam gnome, ale teraz mam taki wpis w fstab i dalej nic LABEL=/1 / ext3 defaults 1 1 devpts /dev/pts devpts gid=5,mode=620 0 0 tmpfs /dev/shm tmpfs defaults 0 0 proc /proc proc defaults 0 0 sysfs /sys sysfs defaults 0 0 LABEL=SWAP-hda8 swap swap defaults 0 0 /dev/hda1 /mnt/c vfat umask=000,users 1 0 /dev/hda5 /mnt/d vfat umask=000,users 1 0 /dev/hda6 /mnt/e vfat umask=000,users 1 0 /dev/scd0 /media/cdrecorder auto pamconsole,exec,noauto,managed,user 0 0 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
etz257 Napisano Październik 27, 2006 Autor Zgłoszenie Share Napisano Październik 27, 2006 Teraz zrobiłem jeszcze tak: /dev/hdd /mnt/cdrom iso9660 noauto,user,ro 0 0 i jest o tyle lepiej że pojawiła się możliwośc zamontowania płyty, tzn jest dostepna ta opcja dla user'a ale gdy chce zamontowac to wyskakuje komunikat:Cannot mount volume You are not privileged to mount the volume 'K3b data project'. Próbowałem zamontować jako root ale też ten sam komunikat wyskakuje Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
