Sanczo Napisano Październik 5, 2006 Zgłoszenie Share Napisano Październik 5, 2006 Zainstalowalem na laptopie HP nx7400 slaka 10.2 i dziala. Proboje zrobic to samo z najnowszym jajkiem 2.6.18 (skompilowanym) i dostaje: > >> VFS: Cannot open root device "305" or unknown-block(3,5) > >> Please append a correct "root=" boot option > >> Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(3,5) wyglada to mniej wiecej jak powyzej. lspci: 00:00.0 Host bridge: Intel Corporation Mobile Memory Controller Hub (rev 03) 00:02.0 VGA compatible controller: Intel Corporation Mobile Integrated Graphics Controller (rev 03) 00:02.1 Display controller: Intel Corporation Mobile Integrated Graphics Controller (rev 03) 00:1b.0 Class 0403: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 01) 00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 01) 00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 01) 00:1c.3 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 4 (rev 01) 00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #1 (rev 01) 00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #2 (rev 01) 00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #3 (rev 01) 00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #4 (rev 01) 00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 01) 00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e1) 00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 01) 00:1f.2 IDE interface: Intel Corporation 82801GBM/GHM (ICH7 Family) Serial ATA Storage Controllers cc=IDE (rev 01) 02:06.0 CardBus bridge: Texas Instruments: Unknown device 8039 02:06.1 FireWire (IEEE 1394): Texas Instruments: Unknown device 803a 02:0e.0 Ethernet controller: Broadcom Corporation BCM4401-B0 100Base-TX (rev 02) 10:00.0 Network controller: Intel Corporation: Unknown device 4222 (rev 02) .config: # # Automatically generated make config: don't edit # Linux kernel version: 2.6.18 # Wed Oct 4 23:40:24 2006 # CONFIG_X86_32=y CONFIG_GENERIC_TIME=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_SEMAPHORE_SLEEPERS=y CONFIG_X86=y CONFIG_MMU=y CONFIG_GENERIC_ISA_DMA=y CONFIG_GENERIC_IOMAP=y CONFIG_GENERIC_HWEIGHT=y CONFIG_ARCH_MAY_HAVE_PC_FDC=y CONFIG_DMI=y CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config" # # Code maturity level options # CONFIG_EXPERIMENTAL=y CONFIG_BROKEN_ON_SMP=y CONFIG_LOCK_KERNEL=y CONFIG_INIT_ENV_ARG_LIMIT=32 # # General setup # CONFIG_LOCALVERSION="_Sanczo" CONFIG_LOCALVERSION_AUTO=y # CONFIG_SWAP is not set CONFIG_SYSVIPC=y # CONFIG_POSIX_MQUEUE is not set CONFIG_BSD_PROCESS_ACCT=y # CONFIG_BSD_PROCESS_ACCT_V3 is not set # CONFIG_TASKSTATS is not set CONFIG_AUDIT=y CONFIG_AUDITSYSCALL=y CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y # CONFIG_RELAY is not set CONFIG_INITRAMFS_SOURCE="" CONFIG_CC_OPTIMIZE_FOR_SIZE=y # CONFIG_EMBEDDED is not set CONFIG_UID16=y CONFIG_SYSCTL=y CONFIG_KALLSYMS=y # CONFIG_KALLSYMS_ALL is not set # CONFIG_KALLSYMS_EXTRA_PASS is not set CONFIG_HOTPLUG=y CONFIG_PRINTK=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_EPOLL=y CONFIG_SHMEM=y CONFIG_SLAB=y CONFIG_VM_EVENT_COUNTERS=y CONFIG_RT_MUTEXES=y # CONFIG_TINY_SHMEM is not set CONFIG_BASE_SMALL=0 # CONFIG_SLOB is not set # # Loadable module support # CONFIG_MODULES=y CONFIG_MODULE_UNLOAD=y # CONFIG_MODULE_FORCE_UNLOAD is not set # CONFIG_MODVERSIONS is not set # CONFIG_MODULE_SRCVERSION_ALL is not set CONFIG_KMOD=y # # Block layer # # CONFIG_LBD is not set # CONFIG_BLK_DEV_IO_TRACE is not set # CONFIG_LSF is not set # # IO Schedulers # CONFIG_IOSCHED_NOOP=y # CONFIG_IOSCHED_AS is not set # CONFIG_IOSCHED_DEADLINE is not set CONFIG_IOSCHED_CFQ=y # CONFIG_DEFAULT_AS is not set # CONFIG_DEFAULT_DEADLINE is not set CONFIG_DEFAULT_CFQ=y # CONFIG_DEFAULT_NOOP is not set CONFIG_DEFAULT_IOSCHED="cfq" # # Processor type and features # # CONFIG_SMP is not set CONFIG_X86_PC=y # CONFIG_X86_ELAN is not set # CONFIG_X86_VOYAGER is not set # CONFIG_X86_NUMAQ is not set # CONFIG_X86_SUMMIT is not set # CONFIG_X86_BIGSMP is not set # CONFIG_X86_VISWS is not set # CONFIG_X86_GENERICARCH is not set # CONFIG_X86_ES7000 is not set # CONFIG_M386 is not set # CONFIG_M486 is not set # CONFIG_M586 is not set # CONFIG_M586TSC is not set # CONFIG_M586MMX is not set # CONFIG_M686 is not set # CONFIG_MPENTIUMII is not set # CONFIG_MPENTIUMIII is not set # CONFIG_MPENTIUMM is not set CONFIG_MPENTIUM4=y # CONFIG_MK6 is not set # CONFIG_MK7 is not set # CONFIG_MK8 is not set # CONFIG_MCRUSOE is not set # CONFIG_MEFFICEON is not set # CONFIG_MWINCHIPC6 is not set # CONFIG_MWINCHIP2 is not set # CONFIG_MWINCHIP3D is not set # CONFIG_MGEODEGX1 is not set # CONFIG_MGEODE_LX is not set # CONFIG_MCYRIXIII is not set # CONFIG_MVIAC3_2 is not set # CONFIG_X86_GENERIC is not set CONFIG_X86_CMPXCHG=y CONFIG_X86_XADD=y CONFIG_X86_L1_CACHE_SHIFT=7 CONFIG_RWSEM_XCHGADD_ALGORITHM=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_X86_WP_WORKS_OK=y CONFIG_X86_INVLPG=y CONFIG_X86_BSWAP=y CONFIG_X86_POPAD_OK=y CONFIG_X86_CMPXCHG64=y CONFIG_X86_GOOD_APIC=y CONFIG_X86_INTEL_USERCOPY=y CONFIG_X86_USE_PPRO_CHECKSUM=y CONFIG_X86_TSC=y CONFIG_HPET_TIMER=y # CONFIG_PREEMPT_NONE is not set # CONFIG_PREEMPT_VOLUNTARY is not set CONFIG_PREEMPT=y CONFIG_PREEMPT_BKL=y # CONFIG_X86_UP_APIC is not set CONFIG_X86_MCE=y CONFIG_X86_MCE_NONFATAL=y CONFIG_VM86=y # CONFIG_TOSHIBA is not set # CONFIG_I8K is not set # CONFIG_X86_REBOOTFIXUPS is not set # CONFIG_MICROCODE is not set # CONFIG_X86_MSR is not set # CONFIG_X86_CPUID is not set # # Firmware Drivers # # CONFIG_EDD is not set # CONFIG_DELL_RBU is not set # CONFIG_DCDBAS is not set # CONFIG_NOHIGHMEM is not set CONFIG_HIGHMEM4G=y # CONFIG_HIGHMEM64G is not set CONFIG_PAGE_OFFSET=0xC0000000 CONFIG_HIGHMEM=y CONFIG_ARCH_FLATMEM_ENABLE=y CONFIG_ARCH_SPARSEMEM_ENABLE=y CONFIG_ARCH_SELECT_MEMORY_MODEL=y CONFIG_SELECT_MEMORY_MODEL=y CONFIG_FLATMEM_MANUAL=y # CONFIG_DISCONTIGMEM_MANUAL is not set # CONFIG_SPARSEMEM_MANUAL is not set CONFIG_FLATMEM=y CONFIG_FLAT_NODE_MEM_MAP=y CONFIG_SPARSEMEM_STATIC=y CONFIG_SPLIT_PTLOCK_CPUS=4 # CONFIG_RESOURCES_64BIT is not set # CONFIG_HIGHPTE is not set # CONFIG_MATH_EMULATION is not set CONFIG_MTRR=y # CONFIG_EFI is not set # CONFIG_REGPARM is not set CONFIG_SECCOMP=y # CONFIG_HZ_100 is not set # CONFIG_HZ_250 is not set CONFIG_HZ_1000=y CONFIG_HZ=1000 # CONFIG_KEXEC is not set # CONFIG_CRASH_DUMP is not set CONFIG_PHYSICAL_START=0x100000 # CONFIG_COMPAT_VDSO is not set CONFIG_ARCH_ENABLE_MEMORY_HOTPLUG=y # # Power management options (ACPI, APM) # CONFIG_PM=y CONFIG_PM_LEGACY=y CONFIG_PM_DEBUG=y # CONFIG_PM_TRACE is not set # # ACPI (Advanced Configuration and Power Interface) Support # CONFIG_ACPI=y # CONFIG_ACPI_SLEEP is not set CONFIG_ACPI_AC=y CONFIG_ACPI_BATTERY=y CONFIG_ACPI_BUTTON=y # CONFIG_ACPI_VIDEO is not set # CONFIG_ACPI_HOTKEY is not set CONFIG_ACPI_FAN=y # CONFIG_ACPI_DOCK is not set CONFIG_ACPI_PROCESSOR=y CONFIG_ACPI_THERMAL=y # CONFIG_ACPI_ASUS is not set # CONFIG_ACPI_IBM is not set # CONFIG_ACPI_TOSHIBA is not set CONFIG_ACPI_BLACKLIST_YEAR=0 CONFIG_ACPI_DEBUG=y CONFIG_ACPI_EC=y CONFIG_ACPI_POWER=y CONFIG_ACPI_SYSTEM=y CONFIG_X86_PM_TIMER=y # CONFIG_ACPI_CONTAINER is not set # CONFIG_ACPI_SBS is not set # # APM (Advanced Power Management) BIOS Support # CONFIG_APM=y # CONFIG_APM_IGNORE_USER_SUSPEND is not set # CONFIG_APM_DO_ENABLE is not set # CONFIG_APM_CPU_IDLE is not set # CONFIG_APM_DISPLAY_BLANK is not set # CONFIG_APM_RTC_IS_GMT is not set # CONFIG_APM_ALLOW_INTS is not set # CONFIG_APM_REAL_MODE_POWER_OFF is not set # # CPU Frequency scaling # # CONFIG_CPU_FREQ is not set # # Bus options (PCI, PCMCIA, EISA, MCA, ISA) # CONFIG_PCI=y CONFIG_PCI_GOBIOS=y # CONFIG_PCI_GOMMCONFIG is not set # CONFIG_PCI_GODIRECT is not set # CONFIG_PCI_GOANY is not set CONFIG_PCI_BIOS=y CONFIG_PCIEPORTBUS=y # CONFIG_PCI_DEBUG is not set CONFIG_ISA_DMA_API=y # CONFIG_ISA is not set # CONFIG_MCA is not set # CONFIG_SCx200 is not set # # PCCARD (PCMCIA/CardBus) support # CONFIG_PCCARD=m # CONFIG_PCMCIA_DEBUG is not set CONFIG_PCMCIA=m # CONFIG_PCMCIA_LOAD_CIS is not set # CONFIG_PCMCIA_IOCTL is not set CONFIG_CARDBUS=y # # PC-card bridges # # CONFIG_YENTA is not set # CONFIG_PD6729 is not set # CONFIG_I82092 is not set # # PCI Hotplug Support # # CONFIG_HOTPLUG_PCI is not set # # Executable file formats # CONFIG_BINFMT_ELF=y # CONFIG_BINFMT_AOUT is not set # CONFIG_BINFMT_MISC is not set # # Networking # CONFIG_NET=y # # Networking options # # CONFIG_NETDEBUG is not set CONFIG_PACKET=y # CONFIG_PACKET_MMAP is not set CONFIG_UNIX=y CONFIG_XFRM=y # CONFIG_XFRM_USER is not set CONFIG_NET_KEY=m CONFIG_INET=y # CONFIG_IP_MULTICAST is not set # CONFIG_IP_ADVANCED_ROUTER is not set CONFIG_IP_FIB_HASH=y # CONFIG_IP_PNP is not set # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE is not set # CONFIG_ARPD is not set CONFIG_SYN_COOKIES=y # CONFIG_INET_AH is not set # CONFIG_INET_ESP is not set # CONFIG_INET_IPCOMP is not set # CONFIG_INET_XFRM_TUNNEL is not set # CONFIG_INET_TUNNEL is not set CONFIG_INET_XFRM_MODE_TRANSPORT=y CONFIG_INET_XFRM_MODE_TUNNEL=y CONFIG_INET_DIAG=y CONFIG_INET_TCP_DIAG=y # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_BIC=y # # IP: Virtual Server Configuration # # CONFIG_IP_VS is not set # CONFIG_IPV6 is not set # CONFIG_INET6_XFRM_TUNNEL is not set # CONFIG_INET6_TUNNEL is not set # CONFIG_NETWORK_SECMARK is not set CONFIG_NETFILTER=y CONFIG_NETFILTER_DEBUG=y # # Core Netfilter Configuration # # CONFIG_NETFILTER_NETLINK is not set CONFIG_NETFILTER_XTABLES=y # CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set # CONFIG_NETFILTER_XT_TARGET_MARK is not set CONFIG_NETFILTER_XT_TARGET_NFQUEUE=y # CONFIG_NETFILTER_XT_MATCH_COMMENT is not set # CONFIG_NETFILTER_XT_MATCH_CONNTRACK is not set # CONFIG_NETFILTER_XT_MATCH_DCCP is not set # CONFIG_NETFILTER_XT_MATCH_ESP is not set # CONFIG_NETFILTER_XT_MATCH_HELPER is not set # CONFIG_NETFILTER_XT_MATCH_LENGTH is not set CONFIG_NETFILTER_XT_MATCH_LIMIT=y # CONFIG_NETFILTER_XT_MATCH_MAC is not set # CONFIG_NETFILTER_XT_MATCH_MARK is not set # CONFIG_NETFILTER_XT_MATCH_POLICY is not set # CONFIG_NETFILTER_XT_MATCH_MULTIPORT is not set # CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set # CONFIG_NETFILTER_XT_MATCH_QUOTA is not set # CONFIG_NETFILTER_XT_MATCH_REALM is not set # CONFIG_NETFILTER_XT_MATCH_SCTP is not set CONFIG_NETFILTER_XT_MATCH_STATE=m # CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set # CONFIG_NETFILTER_XT_MATCH_STRING is not set # CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set # # IP: Netfilter Configuration # CONFIG_IP_NF_CONNTRACK=y # CONFIG_IP_NF_CT_ACCT is not set # CONFIG_IP_NF_CONNTRACK_MARK is not set # CONFIG_IP_NF_CONNTRACK_EVENTS is not set # CONFIG_IP_NF_CT_PROTO_SCTP is not set # CONFIG_IP_NF_FTP is not set # CONFIG_IP_NF_IRC is not set # CONFIG_IP_NF_NETBIOS_NS is not set # CONFIG_IP_NF_TFTP is not set # CONFIG_IP_NF_AMANDA is not set # CONFIG_IP_NF_PPTP is not set # CONFIG_IP_NF_H323 is not set # CONFIG_IP_NF_SIP is not set # CONFIG_IP_NF_QUEUE is not set CONFIG_IP_NF_IPTABLES=y CONFIG_IP_NF_MATCH_IPRANGE=y # CONFIG_IP_NF_MATCH_TOS is not set # CONFIG_IP_NF_MATCH_RECENT is not set # CONFIG_IP_NF_MATCH_ECN is not set # CONFIG_IP_NF_MATCH_DSCP is not set # CONFIG_IP_NF_MATCH_AH is not set # CONFIG_IP_NF_MATCH_TTL is not set # CONFIG_IP_NF_MATCH_OWNER is not set # CONFIG_IP_NF_MATCH_ADDRTYPE is not set # CONFIG_IP_NF_MATCH_HASHLIMIT is not set CONFIG_IP_NF_FILTER=y # CONFIG_IP_NF_TARGET_REJECT is not set CONFIG_IP_NF_TARGET_LOG=y # CONFIG_IP_NF_TARGET_ULOG is not set # CONFIG_IP_NF_TARGET_TCPMSS is not set # CONFIG_IP_NF_NAT is not set # CONFIG_IP_NF_MANGLE is not set # CONFIG_IP_NF_RAW is not set # CONFIG_IP_NF_ARPTABLES is not set # # DCCP Configuration (EXPERIMENTAL) # # CONFIG_IP_DCCP is not set # # SCTP Configuration (EXPERIMENTAL) # # CONFIG_IP_SCTP is not set # # TIPC Configuration (EXPERIMENTAL) # # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_BRIDGE is not set # CONFIG_VLAN_8021Q is not set # CONFIG_DECNET is not set # CONFIG_LLC2 is not set # CONFIG_IPX is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_ECONET is not set # CONFIG_WAN_ROUTER is not set # # QoS and/or fair queueing # # CONFIG_NET_SCHED is not set # # Network testing # # CONFIG_NET_PKTGEN is not set # CONFIG_HAMRADIO is not set # CONFIG_IRDA is not set CONFIG_BT=y CONFIG_BT_L2CAP=y # CONFIG_BT_SCO is not set CONFIG_BT_RFCOMM=y CONFIG_BT_RFCOMM_TTY=y # CONFIG_BT_BNEP is not set # CONFIG_BT_HIDP is not set # # Bluetooth device drivers # CONFIG_BT_HCIUSB=m # CONFIG_BT_HCIUSB_SCO is not set # CONFIG_BT_HCIUART is not set # CONFIG_BT_HCIBCM203X is not set # CONFIG_BT_HCIBPA10X is not set # CONFIG_BT_HCIBFUSB is not set # CONFIG_BT_HCIDTL1 is not set # CONFIG_BT_HCIBT3C is not set # CONFIG_BT_HCIBLUECARD is not set # CONFIG_BT_HCIBTUART is not set # CONFIG_BT_HCIVHCI is not set # CONFIG_IEEE80211 is not set # # Device Drivers # # # Generic Driver Options # CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y CONFIG_FW_LOADER=m CONFIG_DEBUG_DRIVER=y # CONFIG_SYS_HYPERVISOR is not set # # Connector - unified userspace <-> kernelspace linker # # CONFIG_CONNECTOR is not set # # Memory Technology Devices (MTD) # CONFIG_MTD=m # CONFIG_MTD_DEBUG is not set CONFIG_MTD_CONCAT=m # CONFIG_MTD_PARTITIONS is not set # # User Modules And Translation Layers # CONFIG_MTD_CHAR=m # CONFIG_MTD_BLOCK is not set # CONFIG_MTD_BLOCK_RO is not set # CONFIG_FTL is not set CONFIG_NFTL=m # CONFIG_NFTL_RW is not set # CONFIG_INFTL is not set # CONFIG_RFD_FTL is not set # # RAM/ROM/Flash chip drivers # CONFIG_MTD_CFI=m CONFIG_MTD_JEDECPROBE=m CONFIG_MTD_GEN_PROBE=m # CONFIG_MTD_CFI_ADV_OPTIONS is not set CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y # CONFIG_MTD_CFI_I4 is not set # CONFIG_MTD_CFI_I8 is not set CONFIG_MTD_CFI_INTELEXT=m # CONFIG_MTD_CFI_AMDSTD is not set CONFIG_MTD_CFI_STAA=m CONFIG_MTD_CFI_UTIL=m CONFIG_MTD_RAM=m # CONFIG_MTD_ROM is not set # CONFIG_MTD_ABSENT is not set # CONFIG_MTD_OBSOLETE_CHIPS is not set # # Mapping drivers for chip access # # CONFIG_MTD_COMPLEX_MAPPINGS is not set # CONFIG_MTD_PHYSMAP is not set # CONFIG_MTD_SC520CDP is not set # CONFIG_MTD_TS5500 is not set # CONFIG_MTD_AMD76XROM is not set # CONFIG_MTD_ICHXROM is not set # CONFIG_MTD_SCB2_FLASH is not set # CONFIG_MTD_L440GX is not set # CONFIG_MTD_PLATRAM is not set # # Self-contained MTD device drivers # # CONFIG_MTD_PMC551 is not set # CONFIG_MTD_SLRAM is not set # CONFIG_MTD_PHRAM is not set # CONFIG_MTD_MTDRAM is not set # CONFIG_MTD_BLOCK2MTD is not set # # Disk-On-Chip Device Drivers # # CONFIG_MTD_DOC2000 is not set # CONFIG_MTD_DOC2001 is not set # CONFIG_MTD_DOC2001PLUS is not set # # NAND Flash Device Drivers # # CONFIG_MTD_NAND is not set # # OneNAND Flash Device Drivers # # CONFIG_MTD_ONENAND is not set # # Parallel port support # CONFIG_PARPORT=y CONFIG_PARPORT_PC=y # CONFIG_PARPORT_SERIAL is not set # CONFIG_PARPORT_PC_FIFO is not set # CONFIG_PARPORT_PC_SUPERIO is not set # CONFIG_PARPORT_PC_PCMCIA is not set # CONFIG_PARPORT_GSC is not set # CONFIG_PARPORT_AX88796 is not set # CONFIG_PARPORT_1284 is not set # # Plug and Play support # # CONFIG_PNP is not set # # Block devices # # CONFIG_BLK_DEV_FD is not set # CONFIG_PARIDE is not set # CONFIG_BLK_CPQ_DA is not set CONFIG_BLK_CPQ_CISS_DA=y # CONFIG_CISS_SCSI_TAPE is not set # CONFIG_BLK_DEV_DAC960 is not set # CONFIG_BLK_DEV_UMEM is not set # CONFIG_BLK_DEV_COW_COMMON is not set CONFIG_BLK_DEV_LOOP=y # CONFIG_BLK_DEV_CRYPTOLOOP is not set # CONFIG_BLK_DEV_NBD is not set # CONFIG_BLK_DEV_SX8 is not set # CONFIG_BLK_DEV_UB is not set # CONFIG_BLK_DEV_RAM is not set CONFIG_BLK_DEV_INITRD=y CONFIG_CDROM_PKTCDVD=y CONFIG_CDROM_PKTCDVD_BUFFERS=10 # CONFIG_CDROM_PKTCDVD_WCACHE is not set # CONFIG_ATA_OVER_ETH is not set # # ATA/ATAPI/MFM/RLL support # CONFIG_IDE=y CONFIG_BLK_DEV_IDE=y # # Please see Documentation/ide.txt for help/info on IDE drives # # CONFIG_BLK_DEV_IDE_SATA is not set # CONFIG_BLK_DEV_HD_IDE is not set CONFIG_BLK_DEV_IDEDISK=y # CONFIG_IDEDISK_MULTI_MODE is not set # CONFIG_BLK_DEV_IDECS is not set CONFIG_BLK_DEV_IDECD=y # CONFIG_BLK_DEV_IDETAPE is not set # CONFIG_BLK_DEV_IDEFLOPPY is not set # CONFIG_BLK_DEV_IDESCSI is not set # CONFIG_IDE_TASK_IOCTL is not set # # IDE chipset support/bugfixes # CONFIG_IDE_GENERIC=y # CONFIG_BLK_DEV_CMD640 is not set CONFIG_BLK_DEV_IDEPCI=y CONFIG_IDEPCI_SHARE_IRQ=y # CONFIG_BLK_DEV_OFFBOARD is not set CONFIG_BLK_DEV_GENERIC=y # CONFIG_BLK_DEV_OPTI621 is not set # CONFIG_BLK_DEV_RZ1000 is not set CONFIG_BLK_DEV_IDEDMA_PCI=y # CONFIG_BLK_DEV_IDEDMA_FORCED is not set # CONFIG_IDEDMA_PCI_AUTO is not set # CONFIG_BLK_DEV_AEC62XX is not set # CONFIG_BLK_DEV_ALI15X3 is not set # CONFIG_BLK_DEV_AMD74XX is not set # CONFIG_BLK_DEV_ATIIXP is not set # CONFIG_BLK_DEV_CMD64X is not set # CONFIG_BLK_DEV_TRIFLEX is not set # CONFIG_BLK_DEV_CY82C693 is not set # CONFIG_BLK_DEV_CS5520 is not set # CONFIG_BLK_DEV_CS5530 is not set # CONFIG_BLK_DEV_CS5535 is not set # CONFIG_BLK_DEV_HPT34X is not set # CONFIG_BLK_DEV_HPT366 is not set # CONFIG_BLK_DEV_SC1200 is not set # CONFIG_BLK_DEV_PIIX is not set # CONFIG_BLK_DEV_IT821X is not set # CONFIG_BLK_DEV_NS87415 is not set # CONFIG_BLK_DEV_PDC202XX_OLD is not set # CONFIG_BLK_DEV_PDC202XX_NEW is not set # CONFIG_BLK_DEV_SVWKS is not set # CONFIG_BLK_DEV_SIIMAGE is not set # CONFIG_BLK_DEV_SIS5513 is not set # CONFIG_BLK_DEV_SLC90E66 is not set # CONFIG_BLK_DEV_TRM290 is not set CONFIG_BLK_DEV_VIA82CXXX=y # CONFIG_IDE_ARM is not set CONFIG_BLK_DEV_IDEDMA=y # CONFIG_IDEDMA_IVB is not set # CONFIG_IDEDMA_AUTO is not set # CONFIG_BLK_DEV_HD is not set # # SCSI device support # # CONFIG_RAID_ATTRS is not set CONFIG_SCSI=y CONFIG_SCSI_PROC_FS=y # # SCSI support type (disk, tape, CD-ROM) # CONFIG_BLK_DEV_SD=y # CONFIG_CHR_DEV_ST is not set # CONFIG_CHR_DEV_OSST is not set # CONFIG_BLK_DEV_SR is not set CONFIG_CHR_DEV_SG=m # CONFIG_CHR_DEV_SCH is not set # # Some SCSI devices (e.g. CD jukebox) support multiple LUNs # # CONFIG_SCSI_MULTI_LUN is not set CONFIG_SCSI_CONSTANTS=y # CONFIG_SCSI_LOGGING is not set # # SCSI Transport Attributes # # CONFIG_SCSI_SPI_ATTRS is not set # CONFIG_SCSI_FC_ATTRS is not set # CONFIG_SCSI_ISCSI_ATTRS is not set # CONFIG_SCSI_SAS_ATTRS is not set # # SCSI low-level drivers # # CONFIG_ISCSI_TCP is not set # CONFIG_BLK_DEV_3W_XXXX_RAID is not set # CONFIG_SCSI_3W_9XXX is not set # CONFIG_SCSI_ACARD is not set # CONFIG_SCSI_AACRAID is not set # CONFIG_SCSI_AIC7XXX is not set # CONFIG_SCSI_AIC7XXX_OLD is not set # CONFIG_SCSI_AIC79XX is not set # CONFIG_SCSI_DPT_I2O is not set # CONFIG_SCSI_ADVANSYS is not set # CONFIG_MEGARAID_NEWGEN is not set # CONFIG_MEGARAID_LEGACY is not set # CONFIG_MEGARAID_SAS is not set CONFIG_SCSI_SATA=y CONFIG_SCSI_SATA_AHCI=y # CONFIG_SCSI_SATA_SVW is not set CONFIG_SCSI_ATA_PIIX=y # CONFIG_SCSI_SATA_MV is not set # CONFIG_SCSI_SATA_NV is not set # CONFIG_SCSI_PDC_ADMA is not set # CONFIG_SCSI_HPTIOP is not set # CONFIG_SCSI_SATA_QSTOR is not set # CONFIG_SCSI_SATA_PROMISE is not set # CONFIG_SCSI_SATA_SX4 is not set # CONFIG_SCSI_SATA_SIL is not set # CONFIG_SCSI_SATA_SIL24 is not set # CONFIG_SCSI_SATA_SIS is not set # CONFIG_SCSI_SATA_ULI is not set # CONFIG_SCSI_SATA_VIA is not set # CONFIG_SCSI_SATA_VITESSE is not set CONFIG_SCSI_SATA_INTEL_COMBINED=y CONFIG_SCSI_BUSLOGIC=y # CONFIG_SCSI_OMIT_FLASHPOINT is not set # CONFIG_SCSI_DMX3191D is not set # CONFIG_SCSI_EATA is not set # CONFIG_SCSI_FUTURE_DOMAIN is not set CONFIG_SCSI_GDTH=y # CONFIG_SCSI_IPS is not set # CONFIG_SCSI_INITIO is not set # CONFIG_SCSI_INIA100 is not set # CONFIG_SCSI_PPA is not set # CONFIG_SCSI_IMM is not set # CONFIG_SCSI_SYM53C8XX_2 is not set # CONFIG_SCSI_IPR is not set # CONFIG_SCSI_QLOGIC_1280 is not set # CONFIG_SCSI_QLA_FC is not set # CONFIG_SCSI_LPFC is not set # CONFIG_SCSI_DC395x is not set # CONFIG_SCSI_DC390T is not set # CONFIG_SCSI_NSP32 is not set # CONFIG_SCSI_DEBUG is not set # # PCMCIA SCSI adapter support # # CONFIG_PCMCIA_AHA152X is not set # CONFIG_PCMCIA_FDOMAIN is not set # CONFIG_PCMCIA_NINJA_SCSI is not set # CONFIG_PCMCIA_QLOGIC is not set # CONFIG_PCMCIA_SYM53C500 is not set # # Multi-device support (RAID and LVM) # # CONFIG_MD is not set # # Fusion MPT device support # # CONFIG_FUSION is not set # CONFIG_FUSION_SPI is not set # CONFIG_FUSION_FC is not set # CONFIG_FUSION_SAS is not set # # IEEE 1394 (FireWire) support # # CONFIG_IEEE1394 is not set # # I2O device support # # CONFIG_I2O is not set # # Network device support # CONFIG_NETDEVICES=y # CONFIG_DUMMY is not set CONFIG_BONDING=m # CONFIG_EQUALIZER is not set # CONFIG_TUN is not set # # ARCnet devices # # CONFIG_ARCNET is not set # # PHY device support # # CONFIG_PHYLIB is not set # # Ethernet (10 or 100Mbit) # CONFIG_NET_ETHERNET=y CONFIG_MII=y # CONFIG_HAPPYMEAL is not set # CONFIG_SUNGEM is not set # CONFIG_CASSINI is not set # CONFIG_NET_VENDOR_3COM is not set # # Tulip family network device support # # CONFIG_NET_TULIP is not set # CONFIG_HP100 is not set CONFIG_NET_PCI=y # CONFIG_PCNET32 is not set # CONFIG_AMD8111_ETH is not set # CONFIG_ADAPTEC_STARFIRE is not set # CONFIG_B44 is not set # CONFIG_FORCEDETH is not set # CONFIG_DGRS is not set # CONFIG_EEPRO100 is not set CONFIG_E100=y # CONFIG_FEALNX is not set # CONFIG_NATSEMI is not set # CONFIG_NE2K_PCI is not set # CONFIG_8139CP is not set # CONFIG_8139TOO is not set # CONFIG_SIS900 is not set # CONFIG_EPIC100 is not set # CONFIG_SUNDANCE is not set # CONFIG_TLAN is not set # CONFIG_VIA_RHINE is not set # CONFIG_NET_POCKET is not set # # Ethernet (1000 Mbit) # # CONFIG_ACENIC is not set # CONFIG_DL2K is not set CONFIG_E1000=y # CONFIG_E1000_NAPI is not set # CONFIG_E1000_DISABLE_PACKET_SPLIT is not set # CONFIG_NS83820 is not set # CONFIG_HAMACHI is not set # CONFIG_YELLOWFIN is not set # CONFIG_R8169 is not set # CONFIG_SIS190 is not set # CONFIG_SKGE is not set # CONFIG_SKY2 is not set # CONFIG_SK98LIN is not set # CONFIG_VIA_VELOCITY is not set # CONFIG_TIGON3 is not set # CONFIG_BNX2 is not set # # Ethernet (10000 Mbit) # # CONFIG_CHELSIO_T1 is not set # CONFIG_IXGB is not set CONFIG_S2IO=m # CONFIG_S2IO_NAPI is not set # CONFIG_MYRI10GE is not set # # Token Ring devices # # CONFIG_TR is not set # # Wireless LAN (non-hamradio) # # CONFIG_NET_RADIO is not set # # PCMCIA network device support # # CONFIG_NET_PCMCIA is not set # # Wan interfaces # # CONFIG_WAN is not set # CONFIG_FDDI is not set # CONFIG_HIPPI is not set # CONFIG_PLIP is not set # CONFIG_PPP is not set # CONFIG_SLIP is not set # CONFIG_NET_FC is not set # CONFIG_SHAPER is not set # CONFIG_NETCONSOLE is not set # CONFIG_NETPOLL is not set # CONFIG_NET_POLL_CONTROLLER is not set # # ISDN subsystem # # CONFIG_ISDN is not set # # Telephony Support # # CONFIG_PHONE is not set # # Input device support # CONFIG_INPUT=y # # Userland interfaces # CONFIG_INPUT_MOUSEDEV=y CONFIG_INPUT_MOUSEDEV_PSAUX=y CONFIG_INPUT_MOUSEDEV_SCREEN_X=1280 CONFIG_INPUT_MOUSEDEV_SCREEN_Y=1024 # CONFIG_INPUT_JOYDEV is not set # CONFIG_INPUT_TSDEV is not set # CONFIG_INPUT_EVDEV is not set # CONFIG_INPUT_EVBUG is not set # # Input Device Drivers # CONFIG_INPUT_KEYBOARD=y CONFIG_KEYBOARD_ATKBD=y # CONFIG_KEYBOARD_SUNKBD is not set # CONFIG_KEYBOARD_LKKBD is not set # CONFIG_KEYBOARD_XTKBD is not set # CONFIG_KEYBOARD_NEWTON is not set CONFIG_INPUT_MOUSE=y CONFIG_MOUSE_PS2=y # CONFIG_MOUSE_SERIAL is not set # CONFIG_MOUSE_VSXXXAA is not set # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TOUCHSCREEN is not set CONFIG_INPUT_MISC=y CONFIG_INPUT_PCSPKR=y # CONFIG_INPUT_WISTRON_BTNS is not set CONFIG_INPUT_UINPUT=m # # Hardware I/O ports # CONFIG_SERIO=y CONFIG_SERIO_I8042=y CONFIG_SERIO_SERPORT=y # CONFIG_SERIO_CT82C710 is not set # CONFIG_SERIO_PARKBD is not set CONFIG_SERIO_PCIPS2=m CONFIG_SERIO_LIBPS2=y # CONFIG_SERIO_RAW is not set # CONFIG_GAMEPORT is not set # # Character devices # CONFIG_VT=y CONFIG_VT_CONSOLE=y CONFIG_HW_CONSOLE=y CONFIG_VT_HW_CONSOLE_BINDING=y # CONFIG_SERIAL_NONSTANDARD is not set # # Serial drivers # CONFIG_SERIAL_8250=y # CONFIG_SERIAL_8250_CONSOLE is not set CONFIG_SERIAL_8250_PCI=y # CONFIG_SERIAL_8250_CS is not set CONFIG_SERIAL_8250_NR_UARTS=4 CONFIG_SERIAL_8250_RUNTIME_UARTS=4 # CONFIG_SERIAL_8250_EXTENDED is not set # # Non-8250 serial port support # CONFIG_SERIAL_CORE=y # CONFIG_SERIAL_JSM is not set CONFIG_UNIX98_PTYS=y # CONFIG_LEGACY_PTYS is not set # CONFIG_PRINTER is not set # CONFIG_PPDEV is not set # CONFIG_TIPAR is not set # # IPMI # CONFIG_IPMI_HANDLER=m # CONFIG_IPMI_PANIC_EVENT is not set # CONFIG_IPMI_DEVICE_INTERFACE is not set # CONFIG_IPMI_SI is not set # CONFIG_IPMI_WATCHDOG is not set # CONFIG_IPMI_POWEROFF is not set # # Watchdog Cards # # CONFIG_WATCHDOG is not set # CONFIG_HW_RANDOM is not set # CONFIG_NVRAM is not set # CONFIG_RTC is not set CONFIG_GEN_RTC=y CONFIG_GEN_RTC_X=y # CONFIG_DTLK is not set # CONFIG_R3964 is not set # CONFIG_APPLICOM is not set # CONFIG_SONYPI is not set # # Ftape, the floppy tape device driver # # CONFIG_FTAPE is not set CONFIG_AGP=y # CONFIG_AGP_ALI is not set # CONFIG_AGP_ATI is not set # CONFIG_AGP_AMD is not set # CONFIG_AGP_AMD64 is not set CONFIG_AGP_INTEL=y # CONFIG_AGP_NVIDIA is not set # CONFIG_AGP_SIS is not set # CONFIG_AGP_SWORKS is not set # CONFIG_AGP_VIA is not set # CONFIG_AGP_EFFICEON is not set # CONFIG_DRM is not set # # PCMCIA character devices # # CONFIG_SYNCLINK_CS is not set # CONFIG_CARDMAN_4000 is not set # CONFIG_CARDMAN_4040 is not set # CONFIG_MWAVE is not set # CONFIG_PC8736x_GPIO is not set # CONFIG_NSC_GPIO is not set # CONFIG_CS5535_GPIO is not set # CONFIG_RAW_DRIVER is not set # CONFIG_HPET is not set # CONFIG_HANGCHECK_TIMER is not set # # TPM devices # # CONFIG_TCG_TPM is not set # CONFIG_TELCLOCK is not set # # I2C support # CONFIG_I2C=y CONFIG_I2C_CHARDEV=y # # I2C Algorithms # CONFIG_I2C_ALGOBIT=y # CONFIG_I2C_ALGOPCF is not set CONFIG_I2C_ALGOPCA=m # # I2C Hardware Bus support # # CONFIG_I2C_ALI1535 is not set # CONFIG_I2C_ALI1563 is not set # CONFIG_I2C_ALI15X3 is not set # CONFIG_I2C_AMD756 is not set # CONFIG_I2C_AMD8111 is not set # CONFIG_I2C_I801 is not set # CONFIG_I2C_I810 is not set CONFIG_I2C_PIIX4=m # CONFIG_I2C_NFORCE2 is not set # CONFIG_I2C_OCORES is not set # CONFIG_I2C_PARPORT is not set # CONFIG_I2C_PARPORT_LIGHT is not set # CONFIG_I2C_PROSAVAGE is not set # CONFIG_I2C_SAVAGE4 is not set # CONFIG_SCx200_ACB is not set # CONFIG_I2C_SIS5595 is not set # CONFIG_I2C_SIS630 is not set # CONFIG_I2C_SIS96X is not set # CONFIG_I2C_STUB is not set # CONFIG_I2C_VIA is not set # CONFIG_I2C_VIAPRO is not set # CONFIG_I2C_VOODOO3 is not set CONFIG_I2C_PCA_ISA=m # # Miscellaneous I2C Chip support # # CONFIG_SENSORS_DS1337 is not set # CONFIG_SENSORS_DS1374 is not set # CONFIG_SENSORS_EEPROM is not set # CONFIG_SENSORS_PCF8574 is not set # CONFIG_SENSORS_PCA9539 is not set # CONFIG_SENSORS_PCF8591 is not set # CONFIG_SENSORS_MAX6875 is not set # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set # CONFIG_I2C_DEBUG_CHIP is not set # # SPI support # # CONFIG_SPI is not set # CONFIG_SPI_MASTER is not set # # Dallas's 1-wire bus # # # Hardware Monitoring support # CONFIG_HWMON=y # CONFIG_HWMON_VID is not set # CONFIG_SENSORS_ABITUGURU is not set # CONFIG_SENSORS_ADM1021 is not set # CONFIG_SENSORS_ADM1025 is not set # CONFIG_SENSORS_ADM1026 is not set # CONFIG_SENSORS_ADM1031 is not set # CONFIG_SENSORS_ADM9240 is not set # CONFIG_SENSORS_ASB100 is not set # CONFIG_SENSORS_ATXP1 is not set # CONFIG_SENSORS_DS1621 is not set # CONFIG_SENSORS_F71805F is not set # CONFIG_SENSORS_FSCHER is not set # CONFIG_SENSORS_FSCPOS is not set # CONFIG_SENSORS_GL518SM is not set # CONFIG_SENSORS_GL520SM is not set # CONFIG_SENSORS_IT87 is not set # CONFIG_SENSORS_LM63 is not set # CONFIG_SENSORS_LM75 is not set # CONFIG_SENSORS_LM77 is not set # CONFIG_SENSORS_LM78 is not set # CONFIG_SENSORS_LM80 is not set CONFIG_SENSORS_LM83=m # CONFIG_SENSORS_LM85 is not set # CONFIG_SENSORS_LM87 is not set CONFIG_SENSORS_LM90=m # CONFIG_SENSORS_LM92 is not set # CONFIG_SENSORS_MAX1619 is not set # CONFIG_SENSORS_PC87360 is not set # CONFIG_SENSORS_SIS5595 is not set # CONFIG_SENSORS_SMSC47M1 is not set # CONFIG_SENSORS_SMSC47M192 is not set # CONFIG_SENSORS_SMSC47B397 is not set # CONFIG_SENSORS_VIA686A is not set # CONFIG_SENSORS_VT8231 is not set # CONFIG_SENSORS_W83781D is not set # CONFIG_SENSORS_W83791D is not set # CONFIG_SENSORS_W83792D is not set # CONFIG_SENSORS_W83L785TS is not set # CONFIG_SENSORS_W83627HF is not set # CONFIG_SENSORS_W83627EHF is not set # CONFIG_SENSORS_HDAPS is not set # CONFIG_HWMON_DEBUG_CHIP is not set # # Misc devices # # CONFIG_IBM_ASM is not set # # Multimedia devices # # CONFIG_VIDEO_DEV is not set CONFIG_VIDEO_V4L2=y # # Digital Video Broadcasting Devices # # CONFIG_DVB is not set # CONFIG_USB_DABUSB is not set # # Graphics support # # CONFIG_FIRMWARE_EDID is not set CONFIG_FB=y CONFIG_FB_CFB_FILLRECT=y CONFIG_FB_CFB_COPYAREA=y CONFIG_FB_CFB_IMAGEBLIT=y # CONFIG_FB_MACMODES is not set # CONFIG_FB_BACKLIGHT is not set CONFIG_FB_MODE_HELPERS=y # CONFIG_FB_TILEBLITTING is not set # CONFIG_FB_CIRRUS is not set # CONFIG_FB_PM2 is not set # CONFIG_FB_CYBER2000 is not set # CONFIG_FB_ARC is not set # CONFIG_FB_ASILIANT is not set # CONFIG_FB_IMSTT is not set # CONFIG_FB_VGA16 is not set CONFIG_FB_VESA=y # CONFIG_FB_HGA is not set # CONFIG_FB_S1D13XXX is not set # CONFIG_FB_NVIDIA is not set # CONFIG_FB_RIVA is not set # CONFIG_FB_I810 is not set # CONFIG_FB_INTEL is not set # CONFIG_FB_MATROX is not set # CONFIG_FB_RADEON is not set # CONFIG_FB_ATY128 is not set # CONFIG_FB_ATY is not set # CONFIG_FB_SAVAGE is not set # CONFIG_FB_SIS is not set # CONFIG_FB_NEOMAGIC is not set # CONFIG_FB_KYRO is not set # CONFIG_FB_3DFX is not set # CONFIG_FB_VOODOO1 is not set # CONFIG_FB_CYBLA is not set # CONFIG_FB_TRIDENT is not set # CONFIG_FB_GEODE is not set CONFIG_FB_VIRTUAL=y # # Console display driver support # CONFIG_VGA_CONSOLE=y # CONFIG_VGACON_SOFT_SCROLLBACK is not set CONFIG_VIDEO_SELECT=y CONFIG_DUMMY_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE=y # CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set CONFIG_FONTS=y CONFIG_FONT_8x8=y CONFIG_FONT_8x16=y # CONFIG_FONT_6x11 is not set # CONFIG_FONT_7x14 is not set # CONFIG_FONT_PEARL_8x8 is not set # CONFIG_FONT_ACORN_8x8 is not set # CONFIG_FONT_MINI_4x6 is not set # CONFIG_FONT_SUN8x16 is not set # CONFIG_FONT_SUN12x22 is not set # CONFIG_FONT_10x18 is not set # # Logo configuration # # CONFIG_LOGO is not set # CONFIG_BACKLIGHT_LCD_SUPPORT is not set # # Sound # CONFIG_SOUND=y # # Advanced Linux Sound Architecture # CONFIG_SND=y CONFIG_SND_TIMER=y CONFIG_SND_PCM=y CONFIG_SND_HWDEP=m CONFIG_SND_RAWMIDI=m CONFIG_SND_SEQUENCER=y # CONFIG_SND_SEQ_DUMMY is not set CONFIG_SND_OSSEMUL=y CONFIG_SND_MIXER_OSS=y CONFIG_SND_PCM_OSS=y CONFIG_SND_PCM_OSS_PLUGINS=y CONFIG_SND_SEQUENCER_OSS=y # CONFIG_SND_DYNAMIC_MINORS is not set CONFIG_SND_SUPPORT_OLD_API=y CONFIG_SND_VERBOSE_PROCFS=y # CONFIG_SND_VERBOSE_PRINTK is not set # CONFIG_SND_DEBUG is not set # # Generic devices # CONFIG_SND_AC97_CODEC=y CONFIG_SND_AC97_BUS=y # CONFIG_SND_DUMMY is not set # CONFIG_SND_VIRMIDI is not set # CONFIG_SND_MTPAV is not set # CONFIG_SND_SERIAL_U16550 is not set # CONFIG_SND_MPU401 is not set # # PCI devices # # CONFIG_SND_AD1889 is not set # CONFIG_SND_ALS300 is not set # CONFIG_SND_ALS4000 is not set # CONFIG_SND_ALI5451 is not set # CONFIG_SND_ATIIXP is not set # CONFIG_SND_ATIIXP_MODEM is not set # CONFIG_SND_AU8810 is not set # CONFIG_SND_AU8820 is not set # CONFIG_SND_AU8830 is not set # CONFIG_SND_AZT3328 is not set # CONFIG_SND_BT87X is not set # CONFIG_SND_CA0106 is not set # CONFIG_SND_CMIPCI is not set # CONFIG_SND_CS4281 is not set # CONFIG_SND_CS46XX is not set # CONFIG_SND_CS5535AUDIO is not set # CONFIG_SND_DARLA20 is not set # CONFIG_SND_GINA20 is not set # CONFIG_SND_LAYLA20 is not set # CONFIG_SND_DARLA24 is not set # CONFIG_SND_GINA24 is not set # CONFIG_SND_LAYLA24 is not set # CONFIG_SND_MONA is not set # CONFIG_SND_MIA is not set # CONFIG_SND_ECHO3G is not set # CONFIG_SND_INDIGO is not set # CONFIG_SND_INDIGOIO is not set # CONFIG_SND_INDIGODJ is not set # CONFIG_SND_EMU10K1 is not set # CONFIG_SND_EMU10K1X is not set # CONFIG_SND_ENS1370 is not set # CONFIG_SND_ENS1371 is not set # CONFIG_SND_ES1938 is not set # CONFIG_SND_ES1968 is not set # CONFIG_SND_FM801 is not set # CONFIG_SND_HDA_INTEL is not set # CONFIG_SND_HDSP is not set # CONFIG_SND_HDSPM is not set # CONFIG_SND_ICE1712 is not set # CONFIG_SND_ICE1724 is not set CONFIG_SND_INTEL8X0=y # CONFIG_SND_INTEL8X0M is not set # CONFIG_SND_KORG1212 is not set # CONFIG_SND_MAESTRO3 is not set # CONFIG_SND_MIXART is not set # CONFIG_SND_NM256 is not set # CONFIG_SND_PCXHR is not set # CONFIG_SND_RIPTIDE is not set # CONFIG_SND_RME32 is not set # CONFIG_SND_RME96 is not set # CONFIG_SND_RME9652 is not set # CONFIG_SND_SONICVIBES is not set # CONFIG_SND_TRIDENT is not set # CONFIG_SND_VIA82XX is not set # CONFIG_SND_VIA82XX_MODEM is not set # CONFIG_SND_VX222 is not set # CONFIG_SND_YMFPCI is not set # # USB devices # CONFIG_SND_USB_AUDIO=m CONFIG_SND_USB_USX2Y=m # # PCMCIA devices # # CONFIG_SND_VXPOCKET is not set # CONFIG_SND_PDAUDIOCF is not set # # Open Sound System # CONFIG_SOUND_PRIME=m # CONFIG_OSS_OBSOLETE_DRIVER is not set # CONFIG_SOUND_BT878 is not set # CONFIG_SOUND_ES1371 is not set # CONFIG_SOUND_ICH is not set # CONFIG_SOUND_TRIDENT is not set # CONFIG_SOUND_MSNDCLAS is not set # CONFIG_SOUND_MSNDPIN is not set # CONFIG_SOUND_VIA82CXXX is not set CONFIG_SOUND_OSS=m # CONFIG_SOUND_TRACEINIT is not set # CONFIG_SOUND_DMAP is not set # CONFIG_SOUND_CS4232 is not set # CONFIG_SOUND_SSCAPE is not set # CONFIG_SOUND_VMIDI is not set # CONFIG_SOUND_TRIX is not set # CONFIG_SOUND_MSS is not set # CONFIG_SOUND_MPU401 is not set # CONFIG_SOUND_PAS is not set # CONFIG_SOUND_PSS is not set CONFIG_SOUND_SB=m # CONFIG_SOUND_YM3812 is not set # CONFIG_SOUND_UART6850 is not set # CONFIG_SOUND_AEDSP16 is not set # CONFIG_SOUND_KAHLUA is not set # # USB support # CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB_ARCH_HAS_OHCI=y CONFIG_USB_ARCH_HAS_EHCI=y CONFIG_USB=y CONFIG_USB_DEBUG=y # # Miscellaneous USB options # CONFIG_USB_DEVICEFS=y # CONFIG_USB_BANDWIDTH is not set # CONFIG_USB_DYNAMIC_MINORS is not set # CONFIG_USB_SUSPEND is not set # CONFIG_USB_OTG is not set # # USB Host Controller Drivers # CONFIG_USB_EHCI_HCD=y # CONFIG_USB_EHCI_SPLIT_ISO is not set # CONFIG_USB_EHCI_ROOT_HUB_TT is not set # CONFIG_USB_EHCI_TT_NEWSCHED is not set # CONFIG_USB_ISP116X_HCD is not set CONFIG_USB_OHCI_HCD=y # CONFIG_USB_OHCI_BIG_ENDIAN is not set CONFIG_USB_OHCI_LITTLE_ENDIAN=y CONFIG_USB_UHCI_HCD=y # CONFIG_USB_SL811_HCD is not set # # USB Device Class drivers # # CONFIG_USB_ACM is not set CONFIG_USB_PRINTER=y # # NOTE: USB_STORAGE enables SCSI, and 'SCSI disk support' # # # may also be needed; see USB_STORAGE Help for more information # CONFIG_USB_STORAGE=y CONFIG_USB_STORAGE_DEBUG=y # CONFIG_USB_STORAGE_DATAFAB is not set # CONFIG_USB_STORAGE_FREECOM is not set # CONFIG_USB_STORAGE_ISD200 is not set # CONFIG_USB_STORAGE_DPCM is not set # CONFIG_USB_STORAGE_USBAT is not set # CONFIG_USB_STORAGE_SDDR09 is not set # CONFIG_USB_STORAGE_SDDR55 is not set # CONFIG_USB_STORAGE_JUMPSHOT is not set # CONFIG_USB_STORAGE_ALAUDA is not set # CONFIG_USB_LIBUSUAL is not set # # USB Input Devices # CONFIG_USB_HID=y CONFIG_USB_HIDINPUT=y # CONFIG_USB_HIDINPUT_POWERBOOK is not set # CONFIG_HID_FF is not set # CONFIG_USB_HIDDEV is not set # CONFIG_USB_AIPTEK is not set # CONFIG_USB_WACOM is not set # CONFIG_USB_ACECAD is not set # CONFIG_USB_KBTAB is not set # CONFIG_USB_POWERMATE is not set # CONFIG_USB_TOUCHSCREEN is not set # CONFIG_USB_YEALINK is not set # CONFIG_USB_XPAD is not set # CONFIG_USB_ATI_REMOTE is not set # CONFIG_USB_ATI_REMOTE2 is not set # CONFIG_USB_KEYSPAN_REMOTE is not set # CONFIG_USB_APPLETOUCH is not set # # USB Imaging devices # # CONFIG_USB_MDC800 is not set # CONFIG_USB_MICROTEK is not set # # USB Network Adapters # # CONFIG_USB_CATC is not set # CONFIG_USB_KAWETH is not set # CONFIG_USB_PEGASUS is not set # CONFIG_USB_RTL8150 is not set # CONFIG_USB_USBNET is not set CONFIG_USB_MON=y # # USB port drivers # # CONFIG_USB_USS720 is not set # # USB Serial Converter support # CONFIG_USB_SERIAL=m CONFIG_USB_SERIAL_GENERIC=y # CONFIG_USB_SERIAL_AIRPRIME is not set # CONFIG_USB_SERIAL_ARK3116 is not set # CONFIG_USB_SERIAL_BELKIN is not set # CONFIG_USB_SERIAL_WHITEHEAT is not set # CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set # CONFIG_USB_SERIAL_CP2101 is not set # CONFIG_USB_SERIAL_CYPRESS_M8 is not set # CONFIG_USB_SERIAL_EMPEG is not set # CONFIG_USB_SERIAL_FTDI_SIO is not set # CONFIG_USB_SERIAL_FUNSOFT is not set # CONFIG_USB_SERIAL_VISOR is not set # CONFIG_USB_SERIAL_IPAQ is not set # CONFIG_USB_SERIAL_IR is not set # CONFIG_USB_SERIAL_EDGEPORT is not set # CONFIG_USB_SERIAL_EDGEPORT_TI is not set # CONFIG_USB_SERIAL_GARMIN is not set # CONFIG_USB_SERIAL_IPW is not set # CONFIG_USB_SERIAL_KEYSPAN_PDA is not set # CONFIG_USB_SERIAL_KEYSPAN is not set # CONFIG_USB_SERIAL_KLSI is not set # CONFIG_USB_SERIAL_KOBIL_SCT is not set # CONFIG_USB_SERIAL_MCT_U232 is not set # CONFIG_USB_SERIAL_NAVMAN is not set CONFIG_USB_SERIAL_PL2303=m # CONFIG_USB_SERIAL_HP4X is not set # CONFIG_USB_SERIAL_SAFE is not set # CONFIG_USB_SERIAL_SIERRAWIRELESS is not set # CONFIG_USB_SERIAL_TI is not set # CONFIG_USB_SERIAL_CYBERJACK is not set # CONFIG_USB_SERIAL_XIRCOM is not set # CONFIG_USB_SERIAL_OPTION is not set # CONFIG_USB_SERIAL_OMNINET is not set # # USB Miscellaneous drivers # # CONFIG_USB_EMI62 is not set # CONFIG_USB_EMI26 is not set # CONFIG_USB_AUERSWALD is not set # CONFIG_USB_RIO500 is not set # CONFIG_USB_LEGOTOWER is not set # CONFIG_USB_LCD is not set # CONFIG_USB_LED is not set # CONFIG_USB_CYPRESS_CY7C63 is not set # CONFIG_USB_CYTHERM is not set # CONFIG_USB_PHIDGETKIT is not set # CONFIG_USB_PHIDGETSERVO is not set # CONFIG_USB_IDMOUSE is not set # CONFIG_USB_APPLEDISPLAY is not set # CONFIG_USB_SISUSBVGA is not set # CONFIG_USB_LD is not set # CONFIG_USB_TEST is not set # # USB DSL modem support # # # USB Gadget Support # # CONFIG_USB_GADGET is not set # # MMC/SD Card support # # CONFIG_MMC is not set # # LED devices # # CONFIG_NEW_LEDS is not set # # LED drivers # # # LED Triggers # # # InfiniBand support # # CONFIG_INFINIBAND is not set # # EDAC - error detection and reporting (RAS) (EXPERIMENTAL) # # CONFIG_EDAC is not set # # Real Time Clock # # CONFIG_RTC_CLASS is not set # # DMA Engine support # # CONFIG_DMA_ENGINE is not set # # DMA Clients # # # DMA Devices # # # File systems # CONFIG_EXT2_FS=m # CONFIG_EXT2_FS_XATTR is not set # CONFIG_EXT2_FS_XIP is not set # CONFIG_EXT3_FS is not set CONFIG_REISERFS_FS=y # CONFIG_REISERFS_CHECK is not set # CONFIG_REISERFS_PROC_INFO is not set CONFIG_REISERFS_FS_XATTR=y # CONFIG_REISERFS_FS_POSIX_ACL is not set # CONFIG_REISERFS_FS_SECURITY is not set # CONFIG_JFS_FS is not set # CONFIG_FS_POSIX_ACL is not set # CONFIG_XFS_FS is not set # CONFIG_OCFS2_FS is not set # CONFIG_MINIX_FS is not set CONFIG_ROMFS_FS=y CONFIG_INOTIFY=y CONFIG_INOTIFY_USER=y # CONFIG_QUOTA is not set CONFIG_DNOTIFY=y # CONFIG_AUTOFS_FS is not set # CONFIG_AUTOFS4_FS is not set # CONFIG_FUSE_FS is not set # # CD-ROM/DVD Filesystems # CONFIG_ISO9660_FS=y # CONFIG_JOLIET is not set # CONFIG_ZISOFS is not set CONFIG_UDF_FS=m CONFIG_UDF_NLS=y # # DOS/FAT/NT Filesystems # CONFIG_FAT_FS=y CONFIG_MSDOS_FS=y CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-2" CONFIG_NTFS_FS=m # CONFIG_NTFS_DEBUG is not set # CONFIG_NTFS_RW is not set # # Pseudo filesystems # CONFIG_PROC_FS=y CONFIG_PROC_KCORE=y CONFIG_SYSFS=y CONFIG_TMPFS=y # CONFIG_HUGETLBFS is not set # CONFIG_HUGETLB_PAGE is not set CONFIG_RAMFS=y # CONFIG_CONFIGFS_FS is not set # # Miscellaneous filesystems # # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set # CONFIG_JFFS_FS is not set # CONFIG_JFFS2_FS is not set # CONFIG_CRAMFS is not set # CONFIG_VXFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set # # Network File Systems # # CONFIG_NFS_FS is not set # CONFIG_NFSD is not set # CONFIG_SMB_FS is not set # CONFIG_CIFS is not set # CONFIG_NCP_FS is not set # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set # CONFIG_9P_FS is not set # # Partition Types # # CONFIG_PARTITION_ADVANCED is not set CONFIG_MSDOS_PARTITION=y # # Native Language Support # CONFIG_NLS=y CONFIG_NLS_DEFAULT="iso8859-2" CONFIG_NLS_CODEPAGE_437=m # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set CONFIG_NLS_CODEPAGE_852=y # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set # CONFIG_NLS_CODEPAGE_936 is not set # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set CONFIG_NLS_CODEPAGE_1250=m # CONFIG_NLS_CODEPAGE_1251 is not set # CONFIG_NLS_ASCII is not set CONFIG_NLS_ISO8859_1=m CONFIG_NLS_ISO8859_2=m # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set # CONFIG_NLS_UTF8 is not set # # Instrumentation Support # # CONFIG_PROFILING is not set # CONFIG_KPROBES is not set # # Kernel hacking # CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_PRINTK_TIME=y # CONFIG_MAGIC_SYSRQ is not set CONFIG_UNUSED_SYMBOLS=y CONFIG_DEBUG_KERNEL=y CONFIG_LOG_BUF_SHIFT=14 CONFIG_DETECT_SOFTLOCKUP=y # CONFIG_SCHEDSTATS is not set CONFIG_DEBUG_SLAB=y # CONFIG_DEBUG_SLAB_LEAK is not set CONFIG_DEBUG_PREEMPT=y # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_RT_MUTEX_TESTER is not set # CONFIG_DEBUG_SPINLOCK is not set CONFIG_DEBUG_MUTEXES=y # CONFIG_DEBUG_RWSEMS is not set # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_PROVE_LOCKING is not set # CONFIG_DEBUG_SPINLOCK_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_DEBUG_KOBJECT is not set # CONFIG_DEBUG_HIGHMEM is not set CONFIG_DEBUG_BUGVERBOSE=y # CONFIG_DEBUG_INFO is not set # CONFIG_DEBUG_FS is not set # CONFIG_DEBUG_VM is not set # CONFIG_FRAME_POINTER is not set # CONFIG_UNWIND_INFO is not set CONFIG_FORCED_INLINING=y # CONFIG_RCU_TORTURE_TEST is not set CONFIG_EARLY_PRINTK=y # CONFIG_DEBUG_STACKOVERFLOW is not set # CONFIG_DEBUG_STACK_USAGE is not set # CONFIG_DEBUG_PAGEALLOC is not set # CONFIG_DEBUG_RODATA is not set # CONFIG_4KSTACKS is not set CONFIG_DOUBLEFAULT=y # # Security options # # CONFIG_KEYS is not set # CONFIG_SECURITY is not set # # Cryptographic options # CONFIG_CRYPTO=y # CONFIG_CRYPTO_HMAC is not set # CONFIG_CRYPTO_NULL is not set # CONFIG_CRYPTO_MD4 is not set # CONFIG_CRYPTO_MD5 is not set # CONFIG_CRYPTO_SHA1 is not set # CONFIG_CRYPTO_SHA256 is not set # CONFIG_CRYPTO_SHA512 is not set # CONFIG_CRYPTO_WP512 is not set # CONFIG_CRYPTO_TGR192 is not set # CONFIG_CRYPTO_DES is not set # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_TWOFISH is not set # CONFIG_CRYPTO_SERPENT is not set # CONFIG_CRYPTO_AES is not set # CONFIG_CRYPTO_AES_586 is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set # CONFIG_CRYPTO_TEA is not set # CONFIG_CRYPTO_ARC4 is not set # CONFIG_CRYPTO_KHAZAD is not set # CONFIG_CRYPTO_ANUBIS is not set # CONFIG_CRYPTO_DEFLATE is not set # CONFIG_CRYPTO_MICHAEL_MIC is not set # CONFIG_CRYPTO_CRC32C is not set # CONFIG_CRYPTO_TEST is not set # # Hardware crypto devices # # CONFIG_CRYPTO_DEV_PADLOCK is not set # # Library routines # # CONFIG_CRC_CCITT is not set # CONFIG_CRC16 is not set CONFIG_CRC32=y # CONFIG_LIBCRC32C is not set CONFIG_AUDIT_GENERIC=y CONFIG_PLIST=y CONFIG_GENERIC_HARDIRQS=y CONFIG_GENERIC_IRQ_PROBE=y CONFIG_X86_BIOS_REBOOT=y CONFIG_KTIME_SCALAR=y fstab: /dev/hda5 / reiserfs defaults 1 1 /dev/hda3 /boot reiserfs defaults 1 2 /dev/hda6 /home reiserfs defaults 1 2 /dev/cdrom /mnt/cdrom auto noauto,owner,ro 0 0 /dev/fd0 /mnt/floppy auto noauto,owner 0 0 devpts /dev/pts devpts gid=5,mode=620 0 0 /dev/sda4 /mnt/mp3 vfat noauto,rw,user 0 0 /dev/hda2 /mnt/wymiana vfat auto,rw,user 0 0 proc /proc proc defaults 0 0 lilo.conf: # LILO configuration file # generated by 'liloconfig' # # Start LILO global section boot = /dev/hda message = /boot/boot_message.txt prompt timeout = 1200 change-rules reset vga = 791 other = /dev/hda1 label = Windows table = /dev/hda # Windows bootable partition config ends # Linux bootable partition config begins image = /boot/vmlinuz root = /dev/hda5 label = Linux read-only image = /boot/linux_2.6.18 root = /dev/hda5 label = 2.6.18 # initrd=/boot/initrd.gz read-only # Linux bootable partition config ends fdisk: Disk /dev/hda: 80.0 GB, 80026361856 bytes 240 heads, 63 sectors/track, 10337 cylinders Units = cylinders of 15120 * 512 = 7741440 bytes Device Boot Start End Blocks Id System /dev/hda1 1 2032 15361888+ 7 HPFS/NTFS /dev/hda2 2033 3252 9223168+ c W95 FAT32 (LBA) /dev/hda3 * 3253 3261 68040 83 Linux /dev/hda4 3262 10337 53494560 5 Extended /dev/hda5 3262 4410 8686408+ 83 Linux /dev/hda6 4411 10337 44808088+ 83 Linux Wszystkie dyski mam widziane jako ATA (wylaczona opcja w biosie "native sata" cos w ten desen). W jajko wkompilowame wszystko co wygladalo jak pasujace do konfiguracji. Czytalem ze z laptopami to czesty problem ale rozwiazania istnieja, mnie nie udalo sie z tym poradzic. Czy jedyne rozwiazanie to initrd? Mial ktos taki problem? (czytalem ze tak, ale sprawa nie dotyczyla laptopa lub bylo to na dyskach sata) pozdrawiam ps. probowalem takze: CONFIG_BLK_DEV_IDESCSI=y CONFIG_BLK_DEV_PIIX=y CONFIG_BLK_DEV_SIIMAGE=y CONFIG_CHR_DEV_SG=y i dodatkowo: CONFIG_IDEDMA_PCI_AUTO=y CONFIG_IDEDMA_AUTO=y Ciagle kernel panic... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Sanczo Napisano Październik 7, 2006 Autor Zgłoszenie Share Napisano Październik 7, 2006 Problem rozwiazany, trzeba bylo uzyc min. starego sterownika SCSI. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
kamillys Napisano Październik 7, 2006 Zgłoszenie Share Napisano Październik 7, 2006 Kurde, o codeboksie się nie słyszało? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Sanczo Napisano Październik 8, 2006 Autor Zgłoszenie Share Napisano Październik 8, 2006 Kurde, o codeboksie się nie słyszało? Nie slyszalem, ale skoro jest przydalby sie do niego tag w oknie pisania posta... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Październik 16, 2006 Zgłoszenie Share Napisano Październik 16, 2006 Nie slyszalem, ale skoro jest przydalby sie do niego tag w oknie pisania posta... Tagu nie ma, ale jest "Pomoc BB Code" obok okienka pod emotkami - warto się zapoznać. A tak naprawdę, to karygodne jest cytowanie w całości swojego własnego, kilkudziesięciolinijkowego posta, po to żeby na końcu napisać tylko "problem rozwiązany" Ludzie - myśleć, myśleć. To nie boli... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Sanczo Napisano Październik 16, 2006 Autor Zgłoszenie Share Napisano Październik 16, 2006 Tagu nie ma, ale jest "Pomoc BB Code" obok okienka pod emotkami - warto się zapoznać. A tak naprawdę, to karygodne jest cytowanie w całości swojego własnego, kilkudziesięciolinijkowego posta, po to żeby na końcu napisać tylko "problem rozwiązany" Ludzie - myśleć, myśleć. To nie boli... Przepraszam za smietnik, chcialem dopisac edit na koncu pierwszego posta. Nie sadzilem ze powstanie nowy zawierajacy calego poprzednika. Blad skorygowany. pozdro Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
