Fc6 Kilka Pytań, Drukarka + Zmiana Wersji Kernela
AdwiL
1. Jak zainstalowac drukarke Canon i560 w FC6? Nie mam zielonego pojecia gdzie szukac sterów do serii "I", a na stronie producenta zero sterowników pod linuksa.
2. Sciagnalem sobie pliczek kernel-2.6.18-1-2798.i686.fc6.rpm (czy jakos tak, w kazdym razie najnowszy kernel dla fc6 w i686) i nie wiem jak sie do tego zabrac jak sam próbowalem to tylko sie system wysypal dlatego prosze o jakies instrukcje.
_____________________________________________________
1. Poszukalem znalazlem, link dla potomnych: http://forum.fedora.pl/index.php?act=ST&am...ost&p=73726
Kolejne pytanie. Mam problem, mianowicie cos takiego:
# rpm -Uvh --replacefiles --replacepkgs kernel-2.6.18-1.2798.fc6.i686.rpm
Przygotowywanie... ########################################### [100%]
1:kernel ########################################### [100%]
WARNING: /lib/modules/2.6.18-1.2798.fc6/kernel/arch/x86_64/oprofile/oprofile.ko needs unknown symbol cpu_to_node
WARNING: /lib/modules/2.6.18-1.2798.fc6/kernel/arch/x86_64/oprofile/oprofile.ko needs unknown symbol copy_user_generic
WARNING: /lib/modules/2.6.18-1.2798.fc6/kernel/arch/x86_64/oprofile/oprofile.ko needs unknown symbol profile_pc
WARNING: /lib/modules/2.6.18-1.2798.fc6/kernel/drivers/pci/hotplug/shpchp.ko needs unknown symbol strcpy
WARNING: /lib/modules/2.6.18-1.2798.fc6/kernel/drivers/infiniband/hw/ipath/ib_ipath.ko needs unknown symbol strcat
WARNING: /lib/modules/2.6.18-1.2798.fc6/kernel/drivers/infiniband/hw/ipath/ib_ipath.ko needs unknown symbol mem_section
WARNING: /lib/modules/2.6.18-1.2798.fc6/kernel/drivers/infiniband/hw/ipath/ib_ipath.ko needs unknown symbol strncpy
WARNING: /lib/modules/2.6.18-1.2798.fc6/kernel/drivers/infiniband/hw/ipath/ib_ipath.ko needs unknown symbol __memcpy
WARNING: /lib/modules/2.6.18-1.2798.fc6/kernel/drivers/infiniband/hw/ipath/ipath_core.ko needs unknown symbol find_first_bit
WARNING: /lib/modules/2.6.18-1.2798.fc6/kernel/drivers/infiniband/hw/ipath/ipath_core.ko needs unknown symbol strcat
WARNING: /lib/modules/2.6.18-1.2798.fc6/kernel/drivers/infiniband/hw/ipath/ipath_core.ko needs unknown symbol mem_section
WARNING: /lib/modules/2.6.18-1.2798.fc6/kernel/drivers/infiniband/hw/ipath/ipath_core.ko needs unknown symbol strncpy
Jak temu zapobiec i o co chodzi? Z góry dziekuje za pomoc ;D
EDIT:
Dodam, ze po reboot wywala sie przy bootowaniu kernela, wiec na razie nie chce restartowac systemu :D
Kolejne pytanie. Mam problem, mianowicie coś takiego:
Jak temu zapobiec i o co chodzi? Z góry dziękuję za pomoc ;D
Dlaczego nie korzystasz z yuma? Znacznie prościej niż z RPM.
A przede wszystkim NIGDY-PRZENIGDY nie instaluj kernela z opcją "-U". Zawsze z opcją "-i". Pomyśl co się stanie jeśli nowy kernel nie będzie działał? Jeśli zainstalujesz przez przypadek - przy instalce z RPM b.prwadopodobne - niewłaściwą wersję? Jak wtedy odpalisz system? Coś czuję że masz właśnie do czynienia z takim przypadkiem.
Uruchom yum install kernel.
tylko, ze w yum extenderze nie ma 2.6.18-1.2798.i686.fc6 tylko jest z przedrostkiem xen, który wedlug softpedii jest jakis dziwny. A jaka jest wlasciwa wersja kernela dla Fedora Core 6, 64bit? Pozdrawiam
edit:
[root@localhost ~]# yum install kernel
Loading "installonlyn" plugin
Setting up Install Process
Setting up repositories
updates 100% |=========================| 1.2 kB 00:00
core 100% |=========================| 1.1 kB 00:00
extras 100% |=========================| 1.1 kB 00:00
Nothing to do
Zalezy mi na tym zeby miec kernel w wersji i686. pozdrawiam
edit 2. Instalacja z parametrem -i przebiegla tak:
[root@localhost Kernel 2.6.18-2798 i686 FedoraCore6]# rpm -i --replacefiles --replacepkgs kernel-2.6.18-1.2798.fc6.i686.rpm
Pewnie 64-bitowa ;) Czyli raczej cos z x86_64 w nazwie a nie i686.
Jaki masz procesor?
Co pokazuje wyjscie polecenia rpm -qa kernel oraz uname -a?
Pamietasz jaka wersje kernela miales przed tym nieszczesnym updatem?
[Edit]Aha, nie uzywaj raczej yumexa. Lepiej yum z konsoli - dlaczego? poszukaj wyjasnienia na forum.
Polecenie
podawal gajownik w innym temacie jako sposob na to, ze anaconda w FC6(i386) instaluje i586 na maszynach i686 i dlatego jest blad ale to sie dzieje po instalacji i386 nie wiem skad kolega wpadl na pomysl zeby instalowac i686 na x86_64 to nie jest ta sama architektura a nawet powiem wiecej to sa architektury zupelnie od siebie rozne
To jest ten jeden z wyjątków, kiedy można skorzystać z opcji -U. Jest i tak zły kernel zainstalowany, a w aktualizacjach nie ma jeszcze nowszego.
Przeinstaluje działający w trybie rescue ;-)
Nie pomoże. Yum nie zmienia architektury zainstalowanych pakietów (apt robił coś takiego i kończyło sie nawet padem systemu).
Polecenie
Nie tylko ja - później znalazłem podobne rozwiązanie na wiki fedoraproject → http://fedoraproject.org/wiki/Bugs/FC6Common
piszecie żebym nie używał yum extendera, ale to nim właśnie odzyskałem prawidłowy kernel. Usunąłem ten i686 i razem z nim usunąłem xserver ;P. Teraz mam tylko tryb bez żadnej grafiki (piszę z winzgrozy) i jak wpisać yumowi żeby mi xserver zainstalował?
Hmm... miałem wrażenie, że "dzięki" rpm -Uvh ... AdwiL zupdatował sobie właśnie 64-bitowego kernela na ściągniętą skądś tam wersję i686.
Ja szczerze mówiąc w takiej sytuacji zaryzykowałbym już bardziej kozacką operację: usunięcie (np. rpm -e --nodeps ) wszystkich kerneli a potem bez restartu install nowego.
@AdwiL yum groupinstall "X Window System"
(hehe, będzie złośliwość :P) Albo jakoś tam sobie w yumeksie poradź :rolleyes:
