Popełniłem Fedore I Problem...
Illuminati
oka po kolei:
[root@localhost ~]# fdisk -l
Disk /dev/sda: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders
/dev/sda1 * 1 2132 17125258+ 83 Linux
/dev/sda2 2388 5437 24499125 83 Linux
/dev/sda3 5438 14593 73545570 5 Extended
/dev/sda4 2133 2387 2048287+ 82 Linux swap / Solaris
/dev/sda5 8488 14593 49046413+ 83 Linux
/dev/sda6 5438 8487 24499062 b W95 FAT32
Partition table entries are not in disk order
# grub.conf generated by anaconda
# Note that you do not have to rerun grub after making changes to this file
# NOTICE:  You do not have a /boot partition.  This means that
#          all kernel and initrd paths are relative to /, eg.
#          root (hd0,1)
#          kernel /boot/vmlinuz-version ro root=/dev/sda2
#          initrd /boot/initrd-version.img
#boot=/dev/sda
default=0
timeout=5
splashimage=(hd0,1)/boot/grub/splash.xpm.gz
hiddenmenu
title Fedora Core (2.6.18-1.2798.fc6xen)
root (hd0,1)
kernel /boot/xen.gz-2.6.18-1.2798.fc6
module /boot/vmlinuz-2.6.18-1.2798.fc6xen ro root=LABEL=/ rhgb quiet
module /boot/initrd-2.6.18-1.2798.fc6xen.img
title Ubuntu
rootnoverify (hd0,0)
chainloader +1
Troche mnie nie dziwi, ze sie Ubuntu nie chce podniesc ;)
title Ubuntu
chainloader +1
zmien na
title Ubuntu
root (hd0,0)
kernel ...tu_musisz_wpisac_sciezke_do_kernela_...
module ..._to_tez_musisz_zmienic_
module ..._i_to_tez_do_zmiany_...
Te 3 wiersze powinny wygladac dla Ubuntu podobnie jak dla Fedory...
Najlatwiej bedzie Ci chyba podmontowac na chwile /dev/sda1 i sprawdzic w oryginalnym /boot/grub.conf jak to wszystko wygladalo.
Powodzenia
zrobilem tak:
#          root (hd0,1)
#boot=/dev/sda
default=0
timeout=5
title Fedora Core (2.6.18-1.2849.fc6xen)
root (hd0,1)
kernel /boot/xen.gz-2.6.18-1.2849.fc6
module /boot/vmlinuz-2.6.18-1.2849.fc6xen ro root=LABEL=/ rhgb quiet
module /boot/initrd-2.6.18-1.2849.fc6xen.img
root (hd0,1)
title Ubuntu, kernel 2.4.27-2-k7-smp
root		(hd0,0)
kernel		/boot/vmlinuz-2.4.27-2-k7-smp root=UUID=3a553692-7a8c-4793-9496-8ad760b143cf ro quiet splash
initrd		/boot/initrd.img-2.4.27-2-k7-smp
quiet
boot
i kicha - kernel panikuje...
wiec moze tak...\
to jest mój grub z Ubuntu:
# menu.lst - See: grub(8), info grub, update-grub(8)
#            grub-install(8), grub-floppy(8),
#            grub-md5-crypt, /usr/share/doc/grub
#            and /usr/share/doc/grub-doc/.
#splashimage (hd0,1)/boot/grub/images/ubuntu.xpm.gz
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not change this entry to 'saved' or your
# array will desync and will not let you boot your system.
default		0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout		3
## hiddenmenu
# Hides the menu by default (press ESC to see the menu)
hiddenmenu
# Pretty colours
#color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line)  and entries protected by the
# command 'lock'
# e.g. password topsecret
#      password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title		Windows 95/98/NT/2000
# root		(hd0,0)
# makeactive
# chainloader	+1
# title		Linux
# root		(hd0,1)
# kernel	/vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
##      kopt_2_6_8=root=/dev/hdc1 ro
##      kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=UUID=3a553692-7a8c-4793-9496-8ad760b143cf ro
# kopt_2_6=root=/dev/sda1 ro
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd0,0)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
##      alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
##      lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=quiet splash
## should update-grub lock old automagic boot options
## e.g. lockold=false
##      lockold=true
# lockold=false
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
##      altoptions=(recovery) single
# altoptions=(recovery mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
##      howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
##      memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## ## End Default Options ##
title		Ubuntu, kernel 2.6.17-10-generic
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.17-10-generic root=/dev/sda1 ro quiet splash
initrd		/boot/initrd.img-2.6.17-10-generic
quiet
savedefault
boot
title		Ubuntu, kernel 2.6.17-10-generic (recovery mode)
root		(hd0,0)
kernel		/boot/vmlinuz-2.6.17-10-generic root=/dev/sda1 ro single
boot
root		(hd0,0)
quiet
savedefault
boot
title		Ubuntu, kernel 2.4.27-2-k7-smp (recovery mode)
root		(hd0,0)
kernel		/boot/vmlinuz-2.4.27-2-k7-smp root=UUID=3a553692-7a8c-4793-9496-8ad760b143cf ro single
boot
root		(hd0,0)
kernel		/boot/vmlinuz-2.4.27-2-k7 root=UUID=3a553692-7a8c-4793-9496-8ad760b143cf ro quiet splash
quiet
savedefault
boot
title		Ubuntu, kernel 2.4.27-2-k7 (recovery mode)
root		(hd0,0)
kernel		/boot/vmlinuz-2.4.27-2-k7 root=UUID=3a553692-7a8c-4793-9496-8ad760b143cf ro single
boot
title		Ubuntu, memtest86+
root		(hd0,0)
kernel		/boot/memtest86+.bin
quiet
boot
### END DEBIAN AUTOMAGIC KERNELS LIST
ten z fedory jest wyzej...
Jak powinienem zmodyfikowac gruba z Fedory ??
root        (hd0,0)
quiet
savedefault
boot
Kawałek powyżej wstaw w miejsce tego:
root        (hd0,0)
quiet
boot
Dzięki WalDo śmiga jak rakieta :D
Duży browar za to ;)
Zasługa niewielka. Zrobiłem tylko Copy-Paste z tego co napisałeś. Wystarczy popatrzeć i porównać ;) W szczególności do kernela jako parametr "root=..." powinno być przekazywane urządzenie a nie jakieś dziwne coś. Skad Ty to wziąłeś? ;)
A browarka wypije na Twój koszt, bo właśnie się za niedługo wybieram z kolegami po pracy na jedno ;)
