Vmware Player - Instalacja :/
Kriss
Mam problem, nie potrafię sobie poradzić z konfiguracją Vmware Player'a. Siedzę nad już drugi dzień, próbowałem z wersją Server ale było to samo. Popatrzcie sami:
[root@localhost ~]# vmware-config.pl
Making sure services for VMware Player are stopped.
Stopping VMware services:
  Virtual machine monitor                                 [  OK  ]
Configuring fallback GTK+ 2.4 libraries.
In which directory do you want to install the mime type icons?
[/usr/share/icons] /usr/share/icons
What directory contains your desktop menu entry files? These files have a
.desktop file extension. [/usr/share/applications] /usr/share/applications
In which directory do you want to install the application's icon?
[/usr/share/pixmaps] /usr/share/pixmaps]
The path "/usr/share/pixmaps]" does not exist currently. This program is going
to create it, including needed parent directories. Is this what you want?
[yes] no
Trying to find a suitable vmmon module for your running kernel.
None of the pre-built vmmon modules for VMware Player is suitable for your
running kernel.  Do you want this program to try to build the vmmon module for
your system (you need to have a C compiler installed on your system)? [yes] yes
Using compiler "/usr/bin/gcc". Use environment variable CC to override.
What is the location of the directory of C header files that match your running
kernel? [/usr/src/kernels/2.6.18-1.2868.fc6-i586/include] /usr/src/kernels/2.6.18-1.2868.fc6-i586/include
Extracting the sources of the vmmon module.
Building the vmmon module.
Building for VMware Player 1.0.2 or 1.0.3 or VMware Workstation 5.5.2 or 5.5.3.
Using 2.6.x kernel build system.
make: Wejście do katalogu `/tmp/vmware-config3/vmmon-only'
make -C /usr/src/kernels/2.6.18-1.2868.fc6-i586/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: Wejście do katalogu `/usr/src/kernels/2.6.18-1.2868.fc6-i586'
 CC [M]  /tmp/vmware-config3/vmmon-only/linux/driver.o
 CC [M]  /tmp/vmware-config3/vmmon-only/linux/hostif.o
 CC [M]  /tmp/vmware-config3/vmmon-only/common/cpuid.o
 CC [M]  /tmp/vmware-config3/vmmon-only/common/hash.o
 CC [M]  /tmp/vmware-config3/vmmon-only/common/memtrack.o
 CC [M]  /tmp/vmware-config3/vmmon-only/common/phystrack.o
 CC [M]  /tmp/vmware-config3/vmmon-only/common/task.o
cc1plus: warning: command line option "-Werror-implicit-function-declaration" is valid for C/ObjC but not for C++
cc1plus: warning: command line option "-Wdeclaration-after-statement" is valid for C/ObjC but not for C++
cc1plus: warning: command line option "-Wno-pointer-sign" is valid for C/ObjC but not for C++
cc1plus: warning: command line option "-Wstrict-prototypes" is valid for Ada/C/ObjC but not for C++
cc1plus: warning: command line option "-ffreestanding" is valid for C/ObjC but not for C++
/tmp/vmware-config3/vmmon-only/common/task_compat.h: In function ‘int Vmx86_RunVM(VMCrossPage*, VMDriver*) [with VMCrossPage = VMCrossPageV321]’:
/tmp/vmware-config3/vmmon-only/common/task_compat.h:1522: warning: ‘sysenterState$rsp’ is used uninitialized in this function
/tmp/vmware-config3/vmmon-only/common/task_compat.h:1523: warning: ‘sysenterState$rip’ is used uninitialized in this function
/tmp/vmware-config3/vmmon-only/common/task_compat.h:2073: warning: ‘sysenterState$validEIP’ may be used uninitialized in this function
/tmp/vmware-config3/vmmon-only/common/task_compat.h:2073: warning: ‘sysenterState$cs’ may be used uninitialized in this function
/tmp/vmware-config3/vmmon-only/common/task_compat.h: In function ‘int Vmx86_RunVM(VMCrossPage*, VMDriver*) [with VMCrossPage = VMCrossPageV3]’:
/tmp/vmware-config3/vmmon-only/common/task_compat.h: In function ‘int Vmx86_RunVM(VMCrossPage*, VMDriver*) [with VMCrossPage = VMCrossPageGSX1]’:
/tmp/vmware-config3/vmmon-only/common/task_compat.h: In function ‘int Vmx86_RunVM(VMCrossPage*, VMDriver*) [with VMCrossPage = VMCrossPageV2]’:
/tmp/vmware-config3/vmmon-only/common/task_compat.h: In function ‘int Vmx86_RunVM_V4(VMDriver*, Vcpuid) [with VMCrossPage = VMCrossPageV4]’:
/tmp/vmware-config3/vmmon-only/common/task_compat.h:2073: warning: ‘sysenterState$rsp’ may be used uninitialized in this function
/tmp/vmware-config3/vmmon-only/common/task_compat.h:2073: warning: ‘sysenterState$rip’ may be used uninitialized in this function
/tmp/vmware-config3/vmmon-only/common/task_compat.h: In function ‘int Vmx86_RunVM(VMDriver*, Vcpuid)’:
/tmp/vmware-config3/vmmon-only/common/task_compat.h: In function ‘void Task_Switch_V45(VMDriver*, Vcpuid)’:
/tmp/vmware-config3/vmmon-only/common/task_compat.h:1713: warning: ‘sysenterState$validEIP’ may be used uninitialized in this function
/tmp/vmware-config3/vmmon-only/common/task_compat.h:1713: warning: ‘sysenterState$cs’ may be used uninitialized in this function
/tmp/vmware-config3/vmmon-only/common/task_compat.h:1713: warning: ‘sysenterState$rsp’ may be used uninitialized in this function
/tmp/vmware-config3/vmmon-only/common/task_compat.h:1713: warning: ‘sysenterState$rip’ may be used uninitialized in this function
 CC [M]  /tmp/vmware-config3/vmmon-only/common/vmx86.o
 CC [M]  /tmp/vmware-config3/vmmon-only/vmcore/compat.o
 CC [M]  /tmp/vmware-config3/vmmon-only/vmcore/moduleloop.o
 LD [M]  /tmp/vmware-config3/vmmon-only/vmmon.o
 Building modules, stage 2.
 MODPOST
 CC      /tmp/vmware-config3/vmmon-only/vmmon.mod.o
 LD [M]  /tmp/vmware-config3/vmmon-only/vmmon.ko
make[1]: Opuszczenie katalogu `/usr/src/kernels/2.6.18-1.2868.fc6-i586'
cp -f vmmon.ko ./../vmmon.o
make: Opuszczenie katalogu `/tmp/vmware-config3/vmmon-only'
Unable to make a vmmon module that can be loaded in the running kernel:
insmod: error inserting '/tmp/vmware-config3/vmmon.o': -1 Invalid module format
There is probably a slight difference in the kernel configuration between the
set of C header files you specified and your running kernel.  You may want to
rebuild a kernel based on that directory, or specify another directory.
For more information on how to troubleshoot module-related problems, please
visit our Web site at "http://www.vmware.com/download/modules/modules.html" and
"http://www.vmware.com/support/reference/linux/prebuilt_modules_linux.html".
Execution aborted.
POMÓRZCIE!!
Gość
