Jasiek_M Napisano Styczeń 5, 2007 Zgłoszenie Share Napisano Styczeń 5, 2007 Witam! Chcialem zamontowac sobie partycje NFTS, postepowalem zgodnie z tym linkiem: http://poradnik.fedorapl.org/#partycje . Niestety nic z tego nie wyszlo, ale poniewaz zeby sie tego dowiedziec musialem zrestartowac sytem stracilem to co wpisalem w terminalu, wiec zeby wam pokazac co i jak robilem zrobilem to ponownie, oto teminal: [Jasiek@localhost ~]$ su - Hasło: [root@localhost ~]# yum install kmod-ntfs Loading "installonlyn" plugin Setting up Install Process Setting up repositories livna 100% |=========================| 1.1 kB 00:00 core 100% |=========================| 1.1 kB 00:00 updates 100% |=========================| 1.2 kB 00:00 extras 100% |=========================| 1.1 kB 00:00 Reading repository metadata in from local files primary.xml.gz 100% |=========================| 1.7 MB 00:44 ################################################## 5384/5384 Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Downloading header for kmod-ntfs to pack into transaction set. kmod-ntfs-2.1.27-2.2.6.18 100% |=========================| 6.3 kB 00:00 ---> Package kmod-ntfs.i686 0:2.1.27-2.2.6.18_1.2869.fc6 set to be installed --> Running transaction check --> Processing Dependency: kernel-i686 = 2.6.18-1.2869.fc6 for package: kmod-ntfs --> Processing Dependency: ntfs-kmod-common >= 2.1.27 for package: kmod-ntfs --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Downloading header for ntfs-kmod-common to pack into transaction set. ntfs-kmod-common-2.1.27-2 100% |=========================| 4.9 kB 00:00 ---> Package ntfs-kmod-common.noarch 0:2.1.27-2.lvn6 set to be updated ---> Package kernel.i686 0:2.6.18-1.2869.fc6 set to be installed --> Running transaction check --> Populating transaction set with selected packages. Please wait. ---> Package kernel.i586 0:2.6.18-1.2868.fc6 set to be erased --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: kmod-ntfs i686 2.1.27-2.2.6.18_1.2869.fc6 livna 107 k Removing: kernel i586 2.6.18-1.2868.fc6 installed 43 M Installing for dependencies: kernel i686 2.6.18-1.2869.fc6 updates 16 M ntfs-kmod-common noarch 2.1.27-2.lvn6 livna 54 k Transaction Summary ============================================================================= Install 3 Package(s) Update 0 Package(s) Remove 1 Package(s) Total download size: 16 M Is this ok [y/N]: y Downloading Packages: (1/2): ntfs-kmod-common-2 100% |=========================| 54 kB 00:02 (2/2): kmod-ntfs-2.1.27-2 100% |=========================| 107 kB 00:02 Running Transaction Test Finished Transaction Test Transaction Check Error: package kernel-2.6.18-1.2869.fc6 is already installed file /boot/System.map-2.6.18-1.2869.fc6 from install of kernel-2.6.18-1.2869.fc6 conflicts with file from package kernel-2.6.18-1.2869.fc6 file /boot/config-2.6.18-1.2869.fc6 from install of kernel-2.6.18-1.2869.fc6 conflicts with file from package kernel-2.6.18-1.2869.fc6 file /boot/symvers-2.6.18-1.2869.fc6.gz from install of kernel-2.6.18-1.2869.fc6 conflicts with file from package kernel-2.6.18-1.2869.fc6 file /boot/vmlinuz-2.6.18-1.2869.fc6 from install of kernel-2.6.18-1.2869.fc6 conflicts with file from package kernel-2.6.18-1.2869.fc6 [root@localhost ~]# fdisk -l Disk /dev/hda: 80.0 GB, 80060424192 bytes 255 heads, 63 sectors/track, 9733 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/hda1 * 1 1275 10241406 7 HPFS/NTFS /dev/hda2 1276 1657 3068415 7 HPFS/NTFS /dev/hda3 1658 9199 60581115 f W95 Ext'd (LBA) /dev/hda4 9200 9394 1566337+ 82 Linux swap / Solaris /dev/hda5 1658 7776 49150836 7 HPFS/NTFS /dev/hda6 7777 9199 11430216 83 Linux [root@localhost ~]# mkdir /mnt/hda1 mkdir: nie można utworzyć katalogu `/mnt/hda1': Plik istnieje [root@localhost ~]# mkdir /mnt/hda2 mkdir: nie można utworzyć katalogu `/mnt/hda2': Plik istnieje [root@localhost ~]# mkdir /mnt/hda5 mkdir: nie można utworzyć katalogu `/mnt/hda5': Plik istnieje [root@localhost ~]# mcedit /etc/fstab a oto plik wyedytowany: A oto blad co mi wyskakuje jak chce wejsc do windowsowego dysku(jest on widoczny): Co robie zle, i jak moge to zrobic? Pozdrawiam! Jasiek Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Karlik Napisano Styczeń 5, 2007 Zgłoszenie Share Napisano Styczeń 5, 2007 Poszukaj najpierw sobie na forum jak zmienic kernela z i586 na i686, a potem jak juz poprawisz to musisz jeszcze uruchomic kmod EDIT: Aha nie wklejaj tu bezposrednio tak duzych obrazków (najlepiej w ogóle), tylko podawaj linka Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Jasiek_M Napisano Styczeń 5, 2007 Autor Zgłoszenie Share Napisano Styczeń 5, 2007 Poszukaj najpierw sobie na forum jak zmienić kernela z i586 na i686, a potem jak już poprawisz to musisz jeszcze uruchomić kmod A jak to zrobic? Bo przeszukalem i nigdzie nei bylo:/ bylo byz mienic pakiety a nie caly kernel:/ i zobacz: [Jasiek@localhost ~]$ su - Hasło: [root@localhost ~]# uname -a Linux localhost.localdomain 2.6.18-1.2869.fc6 #1 SMP Wed Dec 20 14:51:46 EST 2006 [b]i686[/b] i686 i386 GNU/Linux [root@localhost ~]# Tak jakbym juz mial:/ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Karlik Napisano Styczeń 5, 2007 Zgłoszenie Share Napisano Styczeń 5, 2007 Moze cos Ci sie przy okazji zainstalowalo, ale: Removing: kernel i586 2.6.18-1.2868.fc6 installed 43 M jednoznacznie wskazuje na i586, dlatego Ci wywala bledy. A ak swoja droga: który kernel masz aktualnie uruchomiony? EDIT: ja pracujesz na i686 aktualnie to mozesz sprobowac usunac tamten przez yum remove Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
bsm Napisano Styczeń 20, 2007 Zgłoszenie Share Napisano Styczeń 20, 2007 jesli moge sie wtracic, to u mnie jest taki problem : [root@bsmGG2877412FC6Linux ~]# fdisk -l Disk /dev/hda: 40.0 GB, 40020664320 bytes 255 heads, 63 sectors/track, 4865 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/hda1 * 665 4865 33744501 7 HPFS/NTFS /dev/hda2 2 664 5325547+ 5 Extended /dev/hda5 2 511 4096543+ 83 Linux /dev/hda6 512 664 1228941 82 Linux swap / Solaris Partition table entries are not in disk order Disk /dev/hdb: 40.0 GB, 40020664320 bytes 255 heads, 63 sectors/track, 4865 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/hdb1 * 1 1275 10241406 c W95 FAT32 (LBA) /dev/hdb2 1276 4865 28836675 f W95 Ext'd (LBA) /dev/hdb5 1276 4865 28836643+ 7 HPFS/NTFS [root@bsmGG2877412FC6Linux ~]# mount /dev/hda1 /mnt/rozrywka mount: unknown filesystem type 'ntfs' [root@bsmGG2877412FC6Linux ~]# yum install kmod-ntfs Loading "installonlyn" plugin Setting up Install Process Setting up repositories core 100% |=========================| 1.1 kB 00:00 updates 100% |=========================| 1.2 kB 00:00 extras 100% |=========================| 1.1 kB 00:00 Reading repository metadata in from local files primary.xml.gz 100% |=========================| 1.7 MB 00:18 extras : ################################################## 5543/5543 Parsing package install arguments No Match for argument: kmod-ntfs Nothing to do [root@bsmGG2877412FC6Linux ~]# mount /dev/hda1 /mnt/rozrywka mount: unknown filesystem type 'ntfs' [root@bsmGG2877412FC6Linux ~]# oczywiscie zaczynam dopiero z linuxem doinstalowalem : NTFS GNOME virtual filesystem (VFS) module i tez nic, tak samo j/w Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Styczeń 20, 2007 Zgłoszenie Share Napisano Styczeń 20, 2007 Pokaz rpm -qa --queryformat="%{n}-%{v}-%{r}.%{arch}.rpm\n" | grep kernel oraz rpm -qa | grep kmod | sort to cos wymyslimy Pozdro Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
bsm Napisano Styczeń 24, 2007 Zgłoszenie Share Napisano Styczeń 24, 2007 czy o to chodzilo ?? [root@localhost ~]# rpm -qa --queryformat="%{n}-%{v}-%{r}.%{arch}.rpm\n" | grep kernel kernel-2.6.18-1.2798.fc6.i586.rpm kernel-headers-2.6.18-1.2798.fc6.i386.rpm [root@localhost ~]# rpm -qa | grep kmod | sort [root@localhost ~]# Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Styczeń 24, 2007 Zgłoszenie Share Napisano Styczeń 24, 2007 O to: [root@localhost ~]# rpm -qa --queryformat="%{n}-%{v}-%{r}.%{arch}.rpm\n" | grep kernel kernel-2.6.18-1.2798.fc6.i586.rpm Zanim zaczniesz dalsza walke z ntfsem podmien kernel na wersje i686 - wskazowki jak tego dokonac znajdziesz bez problemu na http://fedoraproject.org/wiki/ a takze tu na forum (wrzuc w szukajke i586). Powodzenia Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kosi#1 Napisano Styczeń 24, 2007 Zgłoszenie Share Napisano Styczeń 24, 2007 wybaczcie, że spytam... ale czemu w fstab jest w 7, 8 i 9 linijce: /dev/hdaX?? Jeżeli tam masz to zapisane w FSTAB to się nie dziwie, że coś nie działa... http://img442.imageshack.us/img442/848/zrzutekranubw4.png Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Styczeń 24, 2007 Zgłoszenie Share Napisano Styczeń 24, 2007 wybaczcie, ze spytam...Wybaczamy Tyle tylko, ze tamto byl problem Jaska_M, a teraz walczymy z ntfsem u bsma A tak powaznie - podmiana kernela na poprawna wersje, czyli i686 to pierwszy krok. Pozniej mozna zaczac przygladac sie obrazkom i dzialac... Pozdro Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
bsm Napisano Styczeń 29, 2007 Zgłoszenie Share Napisano Styczeń 29, 2007 a wbilem sie na hama chama :::: zobaczymy ??!! [root@localhost ~]# mount /dev/hda1 /mnt/Rozrywka2 WARNING: Old FUSE kernel module detected. This means, some driver features are not available (swap file on NTFS, boot from NTFS by LILO), and unmount is not safe unless you make sure the ntfs-3g process naturally terminates after calling 'umount'. The safe FUSE kernel driver is included in the official Linux kernels since version 2.6.20-rc1, or in the FUSE 2.6 software package. Please see the next page for more help: http://www.ntfs-3g.org/support.html#fuse26 [root@localhost ~]# mount /dev/hda1 /mnt/Rozrywka2 ntfs-3g Usage: mount -V : print version mount -h : print this help mount : list mounted filesystems mount -l : idem, including volume labels So far the informational part. Next the mounting. The command is `mount [-t fstype] something somewhere'. Details found in /etc/fstab may be omitted. mount -a [-t|-O] ... : mount all stuff from /etc/fstab mount device : mount device at the known place mount directory : mount known device here mount -t type dev dir : ordinary mount command Note that one does not really mount a device, one mounts a filesystem (of the given type) found on the device. One can also mount an already visible directory tree elsewhere: mount --bind olddir newdir or move a subtree: mount --move olddir newdir One can change the type of mount containing the directory dir: mount --make-shared dir mount --make-slave dir mount --make-private dir mount --make-unbindable dir One can change the type of all the mounts in a mount subtree containing the directory dir: mount --make-rshared dir mount --make-rslave dir mount --make-rprivate dir mount --make-runbindable dir A device can be given by name, say /dev/hda1 or /dev/cdrom, or by label, using -L label or by uuid, using -U uuid . Other options: [-nfFrsvw] [-o options] [-p passwdfd]. For many more details, say man 8 mount . [root@localhost ~]# poszlo http://www.dorianek.prv.pl/ntfs.png TYLKO TAK JAK WYZEJ : NAJPIERW SAMO MONTOWANIE BEZ "NTFS-3G" (MUSI WYSKOCZYC OSTRZEZENIE) A W KOLEJNEJ PROBIE DODAJEMY WLASNIE TE NIESZCZESNE "NTFS-3G". i juz bez problemu kopiujemy,wycinamy,wklejamy, cuda na kiju. wszystkim serdeczne dzieki. przelaczam sie miedzy userem i root'em bez umount'u i nic sie nie dzieje ale przed wylaczeniem kompa odmontowuje : umount /dev/hda1 umount /dev/hdb5 i to wystarcza. Pozdrowionka. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
tflis Napisano Marzec 11, 2007 Zgłoszenie Share Napisano Marzec 11, 2007 To moze mi ktos pomoze. Zabawe z linuxem dopiero zaczynam wiec wybaczcie z gory. U mnie to wyglada tak. [root@linux-zen8 mnt]# fdisk -l Disk /dev/sda: 250.0 GB, 250059350016 bytes 255 heads, 63 sectors/track, 30401 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sda1 * 1 3824 30716248+ 7 HPFS/NTFS /dev/sda2 3825 30401 213479752+ f W95 Ext'd (LBA) /dev/sda5 3825 7648 30716248+ 7 HPFS/NTFS /dev/sda6 7649 14022 51199123+ 7 HPFS/NTFS /dev/sda7 14023 17839 30660021 7 HPFS/NTFS /dev/sda8 17840 20396 20539071 b W95 FAT32 /dev/sda9 20397 26770 51199123+ 7 HPFS/NTFS /dev/sda10 26771 30173 27334566 83 Linux /dev/sda11 30174 30401 1831378+ 82 Linux swap / Solaris [root@linux-zen8 mnt]# yum install kmod-ntfs Setting up Install Process Setting up repositories http://mirror.netglobalis.net/pub/fedora/c...data/repomd.xml : [Errno 4] IOError: HTTP Error 404: Date: Sat, 10 Mar 2007 23:36:56 GMT Server: NOYB Content-Length: 318 Connection: close Content-Type: text/html; charset=iso-8859-1 Trying other mirror. updates-released 100% |=========================| 951 B 00:00 extras 100% |=========================| 1.1 kB 00:00 base 100% |=========================| 1.1 kB 00:00 Reading repository metadata in from local files primary.xml.gz 100% |=========================| 299 kB 00:01 updates-re: ################################################## 782/782 Added 782 new packages, deleted 0 old in 3.39 seconds primary.xml.gz 100% |=========================| 889 kB 00:02 extras : ################################################## 2871/2871 Added 2871 new packages, deleted 0 old in 9.59 seconds primary.xml.gz 100% |=========================| 824 kB 00:05 base : ################################################## 2772/2772 Added 2772 new packages, deleted 0 old in 7.95 seconds Parsing package install arguments No Match for argument: kmod-ntfs Nothing to do [root@linux-zen8 mnt]# rpm -qa --queryformat="%{n}-%{v}-%{r}.%{arch}.rpm\n" | gr ep kernel kernel-devel-2.6.11-1.1369_FC4.i686.rpm kernel-2.6.11-1.1369_FC4.i686.rpm Nie wiem co jeszcze moge wam umiescic dla informacji. Bardzo bym prosil o pomoc. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
username Napisano Marzec 11, 2007 Zgłoszenie Share Napisano Marzec 11, 2007 nie masz zainstalowanych repozytoriów http://faq.fedora.pl/#getsoftware Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Marzec 11, 2007 Zgłoszenie Share Napisano Marzec 11, 2007 [Off Topic] Uprzejmie przypominam, ze istnieje znacznik 'codebox' w którym warto umieszczac listingi dluzsze niz 12-15 linijek (to czesc do bsm) oraz w ogóle nalezy korzystac ze znaczników 'code' lub 'codebox', bo ulatwia to czytanie (to z kolei do tflisa). Wprowadzilem stosowne poprawki do Waszych postów. Na przyszlosc: edytujac odpowiedz macie pod okienkiem przycisk "BB Code Help" - polecam kliknac i zapoznac sie z zawartoscia. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
