Beryl I Compiz
Adam#1
hmmm... mam jakiś "bug" - 4 pulpity i na każdym to samo okno... tzn mam otworzonego FF i istnieje on na każdym z 4 pulpitów ...
@Adam: dekoracje mam, Emerald działa, efekty żelowania, kostka... wszystko jest :) No ale teraz odkryłem to z tymi oknami...
EDIT: Już jest ok. To okno z FF miałem odpalone przed odpaleniem beryla, zamknąłem, otworzyłem na nowo i jest ok.
beryl-core-0.1.99.2-2.fc6
beryl-gnome-0.1.99.2-2.fc6
beryl-0.1.99.2-2.fc6
beryl-settings-0.1.99.2-1.fc6
beryl-kde-0.1.99.2-2.fc6
beryl-manager-0.1.99.2-1.fc6
beryl-plugins-0.1.99.2-3.fc6
beryl-core-devel-0.1.99.2-2.fc6
Edytowane przez orzeszko
  • Odpowiedzi 34
  • Created
  • Ostatniej odpowiedzi
Top Posters In This Topic
# Xorg configuration created by system-config-display
Section "ServerLayout"
    Identifier     "single head configuration"
    Screen      0  "Screen0" 0 0
    InputDevice    "Mouse0" "CorePointer"
    InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
EndSection
Section "Module"
        Load  "dbe"
         Load  "extmod"
         Load  "fbdevhw"
         Load  "record"
         Load  "freetype"
         Load  "type1"
         Load  "GLCore"
         Load  "dri"
    Load  "glx"
    Load  "extmod"
EndSection
Section "InputDevice"
    # generated from default
    Identifier  "Mouse0"
    Driver      "mouse"
    Option        "Protocol" "auto"
    Option        "Device" "/dev/input/mice"
    Option        "Emulate3Buttons" "no"
    Option        "ZAxisMapping" "4 5"
EndSection
    Identifier  "Keyboard0"
    Driver      "kbd"
    Option        "XkbModel" "pc105"
    Option        "XkbLayout" "pl"
EndSection
Section "Monitor"
    Identifier   "Monitor0"
    VendorName   "Unknown"
    ModelName    "Unknown"
### Comment all HorizSync and VertSync values to use DDC:
    HorizSync    30.0 - 110.0
    VertRefresh  50.0 - 150.0
    Option        "DPMS"
EndSection
Section "Device"
    Identifier  "Videocard0"
    Driver      "nvidia"
EndSection
Section "Screen"
        Option "AllowGLXWithComposite" "True"
        Option "RenderAccel" "True"
        Option "AddARGBGLXVisuals" "True"
    Identifier "Screen0"
    Device     "Videocard0"
    Monitor    "Monitor0"
    DefaultDepth     24
    SubSection "Display"
        Viewport   0 0
        Depth     24
        Modes    "1280x1024" "1280x960" "1280x800" "1152x864" "1152x768" "1024x768" "800x600" "640x480"
    EndSubSection
EndSection
Section "Extensions"
    Option        "Composite"
EndSection
Hah, mój błąd, instalowałem po prostu Beryl a nie beryl-kde, po doinstalowaniu tej paczki działa, z małymi problemami:
- wgrałem sobie z Emeralda theme Black Scaled i czasem znikają mi guziki (nie chodzi o nieaktywne okna), a czasem nawet jak są to nie mam nad nimi kursora ręki tylko strzałkę i nie ma podpowiedzi (tak jakby guzików nie było).
- jak włączam efekty rozmycia albo zanikanie okien, nie pamiętam, to na środku mam czarny prostokąt :|
poza tym denerwuje mnie, że w Operze jak przełączam zakładki to mi "żeluje" okno, nie denerwowałoby mnie to może gdyby to było płynne, ale ten efekt dość mocno zamula :/
wie ktoś gdzie to można wyłączyć?
Mimo wszystko kozak! Przezroczysta kostka wygląda świetnie :) Efekty minimalizacji, maksymalizacji, zwijania, klawo.
jestem nieco podlamany -myslalem, ze moze w krotkim czasie sie pozmienia ale jak nie moglem odpalic beryla tak nie moge... compiz tez nie dziala
krotko mowiac kiedys wszystko dzialalo -wlacznie z berylem, pozniej poszalalem z instalacja sterownikow kmod-fglrx i wszystko siadlo. kombinowalem z xorg.conf i musze przyznac, ze pare razy zrobilo mi sie cieplo w gaciach -system nie wstawal ale pokombinowalem i wstaje :)
oto co dostaje jak wpisuje beryl-manager i chce uruchomic beryla
Ostrzeżenie menedżera okien: Utracono połączenie z ekranem ":0.0".
Prawdopodobnie przestał funkcjonować serwer X lub przerwano działanie menedżera okien.
* Beryl system compatiblity check                            *
Detected xserver                                : AIGLX
Checking Display :0.0 ...
Checking for XComposite extension               : passed (v0.3)
Checking for XDamage extension                  : passed
Checking for RandR extension                    : passed
Checking for XSync extension                    : passed
Checking Screen 0 ...
Checking for GLX_SGIX_fbconfig                  : passed
Checking for GLX_EXT_texture_from_pixmap        : passed
Xlib:  extension "XFree86-DRI" missing on display ":0.0".
Checking for non power of two texture support   : failed
Support for non power of two textures missing
beryl: glXBindTexImageEXT is missing
beryl: Failed to manage screen: 0
beryl: No manageable screens found on display :0.0
moj xorg.conf
Section "Module"
Load  "glx"
Load  "extmod"
Load  "dri"
Load  "dbe"
Load  "fbdevhw"
       Load  "record"
       Load  "freetype"
       Load  "type1"
       Load  "GLCore"
EndSection
Section "Device"
Driver      "radeon"
VendorName  "Videocard vendor"
BoardName   "ATI Technologies Inc RV380 AS [Radeon X600]"
Option	    "VideoOverlay" "on"
Option	    "AccelMethod" "XAA"
Option	    "AccelDFS" "1"
Option	    "AGPMode" "1"
Option	    "AGPFastWrite" "1"
Option	    "GARTSize" "64"
Option	    "EnablePageFlip" "1"
Option	    "ColorTiling" "1"
EndSection
Section "Screen"
Device     "Videocard0"
Monitor    "Monitor0"
DefaultDepth     24
EndSection
Section "DRI"
Group        "video"
Mode         0660
EndSection
Option	"Composite"	"Enable"
EndSection
moje miasto to Białystok, a moja karta to ATI X600 PRO
czy czasem
te opcje nie powinny byc w sekcji device zamiast w screen ?
poza tym spróbuj dri ustawic na
Section "DRI"
        Group        0
        Mode         0666
EndSection
bo z komunikatu
wynika ze nie moze chyba zaladowac DRI
Już wiem gdzie to jest, nie w ustawieniach Beryla w zakładce żelujących okien, ale w ustawieniach Emeralda - "Use Decoration Cropping"
wyłączyłem to i już nie żeluje (żelowało też Amaroka przy przeskakiwaniu na kolejny utwór), ale za to przy zmianie panelu/zakładki w Operze znikają mi guziki z głównego okna... dziwne, ale nie przeszkadza aż tak bo one dalej tam są (jest łapka i dymki z napisami) tylko że ich nie widać jakby okno było nieaktywne.
To pewnie bug do naprawienia :)
a ja mam ciekawostke - wczoraj chyba działałem ze 3 godziny na berylu - ani jeden zwiechy. Dzisiaj co wystaruje - podziała minutę (ale działa) i wywalka do Kwin'a... hmmm... tylko czemu?
I druga sprawa - jak się uruchamia beryl to zawsze domyslnie wybiera kwin jako menedżera a nie beryla... trzeba to ręcznie przestawiać.
A ja jestem wściekły bo już wszystko miałem gotowe, zrobiłem jakieś aktualizacje pakietów zupełnie nie związanych z Berylem, no i po restarcie zupełnie się popsuło - zero dekoracji okien, zniknał nawet pasek zadań itd, po wielu męczarniach jestem znowu na Gnome, ściągam resztę uaktualnień (jeszcze około 80 mi zostało :|) i mam nadzieję, że zadziała....
Świetna sprawa Beryl jak i Linux sam w sobie, ale jednak ma sporo ułomności co mnie drażni mocno.
czy czasem
te opcje nie powinny być w sekcji device zamiast w screen ?
Bingo! Przeoczyłem to a to jest bardzo ważne ;p
poza tym spróbuj dri ustawić na
Section "DRI"
        Group        0
        Mode         0666
EndSection
bo z komunikatu
wynika że nie może chyba załadować DRI
No i gitara wszystko smiga! Dekoracje okien zaczeły działać. To była wina złej konfiguracji xorg'a. Podaje swój dobrze skonfigurowany xorg.conf dla potomnych: http://wklej.org/id/03abe1c171
