Gdzie Można Znaleźć Zapis Przebiegu Uruchamiania Fc6 X86_64
callou
Niestety nic to nie dalo...
Wszelkie komunikaty systemowe powinny byc w /var/log/messages. Oczywiscie nie wygladaja tak jak na ekranie ;) ale tez da sie przeczytac. I jeszcze kilka innych interesujacych rzeczy. Niezastapione informacje przy namierzaniu problemów z systemem.
Mam tutaj takie komunikaty z /var/log/messages:
Mar  4 10:17:00 OSTR kernel:  hdb:hdb: recal_intr: status=0x51 { DriveReady SeekComplete Error }
Mar  4 10:17:00 OSTR kernel: hdb: recal_intr: error=0x04 { DriveStatusError }
Mar  4 10:17:00 OSTR kernel: ide: failed opcode was: unknown
Mar  4 10:17:00 OSTR kernel: hdb: irq timeout: status=0xd0 { Busy }
Mar  4 10:17:00 OSTR kernel: ide0: reset: master: error (0x00?)
Mar  4 10:17:00 OSTR kernel: hdb: set_geometry_intr: status=0x51 { DriveReady SeekComplete Error }
Mar  4 10:17:00 OSTR kernel: hdb: set_geometry_intr: error=0x04 { DriveStatusError }
Mar  4 10:17:00 OSTR kernel: hdb: recal_intr: status=0x51 { DriveReady SeekComplete Error }
Mój fstab wygląda tak:
LABEL=/1                /                       ext3    defaults        1 1
devpts                  /dev/pts                devpts  gid=5,mode=620  0 0
tmpfs                   /dev/shm                tmpfs   defaults        0 0
LABEL=/                 /mnt/old_linux          ext3    defaults        1 2
/dev/hdb1               /mnt/old_start          vfat    defaults        0 0
/dev/hdb2               /mnt/old_wypas          vfat    defaults        0 0
proc                    /proc                   proc    defaults        0 0
sysfs                   /sys                    sysfs   defaults        0 0
LABEL=SWAP-sda9         swap                    swap    defaults        0 0
/dev/hdb4               swap                    swap    defaults        0 0
fdisk -l drukuje:
[root@OSTR ~]# fdisk -l
Disk /dev/hdb: 33.8 GB, 33820286976 bytes
255 heads, 63 sectors/track, 4111 cylinders
  Device Boot      Start         End      Blocks   Id  System
/dev/hdb1   *           1         255     2048256    b  W95 FAT32
/dev/hdb2             256        3359    24932880    c  W95 FAT32 (LBA)
/dev/hdb3            3360        4077     5767335   83  Linux
/dev/hdb4            4078        4111      273105   82  Linux swap / Solaris
Disk /dev/sda: 320.0 GB, 320071851520 bytes
255 heads, 63 sectors/track, 38913 cylinders
/dev/sda1   *           1        4080    32772568+   7  HPFS/NTFS
/dev/sda2            4081       38913   279796072+   f  W95 Ext'd (LBA)
/dev/sda5            4081       17263   105892416    7  HPFS/NTFS
/dev/sda6           17264       30214   104028876    7  HPFS/NTFS
/dev/sda7           30215       34676    35840983+  83  Linux
/dev/sda8           34677       38628    31744408+   7  HPFS/NTFS
/dev/sda9           38629       38913     2289231   82  Linux swap / Solaris
Czy to jakiś poważny problem?
Jak go wyeliminować?
