jurpaw Napisano Marzec 28, 2007 Zgłoszenie Share Napisano Marzec 28, 2007 Po update FC5 > 6 nie chce mi sie montowac partycja windowsa, pewnie dlatego ze nie mam ntfs-3g. Probuje i mam problem. [root@mefisto yum.repos.d]# yum install ntfs-3g Plugin "fastestmirror" uses deprecated constant TYPE_INTERFACE. Please use TYPE_INTERACTIVE instead. Loading "fastestmirror" plugin Loading "installonlyn" plugin Setting up Install Process Setting up repositories dries 100% |=========================| 951 B 00:00 macromedia 100% |=========================| 951 B 00:00 livna 100% |=========================| 1.1 kB 00:00 core 100% |=========================| 1.1 kB 00:00 updates 100% |=========================| 1.2 kB 00:00 extras 100% |=========================| 1.1 kB 00:00 Determining fastest mirrors Traceback (most recent call last): File "/usr/bin/yum", line 29, in ? yummain.main(sys.argv[1:]) File "/usr/share/yum-cli/yummain.py", line 102, in main result, resultmsgs = do() File "/usr/share/yum-cli/cli.py", line 359, in doCommands return self.yum_cli_commands[self.basecmd].doCommand(self, self.basecmd, self.extcmds) File "/usr/share/yum-cli/yumcommands.py", line 134, in doCommand return base.installPkgs(extcmds) File "/usr/share/yum-cli/cli.py", line 509, in installPkgs self.doRepoSetup() File "/usr/share/yum-cli/cli.py", line 102, in doRepoSetup yum.YumBase.doRepoSetup(self, thisrepo=thisrepo) File "/usr/lib/python2.4/site-packages/yum/__init__.py", line 306, in doRepoSetup self.plugins.run('postreposetup') File "/usr/lib/python2.4/site-packages/yum/plugins.py", line 153, in run func(conduitcls(self, self.base, conf, **kwargs)) File "/usr/lib/yum-plugins/fastestmirror.py", line 77, in postreposetup_hook repo.set('urls', repomirrors[str(repo)]) AttributeError: 'YumRepository' object has no attribute 'set' Nie wklejam zawartosci *.repo bo sprawdzalem i "raczej" jest w nich wszystko dobrze. Pewnie ten plugin jest do wywalenia ale: [root@mefisto yum.repos.d]# yum remove yum-plugin-fastestmirror Plugin "fastestmirror" uses deprecated constant TYPE_INTERFACE. Please use TYPE_INTERACTIVE instead. Loading "fastestmirror" plugin Loading "installonlyn" plugin Setting up Remove Process No Match for argument: yum-plugin-fastestmirror No Packages marked for removal probowalem tez: [root@mefisto etc]# rpm -Uvh http://www.fedorafaq.org/yum http://rpm.livna.org/livna-release-6.rpm Sciaganie http://www.fedorafaq.org/yum Sciaganie http://rpm.livna.org/livna-release-6.rpm ostrzezenie: /var/tmp/rpm-xfer.1YB71e: Naglówek V3 DSA signature: NOKEY, key ID a109b1ec Przygotowywanie... ########################################### [100%] pakiet livna-release-6-1 jest juz zainstalowany plik /etc/yum.repos.d/freshrpms.repo z instalacji yum-fedorafaq-6-2007.02.03 jest w konflikcie z plikiem z pakietu freshrpms-release-1.1-1.fc ps. Jak wklejac kod do przesuwanego okienka? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Marzec 28, 2007 Zgłoszenie Share Napisano Marzec 28, 2007 ps. Jak wklejac kod do przesuwanego okienka? Zmien znaczniki z [ c o d e ] - [ / c o d e ] na [ c o d e b o x ] - [ / c o d e b o x ] Co do ntfs i yuma to Ci chyba nie pomoge, bo uzywasz niekompatybilnego repozytorium (dries) wiec ciezko zgadnac co Ci sie w pakietach narobilo. Nie zaszkodzi yum clean all a potem yum install ntfs-3g ... ale ja bym przede wszystkim wywalil dries Powodzenia Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
jurpaw Napisano Marzec 28, 2007 Autor Zgłoszenie Share Napisano Marzec 28, 2007 wywalilem dries, yum clean all robie caly czas. Nic jednak to nie pomaga, nie umiem odinstalowac tego plugina fastestmirror, a to chyba jest problem, bo gdzies wyczytalem ze yum z FC6 nie obsluguje pluginow (czy jakos tak). Wylaczylem w yum.conf plugins=0 no i niby dziala ale to chyba slabe rozwiazanie? a przy okazji to yumex tez mi nie dziala. [root@mefisto etc]# yumex Traceback (most recent call last): File "/usr/share/yumex/yumexmain.py", line 35, in ? import yumex.yumexConst as const File "/usr/lib/python2.4/site-packages/yumex/__init__.py", line 32, in ? from yumexBase import * File "/usr/lib/python2.4/site-packages/yumex/yumexBase.py", line 48, in ? from yum.logger import Logger ImportError: No module named logger nie potrzebuje, ale jakis ten update z 5>6 nie udany. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Karlik Napisano Marzec 28, 2007 Zgłoszenie Share Napisano Marzec 28, 2007 yumex nie ma prawa dzialac, bo to tylko graficzna nakladka na yuma EDIT: aha, ja nie uzywam pluginu fastest mirrors, wiec to mozesz bez problemu wylaczyc jak sprawia problemy, ale ten drugi plugin bym zostawil Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
jurpaw Napisano Marzec 28, 2007 Autor Zgłoszenie Share Napisano Marzec 28, 2007 No tak ale wlasnie sie o to rozchodzi. JAK TEN PLUGIN WYLACZYC. Bo wylaczyc wszystkie to tak jak napisalem wyzej, ale jak wylaczyc jeden konkretny a inne zostawic?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Marzec 28, 2007 Zgłoszenie Share Napisano Marzec 28, 2007 ale jak wylaczyc jeden konkretny a inne zostawic??Zobacz co masz w katalogu /etc/yum/pluginconf.d. Wydaje mi się, że wystarczy usunąć wszystkie niechciane wtyczki z tego katalogu. No i żeby nie było śmieci to jeszcze porządki w /usr/lib/yum-plugins. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
jurpaw Napisano Marzec 28, 2007 Autor Zgłoszenie Share Napisano Marzec 28, 2007 No oka, poszlo dzieki. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
