s1w Napisano Kwiecień 20, 2007 Zgłoszenie Share Napisano Kwiecień 20, 2007 z kontekstu wynika . . [root@localhost d]# rpm -ivh xmms-vis-plugins-3.2-2.i386.rpm błąd: Niespełnione zależności: libGLcore.so.1 jest wymagany przez xmms-vis-plugins-3.2-2.i386 libglut.so.3 jest wymagany przez xmms-vis-plugins-3.2-2.i386 libid3-3.8.so.2 jest wymagany przez xmms-vis-plugins-3.2-2.i386 libslang.so.1 jest wymagany przez xmms-vis-plugins-3.2-2.i386 [root@localhost d]# yum install libGLcore.so.1 Loading "installonlyn" plugin Setting up Install Process Setting up repositories Reading repository metadata in from local files Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package xorg-x11-drv-nvidia.i386 0:1.0.9755-3.lvn6 set to be updated --> Running transaction check --> Processing Dependency: nvidia-kmod >= 1.0.9755 for package: xorg-x11-drv-nvidia --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Package kmod-nvidia.i686 0:1.0.9755-2.2.6.20_1.2944.fc6 set to be updated --> Running transaction check --> Processing Dependency: kernel-i686 = 2.6.20-1.2944.fc6 for package: kmod-nvidia --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Package kernel.i686 0:2.6.20-1.2944.fc6 set to be installed --> Running transaction check --> Populating transaction set with selected packages. Please wait. ---> Package kernel.i586 0:2.6.18-1.2798.fc6 set to be erased --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: xorg-x11-drv-nvidia i386 1.0.9755-3.lvn6 livna 4.9 M Removing: kernel i586 2.6.18-1.2798.fc6 installed 43 M Installing for dependencies: kernel i686 2.6.20-1.2944.fc6 updates 16 M kmod-nvidia i686 1.0.9755-2.2.6.20_1.2944.fc6 livna 2.3 M Transaction Summary ============================================================================= Install 3 Package(s) Update 0 Package(s) Remove 1 Package(s) Total download size: 23 M Is this ok [y/N]: y Downloading Packages: Running Transaction Test Finished Transaction Test Transaction Check Error: package kernel-2.6.20-1.2944.fc6 is already installed file /boot/System.map-2.6.20-1.2944.fc6 from install of kernel-2.6.20-1.2944.fc6 conflicts with file from package kernel-2.6.20-1.2944.fc6 file /boot/config-2.6.20-1.2944.fc6 from install of kernel-2.6.20-1.2944.fc6 conflicts with file from package kernel-2.6.20-1.2944.fc6 file /boot/symvers-2.6.20-1.2944.fc6.gz from install of kernel-2.6.20-1.2944.fc6 conflicts with file from package kernel-2.6.20-1.2944.fc6 file /boot/vmlinuz-2.6.20-1.2944.fc6 from install of kernel-2.6.20-1.2944.fc6 conflicts with file from package kernel-2.6.20-1.2944.fc6 Error Summary ------------- . . . i nie wiem co robic; zadne --force nie pomaga... moze sprawa jest prosta? ale ja zacytuje moj ulubiony cytat Alberta E. - "Ja tam nie wiem" Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Karlik Napisano Kwiecień 20, 2007 Zgłoszenie Share Napisano Kwiecień 20, 2007 Poszukaj jak podmienić jajko i586 na i686, było o tym przynajmniej kilkadziesiąt razy (jak nie więcej) i powinno pomóc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
s1w Napisano Kwiecień 21, 2007 Autor Zgłoszenie Share Napisano Kwiecień 21, 2007 dzieki za szybka odp. retorycznie zarzuce ze podmiana jadra wiaze sie z ponowna instalacja nvidii.. mam nadzieje ze niczego wiecej bo duzo tego bylo. i tylko dziwi mnie fakt ze $ arch wypisuje mi i686. przy okazji dowiedzialem sie ze sa rozne kmody nvidii, ktory jest wlasciwy dla GeForce 7950 GX2 Gainward Bliss 1GB? i jak pozniej sprawdzic czy chodzi (i smiga lepiej niz bez sterow), bo samo logo mnie nie gilga z gory dzieki Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Kwiecień 22, 2007 Zgłoszenie Share Napisano Kwiecień 22, 2007 i jak pozniej sprawdzic czy chodzi (i smiga lepiej niz bez sterow), bo samo logo mnie nie gilga z gory dzieki Porównaj glxgears przed instalacją sterownika i po. Po instalacji ilość klatek na sekundę powinna być zdecydowanie większa. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Kwiecień 23, 2007 Zgłoszenie Share Napisano Kwiecień 23, 2007 sa rozne kmody nvidii, ktory jest wlasciwy dla GeForce 7950 GX2 Gainward Bliss 1GB? i jak pozniej sprawdzic czy chodzi (i smiga lepiej niz bez sterow), bo samo logo mnie nie gilga z gory dzieki kmod-nvidia dla wszystkich kart powyzej GF4... Powodzenia Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
