Fatalna Jakość Multimediów
Burn112
Nic nie obciąża kompa, w spoczynku % użycia PC nie przekracza 2 %. Co do akutalizacji to wątpię, żebym przerwał ale zapuszcze ją jeszcze raz...
Na prelinku wyskakuje mi coś takiego:
 su -
Hasło:
[root@localhost ~]# prelink -all
prelink: /usr/bin/ksolarwinds.kss: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/kwave.kss: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/kfiresaver.kss: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/amarokcollectionscanner: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/mplayer: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/kpendulum.kss: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/kflux.kss: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/kgravity.kss: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/kdesktop_lock: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/glxgears: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/krotation.kss: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/keuphoria.kss: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/amarokapp: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/glxinfo: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/xdriinfo: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/kfountain.kss: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
prelink: /usr/bin/kspace.kss: Cannot prelink against non-PIC shared library /usr/lib/nvidia/libGL.so.1
[root@localhost ~]#
Czyżby jakiś błąd karty graf. ?? Ale niby co to może mieć wspólnego z dźwiękiem. No bo są 2 opcje w filmach.. albo dźwięk się spieszy, albo video muli, ale biorc pod uwage ścinki video raczej to drugie. Ale w takim razie skąd chrobotanie basu w muzyce? No i czy to ma coś ze sobą wspólnego?
EDIT: nie macie już zadnych pomysłów??
Post pod postem, bo tamten jest wczorajszy.
Dobra znalazłem gdzie się w KDE ustawia sterowniki dźwięku. Otóż na kazdy msterowniku (również ALSA) mam to chrobotanie przy basie. Błađ głośnikół to być nie może, bo na słuchawkach mam tak samo, a winda działa dobrze. Nie wiem już co jest nie tak. A to samo się dzieje czy włącze czy wyłącze system dźwięku (czyli rozumeim, że to ten ARTS).... Filmy to już inna sprawa, bo te się desynchronizują i zacinają.... Nawet jak usatwie 16bitową jakość dźwięku, najwyższy bufor i priorytet dla dźwięku to jest to samo!
