Smplayer 0.5.0 Fc 7
piotreek23
B??dy budowania RPM-a:
    Nie znaleziono pliku poprzez glob: /var/tmp/smplayer-0.5.0-1.fc7-root-piotr/usr/share/hicolor/*/apps/smplayer.png
Po zastosowaniu
%{_datadir}/hicolor/*/apps/smplayer.png
Dlatego poprawi?em.
%define name    smplayer
%define version 0.5.0
Version:        %{version}
Release:        1%{?dist}
Summary:        A great front-end for MPlayer
Group:          Applications/Multimedia
License:        GPL
URL:            http://smplayer.sourceforge.net/
Source0:        http://downloads.sourceforge.net/smplayer/...version}.tar.gz
BuildRoot:      %{_tmppath}/%{name}-%{version}-%{release}-root-%(%{__id_u} -n)
BuildRequires:  qt-devel
Requires:       mplayer hicolor-icon-theme
%description
SMPlayer intends to be a complete front-end for MPlayer, from basic features
like playing videos, DVDs, and VCDs to more advanced features like support
for Mplayer filters and more. One of the main features is the ability to
remember the state of a played file, so when you play it later it will resume
at the same point and with the same settings. smplayer is developed with
the Qt toolkit, so it's multi-platform.
%prep
%setup -q
%build
make %{?_smp_mflags} PREFIX=/usr
%install
rm -rf $RPM_BUILD_ROOT
make %{?_smp_mflags} PREFIX=/usr  DESTDIR=$RPM_BUILD_ROOT install
rm -rf $RPM_BUILD_ROOT%{_datadir}/doc
%clean
%files
%doc Changelog Configurable_shortcuts.txt Copying.txt Icon_themes.txt Install.txt
%doc Not_so_obvious_things.txt Readme.txt Release_notes.txt Translations.txt
%defattr(-,root,root,-)
%{_bindir}/smplayer
%{_datadir}/applications/smplayer.desktop
%{_datadir}/smplayer/
%post
touch --no-create %{_datadir}/icons/hicolor || :
%{_bindir}/gtk-update-icon-cache --quiet %{_datadir}/icons/hicolor || :
update-desktop-database &> /dev/null ||:
%postun
%changelog
* Tue Jun 12 2007 Piotr Sabiniewicz <[email protected]> 0.5.0-1
- First Spec for Fedora 7
Dwa ten katalog doc to zawsze mo?na usuwa?? Czy to tylko w tym przypadku.
Dzieki za cierpliwosc ;)
  • Odpowiedzi 31
  • Created
  • Ostatniej odpowiedzi
Top Posters In This Topic
Mój błąd, powinno być:
%{_datadir}/icons/hicolor/*/apps/smplayer.png
Każdy przypadek należy rozpatrywać indywidualnie ;) nie wszystkie paczki w ogóle coś takiego tworzą - a jeśli już tworzą to lepiej z reguły potraktować to ręcznie i katalog wywalić.
Poza tym nie zapomnij o dodaniu desktop-file-install do czego linkowałem.
A na koniec dodam, że przyjęło się, że sekcje %post i %postun znajdują się między %clean i %files - tak będzie czytelniej.
Jestem bardziej niż wdzięczny <jabłko>
Poprawie tego desktop.file i umieszcze tutaj pelen spec file jescze raz do przejrzenia ;)
Rozumiem ze te dokumenty w paczce RPM nie są potrzebne. Piszesz iż recznie to wywalić? rozumiem iż przepakować usuwając te pliki i zapisać źródła na nowo?
Nie, skądże ;)
Miałem na myśli ręczne wywalenie z tamtej ścieżki (czyli nasze rm -rf...), a użycie ich w %doc. Chodziło o to, że po prostu trzeba zrobić to co tutaj - wywalić ich z tej ścieżki, gdzie wgrywa je aplikacja, a użycie ich w %doc (bo dokumentacja zawsze musi być oznaczona przez %doc)
Poza tym nigdy się nie robi czegoś takiego jak zmiana źródeł ;) (chyba, że przy pomocy patchy)
Jescze jedno jak zapisa? ten desktop.file skoro ?ród?a ju? go zawieraj??
Napisa? nowy to pod jak? nazw? zapisa? i czy mo?e tak wygl?da?
[Desktop Entry]
Encoding=UTF-8
Name=SMplayer
GenericName=Mplayer Frontend
Comment=Mplayer Frontend
Comment[pl]=?wietna nak?adka na Mplayer
Exec=smplayer %f
Icon=smplayer
Terminal=false
Type=Application
Categories=AudioVideo;Player;Video;Qt;KDE;
MimeType=audio/ac3;audio/mp4;audio/mpeg;audio/vnd.rn-realaudio;audio/vorbis;
audio/x-adpcm;audio/x-matroska;audio/x-mp2;audio/x-mp3;audio/x-ms-wma;
audio/x-vorbis;audio/x-wav;video/avi;video/mp4;video/mpeg;
video/quicktime;video/vnd.rn-realvideo;video/x-matroska
;video/x-ms-asf;video/x-msvideo;video/x-ms-wmv;video/x-ogm;video/x-theora
Mo?esz wywali? ten desktop, który jest dostarczany z paczk? i da? swój. Np. w paczce bygfoot jest co? w tym stylu. Przed desktop-file-install trza by?oby najpierw usun?? tamten desktop. No i oczywi?cie ten swój do??czy? jako kolejne ?ród?o, podobnie jak w ww. paczce.
Wyrzuci? z ?róde? programu? Czy jako? w spec to mo?na zdefioniowa?. Aha na tej stronie co poda?e? znalaz?em 3 przyk?ady instalacji desktop-file tam jest jakie? usuwanie kategorii dodawanie nowych nie bardzo to rozumiem.
Móg?by? mi rzuci? troch? ?wiat?a ;)
I gdzie odwo?uje si? %{SOURCE3} ??
Tam podano po prostu przykłady.
W pierwszym z nich jest zwykłe instalowanie tego pliku desktop, który jest podany w tagu Source3 w preambule.
W następnym dodaje się do pliku desktop kategorię Multimedia i wgrywa do innego katalogu (dlatego --delete-original).
W trzecim zaś podano przykład usuwania danej kategorii i wgrania pliku do odpowiedniego podkatalogu (tak się robi np. w przypadku aplikacji KDE).
A %{SOURCE3} odnosi się do tego co się poda w Source3 ;)
Tam podano po prostu przyk?ady.
W pierwszym z nich jest zwyk?e instalowanie tego pliku desktop, który jest podany w tagu Source3 w preambule.
W nast?pnym dodaje si? do pliku desktop kategori? Multimedia i wgrywa do innego katalogu (dlatego --delete-original).
W trzecim za? podano przyk?ad usuwania danej kategorii i wgrania pliku do odpowiedniego podkatalogu (tak si? robi np. w przypadku aplikacji KDE).
A %{SOURCE3} odnosi si? do tego co si? poda w Source3 ;)
Kurcze możesz podać przykładem a i co to jest to. I gdzie to sie definiuje?
%{_datadir}/applications/fedora-bygfoot.desktop
Sam to stworzyżyłeś czy już było?? Bo nie ma o tym mowy w dziale desktop.file.
Ok to może jaśniej jak go stworze ten plik desktop to jak mam go nazwać i gdzie umieścić??
I jak i gdzie zdefiniować source3 ?
Nazwiesz go np. smplayer.desktop i umieścisz w tym samym katalogu, w którym umieszczasz źródła. No a Source3 zdefiniujesz pod Source0 :) (wtedy oczywiście nie trzeba podawać adresu URL)
może to Ci pomoże:
mkdir -p $RPM_BUILD_ROOT%{_datadir}/applications
cat > widelands.desktop <<EOF
[Desktop Entry]
Encoding=UTF-8
Type=Application
Name=Widelands
GenericName=Realtime Strategy Game
Comment=Build a growing settlement and rule the world
Exec=widelands
Categories=Game;StrategyGame;
EOF
desktop-file-install --vendor="fedora"                \
  --dir=$RPM_BUILD_ROOT%{_datadir}/applications/   \
        %{name}.desktop
Z mojego speca z widelands. To cat wypisze do katalogu ze źródełkami rozpakowanymi (czyli tam gdzie masz aktualną lokalizacje dokładniej). Oczywiście możesz zastąpić to cat przez dodanie tego co jest potem do pliku i załączyć go w SourceX. Wtedy dajesz w desktop-file-install %{SOURCEX} zamiast %{name}.desktop
