pornostar Napisano Czerwiec 14, 2007 Zgłoszenie Share Napisano Czerwiec 14, 2007 Mam do was pytanie czy FC7 z xorg 7.2 ma już zaimplementowaną obsługę kart graficznych typu VIA UNICHROME PRO K8M800/K8N800,PM8X0 - czy ktoś mógłby wkleić tu wynik polecenia man via z FC7 Obecnie nie mam mozliwości instalacji by się sak przekonać Z góry dzięki za odp Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Czerwiec 14, 2007 Zgłoszenie Share Napisano Czerwiec 14, 2007 via is an Xorg driver for VIA chipsets with onboard unichrome graphics. The via driver supports the VIA CLE266, KM400/KN400, K8M/N800, PM/N800 and CN400 chipsets, including 2D acceleration and the Xv video overlay extensions. Flat panel, TV and VGA outputs are supported, depending on the hardware configuration. Direct rendering 3D is available using experimental drivers in Mesa, www.mesa3d.org. Also there is an XvMC client library for hardware MPEG1 / MPEG2 decoding acceleration available on the CLE266, CN400, PM/N800 and K8M/N800 chipsets that uses the Direct Rendering Infras- tructure, DRI. The XvMC client library implements a nonstandard "VLD" extension to the XvMC standard. The current Direct Rendering Manager Linux kernel module is available at dri.sourceforge.net. The driver supports free modes for Unichome Pro chipsets. (K8M/N800, PM/N800 and CN400). Currently for Unichrome chipsets, it only supports a limited number of dotclocks, so if you are using X modelines, you must make sure that the dotclock is one of those supported. Supported dotclocks on Unichromes are currently (MHz): 25.2, 25.312, 26.591, 31.5, 31.704, 32.663, 33.750, 35.5, 36.0, 39.822, 40.0, 41.164, 46.981, 49.5, 50.0, 56.3, 57.284, 64.995, 65.0, 65.028, 74.480, 75.0, 78.8, 81.613, 94.5, 108.0, 108.28, 122.0, 122.726, 135.0, 148.5, 155.8, 157.5, 161.793, 162.0, 175.5, 189.0, 202.5, 204.8, 218.3, 229.5. On top of this, bandwidth restrictions apply both for Unichromes and Unichrome Pros. Wkleiłem tylko fragment, reszta to configuration details, jeżeli tego też potrzebujesz to pisz. Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
pornostar Napisano Czerwiec 14, 2007 Autor Zgłoszenie Share Napisano Czerwiec 14, 2007 wielkie dzięki - naprawdę Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
