kurzawa Napisano Czerwiec 16, 2007 Zgłoszenie Share Napisano Czerwiec 16, 2007 Używam Fedore Core 6. Wpisuje w terminalu: [root@localhost ~]# yum install kmod-nvidia i pojawia mi się: Loading "installonlyn" plugin Setting up Install Process Setting up repositories Reading repository metadata in from local files Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package kmod-nvidia.i686 0:100.14.09-1.2.6.20_1.2952.fc6 set to be installed --> Running transaction check --> Processing Dependency: kernel-i686 = 2.6.20-1.2952.fc6 for package: kmod-nvidia --> Processing Dependency: nvidia-kmod-common >= 100.14.09 for package: kmod-nvidia --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Package kernel.i686 0:2.6.20-1.2952.fc6 set to be installed ---> Package xorg-x11-drv-nvidia.i386 0:100.14.09-1.lvn6 set to be updated --> Running transaction check --> Processing Dependency: livna-config-display for package: xorg-x11-drv-nvidia --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Package livna-config-display.noarch 0:0.0.12-1.lvn6 set to be updated --> Running transaction check --> Populating transaction set with selected packages. Please wait. ---> Package kernel.i586 0:2.6.18-1.2798.fc6 set to be erased --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: kmod-nvidia i686 100.14.09-1.2.6.20_1.2952.fc6 livna 2.4 M Removing: kernel i586 2.6.18-1.2798.fc6 installed 43 M Installing for dependencies: kernel i686 2.6.20-1.2952.fc6 updates 16 M livna-config-display noarch 0.0.12-1.lvn6 livna 56 k xorg-x11-drv-nvidia i386 100.14.09-1.lvn6 livna 4.9 M Transaction Summary ============================================================================= Install 4 Package(s) Update 0 Package(s) Remove 1 Package(s) Total download size: 23 M Is this ok [y/N]: y Downloading Packages: Running Transaction Test Finished Transaction Test Transaction Check Error: package kernel-2.6.20-1.2952.fc6 is already installed file /boot/System.map-2.6.20-1.2952.fc6 from install of kernel-2.6.20-1.2952.fc6 conflicts with file from package kernel-2.6.20-1.2952.fc6 file /boot/config-2.6.20-1.2952.fc6 from install of kernel-2.6.20-1.2952.fc6 conflicts with file from package kernel-2.6.20-1.2952.fc6 file /boot/symvers-2.6.20-1.2952.fc6.gz from install of kernel-2.6.20-1.2952.fc6 conflicts with file from package kernel-2.6.20-1.2952.fc6 file /boot/vmlinuz-2.6.20-1.2952.fc6 from install of kernel-2.6.20-1.2952.fc6 conflicts with file from package kernel-2.6.20-1.2952.fc6 Error Summary Co zrobić? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Czerwiec 16, 2007 Zgłoszenie Share Napisano Czerwiec 16, 2007 Poszukaj tematu na forum o podmianie kernela z i586 na i686. Problem powtarzał się milion razy btw. w F7 ten błąd anacondy został usunięty Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
kurzawa Napisano Czerwiec 17, 2007 Autor Zgłoszenie Share Napisano Czerwiec 17, 2007 Wykonałem wszystko według tej instrukcji: http://fedoraproject.org/wiki/Bugs/FC6Comm...097983a3822f143 jednak po wpisaniu [root@localhost ~]# su -c "rpm -ivh kernel-2*.i686.rpm" Pojawia mi się: Przygotowywanie... ########################################### [100%] pakiet kernel-2.6.20-1.2952.fc6 jest już zainstalowany plik /boot/System.map-2.6.20-1.2952.fc6 z instalacji kernel-2.6.20-1.2952.fc6 jest w konflikcie z plikiem z pakietu kernel-2.6.20-1.2952.fc6 plik /boot/config-2.6.20-1.2952.fc6 z instalacji kernel-2.6.20-1.2952.fc6 jest w konflikcie z plikiem z pakietu kernel-2.6.20-1.2952.fc6 plik /boot/symvers-2.6.20-1.2952.fc6.gz z instalacji kernel-2.6.20-1.2952.fc6 jest w konflikcie z plikiem z pakietu kernel-2.6.20-1.2952.fc6 plik /boot/vmlinuz-2.6.20-1.2952.fc6 z instalacji kernel-2.6.20-1.2952.fc6 jest w konflikcie z plikiem z pakietu kernel-2.6.20-1.2952.fc6 Co zrobic? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Czerwiec 17, 2007 Zgłoszenie Share Napisano Czerwiec 17, 2007 Właśnie zaśmieciłeś forum zakładając dwa identyczne wątki Do tego nie przeczytałeś dokładnie zawartości linka, którego podałeś wyżej. Nie wiem jak jest z Twoją znajomością j.angielskiego, ale jeżeli znalazłeś rozwiązanie na angielskiej stronie to chyba jest nieźle: Alternatively, if the version of the kernel downloaded is the same as that currently installed: su -c "rpm -ivh --replacefiles --replacepkgs kernel-2*.i686.rpm" kernel-2.6.20-1.2952.fc6 jest w konflikcie z plikiem z pakietu kernel-2.6.20-1.2952.fc6 Czyli z Twoich logów wynika, że jest the same czyli korzystasz z polecenia, które podałem wyżej. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
