radziok18 Napisano Sierpień 14, 2007 Zgłoszenie Share Napisano Sierpień 14, 2007 witam mam linuksa od niedawna w pracy i w domu lecz niestety w domu przy tych samyych uaktualnieniach napotkuje problemy , niechca sie instalowac niektore paczki - zawsze chodiz o te same 3 pliki i nie iwem co juz jest nie tak dla tak samo jak na przykladzie nizej gdy probowalem zainstlaowac xine ze wszystkim naraz; [root@localhost ******]# yum install xine* Loading "installonlyn" plugin Setting up Install Process Parsing package install arguments Resolving Dependencies --> Running transaction check ---> Package xine-lib-devel.i386 0:1.1.7-1.fc7 set to be updated ---> Package xine-plugin.i386 0:1.0-3.fc7 set to be updated ---> Package xine-skins.noarch 0:1.10-1.fc set to be updated ---> Package xinetd.i386 2:2.3.14-12.fc7 set to be updated ---> Package xine-lib-extras.i386 0:1.1.7-1.fc7 set to be updated ---> Package xine.i386 0:0.99.5-1.lvn7 set to be updated ---> Package xine-lib-extras-nonfree.i386 0:1.1.7-1.lvn7 set to be updated --> Processing Dependency: libdts.so.0 for package: xine-lib-extras-nonfree --> Processing Dependency: libfusion-1.0.so.0 for package: xine-lib-extras --> Processing Dependency: libdirectfb-1.0.so.0 for package: xine-lib-extras --> Processing Dependency: libpostproc.so.51 for package: xine-lib-extras-nonfree --> Processing Dependency: libvcdinfo.so.0(VCDINFO_0) for package: xine-lib-extras-nonfree --> Processing Dependency: vcdimager >= 0.7.23 for package: xine-lib-extras-nonfree --> Processing Dependency: libavcodec.so.51 for package: xine-lib-extras-nonfree --> Processing Dependency: libvcdinfo.so.0 for package: xine-lib-extras-nonfree --> Processing Dependency: libavutil.so.49 for package: xine-lib-extras-nonfree --> Processing Dependency: libdirect-1.0.so.0 for package: xine-lib-extras --> Restarting Dependency Resolution with new changes. --> Running transaction check ---> Package ffmpeg-libs.i386 0:0.4.9-0.37.20070503.lvn7 set to be updated ---> Package xine-lib-extras.i386 0:1.1.7-1.fc7 set to be updated ---> Package directfb.i386 0:1.0.0-1.fc7 set to be updated ---> Package vcdimager.i386 0:0.7.23-5.fc7 set to be updated ---> Package xine-lib-extras-nonfree.i386 0:1.1.7-1.lvn7 set to be updated --> Processing Dependency: faad2 < 2.5 for package: ffmpeg-libs --> Processing Dependency: libx264.so.54 for package: ffmpeg-libs --> Processing Dependency: libdts.so.0 for package: xine-lib-extras-nonfree --> Processing Dependency: libdts.so.0 for package: ffmpeg-libs --> Finished Dependency Resolution Error: Missing Dependency: libdts.so.0 is needed by package xine-lib-extras-nonfree Error: Missing Dependency: faad2 < 2.5 is needed by package ffmpeg-libs Error: Missing Dependency: libx264.so.54 is needed by package ffmpeg-libs Error: Missing Dependency: libdts.so.0 is needed by package ffmpeg-libs posciagalem te 3 niby brakujace pliki lecz okazalo sie ze byly.... moze wy wiecie o co chodzi bo ja juz (_niemam_ → nie mam) ORT sily ;/ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
bugaz1978 Napisano Sierpień 14, 2007 Zgłoszenie Share Napisano Sierpień 14, 2007 Error: Missing Dependency: libdts.so.0 is needed by package xine-lib-extras-nonfree Error: Missing Dependency: faad2 < 2.5 is needed by package ffmpeg-libs Error: Missing Dependency: libx264.so.54 is needed by package ffmpeg-libs Error: Missing Dependency: libdts.so.0 is needed by package ffmpeg-libs Według tego co jest napisane to musiałbyś mieć zainstalowane pakiety: libdca-0.0.2-3.lvn7 x264-0-0.8.20061028.lvn7 faad2-2.0-19.20050131.lvn6 ale mogę się mylić :-) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 14, 2007 Zgłoszenie Share Napisano Sierpień 14, 2007 A repozytoria masz podłączone te same w pracy i w domu? P.S. Do obu Panów powyżej moja standardowa uwaga: Listingi do 12-15 linijek umieszczaj między znacznikami [code] i [/code], dłuższe niż 15 linii pomiędzy [codebox] i [/codebox] - tak jest czytelniej. Przeczytaj "BB Code Help" Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
radziok18 Napisano Sierpień 14, 2007 Autor Zgłoszenie Share Napisano Sierpień 14, 2007 repozytoria mam mniej wiecej te same tylko w pracy instalowalem to pakietami praktycznie to co oferowal update yuma natomiast w domu wczesniej sciagalem osobno rpm'y, nie wiem czy o to chodzi.... Co do poprzedniej odpowiedzi to mam takie wersje tylko faad jest nowszy podajze 2.5 lvn7... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 14, 2007 Zgłoszenie Share Napisano Sierpień 14, 2007 Chodzi głównie o to, że niektóre repozytoria się "kłócą". Jeśli masz standardowe repo Fedory (fedora i updates) + livna to OK, ale jeśli masz coś więcej albo pobierałeś RPM z przypadkowych źródeł (innych niż wymienione przeze mnie), to może to być przyczyna kłopotów. Najlepiej podaj dokładnie jakie masz w pracy a jakie w domu. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
radziok18 Napisano Sierpień 15, 2007 Autor Zgłoszenie Share Napisano Sierpień 15, 2007 Moze to glupie pytanie ale jak to moge sprawdzic ? Uzywam tego systemu od niecalego miesiaca wiec dokonca obeznany nie jestem. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 15, 2007 Zgłoszenie Share Napisano Sierpień 15, 2007 [...] jak to moge sprawdzic ?W katalogu /etc/yum.repos.d masz pliki z rozszerzeniem *.repo. To są pliki tekstowe, więc można je obejrzeć w dowolnym edytorze albo wyświetlić poleceniem cat, more lub less na konsoli. Szukaj linii zawierających enabled=1 a powyżej nich nazwy repozytorium w nawiasach kwadratowych. Np.[root@waldo yum.repos.d]# cat fedora.repo [fedora] name=Fedora $releasever - $basearch #baseurl=http://download.fedora.redhat.com/pub/fedora/linux/releases/$releasever/Everything/$basearch/os/ mirrorlist=http://mirrors.fedoraproject.org/mirrorlist?repo=fedora-$releasever&arch=$basearch enabled=1 gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-fedora file:///etc/pki/rpm-gpg/RPM-GPG-KEY [fedora-debuginfo] name=Fedora $releasever - $basearch - Debug #baseurl=http://download.fedora.redhat.com/pub/fedora/linux/releases/$releasever/Everything/$basearch/debug/ mirrorlist=http://mirrors.fedoraproject.org/mirrorlist?repo=fedora-debug-$releasever&arch=$basearch enabled=0 gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-fedora file:///etc/pki/rpm-gpg/RPM-GPG-KEY [fedora-source] name=Fedora $releasever - Source #baseurl=http://download.fedora.redhat.com/pub/fedora/linux/releases/$releasever/Everything/source/SRPMS/ mirrorlist=http://mirrors.fedoraproject.org/mirrorlist?repo=fedora-source-$releasever&arch=$basearch enabled=0 gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-fedora file:///etc/pki/rpm-gpg/RPM-GPG-KEY Widać, że aktywne jest repo [fedora] (enabled=1) a repozytoria [fedora-debuginfo] oraz [fedora-source] są wyłączone (enabled=0) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
InIrudeBwoy Napisano Sierpień 15, 2007 Zgłoszenie Share Napisano Sierpień 15, 2007 Moze to glupie pytanie ale jak to moge sprawdzic ? Uzywam tego systemu od niecalego miesiaca wiec dokonca obeznany nie jestem. Możesz też zrobić yum install yumex a potem uruchomić yumex`a. Tam znajdziesz wszystko w okienkach. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
radziok18 Napisano Sierpień 20, 2007 Autor Zgłoszenie Share Napisano Sierpień 20, 2007 w pracy tez mam tak sprawdzic, w domu znalazlem to [fedora] name=Fedora $releasever - $basearch #baseurl=http://download.fedora.redhat.com/pub/fedora/linux/releases/$releasever/Everything/$basearch/os/ mirrorlist=http://mirrors.fedoraproject.org/mirrorlist?repo=fedora-$releasever&arch=$basearch enabled=1 gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-fedora file:///etc/pki/rpm-gpg/RPM-GPG-KEY [updates] name=Fedora $releasever - $basearch - Updates #baseurl=http://download.fedora.redhat.com/pub/fedora/linux/updates/$releasever/$basearch/ mirrorlist=http://mirrors.fedoraproject.org/mirrorlist?repo=updates-released-f$releasever&arch=$basearch enabled=1 gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-fedora # $Id: freshrpms.repo 3341 2005-06-28 18:40:26Z thias $ [freshrpms] name=Fedora Core $releasever - $basearch - Freshrpms #baseurl=http://ayo.freshrpms.net/fedora/linux/$releasever/$basearch/freshrpms/ mirrorlist=http://ayo.freshrpms.net/fedora/linux/$releasever/mirrors-freshrpms enabled=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-freshrpms gpgcheck=1 [livna] name=Livna for Fedora Core $releasever - $basearch - Base baseurl= http://rpm.livna.org/fedora/$releasever/$basearch/ http://livna.cat.pdx.edu/fedora/$rele...$basearch/ http://wftp.tu-chemnitz.de/pub/linux/livna...$basearch/ http://ftp-stud.fht-esslingen.de/pub/Mirro...$basearch/ http://mirror.atrpms.net/livna/fedora/...$basearch/ ftp://mirrors.tummy.com/pub/rpm.livna.org...$basearch/ failovermethod=priority #mirrorlist=http://rpm.livna.org/mirrorlist-7 enabled=1 gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-livna Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 20, 2007 Zgłoszenie Share Napisano Sierpień 20, 2007 Prawdopodobnie wina repo freshrpms. O ile dobrze pamiętam, to gryzie się z livna. Czyli mówiąc krótko - namieszałeś sobie. Musisz odinstalować wszystkie paczki z freshrpms. Wydaje mi się, że najlepiej bedize z pomocą rpm i opcji --nodeps rpm -e --nodeps <pakiety z repo freshrpms> Potem wyłączyć to repo a następnie sprawdzić, które paczki mają rozwalone zależności yum clean all package-cleanup --problems Potem doinstaluj brakujące paczki yum install <paczki których brakuje> Jeśli nie masz package-cleanup, to yum install yum-utils albo jeśli nie pójdzie, to wyszukaj np. na http://rpm.pbone.net paczkę odpowiednią dla Twojej wersji Fedory i architektury (i386 albo x86_64) - najlepiej skorzystaj z wyszukiwania zaawansowanego i odznacz wszystkie dystrybucje poza Twoją wersją Fedory i zainstaluj pakiet przy pomocy rpm, np. rpm -Uvh yum-utils-1.1.6-1.fc7.noarch.rpm Oczywiście mogę się mylić, więc najpierw sprawdź w pracy. Jeśli tam też masz włączone [freshrpms], to chyba powyższą poradę można wyrzucić do kosza W sumie może najłatwiej byłoby zacząć od yum clean all yum update Może wystarczy wyczyścić yuma i będzie OK. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
radziok18 Napisano Sierpień 21, 2007 Autor Zgłoszenie Share Napisano Sierpień 21, 2007 dla rozwiania watpliwosci w pracy jets cos takiego [adobe-linux-i386] name=Adobe Systems Incorporated baseurl=http://linuxdownload.adobe.com/linux/i386/ enabled=1 gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-adobe-linux [fedora] name=Fedora $releasever - $basearch #baseurl=http://download.fedora.redhat.com/pub/fedora/linux/releases/$releasever/Everything/$basearch/os/ mirrorlist=http://mirrors.fedoraproject.org/mirrorlist?repo=fedora-$releasever&arch=$basearch enabled=1 gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-fedora file:///etc/pki/rpm-gpg/RPM-GPG-KEY [updates] name=Fedora $releasever - $basearch - Updates #baseurl=http://download.fedora.redhat.com/pub/fedora/linux/updates/$releasever/$basearch/ mirrorlist=http://mirrors.fedoraproject.org/mirrorlist?repo=updates-released-f$releasever&arch=$basearch enabled=1 gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-fedora [livna] name=Livna for Fedora Core $releasever - $basearch - Base baseurl= http://rpm.livna.org/fedora/$releasever/$basearch/ http://livna.cat.pdx.edu/fedora/$rele...$basearch/ http://wftp.tu-chemnitz.de/pub/linux/livna...$basearch/ http://ftp-stud.fht-esslingen.de/pub/Mirro...$basearch/ http://mirror.atrpms.net/livna/fedora/...$basearch/ ftp://mirrors.tummy.com/pub/rpm.livna.org...$basearch/ failovermethod=priority #mirrorlist=http://rpm.livna.org/mirrorlist-7 enabled=1 gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-livna teraz tak patrzac na moj poprzedni post widze ze w pracy nie mam tego freshrpms tylko dodatkowo zainstalowane adobe Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 21, 2007 Zgłoszenie Share Napisano Sierpień 21, 2007 teraz tak patrzac na moj poprzedni post widze ze w pracy nie mam tego freshrpms tylko dodatkowo zainstalowane adobeNo to problem zlokalizowany. Pozostaje Ci odkręcić to, co się zamieszało Powodzenia. P.S. [adobe-linux-i386] nie przeszkadza, stamtąd idzie chyba tylko Acrobat Reader. Chociaż IMHO evince jest równie dobry i o wiele MB RAM-u lżejszy. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
