Can't Find X Includes
k_myk
Musisz znaleźć numery wersji, do których chesz downgrade'ować i podac w formie
yum update --enable-downgrade libXau-<wersja>
Jaka była poprzednia wersja to pewnie odszukasz w /var/log/yum.log.
Oto co sie dowiedziałem... :/
[root@fedora ~]# yum --allow-downgrade update libX11-1.0.3-8.fc7 libX11-devel-1.0.3-8.fc7 libXau-1.0.3-1.fc7 libXau-devel-1.0.3-1.fc7 libXdmcp-1.0.2-2.fc7 libXdmcp-devel-1.0.2-2.fc7
Loading "kernel-module" plugin
Loading "allowdowngrade" plugin
Loading "fedorakmod" plugin
Setting up Update Process
Could not find update match for libX11-devel-1.0.3-8.fc7
Could not find update match for libXdmcp-devel-1.0.2-2.fc7
Could not find update match for libXdmcp-1.0.2-2.fc7
Could not find update match for libXau-devel-1.0.3-1.fc7
Could not find update match for libXau-1.0.3-1.fc7
Could not find update match for libX11-1.0.3-8.fc7
No Packages marked for Update
To były wszystkie paczki, które trzeba zdowngrade-ować.. Tylko czemu ten błąd? Próbowałem też to zrobić przez localinstall ze ściągniętymi paczkami, ale yum wypisuje mi coś takiego:
yum --allow-downgrade localinstall libX11-1.0.3-8.fc7.i386.rpm libX11-devel-1.0.3-8.fc7.i386.rpm libXau-1.0.3-1.fc7.i386.rpm libXau-devel-1.0.3-1.fc7.i386.rpm libXdmcp-1.0.2-2.fc7.i386.rpm libXdmcp-devel-1.0.2-2.fc7.i386.rpm
Setting up Local Package Process
Examining libX11-1.0.3-8.fc7.i386.rpm: libX11 - 1.0.3-8.fc7.i386
Examining libX11-devel-1.0.3-8.fc7.i386.rpm: libX11-devel - 1.0.3-8.fc7.i386
Examining libXau-1.0.3-1.fc7.i386.rpm: libXau - 1.0.3-1.fc7.i386
Examining libXau-devel-1.0.3-1.fc7.i386.rpm: libXau-devel - 1.0.3-1.fc7.i386
Examining libXdmcp-1.0.2-2.fc7.i386.rpm: libXdmcp - 1.0.2-2.fc7.i386
Examining libXdmcp-devel-1.0.2-2.fc7.i386.rpm: libXdmcp-devel - 1.0.2-2.fc7.i386
libX11-1.0.3-8.fc7.i386.rpm: does not update installed package.
libX11-devel-1.0.3-8.fc7.i386.rpm: does not update installed package.
libXau-1.0.3-1.fc7.i386.rpm: does not update installed package.
libXau-devel-1.0.3-1.fc7.i386.rpm: does not update installed package.
libXdmcp-1.0.2-2.fc7.i386.rpm: does not update installed package.
libXdmcp-devel-1.0.2-2.fc7.i386.rpm: does not update installed package.
Nothing to do
Może coś źle wpisuję?
k_myk
Wg mnie dobrze. Szczerze mówiąc wtyczkę mam zainstalowaną, ale do tej pory nie miałem okazji i potrzeby jej użyć.
Może są jakieś zależności od innych jeszcze pakietów i stąd brak możliwości obniżenia wersji.
Możesz jeszcze spróbować odinstalować poszczególne biblioteki (od razu zobaczysz jak wyglądają zależności - może się okazać, że całe X-y chce wyrzucić) a potem zainstlować stare wersje, ale coś czuję, że się nie uda. Narobiłeś sobie bigosu podłączając repozytoria deweloperskie - to znaaaacznie gorzej niż testing ;) Obawiam się, że teraz to tylko reinstalacja systemu pomoże, czyli może poczekaj na F8 ;)
Możesz jeszcze zaryzykować i odinstalować paczki z F8 przy pomocy rpm i z pominięciem zależności, ale to hardcore.
No i oczywiście możesz przejść na konsolę tekstową, init 3, odinstalować całe X-y (grupę) i zainstalować na nowo, ale pewnie odinstaluje się też Gnome, KDE i inne desktopy, czyli w sumie prawie cały system reinstalujesz. Tyle, że nie będziesz musiał od nowa bujać się ze sterownikami urządzeń, ustawianiem konfiguracji itp., bo całe /etc powinno zostać - prawie, z wyjątkiem X11 - nieruszone.
Wniosek: Najprościej, najskuteczniej i najmilej będzie przeinstalowąc fedore... Tylko... Trzeba ją stawiać od zera z formatem, czy wystarczy update?
Jeszcze jedna sprawa... Repo devel podpiąłem już po problemie z ./configure w akcie desperacji... Zresztą nieważne. Jak problem powtórzy się po reinstalacji to się pochwalę :D
Dzięki za pomoc i pozdrawiam
k_myk
Zależy jak miałeś ustawione teraz. Ja zawsze robię trzy partycje /, /boot i /home. /home zostawiam nieruszone a przy reinstalacji czy instalacji nowej wersji formatuję tylko / i /boot. W ten sposób system instaluje się "na czysto" a pilki użtkownika, ustawienia itp pozostają bez zmian.
Mam / i /home (btw, jakie korzyści niesie oddzielna partycja na /boot?). Chciałem sie tylko dowiedzieć, czy muszę robić format /, czy wystarczy wybrać w anacondzie update system ;) ale teraz to już nie ma znaczenia. ;)
P.S. Tak z innej beczki... Wiem, że nie ten dział i (_wogóle_ → w ogóle) ORT, ale nie pali mnie to narazie i nie chcę zakładacn owego tematu. Uzywa ktoś korn-a? Nie mam pojecia jak zmusić go do współpracy z kontem na o2...
Pozdrawiam i wielkie dzięki za pomoc
k_myk
To tylko moje przyzwyczajenie. W domowym użytku chyba żadna korzyść. Profesjonalnie tzn. w firmie czy jakoś tak, to wart mieć osobno nawet /var, /usr itd. Ze względu na backupy chociażby.
Witam. :)
Jest pewien progres w temacie :) Jak to mówią mniej wprawieni użytkownicy windblows: "Reinstalacja dobra na wszystko". Z racji tego, iż pomimo stażu w użytkowaniu fedory nie uważam się za zaawansowanego użytkownika i pozwoliłem sobie skorzystać z tego nie do końca eleganckiego sposobu :P
Efekt jest taki, że po groupinstall "X Software Development" i doinstalowaniu paru -develi ./configure przechodzi bezbłędnie :) Pojawił sie za to nowy problem. Na razie dopatrzyłem sie tego podczas instalacji niektórych dekoracji okien kde. Po prostu po (chyba) bezbłędnej kompilacji i instalacji dekoracje nie wyświetlają sie na liście w kcontrol... o.O Ten sam problem dotyczy również instalacji ze źródeł tzw. "textshadowedit". Da sie znaleść w systemie plik. textshadowedit.desktop w /usr/local/kde/share/applications/kde o takiej zawartości:
[Desktop Entry]
Encoding=UTF-8
Exec=kcmshell textshadowedit
Icon=fonts
Type=Application
Comment=Textshadow settings
Comment[de]=Textschatten Einstellungen
Name=Desktop Textshadows
Name[de]=Desktop Textschatten
Keywords=textshadowedit,textshadowedit
X-KDE-ModuleType=Library
X-KDE-Library=textshadowedit
X-KDE-HasReadOnlyMode=false
X-KDE-ParentApp=kcontrol
Categories=Qt;KDE;X-KDE-settings-looknfeel
Z tych ciekawszych rzeczy to by było na tyle :) Pozostało mi tylko prosić o drobną pomoc w tej sparwie :)
[EDIT]
Problem rozwiązany. Nikt nie wpadł na to, że fedora MUSI mieć popieprzone ścieżki i tak też było tym razem... Przy ./configure trzeba było podać --prefix=/usr No cóż, może problem nie okazał sie zbyt skomplikowany, ale troche zajęło, zanim połapałem się o co chodzi :P A, że nikt nie pomógł...
[/EDIT]
k_myk
