Xorg.conf I Nvidia
zyguli
Wczoraj, po restarcie X'a, serwer nie wstał. Musiałem skonfigurować go na nowo. To obecny jego, działający kształt:
# Xorg configuration created by system-config-display
Section "ServerLayout"
Identifier	 "single head configuration"
Screen	  0  "Screen0" 0 0
InputDevice	"Keyboard0" "CoreKeyboard"
EndSection
Section "InputDevice"
Identifier  "Keyboard0"
Driver	  "kbd"
Option		"XkbModel" "pc105"
Option		"XkbLayout" "pl"
EndSection
Section "Device"
Identifier  "Videocard0"
Driver	  "nv"
EndSection
Section "Screen"
Identifier "Screen0"
Device	 "Videocard0"
DefaultDepth	 24
SubSection "Display"
	Viewport   0 0
	Depth	 24
	Modes	"1152x864" "1152x768" "1024x768" "800x600" "640x480"
EndSubSection
EndSection
A to moja stara konfiguracja xorg.conf. Używałem TwinView, aiglx i compiz fusion:
# Xorg configuration created by livna-config-display
EndSection
Section "Files"
ModulePath   "/usr/lib/xorg/modules/extensions/nvidia"
ModulePath   "/usr/lib/xorg/modules"
EndSection
Section "ServerFlags"
# Removed Option "Xinerama" "1"
Option		"AIGLX" "on"
Option		"Xinerama" "0"
EndSection
Driver	  "kbd"
Option		"XkbOptions" "altwin:super_win"
EndSection
Identifier  "Mouse0"
Driver	  "mouse"
Option		"Emulate3Buttons" "false"
Option		"Buttons" "7"
Option		"ButtonMapping" "1 2 3 7 6"
Option		"ZAxisMapping" "4 5"
EndSection
Section "Monitor"
Identifier   "Monitor0"
VendorName   "Unknown"
ModelName	"Philips"
HorizSync	31.0 - 68.0
VertRefresh  60.0 - 85.0
EndSection
Section "Monitor"
Identifier   "Monitor1"
ModelName	"LG StudioWorks 775N"
HorizSync	30.0 - 70.0
VertRefresh  50.0 - 160.0
EndSection
Section "Device"
Driver	  "nvidia"
VendorName  "NVIDIA Corporation"
BoardName   "GeForce 6800"
Option		"NoLogo" "true"
Option		"DamageEvents" "True"
Option		"UseEvents" "False"
Option		"TripleBuffer" "True"
Option		"BackingStore" "True"
Option		"AddARGBGLXVisuals" "True"
EndSection
Section "Device"
Identifier  "Videocard1"
Driver	  "nvidia"
BusID	   "PCI:1:0:0"
Screen	  1
EndSection
Section "Screen"
# Removed Option "TwinView" "0"
# Removed Option "metamodes" "CRT-0: 1152x864 +0+0; CRT-0: 1024x768 +0+0; CRT-0: 800x600 +0+0; CRT-0: 640x480 +0+0"
Device	 "Videocard0"
Monitor	"Monitor0"
DefaultDepth	 24
Option		"TwinView" "1"
Option		"metamodes" "CRT-0: 1152x864 +0+0, CRT-1: 1152x864 +1152+0; CRT-0: 1024x768 +0+0; CRT-0: 800x600 +0+0; CRT-0: 640x480 +0+0"
	Depth	 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device	 "Videocard1"
Monitor	"Monitor1"
DefaultDepth	 24
Option		"metamodes" "CRT-1: 1152x864 +0+0"
EndSection
Section "Extensions"
Option		"Composite" "Enable"
EndSection
Zmienił się sterownik z "nvidia" na "nv" a ręczna zmiana w xorg'u z powrotem na nvidia powoduje, że środowisko graficzne nie chce się ładować. Oczywiście skopiowanie starej konfiguracji powoduje wywalenie się X'a. Każdy restart komputera powoduje wywalenie się x'a, mimo że z każdym konfugurowaniem, xorg.conf wyglada tak samo -restart X'a działa, komputera wywołuje te sytuację.
Po wejściu do "nVidia dispay settings" wyświetla się ten komunikat:
You do not appear to be using the NVIDIA X driver. Please edit your X configuration file (just run `nvidia-xconfig` as root), and restart the X server.
Brakuje również tych wszystkich kategorii, które były wcześniej.
Co się stało? Nie wprowadzałem wczoraj żadnych zmian i nie wiem, skąd wziął się problem. Próbowałem PIRUTem usunięcia pakietów livny nvidia-kernel i xorg'a i ogólnie wszelkich, mających jakiś związek i zainstalowania ich na nowo. Nic nie przynosi skutku. Bardzo proszę o pomoc.
Listingi do 12-15 linijek umieszczaj między znacznikami [code] i [/code], dłuższe niż 15 linii pomiędzy [codebox] i [/codebox] - tak jest czytelniej. Przeczytaj "BB Code Help" - WalDo
http://forum.fedora.pl/index.php?showtopic=14930 pkt.II.2 :angry:
http://poradnik.fedora.pl/index.html#graficzne
Off Topic
Osobiście nie polecam korzystania z nakładek typu pirut, yumex itp.
Nie bardzo rozumiem skierowanie do regulaminu. Przeszukałem forum i googla pod kątem problemu, w faq i wiki też nic nie znalazłem. Być może źle szukałem, ale nie można mi zarzucić braku woli, bo poświęciłem na to trochę czasu.
Jeżeli wskazałeś mi jako pomoc to:
su -c "/usr/bin/chcon -cv system_u:object_r:xserver_misc_device_t /etc/udev/devices/nvidia*"
to otrzymuję w konsoli komunikat "/usr/bin/chcon: /etc/udev/devices/nvidia*: Nie ma takiego pliku ani katalogu"
Usprawiedliwiony :)
Wskazałem całą część poradnika dot. grafiki. Na pewno masz zainstalowane sterowniki nVidia? Instalowałeś paczki z repozytorium czy nie daj Boże binarki ze strony nVidii?
Pokaż wynik:
rpm -qa | grep nvidia
Jaką masz kartę? Może potrzebny jest kmod-nvidia-96xx a nie kmod-nvidia?
Usprawiedliwiony :)
Wszystko zrobione było zgodnie "ze sztuką" - korzystałem z poradników. System działał mi od poczatku instalacji, tj od około miesiąca, na sterownikach z paczki, z TwinView (czyli na dwóch monitoracj) z aiglx i compiz-fusion bez żadnych kłopotów - dokładnie na starym xorg'u powyżej - wszystko działało jak należy, aż nagle wczoraj, mimo braku ingerencji w xorg'a, po przeładowaniu X'a, pojawiły się opisane wyżej problemy. Ni stąd ni zowąd coś się zepsuło, a ja nie potrafię tego powiązać z niczym...
A karta, co wskazuje też wklejona treść starego xorg.conf, to geforce 6800.
edit: Wiem, że są w systemie logi. Mógłbym załadować z powrotem stary plik xorg'a i później przedstawić treść loga z komunikatami o przyczynach, tylko wskaż mi, proszę, który to plik.
Piszesz, że edytowałeś ręcznie jeden wpis ("nv" na "nvidia") a próbowałeś podstawić stary xorg.conf? No i czy zrobiłeś to co sugerował system → "You do not appear to be using the NVIDIA X driver. Please edit your X configuration file (just run `nvidia-xconfig` as root), and restart the X server."
[EDIT] No i pokaż jakie masz pakiety nvidia zainstalowane (polecenie w poprzednim moim poście)
Piszesz, że edytowałeś ręcznie jeden wpis ("nv" na "nvidia") a próbowałeś podstawić stary xorg.conf? No i czy zrobiłeś to co sugerował system ? "You do not appear to be using the NVIDIA X driver. Please edit your X configuration file (just run `nvidia-xconfig` as root), and restart the X server."
Próbowałem podstawić stary xcorg.conf - napisałem to w pierwszym poście. Polecenie dane mi przez konfigurator nvidii też wykonałem; tworzy on własną wersję xorg.conf, która też wywała X przy przeładowaniu.
Jedyne polecenie, jakiego się doszukałem to z podaniem modelu karty - nie było pytania o pakiety ;)
zainstalowany pakiet to:
kmod-nvidia.i686 100.14.19-1.2.6.22.9_9
Instalowałem go yumem przez yum install kmod-nvidia, na początku używania systemu.
edit: dokładniej to kmod-nvidia - 100.14.19-1.2.6.22.9_91.fc7.i686
