marciek Napisano Listopad 10, 2007 Zgłoszenie Share Napisano Listopad 10, 2007 Witam... Zainstalowlem ' Oxine ' z repo... i mi się zawiesza. $ oxine [2007-11-22 23:59:19] [ oxine.c: 697] INFO: oxine version: 0.7.0 [2007-11-22 23:59:19] [ oxine.c: 698] INFO: xine-lib version: 1.1.8 [2007-11-22 23:59:19] [ oxine.c: 699] INFO: language: pl_PL.UTF-8 [2007-11-22 23:59:19] [ oxine.c: 700] INFO: codeset: UTF-8 [2007-11-22 23:59:20] [ scheduler.c: 72] INFO: Successfully started scheduler thread. [2007-11-22 23:59:20] [ odk_x11.c: 214] INFO: The current window manager supports 'Extended Window Manager Hints'. *** PULSEAUDIO: Unable to connect: Connection refused [2007-11-22 23:59:20] [ odk.c:1564] ERROR: Failed to open audio port using audio driver 'alsa'! *** PULSEAUDIO: Unable to connect: Connection refused [2007-11-22 23:59:20] [ odk_osd.c:2163] INFO: The current video driver supports unscaled OSD! [2007-11-22 23:59:20] [ odk_joystick.c: 202] ERROR: Failed to open joystick using raw interface! [2007-11-22 23:59:20] [ odk_joystick.c: 348] INFO: Make sure you have the permissions to open the joystick devices. [2007-11-22 23:59:20] [ odk_joystick.c: 349] INFO: Devices oxine tried to open are: [2007-11-22 23:59:20] [ odk_joystick.c: 353] INFO: /dev/js0, /dev/input/js0, [2007-11-22 23:59:20] [ odk_joystick.c: 353] INFO: /dev/js1, /dev/input/js1, [2007-11-22 23:59:20] [ utils_files.c: 249] ERROR: Could not open '/home/marcin/.oxine/playlist_rw.oxp': Nie ma takiego pliku ani katalogu! [2007-11-22 23:59:20] [ menulist.c: 316] INFO: Loading menu file '/home/marcin/.oxine/mainmenu.xml'... [2007-11-22 23:59:20] [ utils_files.c: 249] ERROR: Could not open '/home/marcin/.oxine/mainmenu.xml': Nie ma takiego pliku ani katalogu! [2007-11-22 23:59:20] [ menulist.c: 316] INFO: Loading menu file '/usr/share/oxine/skins/default/mainmenu.xml'... [2007-11-22 23:59:21] [ odk.c: 965] INFO: main MRL: '/usr/share/oxine/skins/default/backgrounds/menu_main_music.png' [2007-11-22 23:59:21] [ odk.c: 966] INFO: subtitle MRL: 'no subtitle' [2007-11-22 23:59:21] [ weather.c: 94] INFO: Successfully started weather thread. [2007-11-22 23:59:21] [ disc_hal.c: 595] INFO: Successfully started HAL monitor thread. Dlaczego ??. Sprawdził ktoś czy Oxine działa ? Jesli ma ktoś używa program niech sie wypowie. ps. może skompilować samemu, hmm... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
marciek Napisano Listopad 24, 2007 Autor Zgłoszenie Share Napisano Listopad 24, 2007 wie moze ktos co jest ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
bartucha82 Napisano Listopad 24, 2007 Zgłoszenie Share Napisano Listopad 24, 2007 Wygląda to tak, jakby OXINE nie mógł uzyskać dostępu do karty dźwiękowej. Generalnie pulseaudio nie może się do niej podłączyć. Jeżeli to ma jakieś ustawienia to spróbuj zmienić sterownik bezpośrednio na alsa. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
marciek Napisano Listopad 24, 2007 Autor Zgłoszenie Share Napisano Listopad 24, 2007 odinstalowalem . " alsa plugin pulse audio " wiec na samej alsie mi chodzi dzwiek ... Ale nadal to samo ... ps. Dziwiek mam ustawiony na "Alsa" ps. Jeśli ktoś może niech zainstaluje OXINE i napisze czy chodzi czy tylko u mnie sie zawisza ... Z gory Dzieki Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Listopad 24, 2007 Zgłoszenie Share Napisano Listopad 24, 2007 ps. Jeśli ktoś może niech zainstaluje OXINE i napisze czy chodzi czy tylko u mnie sie zawisza ...U mnie też zwis. Pokazuje się menu i koniec. Potem już tylko "killall oxine". Jakieś badziewie Nie prościej korzystać z mplayera? Do tego bardzo fajna nakładka smplayer - niestety nie ma chyba w repozytoriach, trzeba samemu paczkę zrobić. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
marciek Napisano Listopad 24, 2007 Autor Zgłoszenie Share Napisano Listopad 24, 2007 No tak tylko ja bym potrzebowal z checia takiego OXINE badz FREEVO taki kombajn ps. mam podlaczony telewizor i na telewizorze mam wlaczone to fajnie by bylo sobie zmieniac to pilotem miedzy tv, filmem i innymi multimediami. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
