Instalacja Vmware
porterneon
Witam.
Mam Fedore 8 i nie moge odpalic na niej vmware.
Przy poleceniu vmware-config.pl lub za pmoca patcha ./runme dostaje taki blad:
Please specify a port for remote console connections to use [904] 904
WARNING: VMware Server has been configured to run on a port different from the
default port. Remember to use this port when connecting to this server.
Unable to find any instance of the super-server "inetd" or "xinetd".  It is
possible that you do not have one of these packages installed on this machine.
Please install "inetd" or "xinetd".
If you do have "inetd" or "xinetd" installed, make sure that /etc/inetd.conf or
/etc/xinetd.d exists.
The configuration will continue, but you should re-run
/usr/bin/vmware-config.pl after you fix the super-server.
Hit enter to continue.
Czego mi brakuje w systemie?
Mam zaisntalowany kernel-devel i gcc.
Prosze moderatora o zamkniecie posta. Okazalo sie ze jakims cudem xinetd sie nie zainstalowal poprawnie i po reinstalacji poszlo. Juz dziala.
Gość
