Init: Id "co" Respawning Too Fast: Disabled For 5 Minutes
samba
Po aktualizacji FC7 i restarcie servera w \var\log\messages dostaję taki błąd
"INIT: Id "co" respawning too fast: disabled for 5 minutes. "
Wie ktoś o co chodzi ?? Co to jest "co" ? I czego ten błąd dotyczy??
Mój inittab
# inittab       This file describes how the INIT process should set up
#               the system in a certain run-level.
# Author:       Miquel van Smoorenburg, <[email protected]>
#               Modified for RHS Linux by Marc Ewing and Donnie Barnes
# Default runlevel. The runlevels used by RHS are:
#   0 - halt (Do NOT set initdefault to this)
#   1 - Single user mode
#   2 - Multiuser, without NFS (The same as 3, if you do not have networking)
#   3 - Full multiuser mode
#   4 - unused
#   5 - X11
#   6 - reboot (Do NOT set initdefault to this)
# System initialization.
si::sysinit:/etc/rc.d/rc.sysinit
l0:0:wait:/etc/rc.d/rc 0
l1:1:wait:/etc/rc.d/rc 1
l2:2:wait:/etc/rc.d/rc 2
l3:3:wait:/etc/rc.d/rc 3
l4:4:wait:/etc/rc.d/rc 4
l5:5:wait:/etc/rc.d/rc 5
l6:6:wait:/etc/rc.d/rc 6
# Trap CTRL-ALT-DELETE
ca::ctrlaltdel:/sbin/shutdown -t3 -r now
# When our UPS tells us power has failed, assume we have a few minutes
# of power left.  Schedule a shutdown for 2 minutes from now.
# This does, of course, assume you have powerd installed and your
# UPS connected and working correctly.
pf::powerfail:/sbin/shutdown -f -h +2 "Power Failure; System Shutting Down"
# If power was restored before the shutdown kicked in, cancel it.
pr:12345:powerokwait:/sbin/shutdown -c "Power Restored; Shutdown Cancelled"
# Run gettys in standard runlevels
co:2345:respawn:/sbin/agetty xvc0 9600 vt100-nav
1:2345:respawn:/sbin/mingetty tty1
2:2345:respawn:/sbin/mingetty tty2
3:2345:respawn:/sbin/mingetty tty3
4:2345:respawn:/sbin/mingetty tty4
5:2345:respawn:/sbin/mingetty tty5
6:2345:respawn:/sbin/mingetty tty6
# Run xdm in runlevel 5
x:5:respawn:/etc/X11/prefdm -nodaemon
samba - stary user a Googli nie zna? Tobie to bana na miesiąc powinienem dać za taki wątek.
http://www.google.pl/search?hl=pl&q=%2...+Google&lr=
Pierwszy link załatwia temat. Chodzi o linię zaczynajacą się od "co:"
Zanim napisałem posta czytałem ten sam link co podałeś (wierz mi albo nie :) .Tam jest napisane że
I'm getting this message, and boot-up procedure hangs here;
Stwierdziłem że jeśli tamtej osobie system się zawieszał podczas boot-up (a mi nie) to pomyślałem że to coś innego i szukałem dalej, ale nic sensownego nie znalazłem dlatego postawiłem pytanie na forum. O tu od razu bana chcą dać :) W każdym bądź razie dzięki za linka !
Zaraz zobaczę czy faktycznie zahaszowanie pomoże pewno tak bo jak porównałem to z moim innittab z kopi zapasowej takiego wpisu wcześniej nie miałem .
Tak na marginesie wytłumacz jeśli wiesz o co chodzi w tym wpisie?? Co to za dziwna konsola??
Sądząc po pogrubieniach (moje) to konsola szeregowa
http://linux.die.net/man/8/agetty
A tutaj chyba wyjaśnione do końca co to :ph34r:
Dzięki za info Arabski. Ja aktualizowałem poniższe pakiety i dopiero po tych aktualizacjach miałem ten błąd.Teraz po zahaszowaniu w inittabie już tego nie mam :) THX.
Jan 04 07:50:48 Installed: system-config-boot - 0.2.15-1.fc7.i386
Jan 04 08:35:50 Updated: gimp-libs - 2:2.4.3-1.fc7.i386
Jan 04 08:35:50 Updated: libcdio - 0.78.2-4.fc7.i386
Jan 04 08:35:51 Updated: imlib - 1:1.9.15-6.fc7.i386
Jan 04 08:35:51 Installed: dirmngr - 1.0.0-2.fc7.i386
Jan 04 08:35:52 Updated: selinux-policy - 2.6.4-66.fc7.noarch
Jan 04 08:36:06 Updated: selinux-policy-targeted - 2.6.4-66.fc7.noarch
Jan 04 08:36:08 Updated: kernel-headers - 2.6.23.12-52.fc7.i386
Jan 04 08:36:34 Installed: kernel - 2.6.23.12-52.fc7.i686
Jan 04 08:36:35 Updated: gnupg2 - 2.0.8-1.fc7.i386
Jan 04 08:36:46 Updated: gimp - 2:2.4.3-1.fc7.i386
Jan 04 08:36:47 Updated: qt4 - 4.3.3-1.fc7.i386
Jan 04 08:36:48 Updated: qt4-x11 - 4.3.3-1.fc7.i386
Jan 04 09:47:56 Installed: system-config-audit.i386 0.4.3-1.fc7
  • 1 month later...
No dobra, też mi ten błąd dziś namieszał, ale zanim coś wyrzucę to chciałbym wiedzieć do końca co to było, poprawcie mnie jeśli się mylę.
1. agetty to program pozwalający zalogować się przez modem, terminal wirtualny, tekstowy, szeregowy (np. takie cos). Gdy podamy nazwę użytkownika agetty przekazuje kontrole do programu login, który pyta nas o hasło oraz przydziela nam powłokę (np. bash).
2. konsola xen jest ustawiona na xvc0
* Fedora system przy starcie tworzy zupełnie na nowo zawartość katalogu /dev/ (zresztą z błędami) a tam nie ma xvc0
* konsola Xen jest ustawiona właśnie na xvc0 więc dopóki sam sobie nie naprawisz systemu (ale pamiętaj, że /dev/ jest psuty po każdym restarcie) to nie masz dostępu do konsoli. żródło
3. 9600 oznacza ustawienia prędkości terminala
4. Ostatnia opcja vt100-nav, umieszczona została przez program instalacyjny systemu Fedora, który domyślnie ustawia wpis inittab, jeśli coś jest podłączone do portu konsoli w trakcie instalacji. Opcja vt100-nav ustawia zmienną środowiskową TERM (??). Jeżeli pominiemy to ustawienie, większość systemów linuksowych przyjmie jako ustawienie domyślnie vt100, co jest na ogół prawidłowe. żródło
Wynikało by z tego, że całe to zamieszanie bierze się po instalacji jądra xen. Ja je miałem, ale nie używałem, a wczoraj wyrzuciłem i dziś system padł. Tylko czy ktoś może to potwierdzić?
