Instalacja Kde 4 ( 3.98 ) Na Fedore 7 ;]
SurX
KDE4 jest w chyba repozytorium rawhide. Nie radzę instalować stamtąd jeśli nie jesteś deweloperem i nie wiesz dokładnie czym to grozi. A grozi rozwaleniem systemu :ph34r:
Poczekaj - będzie gotowe, to sobie z normalnych repozytoriów zainstalujesz.
jestem prawie deweloperem ;] no tak dalej nastepujace zrobilem cos w konsole i ale jest blad
[root@localhost kdesvn]# ./kdesvn-build
Script started processing at Mon Jan  7 22:16:03 2008
<<<  Build Process  >>>
[u][b]Building qt-copy (1/7)
        Waiting for source code update.
Error updating qt-copy, removing from list of packages to build.
        Unable to update qt-copy, build canceled.[/b][/u]
Building kdesupport (1/7)
        Source update complete for kdesupport: 0 files affected.
        Preparing build system for kdesupport.
        Removing files in build directory for kdesupport
        Old build system cleaned, starting new build system.
        Running cmake...
        Compiling, attempt 1...
        Build succeeded after 2 minutes, and 54 seconds.
        Installing kdesupport.
        Overall time for kdesupport was 3 minutes, and 8 seconds.
Building kdelibs (2/7)
        Source update complete for kdelibs: 0 files affected.
        Preparing build system for kdelibs.
        Removing files in build directory for kdelibs
        Running cmake...
7%
Mam taki blad z qt-copy , dlaczego ?
<<<  PACKAGES SUCCESSFULLY BUILT  >>>
kdesupport
kdelibs
<<<  PACKAGES FAILED TO BUILD  >>>
kdepimlibs - ~/kdesvn/log/2008-01-07-06/kdepimlibs/cmake.log
kdemultimedia - ~/kdesvn/log/2008-01-07-06/kdemultimedia/build-1.log
kdegames - ~/kdesvn/log/2008-01-07-06/kdegames/build-1.log
<<<  PACKAGES FAILED TO UPDATE  >>>
qt-copy - No log file
kdebase - No log file
Script finished processing at Mon Jan  7 22:46:05 2008
Your logs are saved in /root/kdesvn/log/2008-01-07-06
qt-copy to jest potrzebne narzedzia do kompilkowania ??? i jeszcze raz sciagam gt-copy ;]
[ 94%] Building CXX object security/crypto/CMakeFiles/kcm_crypto.dir/kcm_crypto_automoc.o
[ 94%] Building CXX object security/crypto/CMakeFiles/kcm_crypto.dir/crypto.o
/root/qt4/lib/libQtSql.so.4: undefined reference to `QObjectPrivate::checkWindowRole()'
collect2: ld returned 1 exit status
make[2]: *** [kate/testkateregression] Błąd 1
make[1]: *** [kate/CMakeFiles/testkateregression.dir/all] Błąd 2
make[1]: *** Oczekiwanie na niezakończone zadania....
[ 94%] Building CXX object security/crypto/CMakeFiles/kcm_crypto.dir/certexport.o
[ 94%] Building CXX object security/crypto/CMakeFiles/kcm_crypto.dir/kdatetimedlg.o
/root/kdesvn/kdelibs/security/crypto/crypto.cpp:1336: warning: unused parameter ?id?
Linking CXX shared module ../../lib/kcm_crypto.so
[ 94%] Built target kcm_crypto
make: *** [all] Błąd 2
:( blad wywalil mi , to jesst kdelibs ,przeciez ja na pewno nie poradze naprawic system .. no ale jak to ? prosze o pomoc;]
[---- łączenie postów ----]
Jednak kde 4 do [cenzura :ph34r:], taki paskudny wyglad ... wlasnie zainstalowalem a teraz kasuje ;/ i wole kde 3.5
Nie pisz postów pod własnymi postami, korzystaj z przycisku "EDYTUJ". WalDo
