PIKeR PL Napisano Luty 23, 2008 Zgłoszenie Share Napisano Luty 23, 2008 Witam, mam problem z kompilacją Lame-3.97 pod Fedorą 7. Configure przechodzi bez problemów, natomiast make już nie... Oto jak kończy się make'owanie /bin/sh ../libtool --tag=CC --mode=link gcc -O3 -ffast-math -funroll-loops -Wall -pipe -static -o lame main.o get_audio.o lametime.o parse.o portableio.o timestatus.o brhist.o ../libmp3lame/libmp3lame.la -lncurses -lm mkdir .libs gcc -O3 -ffast-math -funroll-loops -Wall -pipe -o lame main.o get_audio.o lametime.o parse.o portableio.o timestatus.o brhist.o ../libmp3lame/.libs/libmp3lame.a -lncurses -lm ../libmp3lame/.libs/libmp3lame.a(mpglib_interface.o): In function `lame_decode1_headersB_clipchoice': mpglib_interface.c:(.text+0x71): undefined reference to `freqs' mpglib_interface.c:(.text+0x2ff): undefined reference to `tabsel_123' ../libmp3lame/.libs/libmp3lame.a(mpglib_interface.o): In function `lame_decode1_headersB': mpglib_interface.c:(.text+0x753): undefined reference to `decodeMP3' ../libmp3lame/.libs/libmp3lame.a(mpglib_interface.o): In function `lame_decode1_unclipped': mpglib_interface.c:(.text+0x7cf): undefined reference to `decodeMP3_unclipped' ../libmp3lame/.libs/libmp3lame.a(mpglib_interface.o): In function `lame_decode_init': mpglib_interface.c:(.text+0x80e): undefined reference to `InitMP3' ../libmp3lame/.libs/libmp3lame.a(mpglib_interface.o): In function `lame_decode_exit': mpglib_interface.c:(.text+0x82e): undefined reference to `ExitMP3' ../libmp3lame/.libs/libmp3lame.a(mpglib_interface.o): In function `lame_decode1_headers': mpglib_interface.c:(.text+0x861): undefined reference to `decodeMP3' ../libmp3lame/.libs/libmp3lame.a(mpglib_interface.o): In function `lame_decode_headers': mpglib_interface.c:(.text+0x8c5): undefined reference to `decodeMP3' ../libmp3lame/.libs/libmp3lame.a(mpglib_interface.o): In function `lame_decode': mpglib_interface.c:(.text+0x945): undefined reference to `decodeMP3' ../libmp3lame/.libs/libmp3lame.a(mpglib_interface.o): In function `lame_decode1': mpglib_interface.c:(.text+0x9cf): undefined reference to `decodeMP3' collect2: ld returned 1 exit status make[2]: *** [lame] Błąd 1 make[2]: Opuszczenie katalogu `/usr/local/src/lame-3.97/frontend' make[1]: *** [all-recursive] Błąd 1 make[1]: Opuszczenie katalogu `/usr/local/src/lame-3.97' make: *** [all] Błąd 2 [root@pikergda lame-3.97]# Czy ktoś wie co jest grane? ----------- Listingi do 12-15 linijek umieszczaj między znacznikami [code] i [/code], dłuższe niż 15 linii pomiędzy [codebox] i [/codebox] - tak jest czytelniej. Przeczytaj "BB Code Help" Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Luty 23, 2008 Zgłoszenie Share Napisano Luty 23, 2008 A Ty to dla sportu robisz czy z jakieś potrzeby? Nie może być z repo? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
PIKeR PL Napisano Luty 23, 2008 Autor Zgłoszenie Share Napisano Luty 23, 2008 Z potrzeby ;]. ffmpeg i inne też skompilowałem . Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
morsik Napisano Luty 23, 2008 Zgłoszenie Share Napisano Luty 23, 2008 to ci kolego teraz powiem tak: Te paczki masz w repozytorium livna (rpm.livna.org) nie potrzebnie sie meczyles Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Luty 24, 2008 Zgłoszenie Share Napisano Luty 24, 2008 Z potrzeby ;]Zdradzisz jakiej? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
PIKeR PL Napisano Luty 24, 2008 Autor Zgłoszenie Share Napisano Luty 24, 2008 Że z paczek nic do siebie nie pasuje - a przynajmniej ja tak sądzę . ffmpeg-php nie daje się skompilować jak masz ffmpeg z paczki, cause: checking for ffmpeg headers... configure: error: ffmpeg headers not found. Make sure you've built ffmpeg as shared libs using the --enable-shared option Ot sprawa . Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Luty 24, 2008 Zgłoszenie Share Napisano Luty 24, 2008 checking for ffmpeg headers... configure: error: ffmpeg headers not found. Make sure you've built ffmpeg as shared libs using the --enable-shared option ehhh...czytanie ze zrozumieniem zazwyczaj nie boli... yum install ffmpeg-devel Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
PIKeR PL Napisano Luty 24, 2008 Autor Zgłoszenie Share Napisano Luty 24, 2008 Wydawało mi się, że instalowałem ten pakiet :lammer: ... No ok, poszło, ale mam kolejny problem: make test pokazuje taki oto błąd [root@pikergda ffmpeg-php-0.5.1]# make test Build complete. Don't forget to run 'make test'. PHP Warning: PHP Startup: Unable to load dynamic library 'modules/dbase.so' - modules/dbase.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/dbase.so' - modules/dbase.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/dom.so' - modules/dom.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/dom.so' - modules/dom.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/gd.so' - modules/gd.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/gd.so' - modules/gd.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/json.so' - modules/json.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/json.so' - modules/json.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/mbstring.so' - modules/mbstring.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/mbstring.so' - modules/mbstring.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/mcrypt.so' - modules/mcrypt.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/mcrypt.so' - modules/mcrypt.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/mysql.so' - modules/mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/mysql.so' - modules/mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/mysqli.so' - modules/mysqli.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/mysqli.so' - modules/mysqli.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/pdo.so' - modules/pdo.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/pdo.so' - modules/pdo.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/pdo_mysql.so' - modules/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/pdo_mysql.so' - modules/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/pdo_sqlite.so' - modules/pdo_sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/pdo_sqlite.so' - modules/pdo_sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/xmlreader.so' - modules/xmlreader.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/xmlreader.so' - modules/xmlreader.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/xmlwriter.so' - modules/xmlwriter.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/xmlwriter.so' - modules/xmlwriter.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/xsl.so' - modules/xsl.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/xsl.so' - modules/xsl.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/zip.so' - modules/zip.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/zip.so' - modules/zip.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/dbase.so' - modules/dbase.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/dbase.so' - modules/dbase.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/dom.so' - modules/dom.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/dom.so' - modules/dom.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/gd.so' - modules/gd.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/gd.so' - modules/gd.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/json.so' - modules/json.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/json.so' - modules/json.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/mbstring.so' - modules/mbstring.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/mbstring.so' - modules/mbstring.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/mcrypt.so' - modules/mcrypt.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/mcrypt.so' - modules/mcrypt.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/mysql.so' - modules/mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/mysql.so' - modules/mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/mysqli.so' - modules/mysqli.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/mysqli.so' - modules/mysqli.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/pdo.so' - modules/pdo.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/pdo.so' - modules/pdo.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/pdo_mysql.so' - modules/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/pdo_mysql.so' - modules/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/pdo_sqlite.so' - modules/pdo_sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/pdo_sqlite.so' - modules/pdo_sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/xmlreader.so' - modules/xmlreader.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/xmlreader.so' - modules/xmlreader.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/xmlwriter.so' - modules/xmlwriter.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/xmlwriter.so' - modules/xmlwriter.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/xsl.so' - modules/xsl.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/xsl.so' - modules/xsl.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library 'modules/zip.so' - modules/zip.so: cannot open shared object file: No such file or directory in Unknown on line 0 Warning: PHP Startup: Unable to load dynamic library 'modules/zip.so' - modules/zip.so: cannot open shared object file: No such file or directory in Unknown on line 0 ===================================================================== CWD : /usr/local/src/ffmpeg-php-0.5.1 PHP : /usr/bin/php PHP_SAPI : cli PHP_VERSION : 5.2.4 ZEND_VERSION: 2.2.0 PHP_OS : Linux - Linux pikergda 2.6.18-rhel53.4-vmd #3 SMP Mon Feb 11 00:31:22 CET 2008 i686 INI actual : /etc/php.ini More .INIs : /etc/php.d/dbase.ini,/etc/php.d/dom.ini,/etc/php.d/gd.ini,/etc/php.d/json.ini,/etc/php.d/mbstring.ini,/etc/php.d/mcrypt.ini,/etc/php.d/mysql.ini,/etc/php.d/mysqli.ini,/etc/php.d/pdo.ini,/etc/php.d/pdo_mysql.ini,/etc/php.d/pdo_sqlite.ini,/etc/php.d/xmlreader.ini,/etc/php.d/xmlwriter.ini,/etc/php.d/xsl.ini,/etc/php.d/zip.ini Extra dirs : ===================================================================== Running selected tests. SKIP ffmpeg animatedGif [tests/animatedGif.phpt] reason: gd extension not avaliable. FAIL ffmpeg getAudioBitRate test [tests/getAudioBitRate.phpt] FAIL ffmpeg getAudioChannels test [tests/getAudioChannels.phpt] FAIL ffmpeg getAudioCodec test [tests/getAudioCodec.phpt] FAIL ffmpeg getAudioSampleRate test [tests/getAudioSampleRate.phpt] FAIL ffmpeg getBitRate test [tests/getBitRate.phpt] FAIL ffmpeg getDuration test [tests/getDuration.phpt] FAIL ffmpeg getFileName test [tests/getFileName.phpt] SKIP ffmpeg getFrame test [tests/getFrame.phpt] reason: gd extension not avaliable. FAIL ffmpeg getFrameCount test [tests/getFrameCount.phpt] SKIP ffmpeg getFrame cropping test [tests/getFrameCrop.phpt] reason: gd extension not avaliable. FAIL ffmpeg getFrameHeight test [tests/getFrameHeight.phpt] FAIL ffmpeg getFrameNumber test [tests/getFrameNumber.phpt] FAIL ffmpeg getFrameRate test [tests/getFrameRate.phpt] SKIP ffmpeg getFrameResampled test [tests/getFrameResampled.phpt] reason: gd extension not avaliable. FAIL ffmpeg getFrameWidth test [tests/getFrameWidth.phpt] SKIP ffmpeg getFrame backwards test [tests/getFramesBackwards.phpt] reason: gd extension not avaliable. SKIP ffmpeg getFrames forward test [tests/getFramesForward.phpt] reason: gd extension not avaliable. SKIP ffmpeg getFrames forward test [tests/getFramesForwardPassedEnd.phpt] reason: gd extension not avaliable. SKIP ffmpeg getFramesNoArg test [tests/getFramesNoArg.phpt] reason: gd extension not avaliable. SKIP ffmpeg getFramesResampled test [tests/getFramesResampled.phpt] reason: gd extension not avaliable. FAIL ffmpeg getID3Info() test [tests/getID3Info.phpt] SKIP ffmpeg getFrame without an argument test [tests/getNextKeyFrame.phpt] reason: gd extension not avaliable. SKIP ffmpeg getPTS test [tests/getPTS.phpt] reason: gd extension not avaliable. FAIL ffmpeg getPixelAspectRatio test [tests/getPixelAspectRatio.phpt] FAIL ffmpeg getPixelFormat test [tests/getPixelFormat.phpt] FAIL ffmpeg getVideoBitRate test [tests/getVideoBitRate.phpt] FAIL ffmpeg getVideoCodec test [tests/getVideoCodec.phpt] FAIL ffmpeg hasAudio test [tests/hasAudio.phpt] SKIP ffmpeg getFrame without an argument test [tests/isKeyFrame.phpt] reason: gd extension not avaliable. FAIL ffmpeg persistent movie test [tests/persistentMovie.phpt] ===================================================================== Number of tests : 31 19 Tests skipped : 12 ( 38.7%) -------- Tests warned : 0 ( 0.0%) ( 0.0%) Tests failed : 19 ( 61.3%) (100.0%) Tests passed : 0 ( 0.0%) ( 0.0%) --------------------------------------------------------------------- Time taken : 20 seconds ===================================================================== ===================================================================== FAILED TEST SUMMARY --------------------------------------------------------------------- ffmpeg getAudioBitRate test [tests/getAudioBitRate.phpt] ffmpeg getAudioChannels test [tests/getAudioChannels.phpt] ffmpeg getAudioCodec test [tests/getAudioCodec.phpt] ffmpeg getAudioSampleRate test [tests/getAudioSampleRate.phpt] ffmpeg getBitRate test [tests/getBitRate.phpt] ffmpeg getDuration test [tests/getDuration.phpt] ffmpeg getFileName test [tests/getFileName.phpt] ffmpeg getFrameCount test [tests/getFrameCount.phpt] ffmpeg getFrameHeight test [tests/getFrameHeight.phpt] ffmpeg getFrameNumber test [tests/getFrameNumber.phpt] ffmpeg getFrameRate test [tests/getFrameRate.phpt] ffmpeg getFrameWidth test [tests/getFrameWidth.phpt] ffmpeg getID3Info() test [tests/getID3Info.phpt] ffmpeg getPixelAspectRatio test [tests/getPixelAspectRatio.phpt] ffmpeg getPixelFormat test [tests/getPixelFormat.phpt] ffmpeg getVideoBitRate test [tests/getVideoBitRate.phpt] ffmpeg getVideoCodec test [tests/getVideoCodec.phpt] ffmpeg hasAudio test [tests/hasAudio.phpt] ffmpeg persistent movie test [tests/persistentMovie.phpt] ===================================================================== [root@pikergda ffmpeg-php-0.5.1]# Gdyby te błędy to była prawda, to by mi PHP w sumie nie działało ;x I jak chcę zainstalować dajmy na to php-dbase, yum zwraca następujący błąd: Package php-common - 5.2.4-1.fc7.i386 already installed and latest version Naprawdę, dziwne to :\... PS. Nie wiem czemu wykrywa brak GD. GD2 nie pasuje? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Luty 24, 2008 Zgłoszenie Share Napisano Luty 24, 2008 a masz poinstalowane odpowiednie pakiety? np php-gd itd ?Możesz zainstalować wszystkie moduły php przez yum install php\* Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
PIKeR PL Napisano Luty 24, 2008 Autor Zgłoszenie Share Napisano Luty 24, 2008 Ok, skompilowałem, dopisałem rozszerzenie do php.ini i chyba działa. Po wywołaniu pliku test_ffmpeg.php otrzymuję takie coś: ffmpeg-php version string: 0.5.1 libavcodec build number: 3352580 libavcodec version number: 3352580 libavcodec build number: 3352580 Methods available in class 'ffmpeg_movie': ffmpeg_movie getduration getframecount getframerate getfilename getcomment gettitle getauthor getartist getcopyright getalbum getgenre getyear gettracknumber getframewidth getframeheight getframenumber getpixelformat getbitrate hasaudio hasvideo getnextkeyframe getframe getvideocodec getaudiocodec getaudiochannels getaudiosamplerate getaudiobitrate getvideobitrate getpixelaspectratio Methods available in class 'ffmpeg_frame': ffmpeg_frame togdimage getwidth getheight resize crop iskeyframe getpresentationtimestamp getpts Methods available in class 'ffmpeg_animated_gif': ffmpeg_animated_gif addframe -------------------- Jest OK? Bo zOOm gallery cosik nie widzi rozszerzenia (phpinfo(); zwraca informacje o ffmpeg) . Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
