Rivendell I F8
p4v3u
hello,
Jako ze chce/musze naucztc sie obslugi programu zwanego rivendell - rivendellaudio.org musze/chce go miec na kompie w domu rowniez.
i teraz:
instaluje wysztko wg schematu/tutoriala na ich stornie : http://rivendell.tryphon.org/wiki/index.ph...stall_Rivendell
i daje to taki efekt:
[root@nv rivendell-0.9.84]# ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for g++... g++
checking for C++ compiler default output file name... a.out
checking whether the C++ compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of g++... gcc3
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognize dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking the maximum length of command line arguments... 98304
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
Fixing libtool for -rpath problems.
checking for X... libraries , headers
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for Qt... yes:
    QT_CXXFLAGS=-I/usr/lib/qt-3.3/include -DQT_THREAD_SUPPORT
    QT_DIR=/usr/lib/qt-3.3
    QT_LIBS=-L/usr/lib/qt-3.3/lib -lqt-mt  -lSM -lICE  -lX11 -lXext -lXmu -lXt -lXi
    QT_BIN=/usr/lib/qt-3.3/bin
    QT_UIC=/usr/lib/qt-3.3/bin/uic
    QT_MOC=/usr/lib/qt-3.3/bin/moc
checking correct functioning of Qt installation... failure
configure: error: Failed to find matching components of a complete
                  Qt installation. Try using more options,
                  see ./configure --help.
i juz naprawde nie wiem co mam robic :[
to wazne dla mnie, ktos sie spotkal z takim problemem ??
Ty ze zrozumieniem potrafisz czyttac ??
No, właśnie nie byłem pewien czy aby w tym samym internecie jesteśmy ;)
Co do czytania ze zrozumieniem... Podałeś odnośnik do sekcji "Install Rivendell" tymczasem cała zawartość tej strony jest procedurą. Łącznie z uruchomieniem serwera MySQL i zainstalowaniem pakietów. Nie wspomnialeś czy wykonałeś pozostałe cześci procesu opisane na stronie.
zwykle jak mi ktos daje tutorail to nie zaczynam od srodka. a ze taki link podalem, mialem akurat pod reka.
tak baza zaisnatlowana, dziala nie ma problemow. zreszta nie wiem czyt to ma jakikolwiek zwiazek z bibliotekami qt
update:
root@nv ~]# yum -y install qt-devel
Setting up Install Process
Package qt-devel - 1:3.3.8b-2.fc8.i386 is already installed.
Nothing to do
[root@nv ~]#
Wiesz z ludźmi różnie bywa a nie zanmy się, więc nie wiem czego się po Tobie spodziewać. Sorry.
U mnie ./configure poszło po doinstalowaniu libXmu-devel.
Gość
