Problem Z Instalacją Oracle
danziger
próbuję zainstalować Oralce 11g, ale wywala mi coć takiego
teks w konsoli
Exception java.lang.UnsatisfiedLinkError: /tmp/OraInstall2008-06-15_12-59-37AM/jre/1.4.2/lib/i386/libawt.so: libXp.so.6: cannot open shared object file: No such file or directory occurred..
LOG
Using paramFile: /home/oracle/database/install/oraparam.ini
Checking installer requirements...
Checking operating system version: must be redhat-3, SuSE-9, redhat-4, UnitedLinux-1.0, asianux-1 or asianux-2
                                      Failed <<<<
>>> Ignoring required pre-requisite failures. Continuing...
The commandline for unzip:
/home/oracle/database/install/unzip -qqq ../stage/Components/oracle.swd.jre/1.4.2.8.0/1/DataFiles/\*.jar -d /tmp/OraInstall2008-06-15_12-59-37AM
/home/oracle/database/install/unzip -qqq ../stage/Components/oracle.swd.oui/10.2.0.1.0/1/DataFiles/\*.jar -d /tmp/OraInstall2008-06-15_12-59-37AM
/home/oracle/database/install/unzip -qqq ../stage/Components/oracle.swd.oui.core/10.2.0.1.0/1/DataFiles/\*.jar -d /tmp/OraInstall2008-06-15_12-59-37AM
The number of files bootstrapped for the jre is 590.
The number of files bootstrapped for the oui is 94.
Execvp of the child jre : the cmdline is /tmp/OraInstall2008-06-15_12-59-37AM/jre/1.4.2/bin/java, and the argv is
-Doracle.installer.library_loc=/tmp/OraInstall2008-06-15_12-59-37AM/oui/lib/linux
-Doracle.installer.oui_loc=/tmp/OraInstall2008-06-15_12-59-37AM/oui
-Doracle.installer.bootstrap=TRUE
-Doracle.installer.startup_location=/home/oracle/database/install
-Doracle.installer.jre_loc=/tmp/OraInstall2008-06-15_12-59-37AM/jre/1.4.2
-Doracle.installer.nlsEnabled="TRUE"
-Doracle.installer.prereqConfigLoc=/tmp/OraInstall2008-06-15_12-59-37AM/prereq
-Doracle.installer.unixVersion=2.6.25-14.fc9.i686
-mx150m
-cp
/tmp/OraInstall2008-06-15_12-59-37AM:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/OraInstaller.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/oneclick.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/xmlparserv2.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/srvm.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/share.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/OraInstallerNet.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/xml.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/orai18n-collation.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/orai18n-mapping.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/emCfg.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/ojmisc.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/InstImages.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/InstHelp.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/InstHelp_de.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/InstHelp_es.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/InstHelp_fr.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/InstHelp_it.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/InstHelp_ja.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/InstHelp_ko.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/InstHelp_pt_BR.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/InstHelp_zh_CN.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/InstHelp_zh_TW.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/oracle_ice.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/help4.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/help4-nls.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/ewt3.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/ewt3-swingaccess.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/ewt3-nls.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/swingaccess.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/classes12.jar::/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/OraPrereq.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/jewt4.jar:/tmp/OraInstall2008-06-15_12-59-37AM/oui/jlib/jewt4-nls.jar
oracle.sysman.oii.oiic.OiicInstaller
-scratchPath
-sourceLoc
/home/oracle/database/install/../stage/products.xml
-sourceType
network
-timestamp
-ignoreSysPrereqs
widzę że raczej nie jest to dla Fedory ale na pewno da sie zaistalować :-), czy ktoś instalował i może mi pomóc?
sprawdź czy masz: zainstalowaną wymagana wersję java oraz odpowiednie ścieżki do bibliotek
ponadto podaj na czym Ty chcesz instalować Oracle? RedHat Enterprise? bo widzę że automatyczny skrypt instalacji jest tylko pod kilka wspieranych dystrybucji:
yum mi pokazuje
Analizowanie argumentów instalacji pakietów
Pakiet java-1.5.0-gcj-1.5.0.0-21.fc9.i386 jest już zainstalowany w najnowszej wersji
To chyba nie musze obniżać do 1.4.2.8.0?
Jest rpm dla Fedory z tego co pamiętam, tylko że jakaś okrojona wersja, do ćwiczeń. Na forum było podane gdzie tego szukać. Jeżeli jednak chcesz koniecznie całą wersję stawiać to trochę się pomęczysz. Problemy z SELinux, zakłądanie użytkowników, nadawanie praw, itd itp.
PS: z tego co pamiętam nie zainstalujesz Oracla na maszynie mającej tylko 1GB ram, można to przejść ale też jest z tym trochę zabawy.
ten oraklowy skrypt można łatwo oszukać, albo zabronić mu sprawdzania wersji systemu - http://www.centos.org/modules/newbb/viewto...54&forum=49 ; po logu widzę, że instalator sam się doszukał że nie używasz Red Hata, ale może pomoże
następna sprawa, to ta biblioteka - zainstaluj (_rpma_ → RPM-a) ORT z CentOSa http://rpm.pbone.net/index.php3/stat/4/idp...5.i386.rpm.html ; tylko zastosuj
rpm --nodeps --force -Ivh
gdyż inaczej utoniesz w zależnościach; możliwe, że po instalacji Oracle będziesz mógł odinstalować ten pakiet
ten oraklowy skrypt można łatwo oszukać, albo zabronić mu sprawdzania wersji systemu...; po logu widzę, że instalator sam się doszukał że nie używasz Red Hata, ale może pomoże
następna sprawa, to ta biblioteka - zainstaluj (_rpma_ ? RPM-a) ORT z CentOSa
dzięki udało sie (raczej) zainstalować dzięki waszym wskazówkom.
Niestety, raczej za mało pamięci RAM. Przy próbie uruchomienia mam
ORA-00371: not enough shared pool memory, should be atleast 62198988 bytes
Trochę mnie martwi bo nie wiem czy on chce 62 giga????????? Fakt, mam teraz tylko 786 mega, jak wymienię to będę miał więcej, ale tylko 4 giga. Nadmienię ze jak oracla z tej samej strony instalowałem na XP to co prawda muli ale zainstalował i jeszcze Toada i Crystal Reports uruchomiłem. Komfort pracy żaden ale się dało.
Zmodyfikował init.ora, wprowadziłem tam 350 mega, ale skubany odrzucił mają modyfikację
SQL> startup
ORACLE instance started.
Total System Global Area   96468992 bytes
Fixed Size            1217884 bytes
Variable Size           88083108 bytes
Database Buffers        4194304 bytes
Redo Buffers            2973696 bytes
ORA-00205: error in identifying control file, check alert log for more info
Co proponujecie, kombinować czy na razie odpuścić?
Pod koniec tygodnia kupuję nową płyte główną, e8400 4-8 giga RAM, i dwie baracudy 500 by je w RAID 0 ustawić, więc wtedy raczej nie będzie problemów, ale nie chcę czekać do końca tygodnia :-(
Gość
