Potrzebujęe Pakietu Arecord
DAREK WL.
root@localhost ~]# yum install arecord
Wczytane wtyczki: fastestmirror, refresh-packagekit
Loading mirror speeds from cached hostfile
* livna: rpm.livna.org
* fedora: sunsite.icm.edu.pl
* updates-newkey: sunsite.icm.edu.pl
* updates: sunsite.icm.edu.pl
Ustawianie procesu instalacji
Analizowanie argumentów instalacji pakietów
Nie ma pakietu arecord.
Nie ma niczego do zrobienia
[root@localhost ~]#
Skąd wiec moge wziąć tai program dla fedory :?:
Prosze o pomoc :rolleyes:
I przy okazji jeszcze 1 problem ; nie chce działać program ZYNADDSUBFX
[root@localhost ~]# zynaddsubfx
lash_open_socket: could not connect to host 'localhost', service '14541'
lash_comm_connect_to_server: could not create server connection
jackd 0.109.2
Copyright 2001-2005 Paul Davis and others.
jackd comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK compiled with System V SHM support.
loading driver ..
creating alsa driver ... hw:0|hw:0|1024|2|48000|0|0|nomon|swmeter|-|32bit
control device hw:0
configuring for 48000Hz, period = 1024 frames (21.3 ms), buffer = 2 periods
ALSA: final selected sample format for capture: 32bit little-endian
ALSA: use 2 periods for capture
ALSA: final selected sample format for playback: 32bit little-endian
ALSA: use 2 periods for playback
Connected to JACK server with client name 'LASH_Server'
Opened ALSA sequencer with client ID 128
Listening for connections
ZynAddSubFX - Copyright (c) 2002-2005 Nasca Octavian Paul
Compiled: Feb 19 2008 15:17:35
This program is free software (GNU GPL v.2) and
    it comes with ABSOLUTELY NO WARRANTY.
Try 'zynaddsubfx --help' for command-line options.
Sound Buffer Size =     256 samples
Internal latency =      5.8 ms
ADsynth Oscil.Size =    512 samples
Created project project-1 in directory /root/audio-projects/project-1
Added client 0563d2e5-7823-4a15-81fb-fc04e8c58c3a of class ZynAddSubFX to project project-1
**** alsa_pcm: xrun of at least 1225314441101.312 msecs
Internal SampleRate   = 44100
Jack Output SampleRate= 48000
It is recomanded that the both samplerates to be equal.
Naruszenie ochrony pamięci
[root@localhost ~]# Client 0563d2e5-7823-4a15-81fb-fc04e8c58c3a removed from project project-1
Project project-1 removed
[root@localhost ~]#
Co można zrobićc z tym programem by działał :?:
Z góry dzieki za wzelkie porady :D
Niestety Waldo , rezultat jest taki
[root@localhost ~]# yum provides */arecord
alsa-utils-1.0.17-2.fc9.x86_64 : Advanced Linux Sound Architecture (ALSA)
                               : utilities
Dopasowano z:
Filename    : /usr/bin/arecord
alsa-utils-1.0.16-2.fc9.x86_64 : Advanced Linux Sound Architecture (ALSA)
                               : utilities
Dopasowano z:
[root@localhost ~]# /usr/bin/arecord
-bash: /usr/bin/arecord: Nie ma takiego pliku ani katalogu
[root@localhost ~]#
Gość
