Conky :exec Ucina Text
xmatom
Otóż napisałem dzisiaj skrypta do automatycznego wykrywania pod montowanych systemów plików.
#!/bin/bash
cat /etc/mtab |grep /dev/sd | sed -e "s/[^ ]*//;s/ \//\//;s/ .*//" >~/.fsdt
cat /etc/mtab |grep //*.*.*.*/ | sed -e "s/[^ ]*//;s/ \//\//;s/ .*//" >>~/.fsdt
len=`wc -l ~/.fsdt | sed "s/ \/.*//"`
todo=2
todo1=1
while [ $todo -le $len ]
do
if [ $todo = 2 ]
then
text=`cat ~/.fsdt | sed -e "$todo,$len d"`
else
text=`cat ~/.fsdt | sed -e "$todo,$len d ; 1,$todo1 d" `
todo1=$[todo1 + 1]
fi
echo "\${offset 240}\${color blue}$text:\${color }\$alignr\${fs_free $text }/\${fs_size $text } "
echo "\${offset 240}\${fs_bar 4,180 $text}"
 todo=$[todo + 1]
done
Problem Polega na tym że na terminalu działa dobrze A na Conkym ucina go w pewnym momencie
Na terminalu
${offset 240}${color blue}/:${color }$alignr${fs_free / }/${fs_size / }
${offset 240}${fs_bar 4,180 /}
${offset 240}${color blue}/usr:${color }$alignr${fs_free /usr }/${fs_size /usr }
${offset 240}${fs_bar 4,180 /usr}
${offset 240}${color blue}/home:${color }$alignr${fs_free /home }/${fs_size /home }
${offset 240}${fs_bar 4,180 /home}
${offset 240}${color blue}/boot:${color }$alignr${fs_free /boot }/${fs_size /boot }
${offset 240}${fs_bar 4,180 /boot}
${offset 240}${color blue}/media/DANE:${color }$alignr${fs_free /media/DANE }/${fs_size /media/DANE }
${offset 240}${fs_bar 4,180 /media/DANE}
${offset 240}${color blue}/media/system-xp:${color }$alignr${fs_free /media/system-xp }/${fs_size /media/system-xp }
${offset 240}${fs_bar 4,180 /media/system-xp}
${offset 240}${color blue}/media/GRY:${color }$alignr${fs_free /media/GRY }/${fs_size /media/GRY }
${offset 240}${fs_bar 4,180 /media/GRY}
${offset 240}${color blue}/media/Programs:${color }$alignr${fs_free /media/Programs }/${fs_size /media/Programs }
${offset 240}${fs_bar 4,180 /media/Programs}
${offset 240}${color blue}/mnt/net/user:${color }$alignr${fs_free /mnt/net/user }/${fs_size /mnt/net/user }
${offset 240}${fs_bar 4,180 /mnt/net/user}
${offset 240}${color blue}/mnt/net/Prog:${color }$alignr${fs_free /mnt/net/Prog }/${fs_size /mnt/net/Prog }
${offset 240}${fs_bar 4,180 /mnt/net/Prog}
Na conkym
Problem
Mój conky rc
# Create own window instead of using desktop (requibluein nautilus)
own_window yes
own_window_hints undecorated,below,skip_taskbar
background no
# Use double buffering (blueuces flicker, may not work for everyone)
double_buffer yes
# fiddle with window
use_spacer yes
use_xft yes
# Update interval in seconds
update_interval 5.0
# Minimum size of text area
minimum_size 400 5
# Draw shades?
draw_shades yes
# Text stuff
draw_outline no # amplifies text if yes
draw_borders no
uppercase no # set to yes if you want all text to be in uppercase
draw_borders no
border_margin no
draw_graph_borders no
border_width 0
draw_outline no
stippled_borders 0
# Default colors and also border colors, blue90 == #e5e5e5
default_color white
default_shade_color black
default_outline_color white
own_window_colour brown
own_window_transparent yes
# Text alignment, other possible values are commented
#alignment top_left
alignment top_right
#alignment bottom_left
#alignment bottom_right
# Gap between borders of screen and text
gap_x 20
gap_y 20
# stuff after 'TEXT' will be formatted on screen
override_utf8_locale no
xftfont :size=8
xftalpha 0.8
TEXT
${offset 240}${font :size=12:weight=bold}Time${font }${hr 1}
${offset 240}${font :size=30:weight=bold}${time %H:%M:%S}${font}
${offset 240}${color blue}${time %a,} ${color }${time %e %B %G}${color  blue}  UpTime: ${color }$uptime
${offset 240}${font :size=12:weight=bold}Host${font }${hr 1}
${offset 240}${color blue}Hostname: ${color }$alignr${execi 30 hostname}
${offset 240}${color blue}Ip: ${color }$alignr ${addr eth0}
${offset 240}${color blue}Kernel:${color }$alignr$kernel
${offset 240}${font :size=12:weight=bold}Cpu${font }${hr 1}
${offset 240}${color blue}CPU1:${color }$alignr ${cpu cpu1}% ${acpitemp}
${offset 240}${cpugraph cpu1 20,180 000000 000000}
${offset 240}${color blue}CPU2:${color }$alignr ${cpu cpu2}% ${acpitemp}
${offset 240}${cpugraph cpu2 20,180 000000 000000}
${offset 240}${color blue}Highest CPU:
${offset 240}${color ffffff} ${top name 1}$alignr${top_mem cpu 1}
${offset 240}${color ffffff} ${top name 2}$alignr${top cpu 2}
${offset 240}${color ffffff} ${top name 3}$alignr${top cpu 3}
${offset 240}${color ffffff} ${top name 4}$alignr${top cpu 4}
${offset 240}${font :size=12:weight=bold}Memory${font }${hr 1}
${offset 240}${color blue}Memory:  ${color }$alignr $memperc% $mem/$memmax
${offset 240}${membar 4,180}
${offset 240}${color blue}Swap: ${color }$alignr $swapperc% $swap/$swapmax
${offset 240}${swapbar 4,180}
${offset 240}${color blue}Processes: ${color }$alignr$processes
${offset 240}${color blue}Running:   ${color }$alignr$running_processes
${offset 240}${color blue}Highest Memory:
${offset 240}${color ffffff} ${top_mem name 1}$alignr${top_mem mem 1}
${offset 240}${color ffffff} ${top_mem name 2}$alignr${top_mem mem 2}
${offset 240}${color ffffff} ${top_mem name 3}$alignr${top_mem mem 3}
${offset 240}${color ffffff} ${top_mem name 4}$alignr${top_mem mem 4}
${offset 240}${font :size=12:weight=bold}File Systems${font }${hr 1}
${execp /home/ms/test/conky/fsdetect.sh} #tu jest problem
${offset 240}${font :size=12:weight=bold}Net${font }${hr 1}
${offset 240}${color}Up: ${color }$alignr${upspeed eth0} k/s
${offset 240}${upspeedgraph eth0 20,180 000000 000000}
${offset 240}${color}Down: ${color }$alignr${downspeed eth0}k/s${color}
${offset 240}${downspeedgraph eth0 20,180 000000 000000}
Z guóy dziękuje z pomoc.
Off topic
pod mątowanych systemów plików.
Człowieku! Zlituj się, oszczędź... :ph34r::lol: Nie wiem czy się śmiać czy płakać. Nie myślałeś o zainstalowaniu wtyczki słownika ortograficznego pod Firefoksa?
Gość
