Samba - Bardzo Proszę O Pomoc.
user_1990
Witam. Uruchomiłem sambę , lecz działa mi tylko folder PUBLICZNY mogę na nim zapisywać pliki i je usuwać. A jak stworze kolejnego użytkownika i chcę w jego folderze coś zapisać to wyskakuje mi informacja " MUSISZ MIEĆ UPRAWNIENIA DO TEJ OPERACJI ". Myślałem ze to wina SElinux-a lecz po jego wyłączeniu problem nie znikną.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options (perhaps too
# many!) most of which are not shown in this example
# For a step to step guide on installing, configuring and using samba,
# read the Samba-HOWTO-Collection. This may be obtained from:
#  http://www.samba.org/samba/docs/Samba-HOWTO-Collection.pdf
# Many working examples of smb.conf files can be found in the
# Samba-Guide which is generated daily and can be downloaded from:
#  http://www.samba.org/samba/docs/Samba-Guide.pdf
# Any line which starts with a ; (semi-colon) or a # (hash)
# is a comment and is ignored. In this example we will use a #
# for commentry and a ; for parts of the config file that you
# may wish to enable
# NOTE: Whenever you modify this file you should run the command "testparm"
# to check that you have not made any basic syntactic errors.
# SELINUX NOTES:
# If you want to use the useradd/groupadd family of binaries please run:
# setsebool -P samba_domain_controller on
# If you want to share home directories via samba please run:
# setsebool -P samba_enable_home_dirs on
# If you create a new directory you want to share you should mark it as
# "samba-share_t" so that selinux will let you write into it.
# Make sure not to do that on system directories as they may already have
# been marked with othe SELinux labels.
# Use ls -ldZ /path to see which context a directory has
# Set labels only on directories you created!
# To set a label use the following: chcon -t samba_share_t /path
# If you need to share a system created directory you can use one of the
# following (read-only/read-write):
# setsebool -P samba_export_all_ro on
# or
# setsebool -P samba_export_all_rw on
# If you want to run scripts (preexec/root prexec/print command/...) please
# put them into the /var/lib/samba/scripts directory so that smbd will be
# allowed to run them.
# Make sure you COPY them and not MOVE them so that the right SELinux context
# is applied, to check all is ok use restorecon -R -v /var/lib/samba/scripts
#======================= Global Settings =====================================
[global]
# ----------------------- Netwrok Related Options -------------------------
# workgroup = NT-Domain-Name or Workgroup-Name, eg: MIDEARTH
# server string is the equivalent of the NT Description field
# netbios name can be used to specify a server name not tied to the hostname
# Interfaces lets you configure Samba to use multiple interfaces
# If you have multiple network interfaces then you can list the ones
# you want to listen on (never omit localhost)
# Hosts Allow/Hosts Deny lets you restrict who can connect, and you can
# specifiy it as a per share option as well
workgroup = jars
server string = Samba Server Version %v
;	netbios name = JARS_SERWER
;	netbios aliases= SERWER
;	interfaces = lo eth0
;	hosts allow = 127. 192.168.
# --------------------------- Logging Options -----------------------------
# Log File let you specify where to put logs and how to split them up.
# Max Log Size let you specify the max size log files should reach
# logs split per machine
log file = /var/log/samba/log.%m
# max 50KB per log file, then rotate
max log size = 50
# ----------------------- Standalone Server Options ------------------------
# Scurity can be set to user, share(deprecated) or server(deprecated)
# Backend to store user information in. New installations should
# use either tdbsam or ldapsam. smbpasswd is available for backwards
# compatibility. tdbsam requires no further configuration.
security = user
;	passdb backend = smbpasswd
# ----------------------- Domain Members Options ------------------------
# Security must be set to domain or ads
# Use the realm option only with security = ads
# Specifies the Active Directory realm the host is part of
# Use password server option only with security = server or if you can't
# use the DNS to locate Domain Controllers
# The argument list may include:
#   password server = My_PDC_Name [My_BDC_Name] [My_Next_BDC_Name]
# or to auto-locate the domain controller/s
#   password server = *
;	realm = MY_REALM
;	password server = <NT-Server-Name>
# ----------------------- Domain Controller Options ------------------------
# Security must be set to user for domain controllers
# Domain Master specifies Samba to be the Domain Master Browser. This
# allows Samba to collate browse lists between subnets. Don't use this
# if you already have a Windows NT domain controller doing this job
# Domain Logons let Samba be a domain logon server for Windows workstations.
# Logon Scrpit let yuou specify a script to be run at login time on the client
# You need to provide it in a share called NETLOGON
# Logon Path let you specify where user profiles are stored (UNC path)
# Various scripts can be used on a domain controller or stand-alone
# machine to add or delete corresponding unix accounts
;	domain master = yes
;	domain logons = yes
# the login script name depends on the machine name
;	logon script = %m.bat
# the login script name depends on the unix user used
;	logon script = %u.bat
;	logon path = \\%L\Profiles\%u
# disables profiles support by specifing an empty path
;	logon path =
;	add user script = /usr/sbin/useradd "%u" -n -g users
;	add group script = /usr/sbin/groupadd "%g"
;	add machine script = /usr/sbin/useradd -n -c "Workstation (%u)" -M -d /nohome -s /bin/false "%u"
;	delete user script = /usr/sbin/userdel "%u"
;	delete user from group script = /usr/sbin/userdel "%u" "%g"
;	delete group script = /usr/sbin/groupdel "%g"
# ----------------------- Browser Control Options ----------------------------
# set local master to no if you don't want Samba to become a master
# browser on your network. Otherwise the normal election rules apply
# OS Level determines the precedence of this server in master browser
# elections. The default value should be reasonable
# Preferred Master causes Samba to force a local browser election on startup
# and gives it a slightly higher chance of winning the election
;	local master = no
;	os level = 33
;	preferred master = yes
#----------------------------- Name Resolution -------------------------------
# Windows Internet Name Serving Support Section:
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
# - WINS Support: Tells the NMBD component of Samba to enable it's WINS Server
# - WINS Server: Tells the NMBD components of Samba to be a WINS Client
# - WINS Proxy: Tells Samba to answer name resolution queries on
#   behalf of a non WINS capable client, for this to work there must be
#   at least one	WINS Server on the network. The default is NO.
# DNS Proxy - tells Samba whether or not to try to resolve NetBIOS names
# via DNS nslookups.
;	wins support = yes
;	wins server = w.x.y.z
;	wins proxy = yes
;	dns proxy = yes
# --------------------------- Printing Options -----------------------------
# Load Printers let you load automatically the list of printers rather
# than setting them up individually
# Cups Options let you pass the cups libs custom options, setting it to raw
# for example will let you use drivers on your Windows clients
# Printcap Name let you specify an alternative printcap file
# You can choose a non default printing system using the Printing option
;	load printers = yes
cups options = raw
;	printcap name = /etc/printcap
#obtain list of printers automatically on SystemV
;	printcap name = lpstat
;	printing = cups
# --------------------------- Filesystem Options ---------------------------
# The following options can be uncommented if the filesystem supports
# Extended Attributes and they are enabled (usually by the mount option
# user_xattr). Thess options will let the admin store the DOS attributes
# in an EA and make samba not mess with the permission bits.
# Note: these options can also be set just per share, setting them in global
# makes them the default for all shares
;	map archive = no
;	map hidden = no
;	map read only = no
;	map system = no
;	encrypt passwords = yes
;	guest ok = no
;	guest account = nobody
username map = /etc/samba/smbusers
;	store dos attributes = yes
#============================ Share Definitions ==============================
[homes]
comment = Home Directories
browseable = no
writable = yes
;	valid users = %S
;	valid users = MYDOMAIN\%S
[printers]
comment = All Printers
path = /var/spool/samba
browseable = no
;	guest ok = no
;	writable = No
printable = yes
# Un-comment the following and create the netlogon directory for Domain Logons
;	[netlogon]
;	comment = Network Logon Service
;	path = /var/lib/samba/netlogon
;	guest ok = yes
;	writable = no
;	share modes = no
# Un-comment the following to provide a specific roving profile share
# the default is to use the user's home directory
;	[Profiles]
;	path = /var/lib/samba/profiles
;	browseable = no
;	guest ok = yes
# A publicly accessible directory, but read only, except for people in
# the "staff" group
;	[public]
;	comment = Public Stuff
;	path = /home/samba
;	public = yes
;	writable = yes
;	printable = yes
;	write list = +staff
[DAWID_SERWER]
path = /DAWID_SERWER
writeable = yes
;	browseable = yes
guest ok = yes
Proszę o pomoc. Pozdrawiam Dawid
Edytowane przez WalDo
Prosze korzystać z odpowiednich tagów → code, codebox
może to ci coś pomoże...
http://www.reallylinux.com/docs/sambaserver.shtml
ja w oparciu o tą publikacje stawiałem swoją sambę i jak na razie jest ok :)
moja konfiguracja samby :
[global]
workgroup = osemka
netbios name = Zajec
server string = samba
security = user
nt acl support = yes
nt pipe support = yes
domain master = no
local master = no
os level = 0
name resolve order = wins
wins server = 10.8.0.2
guest ok = yes
guest account = guest
[filmy]
path = /dane/filmy
;	browseable = yes
;	writeable = No
[muzyka]
path = /dane/muzyka
;	writeable = No
;	browseable = yes
Może usuń ; na początku odpowiedniej linii
; valid users = %S
Witam ponownie. Bardzo dziękuję za pomoc. ALE :P
Wszystko działało do czasu kiedy chciałem zmienić połączenie z internetem z DHCP na manualne. Kiedy chcę się zalogować w windowsie na uzytkownika to po wpisaniu danych(login: dawid , pass: dawid10) i wciśnięciu przycisku OK , znów pojawia się okno do logowania tyle ze w nazwie uzytkownika jest wpisane: BIURO\dawid . Nie dam rady się zalogować. Jeszcze zaznaczam że mam folder PUBLICZNY dla wszystkich na który można wejść bez hasła , ten folder działa bez zarzutów.
smb:
# SELINUX NOTES:
# or
[global]
workgroup = JARS
;	interfaces = lo eth* 192.168.
max log size = 50
security = share
passdb backend = tdbsam
;	realm = MY_REALM
;	logon path =
;	local master = no
;	os level = 33
;	wins proxy = yes
;	dns proxy = yes
cups options = raw
;	printing = cups
;	map archive = no
;	map hidden = no
;	map system = no
[homes]
browseable = no
writable = yes
;	valid users = %S
[printers]
browseable = no
;	guest ok = no
;	writable = No
printable = yes
;	[netlogon]
;	guest ok = yes
;	writable = no
;	share modes = no
;	[Profiles]
;	browseable = no
;	guest ok = yes
# the "staff" group
;	[public]
;	public = yes
;	writable = yes
;	printable = no
[dawid]
path = /home/dawid
writeable = yes
;	browseable = yes
valid users = dawid
[jars]
path = /serwer/jars
writeable = yes
;	browseable = yes
valid users = dawid, dawid_j, jaromir, robert
[public]
path = /serwer/public
writeable = yes
;	browseable = yes
guest ok = yes
smbusers:
root = administrator admin
nobody = guest pcguest smbguest
dawid = dawid
jaromir = jaromir
robert = robert
dawid_j = dawid_j
imhosts:
127.0.0.1 localhost
Zależy mi na tym żeby serwer łączył się z internetem na tym IP na którym ja chcę czyli 192.168.1.11 ale żeby też samba działała bez zarzutów jak wcześniej. Bardzo proszę o pomoc. Pozdrawiam Dawid
a jak w oknie logowania wpiszesz:
nazwa kompa z samba\dawid i swoje haslo - tak dziala?
Dalej mam ten sam problem.
"Kiedy chcę się zalogować w windowsie na uzytkownika to po wpisaniu danych(login: dawid , pass: dawid10) i wciśnięciu przycisku OK , znów pojawia się okno do logowania tyle ze w nazwie uzytkownika jest wpisane: BIURO\dawid . Nie dam rady się zalogować. Jeszcze zaznaczam że mam folder PUBLICZNY dla wszystkich na który można wejść bez hasła , ten folder działa bez zarzutów. "
Pomóżcie , bardzo proszę...
aaaa kolega na viście - stary problem - tu masz rozwiązanie http://www.linux-watch.com/news/NS4434907782.html
streszczenie dła współczesnej młodzieży
Click "Start -> Run." Then, type in the Run field: "secpol.msc." That will bring you to Vista's security policy system. Once there, use "Go to: Local Policies > Security Options" and then find "Network Security: LAN Manager" authentication level. Once there, change the Setting from "Send NTLMv2 response only" to "Send LM & NTLM -- use NTLMv2 session security if negotiated."
