piotrino Napisano Lipiec 5, 2009 Zgłoszenie Share Napisano Lipiec 5, 2009 Witam mam drukarkę Phaser-3117(laserowa), system domyslnie po instalacji systemu fedory 11 zainstalował drukarkę w systemie. Szkopuł w tym że nie chce mi (_wogóle_ → w ogóle) ORT drukować ......W czym może być problem i jak mogę ją skonfigurować, żeby drukowało mi bez problemów...Pozdrawiam serdecznie. P.S Ściągłem sterownik do (_linuxa_ → Linuksa) ORT ze strony xeroxa pod (_linuxa_ → Linuksa) ORT, rozpakowałem go ale tu mam problem jak dalej go zainstalować" podaję plik readme: Linux Printing Package Release Candidate ---------------------------------------- The Linux Printer Package is an integrated suite of utilities for the Linux operating system, allowing you to configure and manage Linux laser printers in a user-friendly way. SUPPORTED CONFIGURATIONS ------------------------ - Linux distributions : Redhat 6.x, Mandrake 7.x, SuSE 6.x, Debian 2.2, Caldera OpenLinux 3.x, TurboLinux, Slackware 7.x, Linux/PPC, Yellow Dog, and newer versions. - Linux kernel 2.2 and up - GNU Libc version 2.1 and up Requirements : - GTK+ 1.2 libraries ; these usually come with the GNOME desktop environment, but if your distribution didn't install those by default, you will need to install them before you can use the graphical tools from this package. - A working Ghostscript installation - CUPS 1.1.x is the preferred printing system for this package, but the Linux Package will accommodate any other printing system based on LPD. CUPS 1.1.14 packages are provided as a convenience with this program, and can be installed or upgraded from the installer. However, users of Debian and Slackware distributions should make sure they have an active printing system (such as LPD) before proceeding with the installation. INSTALLATION ------------ You need to be logged in as the super-user (root) to be able to install this package. - Run the 'setup.sh' script on the CDROM to launch the installation program, if the installer didn't start automatically upon insertion of the CDROM in your drive. - You may choose either the "Recommended" or "Expert" types of installation. "Recommended" is fully automated and won't require any interaction on your part. It will install the product under /usr/local/linuxprinter. The "Expert" installation allows you to fine-tune these settings and choose where the package will be installed. - Once the installation is done, you will be offered the option to start the Configuration Tool, which allows to install and configure new Linux printers into your Linux system. - The configuration tool can later be launched by using the 'linux-config' command, or through the menu item that may have been added to your Gnome / KDE menus. GETTING MORE HELP ----------------- Complete Online help is available through the configuration tool. Click on the "Help" button in the dialogs. UNINSTALLATION -------------- To remove this package, you can use the 'linux-uninstall' command, or choose "Uninstall" in the File menu from the Configuration Tool. Jak zrozumiałem z tekstu to muszę zainstalować setup.sh??? Proszę o wyjasnienie tego problemu. Próbuję konfigurować drukarkę z poziomu przeglądarki tzn. tu Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
fafig Napisano Lipiec 5, 2009 Zgłoszenie Share Napisano Lipiec 5, 2009 wlaczasz terminal najpierw chmod +x setup.sh odpalasz przez ./setup.sh Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
piotrino Napisano Lipiec 5, 2009 Autor Zgłoszenie Share Napisano Lipiec 5, 2009 wlaczasz terminal najpierw chmod +x setup.sh odpalasz przez ./setup.sh Dzięki za odpowiedz. Po wpisaniu wyszło tak: [root@localhost Pobrane]# cd Linux_Printer_Package [root@localhost Linux_Printer_Package]# dir autorun cups help locale ppd scripts setup.sh bin data icon.xpm misc README.txt setup.data setup.sh~ [root@localhost Linux_Printer_Package]# chmod +x setup.sh [root@localhost Linux_Printer_Package]# ./setup.sh ./setup.sh: line 7: .: filename argument required .: usage: . filename [arguments] [root@localhost Linux_Printer_Package]# ./setup.sh ./setup.sh: line 7: .: filename argument required .: usage: . filename [arguments] [root@localhost Linux_Printer_Package]# dir Nie zainstalowało mi ....Jakiś argument jest żądany .. P.S Wskazałem w konfiguracjai drukarki ppd.file(phaser3317) to dostałem odpowiedz ze drukarka żada ppmtospl2 -próbowałem to zainstalować przez yum w konsolo: piotrino@localhost ~]$ su Password: [root@localhost piotrino]# yum install ppmtospl2 Loaded plugins: refresh-packagekit Setting up Install Process No package ppmtospl2 available. Nothing to do [root@localhost piotrino]# Nie na takiego pakietu... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Lipiec 5, 2009 Zgłoszenie Share Napisano Lipiec 5, 2009 Na Twoim miejscu jednak próbowałbym uruchomić ją na sterowniku domyślnym (tym fedorowym). Spróbuj coś wydrukować i popatrz w logi cupsa co się dzieje /var/log. W System->Administracja powinien być jakiś graficzny konfigurator, może spróbuj pozmieniać coś z interfejsem obsługującym drukarkę, bo usb może być wykrywane przez hal lub jakoś inaczej Aktualizowałeś system? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
piotrino Napisano Lipiec 5, 2009 Autor Zgłoszenie Share Napisano Lipiec 5, 2009 Na Twoim miejscu jednak próbowałbym uruchomić ją na sterowniku domyślnym (tym fedorowym). Spróbuj coś wydrukować i popatrz w logi cupsa co się dzieje /var/log. W System->Administracja powinien być jakiś graficzny konfigurator, może spróbuj pozmieniać coś z interfejsem obsługującym drukarkę, bo usb może być wykrywane przez hal lub jakoś inaczej Aktualizowałeś system? Dwa dni temu instalowałem z płytki fedorę 11, ale spróbuję ją zaaktualizować z poziomu konsoli.... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
