mikhail Napisano Sierpień 11, 2009 Zgłoszenie Share Napisano Sierpień 11, 2009 Mam problem z kartą Wi-Fi Ralink RT2700E. Nie łączy mnie z internetem. Network Manager jej nie widzi. Oto co wyrzuciło lspci: 00:00.0 Host bridge: Intel Corporation Mobile 945GME Express Memory Controller Hub (rev 03) 00:02.0 VGA compatible controller: Intel Corporation Mobile 945GME Express Integrated Graphics Controller (rev 03) 00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03) 00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 02) 00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 02) 00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 02) 00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 02) 00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 02) 00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 02) 00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 (rev 02) 00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 02) 00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2) 00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02) 00:1f.2 IDE interface: Intel Corporation 82801GBM/GHM (ICH7 Family) SATA IDE Controller (rev 02) 01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 02) 02:00.0 Network controller: RaLink RT2860 Widzi ją jako RT2860 (ponoć do RT2700E instaluje się te same sterowniki). Teraz lsmod: Module Size Used by fuse 49764 2 sco 9356 2 bridge 41496 0 stp 1944 1 bridge llc 4788 2 bridge,stp bnep 10888 2 l2cap 18912 3 bnep bluetooth 44908 5 sco,bnep,l2cap sunrpc 152416 1 ip6t_REJECT 3160 2 nf_conntrack_ipv6 11368 2 ip6table_filter 3136 1 ip6_tables 10728 1 ip6table_filter ipv6 232512 22 ip6t_REJECT,nf_conntrack_ipv6 cpufreq_ondemand 6052 2 acpi_cpufreq 8220 0 dm_multipath 13636 0 uinput 6496 0 snd_hda_codec_realtek 189448 1 snd_hda_intel 23920 2 snd_hda_codec 54288 2 snd_hda_codec_realtek,snd_hda_intel snd_hwdep 6596 1 snd_hda_codec iTCO_wdt 10448 0 snd_pcm 62092 2 snd_hda_intel,snd_hda_codec uvcvideo 49804 0 iTCO_vendor_support 2736 1 iTCO_wdt snd_timer 17896 1 snd_pcm videodev 32216 1 uvcvideo v4l1_compat 11560 2 uvcvideo,videodev usb_storage 82544 0 r8169 28356 0 snd 49084 10 snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_timer pcspkr 2156 0 soundcore 5404 1 snd snd_page_alloc 7572 2 snd_hda_intel,snd_pcm mii 4008 1 r8169 wmi 5868 0 ata_generic 4264 0 pata_acpi 3624 0 i915 147140 2 drm 166144 2 i915 i2c_algo_bit 4788 1 i915 i2c_core 18016 3 i915,drm,i2c_algo_bit video 17344 1 i915 output 2324 1 video I na koniec iwconfig: lo no wireless extensions. eth0 no wireless extensions. pan0 no wireless extensions. Wie ktoś, co trzeba zrobić? Dopiero zaczynam z Linuksem, więc proszę o wyrozumiałość. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Sierpień 11, 2009 Zgłoszenie Share Napisano Sierpień 11, 2009 W pierwszym linku w google dostałem opis jak zainstalować. Ściągnij sterownik http://www.ralinktech.com.tw/data/drivers/...irmware_V11.zip rozpakuj i skompiluj make & make install na końcu załaduj moduł modprobe rt2860sta . Można też użyć ndiswrappera i sterownika z windowsa. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
moorray Napisano Sierpień 11, 2009 Zgłoszenie Share Napisano Sierpień 11, 2009 Można też użyć paczki z RPM Fusion Jak zainstalować to repozytorium oraz jak instaluje się pakiety dowiesz się na wiki: http://wiki.fedora.pl/wiki/Poradnik_F11_(L...um_RPMFusion.3F Potem wystarczy, że zainstalujesz pakiet kmod-rt2860 i po restarcie powinno śmigać Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Sierpień 11, 2009 Zgłoszenie Share Napisano Sierpień 11, 2009 Można też użyć paczki z RPM Fusion Racja, mój błąd, że nie sprawdziłem. To jest zdecydowanie lepsza metoda. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mikhail Napisano Sierpień 11, 2009 Autor Zgłoszenie Share Napisano Sierpień 11, 2009 Można też użyć paczki z RPM Fusion Jak zainstalować to repozytorium oraz jak instaluje się pakiety dowiesz się na wiki: http://wiki.fedora.pl/wiki/Poradnik_F11_(L...um_RPMFusion.3F Potem wystarczy, że zainstalujesz pakiet kmod-rt2860 i po restarcie powinno śmigać RPM Fusion wskoczył bez problemów. Gorzej z kmod-rt2860. Oto co się pojawiło: [Michal@msiu100 ~]$ su - Hasło: [root@msiu100 ~]# cd /home/Michal/Pobrane [root@msiu100 Pobrane]# rpm -Uvh kmod-rt2860-2.6.29.6-213.fc11.i586-2.1.2.0-1.fc11.5.i586.rpm ostrzeżnie: kmod-rt2860-2.6.29.6-213.fc11.i586-2.1.2.0-1.fc11.5.i586.rpm: Podpis Nagłówek V3 RSA/SHA256: NOKEY, identyfikator klucza 8fcff4da błąd: Niespełnione zależności: kernel-uname-r = 2.6.29.6-213.fc11.i586 jest wymagany przez kmod-rt2860-2.6.29.6-213.fc11.i586-2.1.2.0-1.fc11.5.i586 rt2860-kmod-common >= 2.1.2.0 jest wymagany przez kmod-rt2860-2.6.29.6-213.fc11.i586-2.1.2.0-1.fc11.5.i586 Próbowałem znaleźć, nie udało się. Znalazłem natomiast parę wypowiedzi na forach, dotyczące takiego lub podobnego problemu. Próbowałem opcji --force i --nodeps, jak ktoś gdzieś doradził, ale nic z tego. Co z tym zrobić? Spróbować starszą wersję kmod-rt2860, czy co...? Aha, co się tyczy was obu, wielkie dzięki za szybkie odpowiedzi. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
moorray Napisano Sierpień 11, 2009 Zgłoszenie Share Napisano Sierpień 11, 2009 Próbowałem znaleźć, nie udało się. Znalazłem natomiast parę wypowiedzi na forach, dotyczące takiego lub podobnego problemu. Próbowałem opcji --force i --nodeps, jak ktoś gdzieś doradził, ale nic z tego. Opcji --force używa się tylko, jeśli ma się 100% pewność jakie będą skutki. Dotyczy to nie tylko rpm, ale też wielu innych programów. To tak na przyszłość. Co do pakietu, który, jak rozumiem zainstalowałeś, możesz go z czystym sumieniem usunąć i zainstalować przy pomocy yum-a, tzn. yum install kmod-rt2860 O yum-ie na wiki napisane jest kilka linii niżej niż o rpm. YUM korzysta z repozytoriów pakietów (np. RPM Fusion), dzięki temu nie musisz niczego ściągać ręcznie, po prostu wpisujesz yum install <nazwa pakietu>, potem tylko potwierdzasz czy wszystko jest ok i dostajesz pakiet w wersji odpowiedniej dla Twojego jądra. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mikhail Napisano Sierpień 12, 2009 Autor Zgłoszenie Share Napisano Sierpień 12, 2009 Opcji --force używa się tylko, jeśli ma się 100% pewność jakie będą skutki. Dotyczy to nie tylko rpm, ale też wielu innych programów. To tak na przyszłość. Dzięki, będę uważał. O yum-ie na wiki napisane jest kilka linii niżej niż o rpm. YUM korzysta z repozytoriów pakietów (np. RPM Fusion), dzięki temu nie musisz niczego ściągać ręcznie, po prostu wpisujesz yum install <nazwa pakietu>, potem tylko potwierdzasz czy wszystko jest ok i dostajesz pakiet w wersji odpowiedniej dla Twojego jądra. Rozumiem, że muszę być podłączony do internetu...? Jeśli tak, to ta opcja odpada. (W tej chwili łączę się przez Windowsa - aż wstyd się przyznać). Jutro spróbuję zainstalować jakąś wcześniejszą wersję kmod-rt2860 i dam wam znać, co mi z tego wyszło. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
moorray Napisano Sierpień 12, 2009 Zgłoszenie Share Napisano Sierpień 12, 2009 Rozumiem, że muszę być podłączony do internetu...? Jeśli tak, to ta opcja odpada. (W tej chwili łączę się przez Windowsa - aż wstyd się przyznać). Jutro spróbuję zainstalować jakąś wcześniejszą wersję kmod-rt2860 i dam wam znać, co mi z tego wyszło. No tak, sorry. Żeby znów nie ściągać w ciemno, sprawdź sobie wersję kernela, w konsoli wpisujesz: uname -r i ściągnij pasujący pakiet. BTW musisz też ściągnąć rt2860-kmod-common, ale ten pakiet nie zależy od wersji jądra, więc nie powinno być problemów. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mikhail Napisano Sierpień 12, 2009 Autor Zgłoszenie Share Napisano Sierpień 12, 2009 Wielkie dzięki, sprawdzę. Dam znać, jak poszło. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Sierpień 12, 2009 Zgłoszenie Share Napisano Sierpień 12, 2009 Jeśli nie aktualizowałeś systemu (pewnie nie) to masz kernel release i w zależności od tego czy to kernel zwykły czy PAE musisz ściągnąć takie pakiety ręcznie. Przykładowo jeśli zwykły (sprawdź tak jak napisał moorray) to będziesz potrzebował http://download1.rpmfusion.org/free/fedora...mod-rt2860.html i prawdopodobnie http://download1.rpmfusion.org/free/fedora....fc11.i586.html (musisz instalować oba naraz). Możliwe jeszcze, że będzie chciał kernel-headers lub kernel-devel, ale to się okaże przy instalacji. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mikhail Napisano Sierpień 13, 2009 Autor Zgłoszenie Share Napisano Sierpień 13, 2009 Internet działa przyzwoicie. Wielkie dzięki za pomoc. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
