ronon Napisano Sierpień 17, 2009 Zgłoszenie Share Napisano Sierpień 17, 2009 Witajcie, Mam Fedore 10 i zainstalowałem na niej Postfix-a i Dovecot ze strony: http://www.linuxmail.info/postfix-smtp-ser...howto-centos-5/. Oto te konfiguracje: Postfix, main.cf # Global Postfix configuration file. This file lists only a subset # of all parameters. For the syntax, and for a complete parameter # list, see the postconf(5) manual page (command: "man 5 postconf"). # # For common configuration examples, see BASIC_CONFIGURATION_README # and STANDARD_CONFIGURATION_README. To find these documents, use # the command "postconf html_directory readme_directory", or go to # http://www.postfix.org/. # # For best results, change no more than 2-3 parameters at a time, # and test if Postfix still works after every change. # SOFT BOUNCE # # The soft_bounce parameter provides a limited safety net for # testing. When soft_bounce is enabled, mail will remain queued that # would otherwise bounce. This parameter disables locally-generated # bounces, and prevents the SMTP server from rejecting mail permanently # (by changing 5xx replies into 4xx replies). However, soft_bounce # is no cure for address rewriting mistakes or mail routing mistakes. # #soft_bounce = no # LOCAL PATHNAME INFORMATION # # The queue_directory specifies the location of the Postfix queue. # This is also the root directory of Postfix daemons that run chrooted. # See the files in examples/chroot-setup for setting up Postfix chroot # environments on different UNIX systems. # queue_directory = /var/spool/postfix # The command_directory parameter specifies the location of all # postXXX commands. # command_directory = /usr/sbin # The daemon_directory parameter specifies the location of all Postfix # daemon programs (i.e. programs listed in the master.cf file). This # directory must be owned by root. # daemon_directory = /usr/libexec/postfix # The data_directory parameter specifies the location of Postfix-writable # data files (caches, random numbers). This directory must be owned # by the mail_owner account (see below). # data_directory = /var/lib/postfix # QUEUE AND PROCESS OWNERSHIP # # The mail_owner parameter specifies the owner of the Postfix queue # and of most Postfix daemon processes. Specify the name of a user # account THAT DOES NOT SHARE ITS USER OR GROUP ID WITH OTHER ACCOUNTS # AND THAT OWNS NO OTHER FILES OR PROCESSES ON THE SYSTEM. In # particular, don't specify nobody or daemon. PLEASE USE A DEDICATED # USER. # mail_owner = postfix # The default_privs parameter specifies the default rights used by # the local delivery agent for delivery to external file or command. # These rights are used in the absence of a recipient user context. # DO NOT SPECIFY A PRIVILEGED USER OR THE POSTFIX OWNER. # #default_privs = nobody # INTERNET HOST AND DOMAIN NAMES # # The myhostname parameter specifies the internet hostname of this # mail system. The default is to use the fully-qualified domain name # from gethostname(). $myhostname is used as a default value for many # other configuration parameters. # #myhostname = poczta.int.oum.pl #myhostname = virtual.domain.tld # The mydomain parameter specifies the local internet domain name. # The default is to use $myhostname minus the first component. # $mydomain is used as a default value for many other configuration # parameters. # #mydomain = int.oum.pl # SENDING MAIL # # The myorigin parameter specifies the domain that locally-posted # mail appears to come from. The default is to append $myhostname, # which is fine for small sites. If you run a domain with multiple # machines, you should (1) change this to $mydomain and (2) set up # a domain-wide alias database that aliases each user to # [email protected]. # # For the sake of consistency between sender and recipient addresses, # myorigin also specifies the default domain name that is appended # to recipient addresses that have no @domain part. # #myorigin = $myhostname #myorigin = $mydomain # RECEIVING MAIL # The inet_interfaces parameter specifies the network interface # addresses that this mail system receives mail on. By default, # the software claims all active interfaces on the machine. The # parameter also controls delivery of mail to user@[ip.address]. # # See also the proxy_interfaces parameter, for network addresses that # are forwarded to us via a proxy or network address translator. # # Note: you need to stop/start Postfix when this parameter changes. # inet_interfaces = all #inet_interfaces = $myhostname #inet_interfaces = $myhostname, localhost #inet_interfaces = localhost # The proxy_interfaces parameter specifies the network interface # addresses that this mail system receives mail on by way of a # proxy or network address translation unit. This setting extends # the address list specified with the inet_interfaces parameter. # # You must specify your proxy/NAT addresses when your system is a # backup MX host for other domains, otherwise mail delivery loops # will happen when the primary MX host is down. # #proxy_interfaces = #proxy_interfaces = 1.2.3.4 # The mydestination parameter specifies the list of domains that this # machine considers itself the final destination for. # # These domains are routed to the delivery agent specified with the # local_transport parameter setting. By default, that is the UNIX # compatible delivery agent that lookups all recipients in /etc/passwd # and /etc/aliases or their equivalent. # # The default is $myhostname + localhost.$mydomain. On a mail domain # gateway, you should also include $mydomain. # # Do not specify the names of virtual domains - those domains are # specified elsewhere (see VIRTUAL_README). # # Do not specify the names of domains that this machine is backup MX # host for. Specify those names via the relay_domains settings for # the SMTP server, or use permit_mx_backup if you are lazy (see # STANDARD_CONFIGURATION_README). # # The local machine is always the final destination for mail addressed # to user@[the.net.work.address] of an interface that the mail system # receives mail on (see the inet_interfaces parameter). # # Specify a list of host or domain names, /file/name or type:table # patterns, separated by commas and/or whitespace. A /file/name # pattern is replaced by its contents; a type:table is matched when # a name matches a lookup key (the right-hand side is ignored). # Continue long lines by starting the next line with whitespace. # # See also below, section "REJECTING MAIL FOR UNKNOWN LOCAL USERS". # #mydestination = $myhostname, localhost.$mydomain, localhost mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain #mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain, # mail.$mydomain, www.$mydomain, ftp.$mydomain # REJECTING MAIL FOR UNKNOWN LOCAL USERS # # The local_recipient_maps parameter specifies optional lookup tables # with all names or addresses of users that are local with respect # to $mydestination, $inet_interfaces or $proxy_interfaces. # # If this parameter is defined, then the SMTP server will reject # mail for unknown local users. This parameter is defined by default. # # To turn off local recipient checking in the SMTP server, specify # local_recipient_maps = (i.e. empty). # # The default setting assumes that you use the default Postfix local # delivery agent for local delivery. You need to update the # local_recipient_maps setting if: # # - You define $mydestination domain recipients in files other than # /etc/passwd, /etc/aliases, or the $virtual_alias_maps files. # For example, you define $mydestination domain recipients in # the $virtual_mailbox_maps files. # # - You redefine the local delivery agent in master.cf. # # - You redefine the "local_transport" setting in main.cf. # # - You use the "luser_relay", "mailbox_transport", or "fallback_transport" # feature of the Postfix local delivery agent (see local(8)). # # Details are described in the LOCAL_RECIPIENT_README file. # # Beware: if the Postfix SMTP server runs chrooted, you probably have # to access the passwd file via the proxymap service, in order to # overcome chroot restrictions. The alternative, having a copy of # the system passwd file in the chroot jail is just not practical. # # The right-hand side of the lookup tables is conveniently ignored. # In the left-hand side, specify a bare username, an @domain.tld # wild-card, or specify a [email protected] address. # #local_recipient_maps = unix:passwd.byname $alias_maps #local_recipient_maps = proxy:unix:passwd.byname $alias_maps #local_recipient_maps = # The unknown_local_recipient_reject_code specifies the SMTP server # response code when a recipient domain matches $mydestination or # ${proxy,inet}_interfaces, while $local_recipient_maps is non-empty # and the recipient address or address local-part is not found. # # The default setting is 550 (reject mail) but it is safer to start # with 450 (try again later) until you are certain that your # local_recipient_maps settings are OK. # unknown_local_recipient_reject_code = 550 # TRUST AND RELAY CONTROL # The mynetworks parameter specifies the list of "trusted" SMTP # clients that have more privileges than "strangers". # # In particular, "trusted" SMTP clients are allowed to relay mail # through Postfix. See the smtpd_recipient_restrictions parameter # in postconf(5). # # You can specify the list of "trusted" network addresses by hand # or you can let Postfix do it for you (which is the default). # # By default (mynetworks_style = subnet), Postfix "trusts" SMTP # clients in the same IP subnetworks as the local machine. # On Linux, this does works correctly only with interfaces specified # with the "ifconfig" command. # # Specify "mynetworks_style = class" when Postfix should "trust" SMTP # clients in the same IP class A/B/C networks as the local machine. # Don't do this with a dialup site - it would cause Postfix to "trust" # your entire provider's network. Instead, specify an explicit # mynetworks list by hand, as described below. # # Specify "mynetworks_style = host" when Postfix should "trust" # only the local machine. # #mynetworks_style = class #mynetworks_style = subnet #mynetworks_style = host # Alternatively, you can specify the mynetworks list by hand, in # which case Postfix ignores the mynetworks_style setting. # # Specify an explicit list of network/netmask patterns, where the # mask specifies the number of bits in the network part of a host # address. # # You can also specify the absolute pathname of a pattern file instead # of listing the patterns here. Specify type:table for table-based lookups # (the value on the table right-hand side is not used). # mynetworks = 127.0.0.0/8 192.168.1.5/24 #mynetworks = $config_directory/mynetworks #mynetworks = hash:/etc/postfix/network_table # The relay_domains parameter restricts what destinations this system will # relay mail to. See the smtpd_recipient_restrictions description in # postconf(5) for detailed information. # # By default, Postfix relays mail # - from "trusted" clients (IP address matches $mynetworks) to any destination, # - from "untrusted" clients to destinations that match $relay_domains or # subdomains thereof, except addresses with sender-specified routing. # The default relay_domains value is $mydestination. # # In addition to the above, the Postfix SMTP server by default accepts mail # that Postfix is final destination for: # - destinations that match $inet_interfaces or $proxy_interfaces, # - destinations that match $mydestination # - destinations that match $virtual_alias_domains, # - destinations that match $virtual_mailbox_domains. # These destinations do not need to be listed in $relay_domains. # # Specify a list of hosts or domains, /file/name patterns or type:name # lookup tables, separated by commas and/or whitespace. Continue # long lines by starting the next line with whitespace. A file name # is replaced by its contents; a type:name table is matched when a # (parent) domain appears as lookup key. # # NOTE: Postfix will not automatically forward mail for domains that # list this system as their primary or backup MX host. See the # permit_mx_backup restriction description in postconf(5). # #relay_domains = $mydestination # INTERNET OR INTRANET # The relayhost parameter specifies the default host to send mail to # when no entry is matched in the optional transport(5) table. When # no relayhost is given, mail is routed directly to the destination. # # On an intranet, specify the organizational domain name. If your # internal DNS uses no MX records, specify the name of the intranet # gateway host instead. # # In the case of SMTP, specify a domain, host, host:port, [host]:port, # [address] or [address]:port; the form [host] turns off MX lookups. # # If you're connected via UUCP, see also the default_transport parameter. # #relayhost = $mydomain #relayhost = [gateway.my.domain] #relayhost = [mailserver.isp.tld] #relayhost = uucphost #relayhost = [an.ip.add.ress] # REJECTING UNKNOWN RELAY USERS # # The relay_recipient_maps parameter specifies optional lookup tables # with all addresses in the domains that match $relay_domains. # # If this parameter is defined, then the SMTP server will reject # mail for unknown relay users. This feature is off by default. # # The right-hand side of the lookup tables is conveniently ignored. # In the left-hand side, specify an @domain.tld wild-card, or specify # a [email protected] address. # #relay_recipient_maps = hash:/etc/postfix/relay_recipients # INPUT RATE CONTROL # # The in_flow_delay configuration parameter implements mail input # flow control. This feature is turned on by default, although it # still needs further development (it's disabled on SCO UNIX due # to an SCO bug). # # A Postfix process will pause for $in_flow_delay seconds before # accepting a new message, when the message arrival rate exceeds the # message delivery rate. With the default 100 SMTP server process # limit, this limits the mail inflow to 100 messages a second more # than the number of messages delivered per second. # # Specify 0 to disable the feature. Valid delays are 0..10. # #in_flow_delay = 1s # ADDRESS REWRITING # # The ADDRESS_REWRITING_README document gives information about # address masquerading or other forms of address rewriting including # username->Firstname.Lastname mapping. # ADDRESS REDIRECTION (VIRTUAL DOMAIN) # # The VIRTUAL_README document gives information about the many forms # of domain hosting that Postfix supports. # "USER HAS MOVED" BOUNCE MESSAGES # # See the discussion in the ADDRESS_REWRITING_README document. # TRANSPORT MAP # # See the discussion in the ADDRESS_REWRITING_README document. # ALIAS DATABASE # # The alias_maps parameter specifies the list of alias databases used # by the local delivery agent. The default list is system dependent. # # On systems with NIS, the default is to search the local alias # database, then the NIS alias database. See aliases(5) for syntax # details. # # If you change the alias database, run "postalias /etc/aliases" (or # wherever your system stores the mail alias file), or simply run # "newaliases" to build the necessary DBM or DB file. # # It will take a minute or so before changes become visible. Use # "postfix reload" to eliminate the delay. # #alias_maps = dbm:/etc/aliases alias_maps = hash:/etc/aliases #alias_maps = hash:/etc/aliases, nis:mail.aliases #alias_maps = netinfo:/aliases # The alias_database parameter specifies the alias database(s) that # are built with "newaliases" or "sendmail -bi". This is a separate # configuration parameter, because alias_maps (see above) may specify # tables that are not necessarily all under control by Postfix. # #alias_database = dbm:/etc/aliases #alias_database = dbm:/etc/mail/aliases alias_database = hash:/etc/aliases #alias_database = hash:/etc/aliases, hash:/opt/majordomo/aliases # ADDRESS EXTENSIONS (e.g., user+foo) # # The recipient_delimiter parameter specifies the separator between # user names and address extensions (user+foo). See canonical(5), # local(8), relocated(5) and virtual(5) for the effects this has on # aliases, canonical, virtual, relocated and .forward file lookups. # Basically, the software tries user+foo and .forward+foo before # trying user and .forward. # #recipient_delimiter = + # DELIVERY TO MAILBOX # # The home_mailbox parameter specifies the optional pathname of a # mailbox file relative to a user's home directory. The default # mailbox file is /var/spool/mail/user or /var/mail/user. Specify # "Maildir/" for qmail-style delivery (the / is required). # #home_mailbox = Mailbox home_mailbox = Maildir/ # The mail_spool_directory parameter specifies the directory where # UNIX-style mailboxes are kept. The default setting depends on the # system type. # #mail_spool_directory = /var/mail #mail_spool_directory = /var/spool/mail # The mailbox_command parameter specifies the optional external # command to use instead of mailbox delivery. The command is run as # the recipient with proper HOME, SHELL and LOGNAME environment settings. # Exception: delivery for root is done as $default_user. # # Other environment variables of interest: USER (recipient username), # EXTENSION (address extension), DOMAIN (domain part of address), # and LOCAL (the address localpart). # # Unlike other Postfix configuration parameters, the mailbox_command # parameter is not subjected to $parameter substitutions. This is to # make it easier to specify shell syntax (see example below). # # Avoid shell meta characters because they will force Postfix to run # an expensive shell process. Procmail alone is expensive enough. # # IF YOU USE THIS TO DELIVER MAIL SYSTEM-WIDE, YOU MUST SET UP AN # ALIAS THAT FORWARDS MAIL FOR ROOT TO A REAL USER. # #mailbox_command = /some/where/procmail #mailbox_command = /some/where/procmail -a "$EXTENSION" # The mailbox_transport specifies the optional transport in master.cf # to use after processing aliases and .forward files. This parameter # has precedence over the mailbox_command, fallback_transport and # luser_relay parameters. # # Specify a string of the form transport:nexthop, where transport is # the name of a mail delivery transport defined in master.cf. The # :nexthop part is optional. For more details see the sample transport # configuration file. # # NOTE: if you use this feature for accounts not in the UNIX password # file, then you must update the "local_recipient_maps" setting in # the main.cf file, otherwise the SMTP server will reject mail for # non-UNIX accounts with "User unknown in local recipient table". # #mailbox_transport = lmtp:unix:/var/lib/imap/socket/lmtp # If using the cyrus-imapd IMAP server deliver local mail to the IMAP # server using LMTP (Local Mail Transport Protocol), this is prefered # over the older cyrus deliver program by setting the # mailbox_transport as below: # # mailbox_transport = lmtp:unix:/var/lib/imap/socket/lmtp # # The efficiency of LMTP delivery for cyrus-imapd can be enhanced via # these settings. # # local_destination_recipient_limit = 300 # local_destination_concurrency_limit = 5 # # Of course you should adjust these settings as appropriate for the # capacity of the hardware you are using. The recipient limit setting # can be used to take advantage of the single instance message store # capability of Cyrus. The concurrency limit can be used to control # how many simultaneous LMTP sessions will be permitted to the Cyrus # message store. # # To use the old cyrus deliver program you have to set: #mailbox_transport = cyrus # The fallback_transport specifies the optional transport in master.cf # to use for recipients that are not found in the UNIX passwd database. # This parameter has precedence over the luser_relay parameter. # # Specify a string of the form transport:nexthop, where transport is # the name of a mail delivery transport defined in master.cf. The # :nexthop part is optional. For more details see the sample transport # configuration file. # # NOTE: if you use this feature for accounts not in the UNIX password # file, then you must update the "local_recipient_maps" setting in # the main.cf file, otherwise the SMTP server will reject mail for # non-UNIX accounts with "User unknown in local recipient table". # #fallback_transport = lmtp:unix:/var/lib/imap/socket/lmtp #fallback_transport = # The luser_relay parameter specifies an optional destination address # for unknown recipients. By default, mail for unknown@$mydestination, # unknown@[$inet_interfaces] or unknown@[$proxy_interfaces] is returned # as undeliverable. # # The following expansions are done on luser_relay: $user (recipient # username), $shell (recipient shell), $home (recipient home directory), # $recipient (full recipient address), $extension (recipient address # extension), $domain (recipient domain), $local (entire recipient # localpart), $recipient_delimiter. Specify ${name?value} or # ${name:value} to expand value only when $name does (does not) exist. # # luser_relay works only for the default Postfix local delivery agent. # # NOTE: if you use this feature for accounts not in the UNIX password # file, then you must specify "local_recipient_maps =" (i.e. empty) in # the main.cf file, otherwise the SMTP server will reject mail for # non-UNIX accounts with "User unknown in local recipient table". # #luser_relay = [email protected] #luser_relay = [email protected] #luser_relay = admin+$local # JUNK MAIL CONTROLS # # The controls listed here are only a very small subset. The file # SMTPD_ACCESS_README provides an overview. # The header_checks parameter specifies an optional table with patterns # that each logical message header is matched against, including # headers that span multiple physical lines. # # By default, these patterns also apply to MIME headers and to the # headers of attached messages. With older Postfix versions, MIME and # attached message headers were treated as body text. # # For details, see "man header_checks". # #header_checks = regexp:/etc/postfix/header_checks # FAST ETRN SERVICE # # Postfix maintains per-destination logfiles with information about # deferred mail, so that mail can be flushed quickly with the SMTP # "ETRN domain.tld" command, or by executing "sendmail -qRdomain.tld". # See the ETRN_README document for a detailed description. # # The fast_flush_domains parameter controls what destinations are # eligible for this service. By default, they are all domains that # this server is willing to relay mail to. # #fast_flush_domains = $relay_domains # SHOW SOFTWARE VERSION OR NOT # # The smtpd_banner parameter specifies the text that follows the 220 # code in the SMTP server's greeting banner. Some people like to see # the mail version advertised. By default, Postfix shows no version. # # You MUST specify $myhostname at the start of the text. That is an # RFC requirement. Postfix itself does not care. # #smtpd_banner = $myhostname ESMTP $mail_name smtpd_banner = $myhostname ESMTP $mail_name ($mail_version) # PARALLEL DELIVERY TO THE SAME DESTINATION # # How many parallel deliveries to the same user or domain? With local # delivery, it does not make sense to do massively parallel delivery # to the same user, because mailbox updates must happen sequentially, # and expensive pipelines in .forward files can cause disasters when # too many are run at the same time. With SMTP deliveries, 10 # simultaneous connections to the same domain could be sufficient to # raise eyebrows. # # Each message delivery transport has its XXX_destination_concurrency_limit # parameter. The default is $default_destination_concurrency_limit for # most delivery transports. For the local delivery agent the default is 2. #local_destination_concurrency_limit = 2 #default_destination_concurrency_limit = 20 # DEBUGGING CONTROL # # The debug_peer_level parameter specifies the increment in verbose # logging level when an SMTP client or server host name or address # matches a pattern in the debug_peer_list parameter. # debug_peer_level = 2 # The debug_peer_list parameter specifies an optional list of domain # or network patterns, /file/name patterns or type:name tables. When # an SMTP client or server host name or address matches a pattern, # increase the verbose logging level by the amount specified in the # debug_peer_level parameter. # #debug_peer_list = 127.0.0.1 #debug_peer_list = some.domain # The debugger_command specifies the external command that is executed # when a Postfix daemon program is run with the -D option. # # Use "command .. & sleep 5" so that the debugger can attach before # the process marches on. If you use an X-based debugger, be sure to # set up your XAUTHORITY environment variable before starting Postfix. # debugger_command = PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin ddd $daemon_directory/$process_name $process_id & sleep 5 # If you can't use X, use this to capture the call stack when a # daemon crashes. The result is in a file in the configuration # directory, and is named after the process name and the process ID. # # debugger_command = # PATH=/bin:/usr/bin:/usr/local/bin; export PATH; (echo cont; # echo where) | gdb $daemon_directory/$process_name $process_id 2>&1 # >$config_directory/$process_name.$process_id.log & sleep 5 # # Another possibility is to run gdb under a detached screen session. # To attach to the screen sesssion, su root and run "screen -r # <id_string>" where <id_string> uniquely matches one of the detached # sessions (from "screen -list"). # # debugger_command = # PATH=/bin:/usr/bin:/sbin:/usr/sbin; export PATH; screen # -dmS $process_name gdb $daemon_directory/$process_name # $process_id & sleep 1 # INSTALL-TIME CONFIGURATION INFORMATION # # The following parameters are used when installing a new Postfix version. # # sendmail_path: The full pathname of the Postfix sendmail command. # This is the Sendmail-compatible mail posting interface. # sendmail_path = /usr/sbin/sendmail.postfix # newaliases_path: The full pathname of the Postfix newaliases command. # This is the Sendmail-compatible command to build alias databases. # newaliases_path = /usr/bin/newaliases.postfix # mailq_path: The full pathname of the Postfix mailq command. This # is the Sendmail-compatible mail queue listing command. # mailq_path = /usr/bin/mailq.postfix # setgid_group: The group for mail submission and queue management # commands. This must be a group name with a numerical group ID that # is not shared with other accounts, not even with the Postfix account. # setgid_group = postdrop # html_directory: The location of the Postfix HTML documentation. # html_directory = no # manpage_directory: The location of the Postfix on-line manual pages. # manpage_directory = /usr/share/man # sample_directory: The location of the Postfix sample configuration files. # This parameter is obsolete as of Postfix 2.1. # sample_directory = /usr/share/doc/postfix-2.5.5/samples # readme_directory: The location of the Postfix README files. # readme_directory = /usr/share/doc/postfix-2.5.5/README_FILES # Enable IPv4, and IPv6 if supported inet_protocols = all smtpd_sasl_type = dovecot smtpd_sasl_path = private/auth smtpd_sasl_auth_enable = yes smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination broken_sasl_auth_clients = yes Dovecot, dovecot.conf : ## Dovecot configuration file # If you're in a hurry, see http://wiki.dovecot.org/QuickConfiguration # "dovecot -n" command gives a clean output of the changed settings. Use it # instead of copy&pasting this file when posting to the Dovecot mailing list. # '#' character and everything after it is treated as comments. Extra spaces # and tabs are ignored. If you want to use either of these explicitly, put the # value inside quotes, eg.: key = "# char and trailing whitespace " # Default values are shown for each setting, it's not required to uncomment # any of the lines. # Base directory where to store runtime data. #base_dir = /var/run/dovecot/ # Protocols we want to be serving: imap imaps pop3 pop3s managesieve # If you only want to use dovecot-auth, you can set this to "none". protocols = pop3 pop3s imap imaps # A space separated list of IP or host addresses where to listen in for # connections. "*" listens in all IPv4 interfaces. "[::]" listens in all IPv6 # interfaces. Use "*, [::]" for listening both IPv4 and IPv6. # # If you want to specify ports for each service, you will need to configure # these settings inside the protocol imap/pop3/managesieve { ... } section, # so you can specify different ports for IMAP/POP3/MANAGESIEVE. For example: # protocol imap { # listen = *:10143 # ssl_listen = *:10943 # .. # } # protocol pop3 { # listen = *:10100 # .. # } # protocol managesieve { # listen = *:12000 # .. # } #listen = *, [::] # Disable LOGIN command and all other plaintext authentications unless # SSL/TLS is used (LOGINDISABLED capability). Note that if the remote IP # matches the local IP (ie. you're connecting from the same computer), the # connection is considered secure and plaintext authentication is allowed. #disable_plaintext_auth = no # Should all IMAP and POP3 processes be killed when Dovecot master process # shuts down. Setting this to "no" means that Dovecot can be upgraded without # forcing existing client connections to close (although that could also be # a problem if the upgrade is eg. because of a security fix). This however # means that after master process has died, the client processes can't write # to log files anymore. #shutdown_clients = yes ## ## Logging ## # Log file to use for error messages, instead of sending them to syslog. # /dev/stderr can be used to log into stderr. #log_path = # Log file to use for informational and debug messages. # Default is the same as log_path. #info_log_path = # Prefix for each line written to log file. % codes are in strftime(3) # format. #log_timestamp = "%b %d %H:%M:%S " # Syslog facility to use if you're logging to syslog. Usually if you don't # want to use "mail", you'll use local0..local7. Also other standard # facilities are supported. #syslog_facility = mail ## ## SSL settings ## # IP or host address where to listen in for SSL connections. Remember to also # add imaps and/or pop3s to protocols setting. Defaults to same as "listen" # setting if not specified. #ssl_listen = # Disable SSL/TLS support. <doc/wiki/SSL.txt> #ssl_disable = no # PEM encoded X.509 SSL/TLS certificate and private key. They're opened before # dropping root privileges, so keep the key file unreadable by anyone but # root. Included doc/mkcert.sh can be used to easily generate self-signed # certificate, just make sure to update the domains in dovecot-openssl.cnf #ssl_cert_file = /etc/pki/dovecot/certs/dovecot.pem #ssl_key_file = /etc/pki/dovecot/private/dovecot.pem # If key file is password protected, give the password here. Alternatively # give it when starting dovecot with -p parameter. Since this file is often # world-readable, you may want to place this setting instead to a different # root owned 0600 file by using !include_try <path>. #ssl_key_password = # File containing trusted SSL certificate authorities. Set this only if you # intend to use ssl_verify_client_cert=yes. The CAfile should contain the # CA-certificate(s) followed by the matching CRL(s). #ssl_ca_file = # Request client to send a certificate. If you also want to require it, set # ssl_require_client_cert=yes in auth section. #ssl_verify_client_cert = no # Which field from certificate to use for username. commonName and # x500UniqueIdentifier are the usual choices. You'll also need to set # ssl_username_from_cert=yes. #ssl_cert_username_field = commonName # How often to regenerate the SSL parameters file. Generation is quite CPU # intensive operation. The value is in hours, 0 disables regeneration # entirely. #ssl_parameters_regenerate = 168 # SSL ciphers to use #ssl_cipher_list = ALL:!LOW:!SSLv2 # Show protocol level SSL errors. #verbose_ssl = no ## ## Login processes ## # <doc/wiki/LoginProcess.txt> # Directory where authentication process places authentication UNIX sockets # which login needs to be able to connect to. The sockets are created when # running as root, so you don't have to worry about permissions. Note that # everything in this directory is deleted when Dovecot is started. #login_dir = /var/run/dovecot/login # chroot login process to the login_dir. Only reason not to do this is if you # wish to run the whole Dovecot without roots. <doc/wiki/Rootless.txt> #login_chroot = yes # User to use for the login process. Create a completely new user for this, # and don't use it anywhere else. The user must also belong to a group where # only it has access, it's used to control access for authentication process. # Note that this user is NOT used to access mails. <doc/wiki/UserIds.txt> #login_user = dovecot # Set max. process size in megabytes. If you don't use # login_process_per_connection you might need to grow this. #login_process_size = 64 # Should each login be processed in it's own process (yes), or should one # login process be allowed to process multiple connections (no)? Yes is more # secure, espcially with SSL/TLS enabled. No is faster since there's no need # to create processes all the time. #login_process_per_connection = yes # Number of login processes to keep for listening new connections. #login_processes_count = 3 # Maximum number of login processes to create. The listening process count # usually stays at login_processes_count, but when multiple users start logging # in at the same time more extra processes are created. To prevent fork-bombing # we check only once in a second if new processes should be created - if all # of them are used at the time, we double their amount until the limit set by # this setting is reached. #login_max_processes_count = 128 # Maximum number of connections allowed per each login process. This setting # is used only if login_process_per_connection=no. Once the limit is reached, # the process notifies master so that it can create a new login process. #login_max_connections = 256 # Greeting message for clients. #login_greeting = Dovecot ready. # Space-separated list of elements we want to log. The elements which have # a non-empty variable value are joined together to form a comma-separated # string. #login_log_format_elements = user=<%u> method=%m rip=%r lip=%l %c # Login log format. %$ contains login_log_format_elements string, %s contains # the data we want to log. #login_log_format = %$: %s ## ## Mailbox locations and namespaces ## # Location for users' mailboxes. This is the same as the old default_mail_env # setting. The default is empty, which means that Dovecot tries to find the # mailboxes automatically. This won't work if the user doesn't have any mail # yet, so you should explicitly tell Dovecot the full location. # # If you're using mbox, giving a path to the INBOX file (eg. /var/mail/%u) # isn't enough. You'll also need to tell Dovecot where the other mailboxes are # kept. This is called the "root mail directory", and it must be the first # path given in the mail_location setting. # # There are a few special variables you can use, eg.: # # %u - username # %n - user part in user@domain, same as %u if there's no domain # %d - domain part in user@domain, empty if there's no domain # %h - home directory # # See <doc/wiki/Variables.txt> for full list. Some examples: # mail_location = maildir:~/Maildir # mail_location = mbox:~/mail:INBOX=/var/mail/%u # mail_location = mbox:/var/mail/%d/%1n/%n:INDEX=/var/indexes/%d/%1n/%n # # <doc/wiki/MailLocation.txt> # #mail_location = # If you need to set multiple mailbox locations or want to change default # namespace settings, you can do it by defining namespace sections. # # You can have private, shared and public namespaces. The only difference # between them is how Dovecot announces them to client via NAMESPACE # extension. Shared namespaces are meant for user-owned mailboxes which are # shared to other users, while public namespaces are for more globally # accessible mailboxes. # # REMEMBER: If you add any namespaces, the default namespace must be added # explicitly, ie. mail_location does nothing unless you have a namespace # without a location setting. Default namespace is simply done by having a # namespace with empty prefix. #namespace private { # Hierarchy separator to use. You should use the same separator for all # namespaces or some clients get confused. '/' is usually a good one. # The default however depends on the underlying mail storage format. #separator = # Prefix required to access this namespace. This needs to be different for # all namespaces. For example "Public/". #prefix = # Physical location of the mailbox. This is in same format as # mail_location, which is also the default for it. #location = # There can be only one INBOX, and this setting defines which namespace # has it. #inbox = no # If namespace is hidden, it's not advertised to clients via NAMESPACE # extension. You'll most likely also want to set list=no. This is mostly # useful when converting from another server with different namespaces which # you want to deprecate but still keep working. For example you can create # hidden namespaces with prefixes "~/mail/", "~%u/mail/" and "mail/". #hidden = yes # Show the mailboxes under this namespace with LIST command. This makes the # namespace visible for clients that don't support NAMESPACE extension. #list = yes # Namespace handles its own subscriptions. If set to "no", the parent # namespace handles them (empty prefix should always have this as "yes") #subscriptions = yes #} # System user and group used to access mails. If you use multiple, userdb # can override these by returning uid or gid fields. You can use either numbers # or names. <doc/wiki/UserIds.txt> #mail_uid = #mail_gid = # Group to enable temporarily for privileged operations. Currently this is # used only with INBOX when either its initial creation or dotlocking fails. # Typically this is set to "mail" to give access to /var/mail. #mail_privileged_group = # Grant access to these supplementary groups for mail processes. Typically # these are used to set up access to shared mailboxes. Note that it may be # dangerous to set these if users can create symlinks (e.g. if "mail" group is # set here, ln -s /var/mail ~/mail/var could allow a user to delete others' # mailboxes, or ln -s /secret/shared/box ~/mail/mybox would allow reading it). #mail_access_groups = # Allow full filesystem access to clients. There's no access checks other than # what the operating system does for the active UID/GID. It works with both # maildir and mboxes, allowing you to prefix mailboxes names with eg. /path/ # or ~user/. #mail_full_filesystem_access = no ## ## Mail processes ## # Enable mail process debugging. This can help you figure out why Dovecot # isn't finding your mails. #mail_debug = no # Log prefix for mail processes. See <doc/wiki/Variables.txt> for list of # possible variables you can use. #mail_log_prefix = "%Us(%u): " # Max. number of lines a mail process is allowed to log per second before it's # throttled. 0 means unlimited. Typically there's no need to change this # unless you're using mail_log plugin, which may log a lot. This setting is # ignored while mail_debug=yes to avoid pointless throttling. #mail_log_max_lines_per_sec = 10 # Don't use mmap() at all. This is required if you store indexes to shared # filesystems (NFS or clustered filesystem). #mmap_disable = no # Rely on O_EXCL to work when creating dotlock files. NFS supports O_EXCL # since version 3, so this should be safe to use nowadays by default. #dotlock_use_excl = yes # Don't use fsync() or fdatasync() calls. This makes the performance better # at the cost of potential data loss if the server (or the file server) # goes down. #fsync_disable = no # Mail storage exists in NFS. Set this to yes to make Dovecot flush NFS caches # whenever needed. If you're using only a single mail server this isn't needed. #mail_nfs_storage = no # Mail index files also exist in NFS. Setting this to yes requires # mmap_disable=yes and fsync_disable=no. #mail_nfs_index = no # Locking method for index files. Alternatives are fcntl, flock and dotlock. # Dotlocking uses some tricks which may create more disk I/O than other locking # methods. NFS users: flock doesn't work, remember to change mmap_disable. #lock_method = fcntl # Drop all privileges before exec()ing the mail process. This is mostly # meant for debugging, otherwise you don't get core dumps. It could be a small # security risk if you use single UID for multiple users, as the users could # ptrace() each others processes then. #mail_drop_priv_before_exec = no # Show more verbose process titles (in ps). Currently shows user name and # IP address. Useful for seeing who are actually using the IMAP processes # (eg. shared mailboxes or if same uid is used for multiple accounts). #verbose_proctitle = no # Valid UID range for users, defaults to 500 and above. This is mostly # to make sure that users can't log in as daemons or other system users. # Note that denying root logins is hardcoded to dovecot binary and can't # be done even if first_valid_uid is set to 0. #first_valid_uid = 500 #last_valid_uid = 0 # Valid GID range for users, defaults to non-root/wheel. Users having # non-valid GID as primary group ID aren't allowed to log in. If user # belongs to supplementary groups with non-valid GIDs, those groups are # not set. #first_valid_gid = 1 #last_valid_gid = 0 # Maximum number of running mail processes. When this limit is reached, # new users aren't allowed to log in. #max_mail_processes = 512 # Set max. process size in megabytes. Most of the memory goes to mmap()ing # files, so it shouldn't harm much even if this limit is set pretty high. #mail_process_size = 256 # Maximum allowed length for mail keyword name. It's only forced when trying # to create new keywords. #mail_max_keyword_length = 50 # ':' separated list of directories under which chrooting is allowed for mail # processes (ie. /var/mail will allow chrooting to /var/mail/foo/bar too). # This setting doesn't affect login_chroot, mail_chroot or auth chroot # settings. If this setting is empty, "/./" in home dirs are ignored. # WARNING: Never add directories here which local users can modify, that # may lead to root exploit. Usually this should be done only if you don't # allow shell access for users. <doc/wiki/Chrooting.txt> #valid_chroot_dirs = # Default chroot directory for mail processes. This can be overridden for # specific users in user database by giving /./ in user's home directory # (eg. /home/./user chroots into /home). Note that usually there is no real # need to do chrooting, Dovecot doesn't allow users to access files outside # their mail directory anyway. If your home directories are prefixed with # the chroot directory, append "/." to mail_chroot. <doc/wiki/Chrooting.txt> #mail_chroot = ## ## Mailbox handling optimizations ## # The minimum number of mails in a mailbox before updates are done to cache # file. This allows optimizing Dovecot's behavior to do less disk writes at # the cost of more disk reads. #mail_cache_min_mail_count = 0 # When IDLE command is running, mailbox is checked once in a while to see if # there are any new mails or other changes. This setting defines the minimum # time in seconds to wait between those checks. Dovecot can also use dnotify, # inotify and kqueue to find out immediately when changes occur. #mailbox_idle_check_interval = 30 # Save mails with CR+LF instead of plain LF. This makes sending those mails # take less CPU, especially with sendfile() syscall with Linux and FreeBSD. # But it also creates a bit more disk I/O which may just make it slower. # Also note that if other software reads the mboxes/maildirs, they may handle # the extra CRs wrong and cause problems. #mail_save_crlf = no ## ## Maildir-specific settings ## # By default LIST command returns all entries in maildir beginning with a dot. # Enabling this option makes Dovecot return only entries which are directories. # This is done by stat()ing each entry, so it causes more disk I/O. # (For systems setting struct dirent->d_type, this check is free and it's # done always regardless of this setting) #maildir_stat_dirs = no # When copying a message, do it with hard links whenever possible. This makes # the performance much better, and it's unlikely to have any side effects. #maildir_copy_with_hardlinks = yes # When copying a message, try to preserve the base filename. Only if the # destination mailbox already contains the same name (ie. the mail is being # copied there twice), a new name is given. The destination filename check is # done only by looking at dovecot-uidlist file, so if something outside # Dovecot does similar filename preserving copies, you may run into problems. # NOTE: This setting requires maildir_copy_with_hardlinks = yes to work. #maildir_copy_preserve_filename = no ## ## mbox-specific settings ## # Which locking methods to use for locking mbox. There are four available: # dotlock: Create <mailbox>.lock file. This is the oldest and most NFS-safe # solution. If you want to use /var/mail/ like directory, the users # will need write access to that directory. # dotlock_try: Same as dotlock, but if it fails because of permissions or # because there isn't enough disk space, just skip it. # fcntl : Use this if possible. Works with NFS too if lockd is used. # flock : May not exist in all systems. Doesn't work with NFS. # lockf : May not exist in all systems. Doesn't work with NFS. # # You can use multiple locking methods; if you do the order they're declared # in is important to avoid deadlocks if other MTAs/MUAs are using multiple # locking methods as well. Some operating systems don't allow using some of # them simultaneously. #mbox_read_locks = fcntl #mbox_write_locks = fcntl # Maximum time in seconds to wait for lock (all of them) before aborting. #mbox_lock_timeout = 300 # If dotlock exists but the mailbox isn't modified in any way, override the # lock file after this many seconds. #mbox_dotlock_change_timeout = 120 # When mbox changes unexpectedly we have to fully read it to find out what # changed. If the mbox is large this can take a long time. Since the change # is usually just a newly appended mail, it'd be faster to simply read the # new mails. If this setting is enabled, Dovecot does this but still safely # fallbacks to re-reading the whole mbox file whenever something in mbox isn't # how it's expected to be. The only real downside to this setting is that if # some other MUA changes message flags, Dovecot doesn't notice it immediately. # Note that a full sync is done with SELECT, EXAMINE, EXPUNGE and CHECK # commands. #mbox_dirty_syncs = yes # Like mbox_dirty_syncs, but don't do full syncs even with SELECT, EXAMINE, # EXPUNGE or CHECK commands. If this is set, mbox_dirty_syncs is ignored. #mbox_very_dirty_syncs = no # Delay writing mbox headers until doing a full write sync (EXPUNGE and CHECK # commands and when closing the mailbox). This is especially useful for POP3 # where clients often delete all mails. The downside is that our changes # aren't immediately visible to other MUAs. #mbox_lazy_writes = yes # If mbox size is smaller than this (in kilobytes), don't write index files. # If an index file already exists it's still read, just not updated. #mbox_min_index_size = 0 ## ## dbox-specific settings ## # Maximum dbox file size in kilobytes until it's rotated. #dbox_rotate_size = 2048 # Minimum dbox file size in kilobytes before it's rotated # (overrides dbox_rotate_days) #dbox_rotate_min_size = 16 # Maximum dbox file age in days until it's rotated. Day always begins from # midnight, so 1 = today, 2 = yesterday, etc. 0 = check disabled. #dbox_rotate_days = 0 ## ## IMAP specific settings ## protocol imap { # Login executable location. #login_executable = /usr/libexec/dovecot/imap-login # IMAP executable location. Changing this allows you to execute other # binaries before the imap process is executed. # # This would write rawlogs into ~/dovecot.rawlog/ directory: # mail_executable = /usr/libexec/dovecot/rawlog /usr/libexec/dovecot/imap # # This would attach gdb into the imap process and write backtraces into # /tmp/gdbhelper.* files: # mail_executable = /usr/libexec/dovecot/gdbhelper /usr/libexec/dovecot/imap # #mail_executable = /usr/libexec/dovecot/imap # Maximum IMAP command line length in bytes. Some clients generate very long # command lines with huge mailboxes, so you may need to raise this if you get # "Too long argument" or "IMAP command line too large" errors often. #imap_max_line_length = 65536 # Maximum number of IMAP connections allowed for a user from each IP address. # NOTE: The username is compared case-sensitively. #mail_max_userip_connections = 10 # Support for dynamically loadable plugins. mail_plugins is a space separated # list of plugins to load. #mail_plugins = #mail_plugin_dir = /usr/lib/dovecot/imap # Send IMAP capabilities in greeting message. This makes it unnecessary for # clients to request it with CAPABILITY command, so it saves one round-trip. # Many clients however don't understand it and ask the CAPABILITY anyway. #login_greeting_capability = no # IMAP logout format string: # %i - total number of bytes read from client # %o - total number of bytes sent to client #imap_logout_format = bytes=%i/%o # Override the IMAP CAPABILITY response. #imap_capability = # Workarounds for various client bugs: # delay-newmail: # Send EXISTS/RECENT new mail notifications only when replying to NOOP # and CHECK commands. Some clients ignore them otherwise, for example OSX # Mail (<v2.1). Outlook Express breaks more badly though, without this it # may show user "Message no longer in server" errors. Note that OE6 still # breaks even with this workaround if synchronization is set to # "Headers Only". # netscape-eoh: # Netscape 4.x breaks if message headers don't end with the empty "end of # headers" line. Normally all messages have this, but setting this # workaround makes sure that Netscape never breaks by adding the line if # it doesn't exist. This is done only for FETCH BODY[HEADER.FIELDS..] # commands. Note that RFC says this shouldn't be done. # tb-extra-mailbox-sep: # With mbox storage a mailbox can contain either mails or submailboxes, # but not both. Thunderbird separates these two by forcing server to # accept '/' suffix in mailbox names in subscriptions list. # The list is space-separated. imap_client_workarounds = delay-newmail outlook-idle netscape-eoh } ## ## POP3 specific settings ## protocol pop3 { # Login executable location. #login_executable = /usr/libexec/dovecot/pop3-login # POP3 executable location. See IMAP's mail_executable above for examples # how this could be changed. #mail_executable = /usr/libexec/dovecot/pop3 # Don't try to set mails non-recent or seen with POP3 sessions. This is # mostly intended to reduce disk I/O. With maildir it doesn't move files # from new/ to cur/, with mbox it doesn't write Status-header. #pop3_no_flag_updates = no # Support LAST command which exists in old POP3 specs, but has been removed # from new ones. Some clients still wish to use this though. Enabling this # makes RSET command clear all \Seen flags from messages. #pop3_enable_last = no # If mail has X-UIDL header, use it as the mail's UIDL. #pop3_reuse_xuidl = no # Keep the mailbox locked for the entire POP3 session. #pop3_lock_session = no # POP3 UIDL (unique mail identifier) format to use. You can use following # variables, along with the variable modifiers described in # <doc/wiki/Variables.txt> (e.g. %Uf for the filename in uppercase) # # %v - Mailbox's IMAP UIDVALIDITY # %u - Mail's IMAP UID # %m - MD5 sum of the mailbox headers in hex (mbox only) # %f - filename (maildir only) # # If you want UIDL compatibility with other POP3 servers, use: # UW's ipop3d : %08Xv%08Xu # Courier : %f or %v-%u (both might be used simultaneosly) # Cyrus (<= 2.1.3) : %u # Cyrus (>= 2.1.4) : %v.%u # Dovecot v0.99.x : %v.%u # tpop3d : %Mf # # Note that Outlook 2003 seems to have problems with %v.%u format which was # Dovecot's default, so if you're building a new server it would be a good # idea to change this. %08Xu%08Xv should be pretty fail-safe. # pop3_uidl_format = %08Xu%08Xv # POP3 logout format string: # %i - total number of bytes read from client # %o - total number of bytes sent to client # %t - number of TOP commands # %p - number of bytes sent to client as a result of TOP command # %r - number of RETR commands # %b - number of bytes sent to client as a result of RETR command # %d - number of deleted messages # %m - number of messages (before deletion) # %s - mailbox size in bytes (before deletion) #pop3_logout_format = top=%t/%p, retr=%r/%b, del=%d/%m, size=%s # Maximum number of POP3 connections allowed for a user from each IP address. # NOTE: The username is compared case-sensitively. #mail_max_userip_connections = 3 # Support for dynamically loadable plugins. mail_plugins is a space separated # list of plugins to load. #mail_plugins = #mail_plugin_dir = /usr/lib/dovecot/pop3 # Workarounds for various client bugs: # outlook-no-nuls: # Outlook and Outlook Express hang if mails contain NUL characters. # This setting replaces them with 0x80 character. # oe-ns-eoh: # Outlook Express and Netscape Mail breaks if end of headers-line is # missing. This option simply sends it if it's missing. # The list is space-separated. pop3_client_workarounds = outlook-no-nuls oe-ns-eoh } ## ## MANAGESIEVE specific settings ## protocol managesieve { # Login executable location. #login_executable = /usr/libexec/dovecot/managesieve-login # MANAGESIEVE executable location. See IMAP's mail_executable above for # examples how this could be changed. #mail_executable = /usr/libexec/dovecot/managesieve # Maximum MANAGESIEVE command line length in bytes. This setting is # directly borrowed from IMAP. But, since long command lines are very # unlikely with MANAGESIEVE, changing this will not be very useful. #managesieve_max_line_length = 65536 # Specifies the location of the symlink pointing to the active script in # the sieve storage directory. This must match the SIEVE setting used by # deliver (refer to http://wiki.dovecot.org/LDA/Sieve#location for more # info). Variable substitution with % is recognized. sieve=~/.dovecot.sieve # This specifies the path to the directory where the uploaded scripts must # be stored. In terms of '%' variable substitution it is identical to # dovecot's mail_location setting used by the mail protocol daemons. sieve_storage=~/sieve # If, for some inobvious reason, the sieve_storage remains unset, the # managesieve daemon uses the specification of the mail_location to find out # where to store the sieve files (see explaination in README.managesieve). # The example below, when uncommented, overrides any global mail_location # specification and stores all the scripts in '~/mail/sieve' if sieve_storage # is unset. However, you should always use the sieve_storage setting. # mail_location = mbox:~/mail # To fool managesieve clients that are focused on timesieved you can # specify the IMPLEMENTATION capability that the dovecot reports to clients # (default: dovecot). #managesieve_implementation_string = Cyrus timsieved v2.2.13 } ## ## LDA specific settings ## protocol lda { # Address to use when sending rejection mails. postmaster_address = [email protected] # Hostname to use in various parts of sent mails, eg. in Message-Id. # Default is the system's real hostname. #hostname = # Support for dynamically loadable plugins. mail_plugins is a space separated # list of plugins to load. #mail_plugins = #mail_plugin_dir = /usr/lib/dovecot/lda # If user is over quota, return with temporary failure instead of # bouncing the mail. #quota_full_tempfail = no # Format to use for logging mail deliveries. You can use variables: # %$ - Delivery status message (e.g. "saved to INBOX") # %m - Message-ID # %s - Subject # %f - From address #deliver_log_format = msgid=%m: %$ # Binary to use for sending mails. #sendmail_path = /usr/lib/sendmail # Subject: header to use for rejection mails. You can use the same variables # as for rejection_reason below. #rejection_subject = Automatically rejected mail # Human readable error message for rejection mails. You can use variables: # %n = CRLF, %r = reason, %s = original subject, %t = recipient #rejection_reason = Your message to <%t> was automatically rejected:%n%r # UNIX socket path to master authentication server to find users. #auth_socket_path = /var/run/dovecot/auth-master } ## ## Authentication processes ## # Executable location #auth_executable = /usr/libexec/dovecot/dovecot-auth # Set max. process size in megabytes. #auth_process_size = 256 # Authentication cache size in kilobytes. 0 means it's disabled. # Note that bsdauth, PAM and vpopmail require cache_key to be set for caching # to be used. #auth_cache_size = 0 # Time to live in seconds for cached data. After this many seconds the cached # record is no longer used, *except* if the main database lookup returns # internal failure. We also try to handle password changes automatically: If # user's previous authentication was successful, but this one wasn't, the # cache isn't used. For now this works only with plaintext authentication. #auth_cache_ttl = 3600 # TTL for negative hits (user not found). 0 disables caching them completely. #auth_cache_negative_ttl = 3600 # Space separated list of realms for SASL authentication mechanisms that need # them. You can leave it empty if you don't want to support multiple realms. # Many clients simply use the first one listed here, so keep the default realm # first. #auth_realms = # Default realm/domain to use if none was specified. This is used for both # SASL realms and appending @domain to username in plaintext logins. #auth_default_realm = # List of allowed characters in username. If the user-given username contains # a character not listed in here, the login automatically fails. This is just # an extra check to make sure user can't exploit any potential quote escaping # vulnerabilities with SQL/LDAP databases. If you want to allow all characters, # set this value to empty. #auth_username_chars = abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ01234567890.-_@ # Username character translations before it's looked up from databases. The # value contains series of from -> to characters. For example "#@/@" means # that '#' and '/' characters are translated to '@'. #auth_username_translation = # Username formatting before it's looked up from databases. You can use # the standard variables here, eg. %Lu would lowercase the username, %n would # drop away the domain if it was given, or "%n-AT-%d" would change the '@' into # "-AT-". This translation is done after auth_username_translation changes. #auth_username_format = # If you want to allow master users to log in by specifying the master # username within the normal username string (ie. not using SASL mechanism's # support for it), you can specify the separator character here. The format # is then <username><separator><master username>. UW-IMAP uses "*" as the # separator, so that could be a good choice. #auth_master_user_separator = # Username to use for users logging in with ANONYMOUS SASL mechanism #auth_anonymous_username = anonymous # More verbose logging. Useful for figuring out why authentication isn't # working. #auth_verbose = no # Even more verbose logging for debugging purposes. Shows for example SQL # queries. #auth_debug = no # In case of password mismatches, log the passwords and used scheme so the # problem can be debugged. Enabling this also enables auth_debug. #auth_debug_passwords = no # Maximum number of dovecot-auth worker processes. They're used to execute # blocking passdb and userdb queries (eg. MySQL and PAM). They're # automatically created and destroyed as needed. #auth_worker_max_count = 30 # Number of auth requests to handle before destroying the process. This may # be useful if PAM plugins leak memory. #auth_worker_max_request_count = 0 # Host name to use in GSSAPI principal names. The default is to use the # name returned by gethostname(). #auth_gssapi_hostname = # Kerberos keytab to use for the GSSAPI mechanism. Will use the system # default (usually /etc/krb5.keytab) if not specified. #auth_krb5_keytab = # Do NTLM authentication using Samba's winbind daemon and ntlm_auth helper. # <doc/wiki/Authentication/Mechanisms/Winbind.txt> #auth_ntlm_use_winbind = no # Path for Samba's ntlm_auth helper binary. #auth_winbind_helper_path = /usr/bin/ntlm_auth # Number of seconds to delay before replying to failed authentications. #auth_failure_delay = 2 auth default { socket listen { client { path = /var/spool/postfix/private/auth mode = 0660 user = postfix group = postfix } } # Space separated list of wanted authentication mechanisms: # plain login digest-md5 cram-md5 ntlm rpa apop anonymous gssapi otp skey # gss-spnego # NOTE: See also disable_plaintext_auth setting. mechanisms = plain # # Password database is used to verify user's password (and nothing more). # You can have multiple passdbs and userdbs. This is useful if you want to # allow both system users (/etc/passwd) and virtual users to login without # duplicating the system users into virtual database. # # <doc/wiki/PasswordDatabase.txt> # # By adding master=yes setting inside a passdb you make the passdb a list # of "master users", who can log in as anyone else. Unless you're using PAM, # you probably still want the destination user to be looked up from passdb # that it really exists. This can be done by adding pass=yes setting to the # master passdb. <doc/wiki/Authentication.MasterUsers.txt> # Users can be temporarily disabled by adding a passdb with deny=yes. # If the user is found from that database, authentication will fail. # The deny passdb should always be specified before others, so it gets # checked first. Here's an example: #passdb passwd-file { # File contains a list of usernames, one per line #args = /etc/dovecot.deny #deny = yes #} # PAM authentication. Preferred nowadays by most systems. # Note that PAM can only be used to verify if user's password is correct, # so it can't be used as userdb. If you don't want to use a separate user # database (passwd usually), you can use static userdb. # REMEMBER: You'll need /etc/pam.d/dovecot file created for PAM # authentication to actually work. <doc/wiki/PasswordDatabase.PAM.txt> passdb pam { # [session=yes] [setcred=yes] [failure_show_msg=yes] # [cache_key=<key>] [<service name>] # # session=yes makes Dovecot open and immediately close PAM session. Some # PAM plugins need this to work, such as pam_mkhomedir. # # setcred=yes makes Dovecot establish PAM credentials if some PAM plugins # need that. They aren't ever deleted though, so this isn't enabled by # default. # # cache_key can be used to enable authentication caching for PAM # (auth_cache_size also needs to be set). It isn't enabled by default # because PAM modules can do all kinds of checks besides checking password, # such as checking IP address. Dovecot can't know about these checks # without some help. cache_key is simply a list of variables (see # <doc/wiki/Variables.txt>) which must match for the cached data to be used. # Here are some examples: # %u - Username must match. Probably sufficient for most uses. # %u%r - Username and remote IP address must match. # %u%s - Username and service (ie. IMAP, POP3) must match. # # The service name can contain variables, for example %Ls expands to # pop3 or imap. # # Some examples: # args = session=yes %Ls # args = cache_key=%u dovecot #args = dovecot } # System users (NSS, /etc/passwd, or similiar) # In many systems nowadays this uses Name Service Switch, which is # configured in /etc/nsswitch.conf. <doc/wiki/AuthDatabase.Passwd.txt> #passdb passwd { # [blocking=yes] - See userdb passwd for explanation #args = #} # Shadow passwords for system users (NSS, /etc/shadow or similiar). # Deprecated by PAM nowadays. # <doc/wiki/PasswordDatabase.Shadow.txt> #passdb shadow { # [blocking=yes] - See userdb passwd for explanation #args = #} # PAM-like authentication for OpenBSD. # <doc/wiki/PasswordDatabase.BSDAuth.txt> #passdb bsdauth { # [cache_key=<key>] - See cache_key in PAM for explanation. #args = #} # passwd-like file with specified location # <doc/wiki/AuthDatabase.PasswdFile.txt> #passdb passwd-file { # [scheme=<default password scheme>] [username_format=<format>] # <Path for passwd-file> #args = #} # checkpassword executable authentication # NOTE: You will probably want to use "userdb prefetch" with this. # <doc/wiki/PasswordDatabase.CheckPassword.txt> #passdb checkpassword { # Path for checkpassword binary #args = #} # SQL database <doc/wiki/AuthDatabase.SQL.txt> #passdb sql { # Path for SQL configuration file, see doc/dovecot-sql-example.conf #args = #} # LDAP database <doc/wiki/AuthDatabase.LDAP.txt> #passdb ldap { # Path for LDAP configuration file, see doc/dovecot-ldap-example.conf #args = #} # vpopmail authentication <doc/wiki/AuthDatabase.VPopMail.txt> #passdb vpopmail { # [cache_key=<key>] - See cache_key in PAM for explanation. # [quota_template=<template>] - %q expands to Maildir++ quota # (eg. quota_template=quota_rule=*:backend=%q) #args = #} # # User database specifies where mails are located and what user/group IDs # own them. For single-UID configuration use "static". # # <doc/wiki/UserDatabase.txt> # # "prefetch" user database means that the passdb already provided the # needed information and there's no need to do a separate userdb lookup. # This can be made to work with SQL and LDAP databases, see their example # configuration files for more information how to do it. # <doc/wiki/UserDatabase.Prefetch.txt> #userdb prefetch { #} # System users (NSS, /etc/passwd, or similiar). In many systems nowadays this # uses Name Service Switch, which is configured in /etc/nsswitch.conf. # <doc/wiki/AuthDatabase.Passwd.txt> userdb passwd { # [blocking=yes] - By default the lookups are done in the main dovecot-auth # process. This setting causes the lookups to be done in auth worker # proceses. Useful with remote NSS lookups that may block. # NOTE: Be sure to use this setting with nss_ldap or users might get # logged in as each others! #args = } # passwd-like file with specified location # <doc/wiki/AuthDatabase.PasswdFile.txt> #userdb passwd-file { # [username_format=<format>] <Path for passwd-file> #args = #} # static settings generated from template <doc/wiki/UserDatabase.Static.txt> #userdb static { # Template for the fields. Can return anything a userdb could normally # return. For example: # # args = uid=500 gid=500 home=/var/mail/%u # # If you use deliver, it needs to look up users only from the userdb. This # of course doesn't work with static because there is no list of users. # Normally static userdb handles this by doing a passdb lookup. This works # with most passdbs, with PAM being the most notable exception. If you do # the user verification another way, you can add allow_all_users=yes to # the args in which case the passdb lookup is skipped. # #args = #} # SQL database <doc/wiki/AuthDatabase.SQL.txt> #userdb sql { # Path for SQL configuration file, see doc/dovecot-sql-example.conf #args = #} # LDAP database <doc/wiki/AuthDatabase.LDAP.txt> #userdb ldap { # Path for LDAP configuration file, see doc/dovecot-ldap-example.conf #args = #} # vpopmail <doc/wiki/AuthDatabase.VPopMail.txt> #userdb vpopmail { #} # User to use for the process. This user needs access to only user and # password databases, nothing else. Only shadow and pam authentication # requires roots, so use something else if possible. Note that passwd # authentication with BSDs internally accesses shadow files, which also # requires roots. Note that this user is NOT used to access mails. # That user is specified by userdb above. user = root # Directory where to chroot the process. Most authentication backends don't # work if this is set, and there's no point chrooting if auth_user is root. # Note that valid_chroot_dirs isn't needed to use this setting. #chroot = # Number of authentication processes to create #count = 1 # Require a valid SSL client certificate or the authentication fails. #ssl_require_client_cert = no # Take the username from client's SSL certificate, using # X509_NAME_get_text_by_NID() which returns the subject's DN's # CommonName. #ssl_username_from_cert = no # It's possible to export the authentication interface to other programs: #socket listen { #master { # Master socket provides access to userdb information. It's typically # used to give Dovecot's local delivery agent access to userdb so it # can find mailbox locations. #path = /var/run/dovecot/auth-master #mode = 0600 # Default user/group is the one who started dovecot-auth (root) #user = #group = #} #client { # The client socket is generally safe to export to everyone. Typical use # is to export it to your SMTP server so it can do SMTP AUTH lookups # using it. #path = /var/run/dovecot/auth-client #mode = 0660 #} #} } # If you wish to use another authentication server than dovecot-auth, you can # use connect sockets. They are assumed to be already running, Dovecot's master # process only tries to connect to them. They don't need any other settings # than the path for the master socket, as the configuration is done elsewhere. # Note that the client sockets must exist in the login_dir. #auth external { # socket connect { # master { # path = /var/run/dovecot/auth-master # } # } #} ## ## Dictionary server settings ## # Dictionary can be used by some plugins to store key=value lists. # Currently this is only used by dict quota backend. The dictionary can be # used either directly or though a dictionary server. The following dict block # maps dictionary names to URIs when the server is used. These can then be # referenced using URIs in format "proxy::<name>". dict { #quota = mysql:/etc/dovecot-dict-quota.conf #expire = db:/var/lib/dovecot/expire.db } # Path to Berkeley DB's configuration file. See doc/dovecot-db-example.conf #dict_db_config = ## ## Plugin settings ## plugin { # Here you can give some extra environment variables to mail processes. # This is mostly meant for passing parameters to plugins. %variable # expansion is done for all values. # Quota plugin. Multiple backends are supported: # dirsize: Find and sum all the files found from mail directory. # Extremely SLOW with Maildir. It'll eat your CPU and disk I/O. # dict: Keep quota stored in dictionary (eg. SQL) # maildir: Maildir++ quota # fs: Read-only support for filesystem quota # # Quota limits are set using "quota_rule" parameters, either in here or in # userdb. It's also possible to give mailbox-specific limits, for example: # quota_rule = *:storage=1048576 # quota_rule2 = Trash:storage=102400 # User has now 1GB quota, but when saving to Trash mailbox the user gets # additional 100MB. # # Multiple quota roots are also possible, for example: # quota = dict:user::proxy::quota # quota2 = dict:domain:%d:proxy::quota_domain # quota_rule = *:storage=102400 # quota2_rule = *:storage=1048576 # Gives each user their own 100MB quota and one shared 1GB quota within # the domain. # # You can execute a given command when user exceeds a specified quota limit. # Each quota root has separate limits. Only the command for the first # exceeded limit is excecuted, so put the highest limit first. # Note that % needs to be escaped as %%, otherwise "% " expands to empty. # quota_warning = storage=95%% /usr/local/bin/quota-warning.sh 95 # quota_warning2 = storage=80%% /usr/local/bin/quota-warning.sh 80 #quota = maildir # ACL plugin. vfile backend reads ACLs from "dovecot-acl" file from maildir # directory. You can also optionally give a global ACL directory path where # ACLs are applied to all users' mailboxes. The global ACL directory contains # one file for each mailbox, eg. INBOX or sub.mailbox. cache_secs parameter # specifies how many seconds to wait between stat()ing dovecot-acl file # to see if it changed. #acl = vfile:/etc/dovecot-acls:cache_secs=300 # Convert plugin. If set, specifies the source storage path which is # converted to destination storage (mail_location) when the user logs in. # The existing mail directory is renamed to <dir>-converted. #convert_mail = mbox:%h/mail # Skip mailboxes which we can't open successfully instead of aborting. #convert_skip_broken_mailboxes = no # Skip directories beginning with '.' #convert_skip_dotdirs = no # If source storage has mailbox names with destination storage's hierarchy # separators, replace them with this character. #convert_alt_hierarchy_char = _ # Trash plugin. When saving a message would make user go over quota, this # plugin automatically deletes the oldest mails from configured mailboxes # until the message can be saved within quota limits. The configuration file # is a text file where each line is in format: <priority> <mailbox name> # Mails are first deleted in lowest -> highest priority number order #trash = /etc/dovecot-trash.conf # Expire plugin. Mails are expunged from mailboxes after being there the # configurable time. The first expiration date for each mailbox is stored in # a dictionary so it can be quickly determined which mailboxes contain # expired mails. The actual expunging is done in a nightly cronjob, which # you must set up: # dovecot --exec-mail ext /usr/libexec/dovecot/expire-tool #expire = Trash 7 Spam 30 #expire_dict = proxy::expire # Lazy expunge plugin. Currently works only with maildirs. When a user # expunges mails, the mails are moved to a mailbox in another namespace # (1st). When a mailbox is deleted, the mailbox is moved to another namespace # (2nd) as well. Also if the deleted mailbox had any expunged messages, # they're moved to a 3rd namespace. The mails won't be counted in quota, # and they're not deleted automatically (use a cronjob or something). #lazy_expunge = .EXPUNGED/ .DELETED/ .DELETED/.EXPUNGED/ # Events to log. Default is all. #mail_log_events = delete undelete expunge copy mailbox_delete mailbox_rename # Group events within a transaction to one line. #mail_log_group_events = # Available fields: uid, box, msgid, size, vsize # size and vsize are available only for expunge and copy events. #mail_log_fields = uid box msgid size } Wszystko działa poprawnie, tzn. odbiera mi poczte, ale gdy chce wysłać to pisze mi, że serwer SMTP jest nieosiągalny. Patrzałem w logi /var/log/maillog Aug 17 12:25:13 localhost dovecot: Killed with signal 15 Aug 17 12:25:13 localhost dovecot: dovecot v1.1.16 starting up (core dumps disabled) Aug 17 12:25:25 localhost postfix/postfix-script[3304]: stopping the Postfix mail system Aug 17 12:25:25 localhost postfix/master[3241]: terminating on signal 15 Aug 17 12:25:26 localhost postfix/postfix-script[3355]: starting the Postfix mail system Aug 17 12:25:26 localhost postfix/master[3356]: daemon started -- version 2.5.6, configuration /etc/postfix Aug 17 12:33:47 localhost dovecot: pop3-login: Login: user=<cglicz>, method=PLAIN, rip=192.168.1.113, lip=192.168.1.5, TLS Aug 17 12:33:47 localhost dovecot: POP3(cglicz): Disconnected: Logged out top=0/0, retr=2/942, del=0/2, size=910 Aug 17 12:34:36 localhost dovecot: pop3-login: Login: user=<cglicz>, method=PLAIN, rip=192.168.1.113, lip=192.168.1.5, TLS Aug 17 12:34:36 localhost dovecot: POP3(cglicz): Disconnected: Logged out top=0/0, retr=0/0, del=0/2, size=910 Aug 17 12:42:30 localhost dovecot: pop3-login: Login: user=<cglicz>, method=PLAIN, rip=192.168.1.113, lip=192.168.1.5, TLS Aug 17 12:42:30 localhost dovecot: POP3(cglicz): Disconnected: Logged out top=0/0, retr=0/0, del=0/2, size=910 i wynika, że pocztę odebrał poprawnie, ale nie ma wzmianki o próbie wysyłania. Czy do postfixa jest jakiś program, do wysylania e-maili? Czy jakaś opcja w main.cf jest nieaktywna? Proszę o pomoc. Z góry Dziekuję 2 1 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
qmic Napisano Sierpień 17, 2009 Zgłoszenie Share Napisano Sierpień 17, 2009 Dokładniej opisz, w końcu mail doszedł czy nie ? Wyłączyłeś sendmail i włączyłeś postfixa w ogóle ? W pliku master.cf zmień linię: smtp inet n - n - - smtpd na: smtp inet n - n - - smtpd -v (dodaj -v na końcu - będziesz miał dokładniejsze informacje z postfixa) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ronon Napisano Sierpień 17, 2009 Autor Zgłoszenie Share Napisano Sierpień 17, 2009 Dokładniej opisz, w końcu mail doszedł czy nie ? Wyłączyłeś sendmail i włączyłeś postfixa w ogóle ? W pliku master.cf zmień linię: smtp inet n - n - - smtpd na: smtp inet n - n - - smtpd -v (dodaj -v na końcu - będziesz miał dokładniejsze informacje z postfixa) Wyłączyłem sendmaila i włączyłem postfiksa. W pliku masters.cf dodałem: # # Postfix master process configuration file. For details on the format # of the file, see the master(5) manual page (command: "man 5 master"). # # Do not forget to execute "postfix reload" after editing this file. # # ========================================================================== # service type private unpriv chroot wakeup maxproc command + args # (yes) (yes) (yes) (never) (100) # ========================================================================== smtp inet n - n - - smtpd -v #submission inet n - n - - smtpd # -o smtpd_tls_security_level=encrypt # -o smtpd_sasl_auth_enable=yes # -o smtpd_client_restrictions=permit_sasl_authenticated,reject # -o milter_macro_daemon_name=ORIGINATING #smtps inet n - n - - smtpd # -o smtpd_tls_wrappermode=yes # -o smtpd_sasl_auth_enable=yes # -o smtpd_client_restrictions=permit_sasl_authenticated,reject # -o milter_macro_daemon_name=ORIGINATING #628 inet n - n - - qmqpd pickup fifo n - n 60 1 pickup cleanup unix n - n - 0 cleanup qmgr fifo n - n 300 1 qmgr #qmgr fifo n - n 300 1 oqmgr tlsmgr unix - - n 1000? 1 tlsmgr rewrite unix - - n - - trivial-rewrite bounce unix - - n - 0 bounce defer unix - - n - 0 bounce trace unix - - n - 0 bounce verify unix - - n - 1 verify flush unix n - n 1000? 0 flush proxymap unix - - n - - proxymap proxywrite unix - - n - 1 proxymap smtp unix - - n - - smtp # When relaying mail as backup MX, disable fallback_relay to avoid MX loops relay unix - - n - - smtp -o smtp_fallback_relay= # -o smtp_helo_timeout=5 -o smtp_connect_timeout=5 showq unix n - n - - showq error unix - - n - - error retry unix - - n - - error discard unix - - n - - discard local unix - n n - - local virtual unix - n n - - virtual lmtp unix - - n - - lmtp anvil unix - - n - 1 anvil scache unix - - n - 1 scache # # ==================================================================== # Interfaces to non-Postfix software. Be sure to examine the manual # pages of the non-Postfix software to find out what options it wants. # # Many of the following services use the Postfix pipe(8) delivery # agent. See the pipe(8) man page for information about ${recipient} # and other message envelope options. # ==================================================================== # # maildrop. See the Postfix MAILDROP_README file for details. # Also specify in main.cf: maildrop_destination_recipient_limit=1 # #maildrop unix - n n - - pipe # flags=DRhu user=vmail argv=/usr/local/bin/maildrop -d ${recipient} # # ==================================================================== # # The Cyrus deliver program has changed incompatibly, multiple times. # #old-cyrus unix - n n - - pipe # flags=R user=cyrus argv=/usr/lib/cyrus-imapd/deliver -e -m ${extension} ${user} # # ==================================================================== # # Cyrus 2.1.5 (Amos Gouaux) # Also specify in main.cf: cyrus_destination_recipient_limit=1 # #cyrus unix - n n - - pipe # user=cyrus argv=/usr/lib/cyrus-imapd/deliver -e -r ${sender} -m ${extension} ${user} # # ==================================================================== # # See the Postfix UUCP_README file for configuration details. # #uucp unix - n n - - pipe # flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient) # # ==================================================================== # # Other external delivery methods. # #ifmail unix - n n - - pipe # flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient) # #bsmtp unix - n n - - pipe # flags=Fq. user=bsmtp argv=/usr/local/sbin/bsmtp -f $sender $nexthop $recipient # #scalemail-backend unix - n n - 2 pipe # flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store # ${nexthop} ${user} ${extension} # #mailman unix - n n - - pipe # flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py # ${nexthop} ${user} Mail wysłany nie doszedł. Plik mail.log Aug 17 12:25:13 localhost dovecot: Killed with signal 15 Aug 17 12:25:13 localhost dovecot: dovecot v1.1.16 starting up (core dumps disabled) Aug 17 12:25:25 localhost postfix/postfix-script[3304]: stopping the Postfix mail system Aug 17 12:25:25 localhost postfix/master[3241]: terminating on signal 15 Aug 17 12:25:26 localhost postfix/postfix-script[3355]: starting the Postfix mail system Aug 17 12:25:26 localhost postfix/master[3356]: daemon started -- version 2.5.6, configuration /etc/postfix Aug 17 12:33:47 localhost dovecot: pop3-login: Login: user=<cglicz>, method=PLAIN, rip=192.168.1.113, lip=192.168.1.5, TLS Aug 17 12:33:47 localhost dovecot: POP3(cglicz): Disconnected: Logged out top=0/0, retr=2/942, del=0/2, size=910 Aug 17 12:34:36 localhost dovecot: pop3-login: Login: user=<cglicz>, method=PLAIN, rip=192.168.1.113, lip=192.168.1.5, TLS Aug 17 12:34:36 localhost dovecot: POP3(cglicz): Disconnected: Logged out top=0/0, retr=0/0, del=0/2, size=910 Aug 17 12:42:30 localhost dovecot: pop3-login: Login: user=<cglicz>, method=PLAIN, rip=192.168.1.113, lip=192.168.1.5, TLS Aug 17 12:42:30 localhost dovecot: POP3(cglicz): Disconnected: Logged out top=0/0, retr=0/0, del=0/2, size=910 Aug 17 12:52:30 localhost dovecot: pop3-login: Login: user=<cglicz>, method=PLAIN, rip=192.168.1.113, lip=192.168.1.5, TLS Aug 17 12:52:30 localhost dovecot: POP3(cglicz): Disconnected: Logged out top=0/0, retr=0/0, del=0/2, size=910 Aug 17 13:23:45 localhost dovecot: Killed with signal 15 Aug 17 13:23:45 localhost dovecot: dovecot v1.1.16 starting up (core dumps disabled) Aug 17 13:23:57 localhost postfix/postfix-script[3612]: stopping the Postfix mail system Aug 17 13:23:57 localhost postfix/master[3356]: terminating on signal 15 Aug 17 13:23:58 localhost postfix/postfix-script[3663]: starting the Postfix mail system Aug 17 13:23:58 localhost postfix/master[3664]: daemon started -- version 2.5.6, configuration /etc/postfix Aug 17 13:24:13 localhost dovecot: pop3-login: Login: user=<cglicz>, method=PLAIN, rip=192.168.1.113, lip=192.168.1.5, TLS Aug 17 13:24:13 localhost dovecot: POP3(cglicz): Disconnected: Logged out top=0/0, retr=0/0, del=0/2, size=910 Aug 17 13:37:40 localhost dovecot: pop3-login: Disconnected: Inactivity (no auth attempts): rip=192.168.1.113, lip=192.168.1.5, TLS handshaking Aug 17 13:54:19 localhost postfix/postfix-script[3838]: stopping the Postfix mail system Aug 17 13:54:19 localhost postfix/master[3664]: terminating on signal 15 Aug 17 13:54:19 localhost dovecot: Killed with signal 15 Aug 17 13:55:17 localhost dovecot: dovecot v1.1.16 starting up (core dumps disabled) Aug 17 13:55:20 localhost postfix/postfix-script[1943]: starting the Postfix mail system Aug 17 13:55:20 localhost postfix/master[1944]: daemon started -- version 2.5.6, configuration /etc/postfix Aug 17 14:11:08 localhost postfix/postfix-script[2343]: stopping the Postfix mail system Aug 17 14:11:08 localhost postfix/master[1944]: terminating on signal 15 Aug 17 14:11:09 localhost postfix/postfix-script[2394]: starting the Postfix mail system Aug 17 14:11:09 localhost postfix/master[2395]: daemon started -- version 2.5.6, configuration /etc/postfix Aug 17 14:11:19 localhost dovecot: pop3-login: Login: user=<cglicz>, method=PLAIN, rip=192.168.1.113, lip=192.168.1.5, TLS Aug 17 14:11:19 localhost dovecot: POP3(cglicz): Disconnected: Logged out top=0/0, retr=0/0, del=0/2, size=910 Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const mail Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const all Aug 17 14:11:40 localhost postfix/smtpd[2402]: name_mask: all Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const poczta.localdomain Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const localdomain Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Postfix Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const postfix Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const postfix Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const postdrop Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand $myhostname, localhost.$mydomain, localhost, $mydomain -> poczta.localdomain, localhost.localdomain, localhost, localdomain Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand $myhostname -> poczta.localdomain Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const /usr/libexec/postfix Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const /var/lib/postfix Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const /usr/sbin Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const /var/spool/postfix Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const pid Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const all Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const double-bounce Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const nobody Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const hash:/etc/aliases Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 20090103 Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 2.5.6 Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const hash Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const deferred, defer Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand $mydestination -> poczta.localdomain, localhost.localdomain, localhost, localdomain Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand $relay_domains -> poczta.localdomain, localhost.localdomain, localhost, localdomain Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const TZ MAIL_CONFIG LANG Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const MAIL_CONFIG MAIL_DEBUG MAIL_LOGTAG TZ XAUTHORITY DISPLAY LANG=C Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const subnet Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const += Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const -=+ Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const debug_peer_list,fast_flush_domains,mynetworks,permit_mx_backup_networks,qmq pd_authorized_clients,relay_domains,smtpd_access_maps Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const bounce Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const cleanup Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const defer Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const pickup Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const qmgr Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const rewrite Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const showq Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const error Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const flush Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const verify Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const trace Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 2 Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 100s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 100s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 100s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 100s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 3600s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 3600s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 5s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 5s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 1000s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 1000s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 10s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 10s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 1s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 1s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 1s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 1s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 500s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 500s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 18000s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 18000s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 1s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 1s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 127.0.0.0/8 192.168.1.5/24 Aug 17 14:11:40 localhost postfix/smtpd[2402]: inet_addr_local: configured 2 IPv4 addresses Aug 17 14:11:40 localhost postfix/smtpd[2402]: inet_addr_local: configured 2 IPv6 addresses Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 550 Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand $myhostname ESMTP $mail_name ($mail_version) -> poczta.localdomain ESMTP Postfix (2.5.6) Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const resource, software Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const postmaster Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand $virtual_maps -> Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const hash:/etc/aliases Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand proxy:unix:passwd.byname $alias_maps -> proxy:unix:passwd.byname hash:/etc/aliases Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const noanonymous Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const private/auth Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const CONNECT GET POST Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const <> Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand $double_bounce_sender -> double-bounce Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand $authorized_verp_clients -> Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand $myhostname -> poczta.localdomain Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand ${smtpd_client_connection_limit_exceptions:$mynetworks} -> 127.0.0.0/8 192.168.1.5/24 Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const permit_inet_interfaces Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand $smtpd_sasl_security_options -> noanonymous Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand $smtpd_tls_cert_file -> Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand $smtpd_tls_dcert_file -> Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const medium Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const SSLv3, TLSv1 Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const md5 Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const dovecot Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const j {daemon_name} v Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const {tls_version} {cipher} {cipher_bits} {cert_subject} {cert_issuer} Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const i {auth_type} {auth_authen} {auth_author} {mail_addr} Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const i {rcpt_addr} Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const i Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const i Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const i Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 2 Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const tempfail Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand $myhostname -> poczta.localdomain Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: expand $mail_name $mail_version -> Postfix 2.5.6 Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const yes Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const yes Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 300s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 300s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 1s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 1s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 100s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 100s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 3s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 3s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 100s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 100s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 300s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 300s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 1000s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 1000s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 300s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 300s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 3600s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 3600s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 30s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 30s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 30s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 30s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 300s Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_eval: const 300s Aug 17 14:11:40 localhost postfix/smtpd[2402]: process generation: 3 (3) Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: mynetworks ~? debug_peer_list Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: mynetworks ~? fast_flush_domains Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: mynetworks ~? mynetworks Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: relay_domains ~? debug_peer_list Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: relay_domains ~? fast_flush_domains Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: relay_domains ~? mynetworks Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: relay_domains ~? permit_mx_backup_networks Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: relay_domains ~? qmqpd_authorized_clients Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: relay_domains ~? relay_domains Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: permit_mx_backup_networks ~? debug_peer_list Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: permit_mx_backup_networks ~? fast_flush_domains Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: permit_mx_backup_networks ~? mynetworks Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: permit_mx_backup_networks ~? permit_mx_backup_networks Aug 17 14:11:40 localhost postfix/smtpd[2402]: connect to subsystem private/proxymap Aug 17 14:11:40 localhost postfix/smtpd[2402]: send attr request = open Aug 17 14:11:40 localhost postfix/smtpd[2402]: send attr table = unix:passwd.byname Aug 17 14:11:40 localhost postfix/smtpd[2402]: send attr flags = 16448 Aug 17 14:11:40 localhost postfix/smtpd[2402]: private/proxymap socket: wanted attribute: status Aug 17 14:11:40 localhost postfix/smtpd[2402]: input attribute name: status Aug 17 14:11:40 localhost postfix/smtpd[2402]: input attribute value: 0 Aug 17 14:11:40 localhost postfix/smtpd[2402]: private/proxymap socket: wanted attribute: flags Aug 17 14:11:40 localhost postfix/smtpd[2402]: input attribute name: flags Aug 17 14:11:40 localhost postfix/smtpd[2402]: input attribute value: 16464 Aug 17 14:11:40 localhost postfix/smtpd[2402]: private/proxymap socket: wanted attribute: (list terminator) Aug 17 14:11:40 localhost postfix/smtpd[2402]: input attribute name: (end) Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_proxy_open: connect to map=unix:passwd.byname status=0 server_flags=fixed|lock|fold_fix Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_open: proxy:unix:passwd.byname Aug 17 14:11:40 localhost postfix/smtpd[2402]: Compiled against Berkeley DB: 4.7.25? Aug 17 14:11:40 localhost postfix/smtpd[2402]: Run-time linked against Berkeley DB: 4.7.25? Aug 17 14:11:40 localhost postfix/smtpd[2402]: dict_open: hash:/etc/aliases Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: smtpd_access_maps ~? debug_peer_list Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: smtpd_access_maps ~? fast_flush_domains Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: smtpd_access_maps ~? mynetworks Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: smtpd_access_maps ~? permit_mx_backup_networks Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: smtpd_access_maps ~? qmqpd_authorized_clients Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: smtpd_access_maps ~? relay_domains Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: smtpd_access_maps ~? smtpd_access_maps Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: fast_flush_domains ~? debug_peer_list Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_string: fast_flush_domains ~? fast_flush_domains Aug 17 14:11:40 localhost postfix/smtpd[2402]: auto_clnt_create: transport=local endpoint=private/anvil Aug 17 14:11:40 localhost postfix/smtpd[2402]: connection established Aug 17 14:11:40 localhost postfix/smtpd[2402]: master_notify: status 0 Aug 17 14:11:40 localhost postfix/smtpd[2402]: name_mask: resource Aug 17 14:11:40 localhost postfix/smtpd[2402]: name_mask: software Aug 17 14:11:40 localhost postfix/smtpd[2402]: xsasl_dovecot_server_create: SASL service=smtp, realm=(null) Aug 17 14:11:40 localhost postfix/smtpd[2402]: name_mask: noanonymous Aug 17 14:11:40 localhost postfix/smtpd[2402]: xsasl_dovecot_server_connect: Connecting Aug 17 14:11:40 localhost postfix/smtpd[2402]: xsasl_dovecot_server_connect: auth reply: MECH?PLAIN?plaintext Aug 17 14:11:40 localhost postfix/smtpd[2402]: name_mask: plaintext Aug 17 14:11:40 localhost postfix/smtpd[2402]: xsasl_dovecot_server_connect: auth reply: VERSION?1?0 Aug 17 14:11:40 localhost postfix/smtpd[2402]: xsasl_dovecot_server_connect: auth reply: SPID?1879 Aug 17 14:11:40 localhost postfix/smtpd[2402]: xsasl_dovecot_server_connect: auth reply: CUID?8 Aug 17 14:11:40 localhost postfix/smtpd[2402]: xsasl_dovecot_server_connect: auth reply: DONE Aug 17 14:11:40 localhost postfix/smtpd[2402]: xsasl_dovecot_server_mech_filter: keep mechanism: PLAIN Aug 17 14:11:40 localhost postfix/smtpd[2402]: connect from informatyk.int.oum.pl[192.168.1.113] Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_list_match: informatyk.int.oum.pl: no match Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_list_match: 192.168.1.113: no match Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_list_match: informatyk.int.oum.pl: no match Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_list_match: 192.168.1.113: no match Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_hostname: informatyk.int.oum.pl ~? 127.0.0.0/8 Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_hostaddr: 192.168.1.113 ~? 127.0.0.0/8 Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_hostname: informatyk.int.oum.pl ~? 192.168.1.5/24 Aug 17 14:11:40 localhost postfix/smtpd[2402]: match_hostaddr: 192.168.1.113 ~? 192.168.1.5/24 Aug 17 14:11:40 localhost postfix/smtpd[2402]: fatal: non-null host address bits in "192.168.1.5/24", perhaps you should use "192.168.1.0/24" instead Aug 17 14:11:41 localhost postfix/master[2395]: warning: process /usr/libexec/postfix/smtpd pid 2402 exit status 1 Aug 17 14:11:41 localhost postfix/master[2395]: warning: /usr/libexec/postfix/smtpd: bad command startup -- throttling Z logów wynika, że chyba mam złą adresacje, zamiast 192.168.1.5 ma być 192.168.1.0 i Aug 17 14:11:41 localhost postfix/master[2395]: warning: /usr/libexec/postfix/smtpd: bad command startup -- throttling oznacza, że mam błąd przy uruchamianiu smtpd lub nie mam wcale pliku? Zmieniłem w main.cf parametr : mynetworks = 127.0.0.0/8 192.168.1.5/24 na mynetworks = 127.0.0.0/8 192.168.1.0/24 i działa wysyłanie, ale nie dochodzą maile. Oto log: Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const mail Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const all Aug 17 14:39:49 localhost postfix/smtpd[2326]: name_mask: all Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const poczta.localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Postfix Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const postfix Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const postfix Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const postdrop Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand $myhostname, localhost.$mydomain, localhost, $mydomain -> poczta.localdomain, localhost.localdomain, localhost, localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand $myhostname -> poczta.localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const /usr/libexec/postfix Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const /var/lib/postfix Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const /usr/sbin Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const /var/spool/postfix Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const pid Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const all Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const double-bounce Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const nobody Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const hash:/etc/aliases Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 20090103 Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 2.5.6 Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const hash Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const deferred, defer Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand $mydestination -> poczta.localdomain, localhost.localdomain, localhost, localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand $relay_domains -> poczta.localdomain, localhost.localdomain, localhost, localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const TZ MAIL_CONFIG LANG Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const MAIL_CONFIG MAIL_DEBUG MAIL_LOGTAG TZ XAUTHORITY DISPLAY LANG=C Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const subnet Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const += Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const -=+ Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const debug_peer_list,fast_flush_domains,mynetworks,permit_mx_backup_networks,qmq pd_authorized_clients,relay_domains,smtpd_access_maps Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const bounce Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const cleanup Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const defer Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const pickup Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const qmgr Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const rewrite Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const showq Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const error Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const flush Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const verify Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const trace Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 2 Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 100s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 100s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 100s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 100s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 3600s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 3600s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 5s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 5s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 1000s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 1000s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 10s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 10s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 1s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 1s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 1s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 1s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 500s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 500s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 18000s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 18000s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 1s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 1s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 127.0.0.0/8 192.168.1.0/24 Aug 17 14:39:49 localhost postfix/smtpd[2326]: inet_addr_local: configured 2 IPv4 addresses Aug 17 14:39:49 localhost postfix/smtpd[2326]: inet_addr_local: configured 2 IPv6 addresses Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 550 Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand $myhostname ESMTP $mail_name ($mail_version) -> poczta.localdomain ESMTP Postfix (2.5.6) Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const resource, software Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const postmaster Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand $virtual_maps -> Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const hash:/etc/aliases Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand proxy:unix:passwd.byname $alias_maps -> proxy:unix:passwd.byname hash:/etc/aliases Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const noanonymous Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const private/auth Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const CONNECT GET POST Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const <> Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand $double_bounce_sender -> double-bounce Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand $authorized_verp_clients -> Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand $myhostname -> poczta.localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand ${smtpd_client_connection_limit_exceptions:$mynetworks} -> 127.0.0.0/8 192.168.1.0/24 Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const permit_inet_interfaces Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand $smtpd_sasl_security_options -> noanonymous Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand $smtpd_tls_cert_file -> Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand $smtpd_tls_dcert_file -> Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const medium Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const SSLv3, TLSv1 Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const md5 Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const dovecot Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const j {daemon_name} v Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const {tls_version} {cipher} {cipher_bits} {cert_subject} {cert_issuer} Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const i {auth_type} {auth_authen} {auth_author} {mail_addr} Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const i {rcpt_addr} Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const i Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const i Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const i Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 2 Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const tempfail Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand $myhostname -> poczta.localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: expand $mail_name $mail_version -> Postfix 2.5.6 Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const yes Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const yes Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 300s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 300s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 1s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 1s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 100s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 100s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 3s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 3s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 100s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 100s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 300s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 300s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 1000s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 1000s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 300s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 300s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 3600s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 3600s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 30s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 30s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 30s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 30s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 300s Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_eval: const 300s Aug 17 14:39:49 localhost postfix/smtpd[2326]: process generation: 13 (13) Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: mynetworks ~? debug_peer_list Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: mynetworks ~? fast_flush_domains Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: mynetworks ~? mynetworks Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: relay_domains ~? debug_peer_list Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: relay_domains ~? fast_flush_domains Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: relay_domains ~? mynetworks Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: relay_domains ~? permit_mx_backup_networks Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: relay_domains ~? qmqpd_authorized_clients Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: relay_domains ~? relay_domains Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: permit_mx_backup_networks ~? debug_peer_list Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: permit_mx_backup_networks ~? fast_flush_domains Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: permit_mx_backup_networks ~? mynetworks Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: permit_mx_backup_networks ~? permit_mx_backup_networks Aug 17 14:39:49 localhost postfix/smtpd[2326]: connect to subsystem private/proxymap Aug 17 14:39:49 localhost postfix/smtpd[2326]: send attr request = open Aug 17 14:39:49 localhost postfix/smtpd[2326]: send attr table = unix:passwd.byname Aug 17 14:39:49 localhost postfix/smtpd[2326]: send attr flags = 16448 Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/proxymap socket: wanted attribute: status Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: status Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute value: 0 Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/proxymap socket: wanted attribute: flags Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: flags Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute value: 16464 Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/proxymap socket: wanted attribute: (list terminator) Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: (end) Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_proxy_open: connect to map=unix:passwd.byname status=0 server_flags=fixed|lock|fold_fix Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_open: proxy:unix:passwd.byname Aug 17 14:39:49 localhost postfix/smtpd[2326]: Compiled against Berkeley DB: 4.7.25? Aug 17 14:39:49 localhost postfix/smtpd[2326]: Run-time linked against Berkeley DB: 4.7.25? Aug 17 14:39:49 localhost postfix/smtpd[2326]: dict_open: hash:/etc/aliases Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: smtpd_access_maps ~? debug_peer_list Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: smtpd_access_maps ~? fast_flush_domains Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: smtpd_access_maps ~? mynetworks Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: smtpd_access_maps ~? permit_mx_backup_networks Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: smtpd_access_maps ~? qmqpd_authorized_clients Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: smtpd_access_maps ~? relay_domains Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: smtpd_access_maps ~? smtpd_access_maps Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: fast_flush_domains ~? debug_peer_list Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: fast_flush_domains ~? fast_flush_domains Aug 17 14:39:49 localhost postfix/smtpd[2326]: auto_clnt_create: transport=local endpoint=private/anvil Aug 17 14:39:49 localhost postfix/smtpd[2326]: connection established Aug 17 14:39:49 localhost postfix/smtpd[2326]: master_notify: status 0 Aug 17 14:39:49 localhost postfix/smtpd[2326]: name_mask: resource Aug 17 14:39:49 localhost postfix/smtpd[2326]: name_mask: software Aug 17 14:39:49 localhost postfix/smtpd[2326]: xsasl_dovecot_server_create: SASL service=smtp, realm=(null) Aug 17 14:39:49 localhost postfix/smtpd[2326]: name_mask: noanonymous Aug 17 14:39:49 localhost postfix/smtpd[2326]: xsasl_dovecot_server_connect: Connecting Aug 17 14:39:49 localhost postfix/smtpd[2326]: xsasl_dovecot_server_connect: auth reply: MECH?PLAIN?plaintext Aug 17 14:39:49 localhost postfix/smtpd[2326]: name_mask: plaintext Aug 17 14:39:49 localhost postfix/smtpd[2326]: xsasl_dovecot_server_connect: auth reply: VERSION?1?0 Aug 17 14:39:49 localhost postfix/smtpd[2326]: xsasl_dovecot_server_connect: auth reply: SPID?1880 Aug 17 14:39:49 localhost postfix/smtpd[2326]: xsasl_dovecot_server_connect: auth reply: CUID?11 Aug 17 14:39:49 localhost postfix/smtpd[2326]: xsasl_dovecot_server_connect: auth reply: DONE Aug 17 14:39:49 localhost postfix/smtpd[2326]: xsasl_dovecot_server_mech_filter: keep mechanism: PLAIN Aug 17 14:39:49 localhost postfix/smtpd[2326]: connect from informatyk.int.oum.pl[192.168.1.113] Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_list_match: informatyk.int.oum.pl: no match Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_list_match: 192.168.1.113: no match Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_list_match: informatyk.int.oum.pl: no match Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_list_match: 192.168.1.113: no match Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_hostname: informatyk.int.oum.pl ~? 127.0.0.0/8 Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_hostaddr: 192.168.1.113 ~? 127.0.0.0/8 Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_hostname: informatyk.int.oum.pl ~? 192.168.1.0/24 Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_hostaddr: 192.168.1.113 ~? 192.168.1.0/24 Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 220 poczta.localdomain ESMTP Postfix (2.5.6) Aug 17 14:39:49 localhost postfix/smtpd[2326]: < informatyk.int.oum.pl[192.168.1.113]: EHLO [127.0.0.1] Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250-poczta.localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250-PIPELINING Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250-SIZE 10240000 Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250-VRFY Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250-ETRN Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250-AUTH PLAIN Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_list_match: informatyk.int.oum.pl: no match Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_list_match: 192.168.1.113: no match Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250-AUTH=PLAIN Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250-ENHANCEDSTATUSCODES Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250-8BITMIME Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250 DSN Aug 17 14:39:49 localhost postfix/smtpd[2326]: < informatyk.int.oum.pl[192.168.1.113]: AUTH PLAIN AGNnbGljegBjZ2xpY3o= Aug 17 14:39:49 localhost postfix/smtpd[2326]: xsasl_dovecot_server_first: sasl_method PLAIN, init_response AGNnbGljegBjZ2xpY3o= Aug 17 14:39:49 localhost postfix/smtpd[2326]: xsasl_dovecot_handle_reply: auth reply: OK?1?user=cglicz Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 235 2.7.0 Authentication successful Aug 17 14:39:49 localhost postfix/smtpd[2326]: < informatyk.int.oum.pl[192.168.1.113]: MAIL FROM:<[email protected]> SIZE=419 Aug 17 14:39:49 localhost postfix/smtpd[2326]: extract_addr: input: <[email protected]> Aug 17 14:39:49 localhost postfix/smtpd[2326]: smtpd_check_addr: [email protected] Aug 17 14:39:49 localhost postfix/smtpd[2326]: connect to subsystem private/rewrite Aug 17 14:39:49 localhost postfix/smtpd[2326]: send attr request = rewrite Aug 17 14:39:49 localhost postfix/smtpd[2326]: send attr rule = local Aug 17 14:39:49 localhost postfix/smtpd[2326]: send attr address = [email protected] Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/rewrite socket: wanted attribute: flags Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: flags Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute value: 0 Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/rewrite socket: wanted attribute: address Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: address Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute value: [email protected] Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/rewrite socket: wanted attribute: (list terminator) Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: (end) Aug 17 14:39:49 localhost postfix/smtpd[2326]: rewrite_clnt: local: [email protected] -> [email protected] Aug 17 14:39:49 localhost postfix/smtpd[2326]: send attr request = resolve Aug 17 14:39:49 localhost postfix/smtpd[2326]: send attr sender = Aug 17 14:39:49 localhost postfix/smtpd[2326]: send attr address = [email protected] Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/rewrite socket: wanted attribute: flags Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: flags Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute value: 0 Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/rewrite socket: wanted attribute: transport Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: transport Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute value: smtp Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/rewrite socket: wanted attribute: nexthop Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: nexthop Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute value: poczta.int.oum.pl Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/rewrite socket: wanted attribute: recipient Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: recipient Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute value: [email protected] Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/rewrite socket: wanted attribute: flags Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: flags Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute value: 4096 Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/rewrite socket: wanted attribute: (list terminator) Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: (end) Aug 17 14:39:49 localhost postfix/smtpd[2326]: resolve_clnt: `' -> `[email protected]' -> transp=`smtp' host=`poczta.int.oum.pl' rcpt=`[email protected]' flags= class=default Aug 17 14:39:49 localhost postfix/smtpd[2326]: ctable_locate: install entry key [email protected] Aug 17 14:39:49 localhost postfix/smtpd[2326]: extract_addr: in: <[email protected]>, result: [email protected] Aug 17 14:39:49 localhost postfix/smtpd[2326]: fsspace: .: block size 4096, blocks free 3016308 Aug 17 14:39:49 localhost postfix/smtpd[2326]: smtpd_check_queue: blocks 4096 avail 3016308 min_free 0 msg_size_limit 10240000 Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250 2.1.0 Ok Aug 17 14:39:49 localhost postfix/smtpd[2326]: < informatyk.int.oum.pl[192.168.1.113]: RCPT TO:<[email protected]> Aug 17 14:39:49 localhost postfix/smtpd[2326]: extract_addr: input: <[email protected]> Aug 17 14:39:49 localhost postfix/smtpd[2326]: smtpd_check_addr: [email protected] Aug 17 14:39:49 localhost postfix/smtpd[2326]: ctable_locate: leave existing entry key [email protected] Aug 17 14:39:49 localhost postfix/smtpd[2326]: extract_addr: in: <[email protected]>, result: [email protected] Aug 17 14:39:49 localhost postfix/smtpd[2326]: send attr request = rewrite Aug 17 14:39:49 localhost postfix/smtpd[2326]: send attr rule = local Aug 17 14:39:49 localhost postfix/smtpd[2326]: send attr address = double-bounce Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/rewrite socket: wanted attribute: flags Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: flags Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute value: 0 Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/rewrite socket: wanted attribute: address Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: address Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute value: [email protected] Aug 17 14:39:49 localhost postfix/smtpd[2326]: private/rewrite socket: wanted attribute: (list terminator) Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: (end) Aug 17 14:39:49 localhost postfix/smtpd[2326]: rewrite_clnt: local: double-bounce -> [email protected] Aug 17 14:39:49 localhost postfix/smtpd[2326]: >>> START Recipient address RESTRICTIONS <<< Aug 17 14:39:49 localhost postfix/smtpd[2326]: generic_checks: name=permit_mynetworks Aug 17 14:39:49 localhost postfix/smtpd[2326]: permit_mynetworks: informatyk.int.oum.pl 192.168.1.113 Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_hostname: informatyk.int.oum.pl ~? 127.0.0.0/8 Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_hostaddr: 192.168.1.113 ~? 127.0.0.0/8 Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_hostname: informatyk.int.oum.pl ~? 192.168.1.0/24 Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_hostaddr: 192.168.1.113 ~? 192.168.1.0/24 Aug 17 14:39:49 localhost postfix/smtpd[2326]: generic_checks: name=permit_mynetworks status=1 Aug 17 14:39:49 localhost postfix/smtpd[2326]: >>> CHECKING RECIPIENT MAPS <<< Aug 17 14:39:49 localhost postfix/smtpd[2326]: ctable_locate: leave existing entry key [email protected] Aug 17 14:39:49 localhost postfix/smtpd[2326]: maps_find: recipient_canonical_maps: [email protected]: not found Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? poczta.localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localhost.localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localhost Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_list_match: poczta.int.oum.pl: no match Aug 17 14:39:49 localhost postfix/smtpd[2326]: maps_find: recipient_canonical_maps: @poczta.int.oum.pl: not found Aug 17 14:39:49 localhost postfix/smtpd[2326]: mail_addr_find: [email protected] -> (not found) Aug 17 14:39:49 localhost postfix/smtpd[2326]: maps_find: canonical_maps: [email protected]: not found Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? poczta.localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localhost.localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localhost Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_list_match: poczta.int.oum.pl: no match Aug 17 14:39:49 localhost postfix/smtpd[2326]: maps_find: canonical_maps: @poczta.int.oum.pl: not found Aug 17 14:39:49 localhost postfix/smtpd[2326]: mail_addr_find: [email protected] -> (not found) Aug 17 14:39:49 localhost postfix/smtpd[2326]: maps_find: virtual_alias_maps: [email protected]: not found Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? poczta.localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localhost.localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localhost Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localdomain Aug 17 14:39:49 localhost postfix/smtpd[2326]: match_list_match: poczta.int.oum.pl: no match Aug 17 14:39:49 localhost postfix/smtpd[2326]: maps_find: virtual_alias_maps: @poczta.int.oum.pl: not found Aug 17 14:39:49 localhost postfix/smtpd[2326]: mail_addr_find: [email protected] -> (not found) Aug 17 14:39:49 localhost postfix/smtpd[2326]: smtpd_check_rewrite: trying: permit_inet_interfaces Aug 17 14:39:49 localhost postfix/smtpd[2326]: permit_inet_interfaces: informatyk.int.oum.pl 192.168.1.113 Aug 17 14:39:49 localhost postfix/smtpd[2326]: before input_transp_cleanup: cleanup flags = enable_header_body_filter enable_automatic_bcc enable_address_mapping enable_milters Aug 17 14:39:49 localhost postfix/smtpd[2326]: after input_transp_cleanup: cleanup flags = enable_header_body_filter enable_automatic_bcc enable_address_mapping Aug 17 14:39:49 localhost postfix/smtpd[2326]: connect to subsystem public/cleanup Aug 17 14:39:49 localhost postfix/smtpd[2326]: public/cleanup socket: wanted attribute: queue_id Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: queue_id Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute value: 93884B6053 Aug 17 14:39:49 localhost postfix/smtpd[2326]: public/cleanup socket: wanted attribute: (list terminator) Aug 17 14:39:49 localhost postfix/smtpd[2326]: input attribute name: (end) Aug 17 14:39:49 localhost postfix/smtpd[2326]: send attr flags = 178 Aug 17 14:39:49 localhost postfix/smtpd[2326]: 93884B6053: client=informatyk.int.oum.pl[192.168.1.113], sasl_method=PLAIN, sasl_username=cglicz Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250 2.1.5 Ok Aug 17 14:39:49 localhost postfix/smtpd[2326]: < informatyk.int.oum.pl[192.168.1.113]: RSET Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250 2.0.0 Ok Aug 17 14:39:49 localhost postfix/smtpd[2326]: < informatyk.int.oum.pl[192.168.1.113]: RSET Aug 17 14:39:49 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250 2.0.0 Ok Aug 17 14:39:50 localhost postfix/smtpd[2326]: < informatyk.int.oum.pl[192.168.1.113]: MAIL FROM:<[email protected]> SIZE=419 Aug 17 14:39:50 localhost postfix/smtpd[2326]: extract_addr: input: <[email protected]> Aug 17 14:39:50 localhost postfix/smtpd[2326]: smtpd_check_addr: [email protected] Aug 17 14:39:50 localhost postfix/smtpd[2326]: ctable_locate: leave existing entry key [email protected] Aug 17 14:39:50 localhost postfix/smtpd[2326]: extract_addr: in: <[email protected]>, result: [email protected] Aug 17 14:39:50 localhost postfix/smtpd[2326]: fsspace: .: block size 4096, blocks free 3016307 Aug 17 14:39:50 localhost postfix/smtpd[2326]: smtpd_check_queue: blocks 4096 avail 3016307 min_free 0 msg_size_limit 10240000 Aug 17 14:39:50 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250 2.1.0 Ok Aug 17 14:39:50 localhost postfix/smtpd[2326]: < informatyk.int.oum.pl[192.168.1.113]: RCPT TO:<[email protected]> Aug 17 14:39:50 localhost postfix/smtpd[2326]: extract_addr: input: <[email protected]> Aug 17 14:39:50 localhost postfix/smtpd[2326]: smtpd_check_addr: [email protected] Aug 17 14:39:50 localhost postfix/smtpd[2326]: ctable_locate: leave existing entry key [email protected] Aug 17 14:39:50 localhost postfix/smtpd[2326]: extract_addr: in: <[email protected]>, result: [email protected] Aug 17 14:39:50 localhost postfix/smtpd[2326]: >>> START Recipient address RESTRICTIONS <<< Aug 17 14:39:50 localhost postfix/smtpd[2326]: generic_checks: name=permit_mynetworks Aug 17 14:39:50 localhost postfix/smtpd[2326]: permit_mynetworks: informatyk.int.oum.pl 192.168.1.113 Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_hostname: informatyk.int.oum.pl ~? 127.0.0.0/8 Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_hostaddr: 192.168.1.113 ~? 127.0.0.0/8 Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_hostname: informatyk.int.oum.pl ~? 192.168.1.0/24 Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_hostaddr: 192.168.1.113 ~? 192.168.1.0/24 Aug 17 14:39:50 localhost postfix/smtpd[2326]: generic_checks: name=permit_mynetworks status=1 Aug 17 14:39:50 localhost postfix/smtpd[2326]: >>> CHECKING RECIPIENT MAPS <<< Aug 17 14:39:50 localhost postfix/smtpd[2326]: ctable_locate: leave existing entry key [email protected] Aug 17 14:39:50 localhost postfix/smtpd[2326]: maps_find: recipient_canonical_maps: [email protected]: not found Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? poczta.localdomain Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localhost.localdomain Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localhost Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localdomain Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_list_match: poczta.int.oum.pl: no match Aug 17 14:39:50 localhost postfix/smtpd[2326]: maps_find: recipient_canonical_maps: @poczta.int.oum.pl: not found Aug 17 14:39:50 localhost postfix/smtpd[2326]: mail_addr_find: [email protected] -> (not found) Aug 17 14:39:50 localhost postfix/smtpd[2326]: maps_find: canonical_maps: [email protected]: not found Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? poczta.localdomain Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localhost.localdomain Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localhost Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localdomain Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_list_match: poczta.int.oum.pl: no match Aug 17 14:39:50 localhost postfix/smtpd[2326]: maps_find: canonical_maps: @poczta.int.oum.pl: not found Aug 17 14:39:50 localhost postfix/smtpd[2326]: mail_addr_find: [email protected] -> (not found) Aug 17 14:39:50 localhost postfix/smtpd[2326]: maps_find: virtual_alias_maps: [email protected]: not found Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? poczta.localdomain Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localhost.localdomain Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localhost Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_string: poczta.int.oum.pl ~? localdomain Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_list_match: poczta.int.oum.pl: no match Aug 17 14:39:50 localhost postfix/smtpd[2326]: maps_find: virtual_alias_maps: @poczta.int.oum.pl: not found Aug 17 14:39:50 localhost postfix/smtpd[2326]: mail_addr_find: [email protected] -> (not found) Aug 17 14:39:50 localhost postfix/smtpd[2326]: smtpd_check_rewrite: trying: permit_inet_interfaces Aug 17 14:39:50 localhost postfix/smtpd[2326]: permit_inet_interfaces: informatyk.int.oum.pl 192.168.1.113 Aug 17 14:39:50 localhost postfix/smtpd[2326]: before input_transp_cleanup: cleanup flags = enable_header_body_filter enable_automatic_bcc enable_address_mapping enable_milters Aug 17 14:39:50 localhost postfix/smtpd[2326]: after input_transp_cleanup: cleanup flags = enable_header_body_filter enable_automatic_bcc enable_address_mapping Aug 17 14:39:50 localhost postfix/smtpd[2326]: connect to subsystem public/cleanup Aug 17 14:39:50 localhost postfix/smtpd[2326]: public/cleanup socket: wanted attribute: queue_id Aug 17 14:39:50 localhost postfix/smtpd[2326]: input attribute name: queue_id Aug 17 14:39:50 localhost postfix/smtpd[2326]: input attribute value: 0DD36B6053 Aug 17 14:39:50 localhost postfix/smtpd[2326]: public/cleanup socket: wanted attribute: (list terminator) Aug 17 14:39:50 localhost postfix/smtpd[2326]: input attribute name: (end) Aug 17 14:39:50 localhost postfix/smtpd[2326]: send attr flags = 178 Aug 17 14:39:50 localhost postfix/smtpd[2326]: 0DD36B6053: client=informatyk.int.oum.pl[192.168.1.113], sasl_method=PLAIN, sasl_username=cglicz Aug 17 14:39:50 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250 2.1.5 Ok Aug 17 14:39:50 localhost postfix/smtpd[2326]: < informatyk.int.oum.pl[192.168.1.113]: DATA Aug 17 14:39:50 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 354 End data with <CR><LF>.<CR><LF> Aug 17 14:39:50 localhost postfix/cleanup[2329]: 0DD36B6053: message-id=<[email protected]> Aug 17 14:39:50 localhost postfix/qmgr[1956]: 0DD36B6053: from=<[email protected]>, size=622, nrcpt=1 (queue active) Aug 17 14:39:50 localhost postfix/smtpd[2326]: public/cleanup socket: wanted attribute: status Aug 17 14:39:50 localhost postfix/smtpd[2326]: input attribute name: status Aug 17 14:39:50 localhost postfix/smtpd[2326]: input attribute value: 0 Aug 17 14:39:50 localhost postfix/smtpd[2326]: public/cleanup socket: wanted attribute: reason Aug 17 14:39:50 localhost postfix/smtpd[2326]: input attribute name: reason Aug 17 14:39:50 localhost postfix/smtpd[2326]: input attribute value: (end) Aug 17 14:39:50 localhost postfix/smtpd[2326]: public/cleanup socket: wanted attribute: (list terminator) Aug 17 14:39:50 localhost postfix/smtpd[2326]: input attribute name: (end) Aug 17 14:39:50 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 250 2.0.0 Ok: queued as 0DD36B6053 Aug 17 14:39:50 localhost postfix/smtpd[2326]: < informatyk.int.oum.pl[192.168.1.113]: QUIT Aug 17 14:39:50 localhost postfix/smtpd[2326]: > informatyk.int.oum.pl[192.168.1.113]: 221 2.0.0 Bye Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_hostname: informatyk.int.oum.pl ~? 127.0.0.0/8 Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_hostaddr: 192.168.1.113 ~? 127.0.0.0/8 Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_hostname: informatyk.int.oum.pl ~? 192.168.1.0/24 Aug 17 14:39:50 localhost postfix/smtpd[2326]: match_hostaddr: 192.168.1.113 ~? 192.168.1.0/24 Aug 17 14:39:50 localhost postfix/smtpd[2326]: disconnect from informatyk.int.oum.pl[192.168.1.113] Aug 17 14:39:50 localhost postfix/smtpd[2326]: master_notify: status 1 Aug 17 14:39:50 localhost postfix/smtpd[2326]: connection closed Aug 17 14:39:50 localhost postfix/smtp[2330]: 0DD36B6053: to=<[email protected]>, relay=none, delay=0.09, delays=0.06/0.03/0/0, dsn=5.4.6, status=bounced (mail for poczta.int.oum.pl loops back to myself) Aug 17 14:39:50 localhost postfix/cleanup[2329]: 282EEB6057: message-id=<[email protected]> Aug 17 14:39:50 localhost postfix/qmgr[1956]: 282EEB6057: from=<>, size=2456, nrcpt=1 (queue active) Aug 17 14:39:50 localhost postfix/bounce[2331]: 0DD36B6053: sender non-delivery notification: 282EEB6057 Aug 17 14:39:50 localhost postfix/qmgr[1956]: 0DD36B6053: removed Aug 17 14:39:50 localhost postfix/smtp[2330]: 282EEB6057: to=<[email protected]>, relay=none, delay=0.01, delays=0.01/0/0/0, dsn=5.4.6, status=bounced (mail for poczta.int.oum.pl loops back to myself) Aug 17 14:39:50 localhost postfix/qmgr[1956]: 282EEB6057: removed Aug 17 14:39:54 localhost postfix/smtpd[2326]: proxymap stream disconnect Aug 17 14:39:54 localhost postfix/smtpd[2326]: rewrite stream disconnect Aug 17 14:40:52 localhost dovecot: pop3-login: Login: user=<cglicz>, method=PLAIN, rip=192.168.1.113, lip=192.168.1.5, TLS Aug 17 14:40:52 localhost dovecot: POP3(cglicz): Disconnected: Logged out top=0/0, retr=0/0, del=0/2, size=910 Aug 17 14:41:30 localhost postfix/smtpd[2326]: idle timeout -- exiting Czemu? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ronon Napisano Sierpień 17, 2009 Autor Zgłoszenie Share Napisano Sierpień 17, 2009 W logach wynika, że poczta: Aug 17 14:39:50 localhost postfix/smtp[2330]: 0DD36B6053: to=<[email protected]>, relay=none, delay=0.09, delays=0.06/0.03/0/0, dsn=5.4.6, status=bounced (mail for poczta.int.oum.pl loops back to myself) Aug 17 14:39:50 localhost postfix/cleanup[2329]: 282EEB6057: message-id=<[email protected]> Aug 17 14:39:50 localhost postfix/qmgr[1956]: 282EEB6057: from=<>, size=2456, nrcpt=1 (queue active) Aug 17 14:39:50 localhost postfix/bounce[2331]: 0DD36B6053: sender non-delivery notification: 282EEB6057 Aug 17 14:39:50 localhost postfix/qmgr[1956]: 0DD36B6053: removed Aug 17 14:39:50 localhost postfix/smtp[2330]: 282EEB6057: to=<[email protected]>, relay=none, delay=0.01, delays=0.01/0/0/0, dsn=5.4.6, status=bounced (mail for poczta.int.oum.pl loops back to myself) Aug 17 14:39:50 localhost postfix/qmgr[1956]: 282EEB6057: removed jest kasowana, gdyż wiadomość nie doszła na wskazany adres. Czy może mi ktoś powiedzieć dlaczego? Co jest powodem,że wiadomość nie można wysłać do każdego odbiorcy w sieci 192.168.1.0? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
qmic Napisano Sierpień 17, 2009 Zgłoszenie Share Napisano Sierpień 17, 2009 Zmień linię mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain dodaj tu może na końcu: mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain, mojadomena.com.pl Tylko oczywiście zmień mojadomena.com.pl na swoją której używasz. Masz nieprawidłowo ustawioną zmienną hostname i domainname w systemie. Poza tym wklejając moją poradę dodałeś za dużo: smtp inet n - n - - smtpd -v Usuń te znaczniki w nawiasach Po operacji zawsze trzeba zrestartować postfix`a. Poza tym do testów wyłącz dovecot`a (sprawdzaj czy poczta doszła w katalogach użytkownika, tylko Ci zaśmieca logi. Dostarczanie poczty to oddzielna sprawa z odbieraniem (postfix służy do dostarczania - SMTP a dovecot do odbierania - IMAP,POP) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 17, 2009 Zgłoszenie Share Napisano Sierpień 17, 2009 Off Topic @ranon - bądź łaskaw te swoje tasiemcowe listingi wstawiać w odpowiednich znacznikach. Sprawdź, to może uda Ci się zauważyć pewną różnicę między znacznikami code i codebox. Warto też przed wklejeniem chwilę pomyśleć czy to co się wkleja jest rzeczywiście konieczne i niesie jakąś wartościową informację. Np. komentarze w plikach konfiguracyjnych taką wartościową informacja nie są. Ilość zazwyczaj nie przechodzi w jakość. I nie pisz postów pod własnymi. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ronon Napisano Sierpień 18, 2009 Autor Zgłoszenie Share Napisano Sierpień 18, 2009 Zmień linię mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain dodaj tu może na końcu: mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain, mojadomena.com.pl Tylko oczywiście zmień mojadomena.com.pl na swoją której używasz. Masz nieprawidłowo ustawioną zmienną hostname i domainname w systemie. Poza tym wklejając moją poradę dodałeś za dużo: smtp inet n - n - - smtpd -v Usuń te znaczniki w nawiasach Po operacji zawsze trzeba zrestartować postfix`a. Poza tym do testów wyłącz dovecot`a (sprawdzaj czy poczta doszła w katalogach użytkownika, tylko Ci zaśmieca logi. Dostarczanie poczty to oddzielna sprawa z odbieraniem (postfix służy do dostarczania - SMTP a dovecot do odbierania - IMAP,POP) Dzięki. Już poczta działa, jest super. Znalazłem linijkę : smtpd_banner = $myhostname ESMTP $mail_name ($mail_version) która była odpowiedzialna za niewysyłanie maili. Wielkie dzieki qmic Mam pytanie: Używamy klienta poczty Mozzila Thunderbird. Podczas połaczenia się z postfixem wywala komunikat: Błąd zabezpieczeń: Niezgodność nazwy domeny Podjęto próbę połączenia się z "poczta.int.oum.pl", jednakże przedstawiony przez stronę certyfikat należy do "imap.exlample.com". (...) Czy to jest generowane z davecot czy z postfixa? Jak to usunąć? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
qmic Napisano Sierpień 18, 2009 Zgłoszenie Share Napisano Sierpień 18, 2009 Czy to jest generowane z davecot czy z postfixa? Jak to usunąć? Jak odbieranie to przez dovecota oczywiście jak przy wysyłaniu to postfix. Jeśli robisz zabezpieczenia to zrób na jedno i drugie. Wygeneruj nowe klucze i podmień w miejsce tych które są konfiguracji dovecot`a, w redhatopodobnych dystrybucjach jest od tego polecenie genkey. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ronon Napisano Sierpień 18, 2009 Autor Zgłoszenie Share Napisano Sierpień 18, 2009 Jak odbieranie to przez dovecota oczywiście jak przy wysyłaniu to postfix. Jeśli robisz zabezpieczenia to zrób na jedno i drugie. Wygeneruj nowe klucze i podmień w miejsce tych które są konfiguracji dovecot`a, w redhatopodobnych dystrybucjach jest od tego polecenie genkey. Dzięki za informacje. Czy możesz mi podać dokładne polecenie jak wygenerować nowe klucze i je podmienić. Jestem w tej sprawie "zielony" Jak mam wygenerować klucz davecot.pem? Już stosowałem wszystkie opcje i zawsze mi generował glucz davecot.key? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
qmic Napisano Sierpień 19, 2009 Zgłoszenie Share Napisano Sierpień 19, 2009 Jak mam wygenerować klucz davecot.pem? Już stosowałem wszystkie opcje i zawsze mi generował glucz davecot.key? Nazwa pliku to raczej sprawa drugorzędna Jaką masz dystrybucję i w jakiej wersji ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ronon Napisano Sierpień 19, 2009 Autor Zgłoszenie Share Napisano Sierpień 19, 2009 Nazwa pliku to raczej sprawa drugorzędna Jaką masz dystrybucję i w jakiej wersji ? Już sobie poradziłem. Postfix działa z Dovecot + TLS. Mam pytanie: Jak można z postfixa wyłączyć opcje smtp bez szyfrowania? Teraz działa bez szyfrowania i z szyfrowaniem TLS. Chcę żeby działało tylko z szyfrowaniem TLS i nie wiem jak to zrobic. Już sobie poradziłem. Jaki antywirus do postfixa polecacie? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
qmic Napisano Sierpień 20, 2009 Zgłoszenie Share Napisano Sierpień 20, 2009 Już sobie poradziłem. Postfix działa z Dovecot + TLS. Mam pytanie: Jak można z postfixa wyłączyć opcje smtp bez szyfrowania? Teraz działa bez szyfrowania i z szyfrowaniem TLS. Chcę żeby działało tylko z szyfrowaniem TLS i nie wiem jak to zrobic. Już sobie poradziłem. Jaki antywirus do postfixa polecacie? Clamav wystarcza, jeszcze mi nigdy nic nie przepuścił. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ronon Napisano Sierpień 21, 2009 Autor Zgłoszenie Share Napisano Sierpień 21, 2009 Clamav wystarcza, jeszcze mi nigdy nic nie przepuścił. Możesz mi podać jakiś link co do konfiguracji z postfixem? Szukałem, ale nie znalazlem 100 % opisu. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
qmic Napisano Sierpień 24, 2009 Zgłoszenie Share Napisano Sierpień 24, 2009 Możesz mi podać jakiś link co do konfiguracji z postfixem? Szukałem, ale nie znalazlem 100 % opisu. na www.howtoforge.com jest mnóstwo opisów Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
