Mrugające Conky
movsd
Mam problem z conky bo mruga przy odświeżaniu. Load DBE w xorg.conf i dual_buffer yes w conky.conf nie pomagają, bo pojawia się komunikat:
Conky: desktop window (1600059) is subwindow of root window (1a7)
Conky: window type - desktop
Conky: drawing to created window (0x5800002)
Conky: failed to set up double buffer
Conky: drawing to single buffer
/etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 1.0  (buildmeister@builder63)  Fri Aug 14 17:54:58 PDT 2009
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 1.0  (buildmeister@builder63)  Thu Feb  5 00:19:09 PST 2009
Section "ServerLayout"
   Identifier     "Layout0"
   Screen         "Screen0" 0 0
   InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
   #FontPath        "/usr/share/fonts/default/Type1"
EndSection
Section "Module"
   Load           "dbe"
   Load           "extmod"
   #Load           "type1"
   Load           "freetype"
   Load           "glx"
EndSection
Section "ServerFlags"
   Option         "Xinerama" "1"
EndSection
Section "InputDevice"
   # generated from default
   Identifier     "Mouse0"
   Driver         "mouse"
   Option         "Protocol" "auto"
   Option         "Device" "/dev/input/mice"
   Option         "Emulate3Buttons" "no"
   Option         "ZAxisMapping" "4 5"
EndSection
   Identifier     "Keyboard0"
   Driver         "kbd"
EndSection
Section "Monitor"
   Identifier     "Monitor0"
   VendorName     "Unknown"
   ModelName      "PHILIPS 107E"
   HorizSync       30.0 - 70.0
   VertRefresh     50.0 - 160.0
   Option         "DPMS"
EndSection
Section "Monitor"
   Identifier     "Monitor1"
   ModelName      "NEC A700+"
   HorizSync       31.0 - 70.0
   VertRefresh     55.0 - 120.0
EndSection
Section "Device"
   Identifier     "Device0"
   Driver         "nvidia"
   VendorName     "NVIDIA Corporation"
   BoardName      "GeForce 6800"
EndSection
Section "Device"
   Identifier     "Device1"
   Driver         "nvidia"
   BusID          "PCI:1:0:0"
   Screen          1
EndSection
Section "Screen"
   Identifier     "Screen0"
   Device         "Device0"
   Monitor        "Monitor0"
   DefaultDepth    24
   Option         "TwinView" "1"
   Option         "TwinViewXineramaInfoOrder" "CRT-0"
   Option         "metamodes" "CRT-0: 1024x768 +1024+0, CRT-1: 1024x768 +0+0"
   SubSection     "Display"
       Depth       24
   EndSubSection
EndSection
Section "Screen"
   Identifier     "Screen1"
   Device         "Device1"
   Monitor        "Monitor1"
   DefaultDepth    24
   Option         "TwinView" "0"
   Option         "metamodes" "CRT-1: 1024x768 +1024+0"
       Depth       24
   EndSubSection
EndSection
Section "Extensions"
   Option         "Composite" "Enable"
EndSection
/etc/conky/conky.conf
# Conky, a system monitor, based on torsmo
# Any original torsmo code is licensed under the BSD license
# All code written since the fork of torsmo is licensed under the GPL
# Please see COPYING for details
# Copyright ? 2004, Hannu Saransaari and Lauri Hakkarainen
# Copyright ? 2005-2009 Brenden Matthews, Philip Kovacs, et. al. (see AUTHORS)
# All rights reserved.
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program.  If not, see <http://www.gnu.org/licenses/>.
alignment top_left
background no
border_width 1
cpu_avg_samples 2
default_color white
default_outline_color white
default_shade_color white
draw_borders no
draw_graph_borders yes
draw_outline no
draw_shades no
use_xft yes
xftfont DejaVu Sans Mono:size=12
gap_x 5
gap_y 60
minimum_size 5 5
net_avg_samples 2
no_buffers yes
out_to_console no
out_to_stderr no
own_window yes
own_window_class Conky
own_window_type desktop
stippled_borders 0
update_interval 1.0
uppercase no
use_spacer none
show_graph_scale no
show_graph_range no
double_buffer yes
TEXT
${scroll 16 $nodename - $sysname $kernel on $machine | }
$hr
${color grey}Uptime:$color $uptime
${color grey}Frequency (in MHz):$color $freq
${color grey}Frequency (in GHz):$color $freq_g
${color grey}RAM Usage:$color $mem/$memmax - $memperc% ${membar 4}
${color grey}Swap Usage:$color $swap/$swapmax - $swapperc% ${swapbar 4}
${color grey}CPU Usage:$color $cpu% ${cpubar 4}
${color grey}Processes:$color $processes  ${color grey}Running:$color $running_processes
$hr
${color grey}File systems:
/ $color${fs_used /}/${fs_size /} ${fs_bar 6 /}
${color grey}Networking:
Up:$color ${upspeed eth0} ${color grey} - Down:$color ${downspeed eth0}
$hr
${color grey}Name              PID   CPU%   MEM%
${color lightgrey} ${top name 1} ${top pid 1} ${top cpu 1} ${top mem 1}
${color lightgrey} ${top name 2} ${top pid 2} ${top cpu 2} ${top mem 2}
${color lightgrey} ${top name 3} ${top pid 3} ${top cpu 3} ${top mem 3}
${color lightgrey} ${top name 4} ${top pid 4} ${top cpu 4} ${top mem 4}
# --- Window Layout & Options --- #
own_window yes
own_window_colour brown
own_window_transparent yes
own_window_type override
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
double_buffer yes
use_spacer right
use_xft yes
alignment top_right
# --- Colours, Sizes, Fonts & Margins --- #
update_interval 1.0
maximum_width 285
stippled_borders 3
border_margin 9
border_width 10
default_color white
# --- Text --- #
draw_outline no
draw_borders no
font Sans:size=8:weight=bold
uppercase no
draw_shades yes
override_utf8_locale yes
moje conkyrc
nie mruga,jest na wszystkich pulpitach w compiz,przezroczyste,potestuj
Dzięki, już znalazłem, Xinerama blokuje podwójne buforowanie. Nie chcę jej wyłączyć, wiec Conky raczej odpada.
nie wiem gdzieto znalazles,ale to jakas pomyłka.Co prawda to z gentoo,ale dla przypomnienia wspomne ze to taki sam linux jak fedora :P
tuxuser wert # emerge -s xinerama
Searching...
[ Results for search key : xinerama ]
[ Applications found : 2 ]
*  x11-libs/libXinerama
      Latest version available: 1.0.3
      Latest version installed: 1.0.3
      Size of files: 230 kB
      Homepage:      http://xorg.freedesktop.org/
      Description:   X.Org Xinerama library
      License:       MIT
*  x11-proto/xineramaproto
      Latest version available: 1.1.2
      Latest version installed: 1.1.2
      Size of files: 37 kB
      Description:   X.Org Xinerama protocol headers
      License:       MIT
tuxuser wert #
i mi tam nic nie blokuje
Conky pracuje bez najmniejszego mrugniecia,dziala jak ta lala.
