Nie Typowy Problem Z Grubem
Jarma
wiec probowalem wpisac konfing wedlug http://wiki.fedora.pl/wiki/GRUB
ale tu sie zaczyna problem bo gdy probuje to ciagle albo jest efekt taki ze mryga mi tylko kreseczka w lewym gornym rogu albo poprostu wywala Error 13
a moja konfiguracja dyskow jest taka ze :
primary IDE mam windowsa
secondary ide linuksa
no i na sate dysk z danymi
po wpisaniu polecenia fdisk -l mam taki wynik:
Disk /dev/sda: 40.0 GB, 40020664320 bytes
255 heads, 63 sectors/track, 4865 cylinders
Disk identifier: 0x04260425
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *           1        4864    39070048+   7  HPFS/NTFS
Disk /dev/sdb: 30.7 GB, 30750031872 bytes
255 heads, 63 sectors/track, 3738 cylinders
Disk identifier: 0x12820a2d
/dev/sdb1   *           1          26      204800   83  Linux
Partition 1 does not end on cylinder boundary.
/dev/sdb2              26        3738    29820653+  8e  Linux LVM
Disk /dev/dm-0: 27.8 GB, 27883732992 bytes
255 heads, 63 sectors/track, 3390 cylinders
Disk identifier: 0x00000000
Disk /dev/dm-0 doesn't contain a valid partition table
Disk /dev/dm-1: 2650 MB, 2650800128 bytes
255 heads, 63 sectors/track, 322 cylinders
Disk /dev/dm-1 doesn't contain a valid partition table
Disk /dev/sdc: 200.0 GB, 200049647616 bytes
255 heads, 63 sectors/track, 24321 cylinders
Disk identifier: 0xb29cb29c
/dev/sdc1   *           1        4380    35182318+   7  HPFS/NTFS
/dev/sdc2            4381       17270   103538925    c  W95 FAT32 (LBA)
/dev/sdc3           17271       20754    27985230    c  W95 FAT32 (LBA)
/dev/sdc4           20755       24321    28651927+   7  HPFS/NTFS
a config gruba po mojej edycji tylko dla wpisu Title Windows 7up wiecej nie zmienialem z pliku menu.lst
# grub.conf generated by anaconda
# Note that you do not have to rerun grub after making changes to this file
# NOTICE:  You have a /boot partition.  This means that
#          all kernel and initrd paths are relative to /boot/, eg.
#          root (hd0,0)
#          kernel /vmlinuz-version ro root=/dev/mapper/vg_jarmax-lv_root
#          initrd /initrd-version.img
#boot=/dev/sdf
default=0
timeout=5
splashimage=(hd0,0)/grub/splash.xpm.gz
hiddenmenu
title Fedora (2.6.29.4-167.fc11.i686.PAE)
    root (hd0,0)
    kernel /vmlinuz-2.6.29.4-167.fc11.i686.PAE ro root=/dev/mapper/vg_jarmax-lv_root rhgb quiet vga=0x318
    initrd /initrd-2.6.29.4-167.fc11.i686.PAE.img
title Windows 7up
    map(hd0)(hd1)
    map(hd1)(hd0)
    rootnoverify (hd1,0)
    makeactive
    chainloader +1
gdzie jest bład ;/??
Oj, szczegółów to nie chce mi się kolejny raz powtarzać, ale ogólnie:
sda to jest (hd0), sda1 to jest (hd0,0)
sdb to jest (hd1), sdb1 to jest (hd1,0)
itd itd itp
Więc "root (hd0,0)" to nie jest Twoja Fedora - proponuję "root (hd1,0)"
No i pokombinuj sobie dalej ;) Poszukaj na forum bo takie problemy są dość częste.
