Jusko Napisano Czerwiec 6, 2010 Autor Zgłoszenie Share Napisano Czerwiec 6, 2010 smartctl 5.39.1 2010-01-28 r3054 [i386-redhat-linux-gnu] (local build) Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net === START OF INFORMATION SECTION === Model Family: Western Digital Scorpio EIDE family Device Model: WDC WD400VE-00HDT0 Serial Number: WD-WXE606018153 Firmware Version: 09.07D09 User Capacity: 40,007,761,920 bytes Device is: In smartctl database [for details use: -P show] ATA Version is: 6 ATA Standard is: Exact ATA specification draft version not indicated Local Time is: Sun Jun 6 20:58:38 2010 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x85) Offline data collection activity was aborted by an interrupting command from host. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (2400) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. No General Purpose Logging support. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 37) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0003 163 159 021 Pre-fail Always - 841 4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1707 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x000e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 4022 10 Spin_Retry_Count 0x0012 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0012 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 1020 192 Power-Off_Retract_Count 0x0032 199 199 000 Old_age Always - 1006 193 Load_Cycle_Count 0x0032 162 162 000 Old_age Always - 114298 194 Temperature_Celsius 0x0022 107 080 000 Old_age Always - 36 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0012 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 200 200 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 ATA Error Count: 24 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 24 occurred at disk power-on lifetime: 952 hours (39 days + 16 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 08 2f c8 30 e2 Error: UNC 8 sectors at LBA = 0x0230c82f = 36751407 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 d8 08 2f c8 30 02 58 00:12:08.865 READ DMA c8 d8 08 27 c8 30 02 58 00:12:08.865 READ DMA c8 d8 08 1f c8 30 02 58 00:12:08.865 READ DMA c8 d8 08 17 c8 30 02 58 00:12:08.865 READ DMA c8 d8 08 0f c8 30 02 58 00:12:08.865 READ DMA Error 23 occurred at disk power-on lifetime: 952 hours (39 days + 16 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 08 2f c8 30 e2 Error: UNC 8 sectors at LBA = 0x0230c82f = 36751407 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 d8 80 b7 c7 30 02 58 00:12:06.260 READ DMA c8 d8 80 37 c7 30 02 58 00:12:06.255 READ DMA c8 d8 80 b7 c6 30 02 58 00:12:06.255 READ DMA c8 d8 80 37 c6 30 02 58 00:12:06.250 READ DMA c8 d8 80 b7 c5 30 02 58 00:12:06.250 READ DMA Error 22 occurred at disk power-on lifetime: 952 hours (39 days + 16 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 08 2f c8 30 e2 Error: UNC 8 sectors at LBA = 0x0230c82f = 36751407 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 d8 08 2f c8 30 02 58 00:10:17.710 READ DMA c8 d8 08 27 c8 30 02 58 00:10:17.710 READ DMA c8 d8 08 1f c8 30 02 58 00:10:17.705 READ DMA c8 d8 08 17 c8 30 02 58 00:10:17.705 READ DMA c8 d8 08 0f c8 30 02 58 00:10:17.705 READ DMA Error 21 occurred at disk power-on lifetime: 952 hours (39 days + 16 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 10 2f c8 30 e2 Error: UNC 16 sectors at LBA = 0x0230c82f = 36751407 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 d8 00 3f c8 30 02 58 00:10:17.480 READ DMA c8 d8 00 3f c7 30 02 58 00:10:14.960 READ DMA c8 d8 00 3f c6 30 02 58 00:10:14.955 READ DMA c8 d8 00 3f c5 30 02 58 00:10:14.950 READ DMA c8 d8 00 3f c4 30 02 58 00:10:14.950 READ DMA Error 20 occurred at disk power-on lifetime: 952 hours (39 days + 16 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 08 2f c8 30 e2 Error: UNC 8 sectors at LBA = 0x0230c82f = 36751407 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 d8 08 2f c8 30 02 58 00:04:16.065 READ DMA c8 d8 08 27 c8 30 02 58 00:04:16.065 READ DMA c8 d8 08 1f c8 30 02 58 00:04:16.065 READ DMA c8 d8 08 17 c8 30 02 58 00:04:16.065 READ DMA c8 d8 08 0f c8 30 02 58 00:04:16.065 READ DMA SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 4013 - # 2 Short offline Completed without error 00% 3772 - # 3 Extended offline Aborted by host 90% 3725 - # 4 Short offline Completed without error 00% 3710 - # 5 Short offline Completed without error 00% 3710 - # 6 Short offline Completed without error 00% 2 - # 7 Short captive Completed without error 00% 0 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. Też myślałem o firmware, lecz niestety nic nie znalazłem. Ciężko nawet do tej serii dokopać się na stronie WDC. W moim przypadku wartość standardowa (128) parkuje często, ze 2 razy na minutę. Inne wartości nie lepiej. Obecnie mam wartość 200 i chyba przy niej już zostanę, bo choć parkuje sobie trochę, to i tak lepiej niż na 128 (nieco się grzeje, no ale już trudno, muszę przyzwyczaić się że 49C w spoczynku to norma ...). Myślę, że ten dysk już tak po prostu ma, choć nie jest to miłe. Kiedy jakiś miesiąc temu kupiłem lapka, było na nim 109 tysięcy z grosikiem. Edit: Nie minęło parę minut a wynik już 193 Load_Cycle_Count 0x0032 162 162 000 Old_age Always - 114308 Za szybko to się dzieje, no ale nic już chyba z tym nie zrobię i muszę zacisnąć zęby i przestać patrzeć w smartctl, bo osiwieję :-/ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Czerwiec 7, 2010 Zgłoszenie Share Napisano Czerwiec 7, 2010 To że bije cykle to zauważyłeś, ale już błędów nie Zrób test smartctl -t offline /dev/sda (w wyjściu będzie napisane, kiedy zostanie zakończony), a potem pokaż smartctl -H /dev/sda i smartctl -l error /dev/sda Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Jusko Napisano Czerwiec 7, 2010 Autor Zgłoszenie Share Napisano Czerwiec 7, 2010 # smartctl -H /dev/sda smartctl 5.39.1 2010-01-28 r3054 [i386-redhat-linux-gnu] (local build) Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED # smartctl -l error /dev/sda smartctl 5.39.1 2010-01-28 r3054 [i386-redhat-linux-gnu] (local build) Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net === START OF READ SMART DATA SECTION === SMART Error Log Version: 1 ATA Error Count: 24 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 24 occurred at disk power-on lifetime: 952 hours (39 days + 16 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 08 2f c8 30 e2 Error: UNC 8 sectors at LBA = 0x0230c82f = 36751407 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 d8 08 2f c8 30 02 58 00:12:08.865 READ DMA c8 d8 08 27 c8 30 02 58 00:12:08.865 READ DMA c8 d8 08 1f c8 30 02 58 00:12:08.865 READ DMA c8 d8 08 17 c8 30 02 58 00:12:08.865 READ DMA c8 d8 08 0f c8 30 02 58 00:12:08.865 READ DMA Error 23 occurred at disk power-on lifetime: 952 hours (39 days + 16 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 08 2f c8 30 e2 Error: UNC 8 sectors at LBA = 0x0230c82f = 36751407 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 d8 80 b7 c7 30 02 58 00:12:06.260 READ DMA c8 d8 80 37 c7 30 02 58 00:12:06.255 READ DMA c8 d8 80 b7 c6 30 02 58 00:12:06.255 READ DMA c8 d8 80 37 c6 30 02 58 00:12:06.250 READ DMA c8 d8 80 b7 c5 30 02 58 00:12:06.250 READ DMA Error 22 occurred at disk power-on lifetime: 952 hours (39 days + 16 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 08 2f c8 30 e2 Error: UNC 8 sectors at LBA = 0x0230c82f = 36751407 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 d8 08 2f c8 30 02 58 00:10:17.710 READ DMA c8 d8 08 27 c8 30 02 58 00:10:17.710 READ DMA c8 d8 08 1f c8 30 02 58 00:10:17.705 READ DMA c8 d8 08 17 c8 30 02 58 00:10:17.705 READ DMA c8 d8 08 0f c8 30 02 58 00:10:17.705 READ DMA Error 21 occurred at disk power-on lifetime: 952 hours (39 days + 16 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 10 2f c8 30 e2 Error: UNC 16 sectors at LBA = 0x0230c82f = 36751407 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 d8 00 3f c8 30 02 58 00:10:17.480 READ DMA c8 d8 00 3f c7 30 02 58 00:10:14.960 READ DMA c8 d8 00 3f c6 30 02 58 00:10:14.955 READ DMA c8 d8 00 3f c5 30 02 58 00:10:14.950 READ DMA c8 d8 00 3f c4 30 02 58 00:10:14.950 READ DMA Error 20 occurred at disk power-on lifetime: 952 hours (39 days + 16 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 08 2f c8 30 e2 Error: UNC 8 sectors at LBA = 0x0230c82f = 36751407 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 d8 08 2f c8 30 02 58 00:04:16.065 READ DMA c8 d8 08 27 c8 30 02 58 00:04:16.065 READ DMA c8 d8 08 1f c8 30 02 58 00:04:16.065 READ DMA c8 d8 08 17 c8 30 02 58 00:04:16.065 READ DMA c8 d8 08 0f c8 30 02 58 00:04:16.065 READ DMA Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Czerwiec 8, 2010 Zgłoszenie Share Napisano Czerwiec 8, 2010 Właściwie to wygląda ok, poza tymi błędami. Nie wiem co one oznaczają, mówią tylko, że kiedyś wystąpił błąd. Możesz jeszcze przeprowadzić rozszerzony test offline dla pewności. Nie powinieneś aż tak przejmować się tymi cyklami, bo ja na razie jest mało. Znalazłem stary skrypt na dysku do zliczania: #!/bin/bash echo "`date +%D` `date +%R` `smartctl -a /dev/sda | grep Load_Cycle_Count | awk '{print date " " $10}'`" >> /home/USER/count.txt Zmień tylko USER na swój katalog. Możesz go wrzucić do /etc/cron.hourly wtedy co godzinę będzie zapisywał wartości do pliku. Ustaw sobie jakieś i potestuj kilka dni. Myślę, że jak zejdziesz poniżej 100 parkowań dziennie to będzie ok. 1 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Jusko Napisano Czerwiec 8, 2010 Autor Zgłoszenie Share Napisano Czerwiec 8, 2010 Ten błąd to i pod Windows miałem. Co do stu parkowań dziennie - marzenia. Parkowanie mam jedno średnio co minutę (jakież to szczęście, jeśli co dwie), więc od 60 w górę na godzinę. Nie zlikwiduję tego żadną wartością prócz 254, która robi mi smażalnię z laptopa (już teraz na wartości 204 jest średnio ciekawie). Skrypt wstawiłem, ale aż boję się zobaczyć wynik. Widocznie ten dysk tak ma i koniec - trzepnięty firmware + średnie zarządzanie systemem (nie oszukujmy się, ale problem z parkowaniem ma niemal każdy user Linuksa z tego co widzę, czego wynikiem jest choćby spory temat na forum Ubuntu, gdzie każdy ma ten kłopot) = spora liczba cykli, nie do przeskoczenia. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
