endrjun Napisano Czerwiec 19, 2010 Zgłoszenie Share Napisano Czerwiec 19, 2010 Fedora 12, MB Gigabyte GA-8IPE775-G, grafika Matrox G400 Próbowałem zainstalować sterownik dźwieku ALSA dla wbudowanej Realtek ALC850. Po pobraniu i kompilacji sterownika alsa-driver-1.0.23 przestał działać Gnome. Nie ma X-ów także na poprzednim kernelu. Po STARTX widać czarny ekran i komunikat: X.Org X Server 1.7.6 .... (==) Using config file: "/etc/X11/xorg.conf" The XKEYBOARD keymap compiler (xkbcomp) reports: > Warning: Type "ONE_LEVEL" has 1 levels, but <RALT> has 2 symbols > Ignoring extra symbols Errors from xkbcomp are not fatal to the X server waiting for X server to shut down Xorg.0.log wygląda tak: X.Org X Server 1.7.6 Release Date: 2010-03-17 X Protocol Version 11, Revision 0 Build Operating System: x86-02 2.6.18-164.6.1.el5 Current Operating System: Linux localhost 2.6.32.12-115.fc12.i686 #1 SMP Fri Apr 30 20:34:53 UTC 2010 i686 Kernel command line: ro root=UUID=d0109e64-b8cd-49e4-8d53-1f24be1089b4 noiswmd LANG=pl_PL.UTF-8 SYSFONT=latarcyrheb-sun16 KEYBOARDTYPE=pc KEYTABLE=pl2 rhgb quiet Build Date: 16 April 2010 07:07:54AM Build ID: xorg-x11-server 1.7.6-4.fc12 Current version of pixman: 0.16.6 Before reporting problems, check http://bodhi.fedoraproject.org/ to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jun 19 10:12:53 2010 (==) Using config file: "/etc/X11/xorg.conf" (==) ServerLayout "X.org Configured" (**) |-->Screen "Screen0" (0) (**) | |-->Monitor "Monitor0" (**) | |-->Device "Card0" (**) |-->Input Device "Mouse0" (**) |-->Input Device "Keyboard0" (==) Automatically adding devices (==) Automatically enabling devices (**) FontPath set to: catalogue:/etc/X11/fontpath.d, built-ins, catalogue:/etc/X11/fontpath.d, built-ins (**) ModulePath set to "/usr/lib/xorg/modules" (WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled. (WW) Disabling Mouse0 (WW) Disabling Keyboard0 (II) Loader magic: 0x821c900 (II) Module ABI versions: X.Org ANSI C Emulation: 0.4 X.Org Video Driver: 6.0 X.Org XInput driver : 7.0 X.Org Server Extension : 2.0 (--) using VT number 7 (--) PCI:*(0:1:0:0) 102b:0525:102b:2179 Matrox Graphics, Inc. MGA G400/G450 rev 4, Mem @ 0xf0000000/33554432, 0xf2000000/16384, 0xf3000000/8388608, BIOS @ 0x????????/65536 (II) "extmod" will be loaded. This was enabled by default and also specified in the config file. (II) "dbe" will be loaded. This was enabled by default and also specified in the config file. (II) "glx" will be loaded. This was enabled by default and also specified in the config file. (II) "record" will be loaded. This was enabled by default and also specified in the config file. (II) "dri" will be loaded. This was enabled by default and also specified in the config file. (II) "dri2" will be loaded. This was enabled by default and also specified in the config file. (II) LoadModule: "glx" (II) Loading /usr/lib/xorg/modules/extensions/libglx.so (II) Module glx: vendor="X.Org Foundation" compiled for 1.7.6, module version = 1.0.0 ABI class: X.Org Server Extension, version 2.0 (==) AIGLX enabled (II) Loading extension GLX (II) LoadModule: "dbe" (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so (II) Module dbe: vendor="X.Org Foundation" compiled for 1.7.6, module version = 1.0.0 Module class: X.Org Server Extension ABI class: X.Org Server Extension, version 2.0 (II) Loading extension DOUBLE-BUFFER (II) LoadModule: "record" (II) Loading /usr/lib/xorg/modules/extensions/librecord.so (II) Module record: vendor="X.Org Foundation" compiled for 1.7.6, module version = 1.13.0 Module class: X.Org Server Extension ABI class: X.Org Server Extension, version 2.0 (II) Loading extension RECORD (II) LoadModule: "dri" (II) Loading /usr/lib/xorg/modules/extensions/libdri.so (II) Module dri: vendor="X.Org Foundation" compiled for 1.7.6, module version = 1.0.0 ABI class: X.Org Server Extension, version 2.0 (II) Loading extension XFree86-DRI (II) LoadModule: "dri2" (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so (II) Module dri2: vendor="X.Org Foundation" compiled for 1.7.6, module version = 1.1.0 ABI class: X.Org Server Extension, version 2.0 (II) Loading extension DRI2 (II) LoadModule: "extmod" (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so (II) Module extmod: vendor="X.Org Foundation" compiled for 1.7.6, module version = 1.0.0 Module class: X.Org Server Extension ABI class: X.Org Server Extension, version 2.0 (II) Loading extension SELinux (II) Loading extension MIT-SCREEN-SAVER (II) Loading extension XFree86-VidModeExtension (II) Loading extension XFree86-DGA (II) Loading extension DPMS (II) Loading extension XVideo (II) Loading extension XVideo-MotionCompensation (II) Loading extension X-Resource (II) LoadModule: "mga" (II) Loading /usr/lib/xorg/modules/drivers/mga_drv.so (II) Module mga: vendor="X.Org Foundation" compiled for 1.6.99.1, module version = 1.4.11 Module class: X.Org Video Driver ABI class: X.Org Video Driver, version 6.0 (II) MGA: driver for Matrox chipsets: mga2064w, mga1064sg, mga2164w, mga2164w AGP, mgag100, mgag100 PCI, mgag200, mgag200 PCI, mgag200 SE A PCI, mgag200 SE B PCI, mgag200 EV Maxim, mgag200 eW Nuvoton, mgag400, mgag550 (II) Primary Device is: PCI 01@00:00:0 (II) Loading sub module "vgahw" (II) LoadModule: "vgahw" (II) Loading /usr/lib/xorg/modules/libvgahw.so (II) Module vgahw: vendor="X.Org Foundation" compiled for 1.7.6, module version = 0.1.0 ABI class: X.Org Video Driver, version 6.0 (--) MGA(0): Chipset: "mgag400" (G400) (--) MGA(0): Linear framebuffer at 0xF0000000 (--) MGA(0): MMIO registers at 0xF2000000 (--) MGA(0): Pseudo-DMA transfer window at 0xF3000000 (==) MGA(0): Depth 24, (--) framebuffer bpp 32 (==) MGA(0): RGB weight 888 (==) MGA(0): Using AGP 1x mode (==) MGA(0): Using HW cursor (==) MGA(0): Using XAA acceleration (--) MGA(0): Video BIOS info block at offset 0x07A80 (==) MGA(0): VideoRAM: 32768 kByte (II) Loading sub module "ddc" (II) LoadModule: "ddc" (II) Module "ddc" already built-in (II) Loading sub module "i2c" (II) LoadModule: "i2c" (II) Module "i2c" already built-in (II) MGA(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000 (II) MGA(0): I2C bus "DDC P1" initialized. (II) MGA(0): I2C device "DDC P1:ddc2" registered at address 0xA0. (II) MGA(0): I2C device "DDC P1:DDC control interface" registered at address 0x6E. (II) MGA(0): I2C monitor info (II) MGA(0): Manufacturer: SAM Model: 217 Serial#: 1296380217 (II) MGA(0): Year: 2006 Week: 40 (II) MGA(0): EDID Version: 1.3 (II) MGA(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V (II) MGA(0): Sync: Separate Composite SyncOnGreen (II) MGA(0): Max Image Size [cm]: horiz.: 38 vert.: 30 (II) MGA(0): Gamma: 2.20 (II) MGA(0): DPMS capabilities: Off; RGB/Color Display (II) MGA(0): First detailed timing is preferred mode (II) MGA(0): redX: 0.648 redY: 0.339 greenX: 0.292 greenY: 0.603 (II) MGA(0): blueX: 0.143 blueY: 0.070 whiteX: 0.313 whiteY: 0.329 (II) MGA(0): Supported established timings: (II) MGA(0): 720x400@70Hz (II) MGA(0): 640x480@60Hz (II) MGA(0): 640x480@67Hz (II) MGA(0): 640x480@72Hz (II) MGA(0): 640x480@75Hz (II) MGA(0): 800x600@56Hz (II) MGA(0): 800x600@60Hz (II) MGA(0): 800x600@72Hz (II) MGA(0): 800x600@75Hz (II) MGA(0): 832x624@75Hz (II) MGA(0): 1024x768@60Hz (II) MGA(0): 1024x768@70Hz (II) MGA(0): 1024x768@75Hz (II) MGA(0): 1280x1024@75Hz (II) MGA(0): 1152x864@75Hz (II) MGA(0): Manufacturer's mask: 0 (II) MGA(0): Supported standard timings: (II) MGA(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897 (II) MGA(0): #1: hsize: 1280 vsize 960 refresh: 60 vid: 16513 (II) MGA(0): #2: hsize: 1152 vsize 864 refresh: 75 vid: 20337 (II) MGA(0): Supported detailed timing: (II) MGA(0): clock: 108.0 MHz Image Size: 376 x 301 mm (II) MGA(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0 (II) MGA(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0 (II) MGA(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 81 kHz, PixClock max 140 MHz (II) MGA(0): Monitor name: SyncMaster (II) MGA(0): Serial No: HMBLA00444 (II) MGA(0): EDID (in hex): (II) MGA(0): 00ffffffffffff004c2d17023931454d (II) MGA(0): 281001030e261e782a3d85a6564a9a24 (II) MGA(0): 125054bfef8081808140714f01010101 (II) MGA(0): 010101010101302a009851002a403070 (II) MGA(0): 1300782d1100001e000000fd00384b1e (II) MGA(0): 510e000a202020202020000000fc0053 (II) MGA(0): 796e634d61737465720a2020000000ff (II) MGA(0): 00484d424c4130303434340a2020001f (II) MGA(0): end of monitor info (II) MGA(0): EDID vendor "SAM", prod id 535 (II) MGA(0): Using hsync ranges from config file (II) MGA(0): Using vrefresh ranges from config file (II) MGA(0): Printing DDC gathered Modelines: (II) MGA(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz) (II) MGA(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz) (II) MGA(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz) (II) MGA(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz) (II) MGA(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz) (II) MGA(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz) (II) MGA(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz) (II) MGA(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz) (II) MGA(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz) (II) MGA(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz) (II) MGA(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz) (II) MGA(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz) (II) MGA(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz) (II) MGA(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz) (II) MGA(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz) (II) MGA(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz) (II) MGA(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz) (==) MGA(0): Using gamma correction (1.0, 1.0, 1.0) (==) MGA(0): Min pixel clock is 17 MHz (--) MGA(0): Max pixel clock is 300 MHz (II) MGA(0): Monitor0: Using hsync range of 30.00-81.00 kHz (II) MGA(0): Monitor0: Using vrefresh range of 56.00-75.00 Hz (II) MGA(0): Monitor0: Using maximum pixel clock of 140.00 MHz (II) MGA(0): Estimated virtual size for aspect ratio 1.2667 is 1280x1024 (II) MGA(0): Clock range: 17.75 to 300.00 MHz (II) MGA(0): Not using default mode "640x350" (vrefresh out of range) (II) MGA(0): Not using default mode "320x175" (bad mode clock/interlace/doublescan) (II) MGA(0): Not using default mode "640x400" (vrefresh out of range) (II) MGA(0): Not using default mode "320x200" (bad mode clock/interlace/doublescan) (II) MGA(0): Not using default mode "720x400" (vrefresh out of range) (II) MGA(0): Not using default mode "360x200" (vrefresh out of range) (II) MGA(0): Not using default mode "320x240" (bad mode clock/interlace/doublescan) (II) MGA(0): Not using default mode "320x240" (bad mode clock/interlace/doublescan) (II) MGA(0): Not using default mode "320x240" (bad mode clock/interlace/doublescan) (II) MGA(0): Not using default mode "640x480" (vrefresh out of range) (II) MGA(0): Not using default mode "320x240" (vrefresh out of range) (II) MGA(0): Not using default mode "800x600" (vrefresh out of range) (II) MGA(0): Not using default mode "400x300" (vrefresh out of range) (II) MGA(0): Not using default mode "1024x768" (vrefresh out of range) (II) MGA(0): Not using default mode "512x384" (vrefresh out of range) (II) MGA(0): Not using default mode "1024x768" (vrefresh out of range) (II) MGA(0): Not using default mode "512x384" (vrefresh out of range) (II) MGA(0): Not using default mode "1280x960" (hsync out of range) (II) MGA(0): Not using default mode "640x480" (hsync out of range) (II) MGA(0): Not using default mode "1280x1024" (hsync out of range) (II) MGA(0): Not using default mode "640x512" (hsync out of range) (II) MGA(0): Not using default mode "1600x1200" (width too large for virtual size) (II) MGA(0): Not using default mode "1600x1200" (width too large for virtual size) (II) MGA(0): Not using default mode "1600x1200" (width too large for virtual size) (II) MGA(0): Not using default mode "800x600" (hsync out of range) (II) MGA(0): Not using default mode "1600x1200" (width too large for virtual size) (II) MGA(0): Not using default mode "800x600" (hsync out of range) (II) MGA(0): Not using default mode "1600x1200" (width too large for virtual size) (II) MGA(0): Not using default mode "800x600" (hsync out of range) (II) MGA(0): Not using default mode "1792x1344" (width too large for virtual size) (II) MGA(0): Not using default mode "896x672" (hsync out of range) (II) MGA(0): Not using default mode "1792x1344" (width too large for virtual size) (II) MGA(0): Not using default mode "896x672" (hsync out of range) (II) MGA(0): Not using default mode "1856x1392" (width too large for virtual size) (II) MGA(0): Not using default mode "928x696" (hsync out of range) (II) MGA(0): Not using default mode "1856x1392" (width too large for virtual size) (II) MGA(0): Not using default mode "928x696" (hsync out of range) (II) MGA(0): Not using default mode "1920x1440" (width too large for virtual size) (II) MGA(0): Not using default mode "960x720" (hsync out of range) (II) MGA(0): Not using default mode "1920x1440" (width too large for virtual size) (II) MGA(0): Not using default mode "960x720" (hsync out of range) (II) MGA(0): Not using default mode "1400x1050" (width too large for virtual size) (II) MGA(0): Not using default mode "1400x1050" (width too large for virtual size) (II) MGA(0): Not using default mode "1920x1440" (width too large for virtual size) (II) MGA(0): Not using default mode "960x720" (hsync out of range) (II) MGA(0): Not using default mode "2048x1536" (width too large for virtual size) (II) MGA(0): Not using default mode "1024x768" (hsync out of range) (II) MGA(0): Not using default mode "2048x1536" (width too large for virtual size) (II) MGA(0): Not using default mode "1024x768" (hsync out of range) (II) MGA(0): Not using default mode "2048x1536" (width too large for virtual size) (II) MGA(0): Not using default mode "1024x768" (hsync out of range) (--) MGA(0): Virtual size is 1280x1024 (pitch 1280) (**) MGA(0): *Driver mode "1280x1024": 108.0 MHz, 64.0 kHz, 60.0 Hz (II) MGA(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz) (**) MGA(0): *Driver mode "1280x1024": 135.0 MHz, 80.0 kHz, 75.0 Hz (II) MGA(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz) (**) MGA(0): *Default mode "1280x1024": 135.0 MHz, 80.0 kHz, 75.0 Hz (II) MGA(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz) (**) MGA(0): *Default mode "1280x1024": 108.0 MHz, 64.0 kHz, 60.0 Hz (II) MGA(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz) (**) MGA(0): *Driver mode "1280x960": 108.0 MHz, 60.0 kHz, 60.0 Hz (II) MGA(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz) (**) MGA(0): *Default mode "1280x960": 108.0 MHz, 60.0 kHz, 60.0 Hz (II) MGA(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz) (**) MGA(0): *Driver mode "1152x864": 108.0 MHz, 67.5 kHz, 75.0 Hz (II) MGA(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz) (**) MGA(0): *Default mode "1152x864": 108.0 MHz, 67.5 kHz, 75.0 Hz (II) MGA(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz) (**) MGA(0): *Driver mode "1024x768": 78.8 MHz, 60.0 kHz, 75.0 Hz (II) MGA(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz) (**) MGA(0): *Driver mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz (II) MGA(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz) (**) MGA(0): *Driver mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz (II) MGA(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz) (**) MGA(0): *Default mode "1024x768": 78.8 MHz, 60.0 kHz, 75.0 Hz (II) MGA(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz) (**) MGA(0): *Default mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz (II) MGA(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz) (**) MGA(0): *Default mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz (II) MGA(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz) (**) MGA(0): *Driver mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz (II) MGA(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz) (**) MGA(0): *Default mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz (II) MGA(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz) (**) MGA(0): *Driver mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz (II) MGA(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz) (**) MGA(0): *Driver mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz (II) MGA(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz) (**) MGA(0): *Driver mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz (II) MGA(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz) (**) MGA(0): *Driver mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz (II) MGA(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz) (**) MGA(0): *Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz (II) MGA(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz) (**) MGA(0): *Default mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz (II) MGA(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz) (**) MGA(0): *Default mode "800x600": 87.8 MHz, 81.2 kHz, 65.0 Hz (D) (II) MGA(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz) (**) MGA(0): *Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz (II) MGA(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz) (**) MGA(0): *Default mode "800x600": 81.0 MHz, 75.0 kHz, 60.0 Hz (D) (II) MGA(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz) (**) MGA(0): *Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz (II) MGA(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz) (**) MGA(0): *Default mode "700x525": 77.9 MHz, 81.5 kHz, 74.8 Hz (D) (II) MGA(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz) (**) MGA(0): *Default mode "700x525": 61.0 MHz, 64.9 kHz, 60.0 Hz (D) (II) MGA(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz) (**) MGA(0): *Default mode "640x512": 67.5 MHz, 80.0 kHz, 75.0 Hz (D) (II) MGA(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz) (**) MGA(0): *Default mode "640x512": 54.0 MHz, 64.0 kHz, 60.0 Hz (D) (II) MGA(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz) (**) MGA(0): *Driver mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz (II) MGA(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz) (**) MGA(0): *Driver mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz (II) MGA(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz) (**) MGA(0): *Driver mode "640x480": 30.2 MHz, 35.0 kHz, 66.7 Hz (II) MGA(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz) (**) MGA(0): *Driver mode "640x480": 25.2 MHz, 31.5 kHz, 59.9 Hz (II) MGA(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz) (**) MGA(0): *Default mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz (II) MGA(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz) (**) MGA(0): *Default mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz (II) MGA(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz) (**) MGA(0): *Default mode "640x480": 54.0 MHz, 60.0 kHz, 60.0 Hz (D) (II) MGA(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz) (**) MGA(0): *Default mode "640x480": 25.2 MHz, 31.5 kHz, 59.9 Hz (II) MGA(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz) (**) MGA(0): *Driver mode "720x400": 28.3 MHz, 31.5 kHz, 70.1 Hz (II) MGA(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz) (**) MGA(0): *Default mode "576x432": 54.0 MHz, 67.5 kHz, 75.0 Hz (D) (II) MGA(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz) (**) MGA(0): *Default mode "512x384": 39.4 MHz, 60.0 kHz, 75.0 Hz (D) (II) MGA(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz) (**) MGA(0): *Default mode "512x384": 37.5 MHz, 56.5 kHz, 70.1 Hz (D) (II) MGA(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz) (**) MGA(0): *Default mode "512x384": 32.5 MHz, 48.4 kHz, 60.0 Hz (D) (II) MGA(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz) (**) MGA(0): *Default mode "416x312": 28.6 MHz, 49.7 kHz, 74.7 Hz (D) (II) MGA(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz) (**) MGA(0): *Default mode "400x300": 24.8 MHz, 46.9 kHz, 75.1 Hz (D) (II) MGA(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz) (**) MGA(0): *Default mode "400x300": 25.0 MHz, 48.1 kHz, 72.2 Hz (D) (II) MGA(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz) (**) MGA(0): *Default mode "400x300": 20.0 MHz, 37.9 kHz, 60.3 Hz (D) (II) MGA(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz) (**) MGA(0): *Default mode "400x300": 18.0 MHz, 35.2 kHz, 56.3 Hz (D) (II) MGA(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz) (**) MGA(0): Display dimensions: (380, 300) mm (**) MGA(0): DPI set to (85, 86) (II) MGA(0): YDstOrg is set to 0 (II) Loading sub module "fb" (II) LoadModule: "fb" (II) Loading /usr/lib/xorg/modules/libfb.so (II) Module fb: vendor="X.Org Foundation" compiled for 1.7.6, module version = 1.0.0 ABI class: X.Org ANSI C Emulation, version 0.4 (II) Loading sub module "xaa" (II) LoadModule: "xaa" (II) Loading /usr/lib/xorg/modules/libxaa.so (II) Module xaa: vendor="X.Org Foundation" compiled for 1.7.6, module version = 1.2.1 ABI class: X.Org Video Driver, version 6.0 (II) Loading sub module "ramdac" (II) LoadModule: "ramdac" (II) Module "ramdac" already built-in (--) Depth 24 pixmap format is 32 bpp (II) MGA(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000 (--) MGA(0): 16 DWORD fifo (==) MGA(0): Default visual is TrueColor (II) MGA(0): [drm] bpp: 32 depth: 24 (II) MGA(0): [drm] Sarea 2200+664: 2864 drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is 13, (OK) drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is 13, (OK) drmOpenByBusid: Searching for BusID pci:0000:01:00.0 drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is 13, (OK) drmOpenByBusid: drmOpenMinor returns 13 drmOpenByBusid: drmGetBusid reports pci:0000:01:00.0 (II) [drm] DRM interface version 1.3 (II) [drm] DRM open master succeeded. (II) MGA(0): [drm] Using the DRM lock SAREA also for drawables. (II) MGA(0): [drm] framebuffer handle = 0xf0000000 (II) MGA(0): [drm] added 1 reserved context for kernel (II) MGA(0): X context handle = 0x1 (II) MGA(0): [drm] installed DRM signal handler (II) MGA(0): [dri] visual configs initialized (II) MGA(0): Memory manager initialized to (0,0) (1280,2047) (II) MGA(0): Largest offscreen area available: 1280 x 1023 (II) MGA(0): Reserved back buffer at offset 0xa00000 (II) MGA(0): Reserved depth buffer at offset 0xf00000 (II) MGA(0): Reserved 12288 kb for textures at offset 0x1400000 (II) MGA(0): Using XFree86 Acceleration Architecture (XAA) Screen to screen bit blits Solid filled rectangles Solid filled trapezoids 8x8 mono pattern filled rectangles 8x8 mono pattern filled trapezoids Indirect CPU to Screen color expansion Screen to Screen color expansion Solid Lines Dashed Lines Scanline Image Writes Driver provided FillMono8x8PatternRects replacement Setting up tile and stipple cache: 32 128x128 slots 9 256x256 slots (==) MGA(0): Backing store disabled (==) MGA(0): Silken mouse enabled (**) MGA(0): DPMS enabled (II) MGA(0): Using overlay video (II) MGA(0): [DRI] installation complete (II) MGA(0): [drm] Mapped 128 DMA buffers (II) MGA(0): [drm] dma control initialized, using IRQ 16 (II) MGA(0): Direct rendering enabled (==) RandR enabled (II) Initializing built-in extension Generic Event Extension (II) Initializing built-in extension SHAPE (II) Initializing built-in extension MIT-SHM (II) Initializing built-in extension XInputExtension (II) Initializing built-in extension XTEST (II) Initializing built-in extension BIG-REQUESTS (II) Initializing built-in extension SYNC (II) Initializing built-in extension XKEYBOARD (II) Initializing built-in extension XC-MISC (II) Initializing built-in extension XINERAMA (II) Initializing built-in extension XFIXES (II) Initializing built-in extension RENDER (II) Initializing built-in extension RANDR (II) Initializing built-in extension COMPOSITE (II) Initializing built-in extension DAMAGE (II) SELinux: Disabled by boolean (II) AIGLX: Screen 0 is not DRI2 capable drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is 14, (OK) drmOpenByBusid: Searching for BusID pci:0000:01:00.0 drmOpenDevice: node name is /dev/dri/card0 drmOpenDevice: open result is 14, (OK) drmOpenByBusid: drmOpenMinor returns 14 drmOpenByBusid: drmGetBusid reports pci:0000:01:00.0 (II) AIGLX: enabled GLX_SGI_make_current_read (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control (II) AIGLX: Loaded and initialized /usr/lib/dri/mga_dri.so (II) GLX: Initialized DRI GL provider for screen 0 (II) config/hal: Adding input device AT Translated Set 2 keyboard (II) LoadModule: "evdev" (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so (II) Module evdev: vendor="X.Org Foundation" compiled for 1.7.6, module version = 2.3.3 Module class: X.Org XInput Driver ABI class: X.Org XInput driver, version 7.0 (**) AT Translated Set 2 keyboard: always reports core events (**) AT Translated Set 2 keyboard: Device: "/dev/input/event3" (II) AT Translated Set 2 keyboard: Found keys (II) AT Translated Set 2 keyboard: Configuring as keyboard (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD) (**) Option "xkb_rules" "evdev" (**) Option "xkb_model" "pc105" (**) Option "xkb_layout" "pl" (**) Option "xkb_options" "terminate:ctrl_alt_bksp" (II) config/hal: Adding input device ImPS/2 Generic Wheel Mouse (**) ImPS/2 Generic Wheel Mouse: always reports core events (**) ImPS/2 Generic Wheel Mouse: Device: "/dev/input/event4" (II) ImPS/2 Generic Wheel Mouse: Found 3 mouse buttons (II) ImPS/2 Generic Wheel Mouse: Found scroll wheel(s) (II) ImPS/2 Generic Wheel Mouse: Found relative axes (II) ImPS/2 Generic Wheel Mouse: Found x and y relative axes (II) ImPS/2 Generic Wheel Mouse: Configuring as mouse (**) ImPS/2 Generic Wheel Mouse: YAxisMapping: buttons 4 and 5 (**) ImPS/2 Generic Wheel Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200 (II) XINPUT: Adding extended input device "ImPS/2 Generic Wheel Mouse" (type: MOUSE) (**) ImPS/2 Generic Wheel Mouse: (accel) keeping acceleration scheme 1 (**) ImPS/2 Generic Wheel Mouse: (accel) acceleration profile 0 (II) ImPS/2 Generic Wheel Mouse: initialized for relative axes. (II) config/hal: Adding input device Macintosh mouse button emulation (**) Macintosh mouse button emulation: always reports core events (**) Macintosh mouse button emulation: Device: "/dev/input/event2" (II) Macintosh mouse button emulation: Found 3 mouse buttons (II) Macintosh mouse button emulation: Found relative axes (II) Macintosh mouse button emulation: Found x and y relative axes (II) Macintosh mouse button emulation: Configuring as mouse (**) Macintosh mouse button emulation: YAxisMapping: buttons 4 and 5 (**) Macintosh mouse button emulation: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200 (II) XINPUT: Adding extended input device "Macintosh mouse button emulation" (type: MOUSE) (**) Macintosh mouse button emulation: (accel) keeping acceleration scheme 1 (**) Macintosh mouse button emulation: (accel) acceleration profile 0 (II) Macintosh mouse button emulation: initialized for relative axes. (II) config/hal: Adding input device Power Button (**) Power Button: always reports core events (**) Power Button: Device: "/dev/input/event0" (II) Power Button: Found keys (II) Power Button: Configuring as keyboard (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD) (**) Option "xkb_rules" "evdev" (**) Option "xkb_model" "evdev" (**) Option "xkb_layout" "us" (II) config/hal: Adding input device Power Button (**) Power Button: always reports core events (**) Power Button: Device: "/dev/input/event1" (II) Power Button: Found keys (II) Power Button: Configuring as keyboard (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD) (**) Option "xkb_rules" "evdev" (**) Option "xkb_model" "evdev" (**) Option "xkb_layout" "us" (II) AT Translated Set 2 keyboard: Close (II) UnloadModule: "evdev" (II) ImPS/2 Generic Wheel Mouse: Close (II) UnloadModule: "evdev" (II) Macintosh mouse button emulation: Close (II) UnloadModule: "evdev" (II) Power Button: Close (II) UnloadModule: "evdev" (II) Power Button: Close (II) UnloadModule: "evdev" (II) MGA(0): [drm] removed 1 reserved context for kernel (II) MGA(0): [drm] unmapping 8192 bytes of SAREA 0xf7c27000 at 0xb77d1000 (II) MGA(0): [drm] Closed DRM master. xorg.conf wygenerowany przez X -configure wygląda tak: Section "ServerLayout" Identifier "X.org Configured" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" ModulePath "/usr/lib/xorg/modules" FontPath "catalogue:/etc/X11/fontpath.d" FontPath "built-ins" EndSection Section "Module" Load "glx" Load "dbe" Load "record" Load "dri" Load "dri2" Load "extmod" EndSection Section "InputDevice" Identifier "Keyboard0" Driver "kbd" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5 6 7" EndSection Section "Monitor" #DisplaySize 380 300 # mm Identifier "Monitor0" VendorName "SAM" ModelName "SyncMaster" HorizSync 30.0 - 81.0 VertRefresh 56.0 - 75.0 Option "DPMS" EndSection Section "Device" ### Available Driver options are:- ### Values: <i>: integer, <f>: float, <bool>: "True"/"False", ### <string>: "String", <freq>: "<f> Hz/kHz/MHz" ### [arg]: arg optional #Option "SWcursor" # [<bool>] #Option "HWcursor" # [<bool>] #Option "PciRetry" # [<bool>] #Option "SyncOnGreen" # [<bool>] #Option "NoAccel" # [<bool>] #Option "ShowCache" # [<bool>] #Option "MGASDRAM" # [<bool>] #Option "ShadowFB" # [<bool>] #Option "UseFBDev" # [<bool>] #Option "ColorKey" # <i> #Option "SetMclk" # <freq> #Option "OverclockMem" # [<bool>] #Option "VideoKey" # <i> #Option "Rotate" # [<str>] #Option "TexturedVideo" # [<bool>] #Option "Crtc2Half" # [<bool>] #Option "Crtc2Ram" # <i> #Option "Int10" # [<bool>] #Option "AGPMode" # <i> #Option "AGPSize" # <i> #Option "DigitalScreen1" # [<bool>] #Option "DigitalScreen2" # [<bool>] #Option "TV" # [<bool>] #Option "TVStandard" # [<str>] #Option "CableType" # [<str>] #Option "NoHal" # [<bool>] #Option "SwappedHead" # [<bool>] #Option "DRI" # [<bool>] #Option "MergedFB" # [<bool>] #Option "Monitor2HSync" # [<str>] #Option "Monitor2VRefresh" # [<str>] #Option "Monitor2Position" # [<str>] #Option "MetaModes" # [<str>] #Option "OldDmaInit" # [<bool>] #Option "ForcePciDma" # [<bool>] #Option "AccelMethod" # [<str>] #Option "KVM" # [<bool>] Identifier "Card0" Driver "mga" VendorName "Matrox Graphics, Inc." BoardName "MGA G400/G450" BusID "PCI:1:0:0" EndSection Section "Screen" Identifier "Screen0" Device "Card0" Monitor "Monitor0" SubSection "Display" Viewport 0 0 Depth 1 EndSubSection SubSection "Display" Viewport 0 0 Depth 4 EndSubSection SubSection "Display" Viewport 0 0 Depth 8 EndSubSection SubSection "Display" Viewport 0 0 Depth 15 EndSubSection SubSection "Display" Viewport 0 0 Depth 16 EndSubSection SubSection "Display" Viewport 0 0 Depth 24 EndSubSection EndSection OMFG Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@Sorror Napisano Czerwiec 20, 2010 Zgłoszenie Share Napisano Czerwiec 20, 2010 O znacznikach code/codebox oraz formatowaniu postów nie słyszałeś? Trochę szacunku do czytających jeśli oczekujesz od nich pomocy. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
