Lm_sensors - Nie Działa Moduł
Olbi
Witam
Pod 3 godzinnej batalii z modułem lm_sensors poddaję się. Skorzystałem z 3 poradników i żaden nie zadziałał.
http://forum.ubuntu.pl/showthread.php?t=123825
https://lists.ubuntu.com/archives/ubuntu-us...May/183285.html
http://swiss.ubuntuforums.org/showthread.php?p=8406822
Zatem pytanie do was o pomoc - jak sprawić, aby odpowiednie moduły zadziałały., System to Fedora 13 z jądrem 2.6.33-5 .
Załączam dane odnośnie systemu:
Module Size Used by
vfat 8232 1
fat 43410 1 vfat
fuse 54749 2
lm90 9673 0
sunrpc 192013 1
cpufreq_ondemand 8420 3
powernow_k8 14521 0
freq_table 3851 2 cpufreq_ondemand,powernow_k8
ip6t_REJECT 4055 2
nf_conntrack_ipv6 17513 2
ip6table_filter 2743 1
ip6_tables 16558 1 ip6table_filter
ipv6 267033 42 ip6t_REJECT,nf_conntrack_ipv6
uinput 7230 0
usblp 10716 0
nvidia 10823576 38
snd_hda_codec_realtek 284527 1
snd_hda_intel 24200 2
snd_hda_codec 73671 2 snd_hda_codec_realtek,snd_hda_intel
snd_hwdep 6222 1 snd_hda_codec
snd_seq 50941 0
snd_seq_device 5895 1 snd_seq
snd_pcm 76131 2 snd_hda_intel,snd_hda_codec
snd_timer 19234 2 snd_seq,snd_pcm
snd 60573 12 snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_seq,snd_seq_devi
ce,snd_pcm,snd_timer
soundcore 6198 1 snd
r8169 33027 0
i2c_piix4 11822 0
snd_page_alloc 7221 2 snd_hda_intel,snd_pcm
edac_core 37487 0
i2c_core 24507 3 lm90,nvidia,i2c_piix4
k10temp 3223 0
mii 4142 1 r8169
edac_mce_amd 7767 0
joydev 9439 0
serio_raw 4539 0
microcode 17930 0
pata_acpi 3251 0
ata_generic 3323 0
usb_storage 44408 1
firewire_ohci 20136 0
pata_atiixp 3857 0
firewire_core 42377 1 firewire_ohci
crc_itu_t 1523 1 firewire_core
00:00.0 Host bridge: Advanced Micro Devices [AMD] RS780 Host Bridge Alternate
00:02.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (ext gfx port 0)
00:05.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 1)
00:06.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 2)
00:11.0 SATA controller: ATI Technologies Inc SB700/SB800 SATA Controller [iDE mode]
00:12.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller
00:12.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller
00:12.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller
00:13.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller
00:13.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller
00:13.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller
00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 3c)
00:14.1 IDE interface: ATI Technologies Inc SB700/SB800 IDE Controller
00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA)
00:14.3 ISA bridge: ATI Technologies Inc SB700/SB800 LPC host controller
00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge
00:14.5 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI2 Controller
00:18.0 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] HyperTransport Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Miscellaneous Control
00:18.4 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Link Control
01:00.0 VGA compatible controller: nVidia Corporation NV43 [GeForce 6600 GT] (rev a2)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 03)
03:00.0 FireWire (IEEE 1394): VIA Technologies, Inc. Device 3403
# sensors-detect revision 5818 (2010-01-18 17:22:07 +0100)
# System: MICRO-STAR INTERNATIONAL CO.,LTD MS-7576
# Board: MICRO-STAR INTERNATIONAL CO.,LTD 785G-E53 (MS-7576)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no): YES
Silicon Integrated Systems SIS5595... No
VIA VT82C686 Integrated Sensors... No
VIA VT8231 Integrated Sensors... No
AMD K8 thermal sensors... No
AMD Family 10h thermal sensors... Success!
(driver `k10temp')
AMD Family 11h thermal sensors... No
Intel Core family thermal sensor... No
Intel Atom thermal sensor... No
Intel AMB FB-DIMM thermal sensor... No
VIA C7 thermal sensor... No
VIA Nano thermal sensor... No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no): YES
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor'... No
Trying family `SMSC'... No
Trying family `VIA/Winbond/Nuvoton/Fintek'... No
Trying family `ITE'... No
Probing for Super-I/O at 0x4e/0x4f
Trying family `VIA/Winbond/Nuvoton/Fintek'... Yes
Found `Fintek F71889FG Super IO Sensors' Success!
(address 0x600, driver `f71882fg')
Some systems (mainly servers) implement IPMI, a set of common interfaces
through which system health data may be retrieved, amongst other things.
We first try to get the information from SMBIOS. If we don't find it
there, we have to read from arbitrary I/O ports to probe for such
interfaces. This is normally safe. Do you want to scan for IPMI
interfaces? (YES/no): YES
Probing for `IPMI BMC KCS' at 0xca0... No
Probing for `IPMI BMC SMIC' at 0xca8... No
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (yes/NO): YES
Probing for `National Semiconductor LM78' at 0x290... No
Probing for `National Semiconductor LM79' at 0x290... No
Probing for `Winbond W83781D' at 0x290... No
Probing for `Winbond W83782D' at 0x290... No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no): YES
Using driver `i2c-piix4' for device 0000:00:14.0: ATI Technologies Inc SB600/SB700/SB800 SMBus
Module i2c-dev loaded successfully.
Next adapter: NVIDIA i2c adapter (i2c-0)
Do you want to scan it? (YES/no/selectively): YES
Client found at address 0x50
Probing for `Analog Devices ADM1033'... No
Probing for `Analog Devices ADM1034'... No
Probing for `SPD EEPROM'... No
Probing for `EDID EEPROM'... Yes
(confidence 8, not a hardware monitoring chip)
Next adapter: NVIDIA i2c adapter (i2c-1)
Next adapter: NVIDIA i2c adapter (i2c-2)
Client found at address 0x4c
Probing for `National Semiconductor LM75'... No
Probing for `Dallas Semiconductor DS75'... No
Probing for `Analog Devices ADT7466'... No
Probing for `Andigilog aSC7511'... No
Probing for `Dallas Semiconductor DS1621/DS1631'... No
Probing for `Analog Devices ADM1021'... No
Probing for `Analog Devices ADM1021A/ADM1023'... No
Probing for `Maxim MAX1617'... No
Probing for `Maxim MAX1617A'... No
Probing for `Maxim MAX1668'... No
Probing for `Maxim MAX1805'... No
Probing for `Maxim MAX1989'... No
Probing for `Maxim MAX6655/MAX6656'... No
Probing for `TI THMC10'... No
Probing for `National Semiconductor LM84'... No
Probing for `Genesys Logic GL523SM'... No
Probing for `Onsemi MC1066'... No
Probing for `Maxim MAX1618'... No
Probing for `Maxim MAX1619'... No
Probing for `National Semiconductor LM82/LM83'... No
Probing for `National Semiconductor LM90'... No
Probing for `National Semiconductor LM89/LM99'... No
Probing for `National Semiconductor LM86'... No
Probing for `Analog Devices ADM1032'... No
Probing for `Maxim MAX6654/MAX6690'... No
Probing for `Maxim MAX6657/MAX6658/MAX6659'... No
Probing for `Maxim MAX6648/MAX6649/MAX6692'... Success!
(confidence 8, driver `lm90')
Probing for `Maxim MAX6680/MAX6681'... No
Probing for `Winbond W83L771W/G'... No
Probing for `Winbond W83L771AWG/ASG'... No
Probing for `Texas Instruments TMP401'... No
Probing for `Texas Instruments TMP411'... No
Probing for `Texas Instruments TMP421'... No
Probing for `Texas Instruments TMP422'... No
Probing for `Texas Instruments TMP423'... No
Probing for `Texas Instruments AMC6821'... No
Probing for `National Semiconductor LM63'... No
Probing for `Fintek F75363SG'... No
Probing for `National Semiconductor LM73'... No
Probing for `Maxim MAX6633/MAX6634/MAX6635'... No
Probing for `Analog Devices ADT7461'... No
Probing for `Analog Devices ADT7481'... No
Probing for `Fintek F75383S/M'... No
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `lm90':
* Bus `NVIDIA i2c adapter '
Busdriver `nvidia', I2C address 0x4c
Chip `Maxim MAX6648/MAX6649/MAX6692' (confidence: 8)
Driver `k10temp':
* Chip `AMD Family 10h thermal sensors' (confidence: 9)
Driver `f71882fg':
* ISA bus, address 0x600
Chip `Fintek F71889FG Super IO Sensors' (confidence: 9)
Do you want to overwrite /etc/sysconfig/lm_sensors? (YES/no): YES
Starting lm_sensors: loading module f71882fg k10temp lm90 No sensors found!
Make sure you loaded all the kernel drivers you need.
Try sensors-detect to find out which these are.
[NIEUDANE]
Unloading i2c-dev... OK
