laszjwrz Napisano Lipiec 12, 2010 Zgłoszenie Share Napisano Lipiec 12, 2010 (edytowane) Witam, zamieniłem NetworkManagera na wicd i wszystko wydawało się być w porządku, aż do kolejnego uruchomienia systemu. Otrzymuję komunikat dotyczący problemu połączenia z interfejsem D-bus (?). Package: wicd-gtk-1.7.0-1.fc13 Latest Crash: wto, 13 lip 2010, 00:06:20 Command: /usr/bin/python -O /usr/share/wicd/gtk/wicd-client.py Reason: wicd-client.py:724:_trigger_scan_if_needed:AttributeError: 'NoneType' object has no attribute 'Scan' Comment: None Bug Reports: A tu dość obszerny log: 2010/07/12 18:21:19 :: --------------------------- 2010/07/12 18:21:19 :: wicd initializing... 2010/07/12 18:21:19 :: --------------------------- 2010/07/12 18:21:19 :: wicd is version 1.7.0 552 2010/07/12 18:21:19 :: did not find backend in configuration, setting default external 2010/07/12 18:21:19 :: setting backend to external 2010/07/12 18:21:19 :: trying to load backend external 2010/07/12 18:21:19 :: successfully loaded backend external 2010/07/12 18:21:19 :: trying to load backend external 2010/07/12 18:21:19 :: successfully loaded backend external 2010/07/12 18:21:19 :: Automatically detected wireless interface eth1 2010/07/12 18:21:19 :: did not find wireless_interface in configuration, setting default eth1 2010/07/12 18:21:19 :: setting wireless interface eth1 2010/07/12 18:21:19 :: automatically detected wired interface eth0 2010/07/12 18:21:19 :: did not find wired_interface in configuration, setting default eth0 2010/07/12 18:21:19 :: setting wired interface eth0 2010/07/12 18:21:19 :: did not find wpa_driver in configuration, setting default wext 2010/07/12 18:21:19 :: setting wpa driver wext 2010/07/12 18:21:19 :: did not find always_show_wired_interface in configuration, setting default False 2010/07/12 18:21:19 :: did not find use_global_dns in configuration, setting default False 2010/07/12 18:21:19 :: setting use global dns to False 2010/07/12 18:21:19 :: did not find global_dns_1 in configuration, setting default None 2010/07/12 18:21:19 :: did not find global_dns_2 in configuration, setting default None 2010/07/12 18:21:19 :: did not find global_dns_3 in configuration, setting default None 2010/07/12 18:21:19 :: did not find global_dns_dom in configuration, setting default None 2010/07/12 18:21:19 :: did not find global_search_dom in configuration, setting default None 2010/07/12 18:21:19 :: setting global dns 2010/07/12 18:21:19 :: global dns servers are None None None 2010/07/12 18:21:19 :: domain is None 2010/07/12 18:21:19 :: search domain is None 2010/07/12 18:21:19 :: did not find auto_reconnect in configuration, setting default True 2010/07/12 18:21:19 :: setting automatically reconnect when connection drops True 2010/07/12 18:21:19 :: did not find debug_mode in configuration, setting default False 2010/07/12 18:21:19 :: did not find wired_connect_mode in configuration, setting default 1 2010/07/12 18:21:19 :: did not find signal_display_type in configuration, setting default 0 2010/07/12 18:21:19 :: did not find should_verify_ap in configuration, setting default 1 2010/07/12 18:21:19 :: did not find dhcp_client in configuration, setting default 0 2010/07/12 18:21:19 :: Setting dhcp client to 0 2010/07/12 18:21:19 :: did not find link_detect_tool in configuration, setting default 0 2010/07/12 18:21:19 :: did not find flush_tool in configuration, setting default 0 2010/07/12 18:21:19 :: did not find sudo_app in configuration, setting default 0 2010/07/12 18:21:19 :: did not find prefer_wired in configuration, setting default False 2010/07/12 18:21:19 :: Wireless configuration file not found, creating... 2010/07/12 18:21:19 :: Wired configuration file not found, creating a default... 2010/07/12 18:21:19 :: Creating wired profile for wired-default 2010/07/12 18:21:19 :: dhclient.conf.template not found, copying... 2010/07/12 18:21:19 :: chmoding configuration files 0600... 2010/07/12 18:21:19 :: chowning configuration files root:root... 2010/07/12 18:21:19 :: Using wireless interface...eth1 2010/07/12 18:21:19 :: Using wired interface...eth0 2010/07/12 18:28:26 :: did not find main_width in configuration, setting default -1 2010/07/12 18:28:26 :: did not find main_height in configuration, setting default -1 2010/07/12 18:28:33 :: did not find netprop_width in configuration, setting default -1 2010/07/12 18:28:33 :: did not find netprop_height in configuration, setting default -1 2010/07/12 18:30:18 :: did not find pref_width in configuration, setting default -1 2010/07/12 18:30:18 :: did not find pref_height in configuration, setting default -1 2010/07/12 18:30:18 :: trying to load backend external 2010/07/12 18:30:18 :: trying to load backend ioctl 2010/07/12 18:30:18 :: WARNING: python-iwscan not found, falling back to using iwlist scan. 2010/07/12 18:30:18 :: WARNING: python-wpactrl not found, falling back to using wpa_cli. 2010/07/12 18:30:52 :: setting use global dns to 0 2010/07/12 18:30:52 :: setting global dns 2010/07/12 18:30:52 :: global dns servers are 2010/07/12 18:30:52 :: domain is 2010/07/12 18:30:52 :: search domain is 2010/07/12 18:30:52 :: setting wireless interface eth1 2010/07/12 18:30:52 :: setting wired interface eth0 2010/07/12 18:30:52 :: setting wpa driver wext 2010/07/12 18:30:52 :: setting automatically reconnect when connection drops 1 2010/07/12 18:30:52 :: setting backend to external 2010/07/12 18:30:52 :: Setting dhcp client to 0 2010/07/12 18:33:58 :: attempting to set hostname with dhclient 2010/07/12 18:33:58 :: using dhcpcd or another supported client may work better 2010/07/12 18:33:58 :: attempting to set hostname with dhclient 2010/07/12 18:33:58 :: using dhcpcd or another supported client may work better 2010/07/12 18:35:42 :: Connecting to wireless network x-work 2010/07/12 18:35:42 :: attempting to set hostname with dhclient 2010/07/12 18:35:42 :: using dhcpcd or another supported client may work better 2010/07/12 18:35:42 :: attempting to set hostname with dhclient 2010/07/12 18:35:42 :: using dhcpcd or another supported client may work better 2010/07/12 18:35:44 :: Putting interface down 2010/07/12 18:35:44 :: Releasing DHCP leases... 2010/07/12 18:35:44 :: attempting to set hostname with dhclient 2010/07/12 18:35:44 :: using dhcpcd or another supported client may work better 2010/07/12 18:35:44 :: Setting false IP... 2010/07/12 18:35:44 :: Stopping wpa_supplicant 2010/07/12 18:35:44 :: Flushing the routing table... 2010/07/12 18:35:44 :: Putting interface up... 2010/07/12 18:35:46 :: Generating psk... 2010/07/12 18:35:46 :: Attempting to authenticate... 2010/07/12 18:36:02 :: Running DHCP with hostname dell.laszlo 2010/07/12 18:36:02 :: attempting to set hostname with dhclient 2010/07/12 18:36:02 :: using dhcpcd or another supported client may work better 2010/07/12 18:36:02 :: Internet Systems Consortium DHCP Client 4.1.1-P1 2010/07/12 18:36:02 :: Copyright 2004-2010 Internet Systems Consortium. 2010/07/12 18:36:02 :: All rights reserved. 2010/07/12 18:36:02 :: For info, please visit https://www.isc.org/software/dhcp/ 2010/07/12 18:36:02 :: 2010/07/12 18:36:02 :: Listening on LPF/eth1/00:26:5e:16:8b:47 2010/07/12 18:36:02 :: Sending on LPF/eth1/00:26:5e:16:8b:47 2010/07/12 18:36:02 :: Sending on Socket/fallback 2010/07/12 18:36:03 :: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 3 2010/07/12 18:36:03 :: DHCPOFFER from 192.168.1.2 2010/07/12 18:36:03 :: DHCPREQUEST on eth1 to 255.255.255.255 port 67 2010/07/12 18:36:03 :: DHCPACK from 192.168.1.2 2010/07/12 18:36:03 :: bound to 192.168.1.4 -- renewal in 67230 seconds. 2010/07/12 18:36:03 :: DHCP connection successful 2010/07/12 18:36:03 :: not verifying 2010/07/12 18:36:03 :: Connecting thread exiting. 2010/07/12 18:36:03 :: Sending connection attempt result Success 2010/07/12 18:36:24 :: trying to load backend external 2010/07/12 18:36:24 :: trying to load backend ioctl 2010/07/12 18:36:54 :: setting use global dns to 0 2010/07/12 18:36:54 :: setting global dns 2010/07/12 18:36:54 :: global dns servers are 2010/07/12 18:36:54 :: domain is 2010/07/12 18:36:54 :: search domain is 2010/07/12 18:36:54 :: setting wireless interface x-work 2010/07/12 18:36:54 :: setting wired interface eth0 2010/07/12 18:36:54 :: setting wpa driver wext 2010/07/12 18:36:54 :: setting automatically reconnect when connection drops 1 2010/07/12 18:36:54 :: setting backend to external 2010/07/12 18:36:54 :: Setting dhcp client to 0 2010/07/12 18:36:55 :: attempting to set hostname with dhclient 2010/07/12 18:36:55 :: using dhcpcd or another supported client may work better 2010/07/12 18:37:50 :: setting use global dns to 0 2010/07/12 18:37:50 :: setting global dns 2010/07/12 18:37:50 :: global dns servers are 2010/07/12 18:37:50 :: domain is 2010/07/12 18:37:50 :: search domain is 2010/07/12 18:37:50 :: setting wireless interface x-work 2010/07/12 18:37:50 :: setting wired interface eth0 2010/07/12 18:37:50 :: setting wpa driver wext 2010/07/12 18:37:50 :: setting automatically reconnect when connection drops 1 2010/07/12 18:37:50 :: setting backend to external 2010/07/12 18:37:50 :: Setting dhcp client to 0 2010/07/12 18:38:09 :: Autoconnecting... 2010/07/12 18:38:09 :: No wired connection present, attempting to autoconnect to wireless network 2010/07/12 18:38:09 :: Unable to autoconnect, you'll have to manually connect 2010/07/12 18:38:11 :: Autoconnecting... 2010/07/12 18:38:11 :: No wired connection present, attempting to autoconnect to wireless network 2010/07/12 18:38:11 :: Unable to autoconnect, you'll have to manually connect 2010/07/12 18:38:13 :: Autoconnecting... 2010/07/12 18:38:13 :: No wired connection present, attempting to autoconnect to wireless network 2010/07/12 18:38:13 :: Unable to autoconnect, you'll have to manually connect 2010/07/12 18:38:15 :: Autoconnecting... 2010/07/12 18:38:15 :: No wired connection present, attempting to autoconnect to wireless network 2010/07/12 18:38:15 :: Unable to autoconnect, you'll have to manually connect 2010/07/12 18:40:39 :: setting use global dns to 0 2010/07/12 18:40:39 :: setting global dns 2010/07/12 18:40:39 :: global dns servers are 2010/07/12 18:40:39 :: domain is 2010/07/12 18:40:39 :: search domain is 2010/07/12 18:40:40 :: setting wireless interface eth1 2010/07/12 18:40:40 :: setting wired interface eth0 2010/07/12 18:40:40 :: setting wpa driver wext 2010/07/12 18:40:40 :: setting automatically reconnect when connection drops 1 2010/07/12 18:40:40 :: setting backend to external 2010/07/12 18:40:40 :: Setting dhcp client to 0 2010/07/12 18:46:28 :: trying to load backend external 2010/07/12 18:46:28 :: trying to load backend ioctl 2010/07/12 18:47:40 :: setting use global dns to 0 2010/07/12 18:47:40 :: setting global dns 2010/07/12 18:47:40 :: global dns servers are 2010/07/12 18:47:40 :: domain is 2010/07/12 18:47:40 :: search domain is 2010/07/12 18:47:40 :: setting wireless interface eth1 2010/07/12 18:47:40 :: setting wired interface eth0 2010/07/12 18:47:40 :: setting wpa driver wext 2010/07/12 18:47:40 :: setting automatically reconnect when connection drops 1 2010/07/12 18:47:40 :: setting backend to external 2010/07/12 18:47:40 :: Setting dhcp client to 0 2010/07/12 18:48:23 :: setting use global dns to 0 2010/07/12 18:48:23 :: setting global dns 2010/07/12 18:48:23 :: global dns servers are 2010/07/12 18:48:23 :: domain is 2010/07/12 18:48:23 :: search domain is 2010/07/12 18:48:23 :: setting wireless interface eth1 2010/07/12 18:48:23 :: setting wired interface eth0 2010/07/12 18:48:23 :: setting wpa driver wext 2010/07/12 18:48:23 :: setting automatically reconnect when connection drops 1 2010/07/12 18:48:23 :: setting backend to external 2010/07/12 18:48:23 :: Setting dhcp client to 0 2010/07/12 19:05:23 :: --------------------------- 2010/07/12 19:05:23 :: wicd initializing... 2010/07/12 19:05:23 :: --------------------------- 2010/07/12 19:05:23 :: wicd is version 1.7.0 552 2010/07/12 19:05:23 :: setting backend to external 2010/07/12 19:05:23 :: trying to load backend external 2010/07/12 19:05:23 :: successfully loaded backend external 2010/07/12 19:05:23 :: trying to load backend external 2010/07/12 19:05:23 :: successfully loaded backend external 2010/07/12 19:05:23 :: Automatically detected wireless interface eth1 2010/07/12 19:05:23 :: setting wireless interface eth1 2010/07/12 19:05:23 :: automatically detected wired interface eth0 2010/07/12 19:05:23 :: setting wired interface eth0 2010/07/12 19:05:23 :: setting wpa driver wext 2010/07/12 19:05:23 :: setting use global dns to False 2010/07/12 19:05:23 :: setting global dns 2010/07/12 19:05:23 :: global dns servers are None None None 2010/07/12 19:05:23 :: domain is None 2010/07/12 19:05:23 :: search domain is None 2010/07/12 19:05:23 :: setting automatically reconnect when connection drops True 2010/07/12 19:05:23 :: Setting dhcp client to 0 2010/07/12 19:05:23 :: Wireless configuration file found... 2010/07/12 19:05:23 :: Wired configuration file found... 2010/07/12 19:05:23 :: chmoding configuration files 0600... 2010/07/12 19:05:23 :: chowning configuration files root:root... 2010/07/12 19:05:23 :: Using wireless interface...eth1 2010/07/12 19:05:23 :: Using wired interface...eth0 2010/07/12 19:05:30 :: Autoconnecting... 2010/07/12 19:05:30 :: Couldn't find a default wired connection, wired autoconnect failed. 2010/07/12 19:05:30 :: No wired connection present, attempting to autoconnect to wireless network 2010/07/12 19:05:35 :: trying to automatically connect to...x-work 2010/07/12 19:05:35 :: Connecting to wireless network x-work 2010/07/12 19:05:35 :: attempting to set hostname with dhclient 2010/07/12 19:05:35 :: using dhcpcd or another supported client may work better 2010/07/12 19:05:36 :: attempting to set hostname with dhclient 2010/07/12 19:05:36 :: using dhcpcd or another supported client may work better 2010/07/12 19:05:36 :: Putting interface down 2010/07/12 19:05:36 :: Releasing DHCP leases... 2010/07/12 19:05:36 :: attempting to set hostname with dhclient 2010/07/12 19:05:36 :: using dhcpcd or another supported client may work better 2010/07/12 19:05:36 :: Setting false IP... 2010/07/12 19:05:36 :: Stopping wpa_supplicant 2010/07/12 19:05:36 :: Flushing the routing table... 2010/07/12 19:05:36 :: Putting interface up... 2010/07/12 19:05:38 :: Generating psk... 2010/07/12 19:05:38 :: Attempting to authenticate... 2010/07/12 19:05:55 :: Running DHCP with hostname dell.laszlo 2010/07/12 19:05:55 :: attempting to set hostname with dhclient 2010/07/12 19:05:55 :: using dhcpcd or another supported client may work better 2010/07/12 19:05:55 :: Internet Systems Consortium DHCP Client 4.1.1-P1 2010/07/12 19:05:55 :: Copyright 2004-2010 Internet Systems Consortium. 2010/07/12 19:05:55 :: All rights reserved. 2010/07/12 19:05:55 :: For info, please visit https://www.isc.org/software/dhcp/ 2010/07/12 19:05:55 :: 2010/07/12 19:05:55 :: Listening on LPF/eth1/00:26:5e:16:8b:47 2010/07/12 19:05:55 :: Sending on LPF/eth1/00:26:5e:16:8b:47 2010/07/12 19:05:55 :: Sending on Socket/fallback 2010/07/12 19:05:56 :: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 8 2010/07/12 19:05:56 :: DHCPOFFER from 192.168.1.2 2010/07/12 19:05:56 :: DHCPREQUEST on eth1 to 255.255.255.255 port 67 2010/07/12 19:05:56 :: DHCPACK from 192.168.1.2 2010/07/12 19:05:56 :: bound to 192.168.1.4 -- renewal in 67663 seconds. 2010/07/12 19:05:56 :: DHCP connection successful 2010/07/12 19:05:56 :: not verifying 2010/07/12 19:05:56 :: Connecting thread exiting. 2010/07/12 19:05:56 :: Sending connection attempt result Success 2010/07/12 19:06:29 :: attempting to set hostname with dhclient 2010/07/12 19:06:29 :: using dhcpcd or another supported client may work better 2010/07/12 19:06:30 :: Autoconnecting... 2010/07/12 19:06:30 :: Couldn't find a default wired connection, wired autoconnect failed. 2010/07/12 19:06:30 :: No wired connection present, attempting to autoconnect to wireless network 2010/07/12 19:06:30 :: trying to automatically connect to...x-work 2010/07/12 19:06:30 :: Connecting to wireless network x-work 2010/07/12 19:06:30 :: attempting to set hostname with dhclient 2010/07/12 19:06:30 :: using dhcpcd or another supported client may work better 2010/07/12 19:06:30 :: attempting to set hostname with dhclient 2010/07/12 19:06:30 :: using dhcpcd or another supported client may work better 2010/07/12 19:06:30 :: Putting interface down 2010/07/12 19:06:30 :: Releasing DHCP leases... 2010/07/12 19:06:30 :: attempting to set hostname with dhclient 2010/07/12 19:06:30 :: using dhcpcd or another supported client may work better 2010/07/12 19:06:30 :: Setting false IP... 2010/07/12 19:06:30 :: Stopping wpa_supplicant 2010/07/12 19:06:30 :: Flushing the routing table... 2010/07/12 19:06:30 :: Putting interface up... 2010/07/12 19:06:31 :: attempting to set hostname with dhclient 2010/07/12 19:06:31 :: using dhcpcd or another supported client may work better 2010/07/12 19:06:31 :: attempting to set hostname with dhclient 2010/07/12 19:06:31 :: using dhcpcd or another supported client may work better 2010/07/12 19:06:32 :: Generating psk... 2010/07/12 19:06:32 :: Attempting to authenticate... 2010/07/12 19:06:49 :: Running DHCP with hostname dell.laszlo 2010/07/12 19:06:49 :: attempting to set hostname with dhclient 2010/07/12 19:06:49 :: using dhcpcd or another supported client may work better 2010/07/12 19:06:49 :: Internet Systems Consortium DHCP Client 4.1.1-P1 2010/07/12 19:06:49 :: Copyright 2004-2010 Internet Systems Consortium. 2010/07/12 19:06:49 :: All rights reserved. 2010/07/12 19:06:49 :: For info, please visit https://www.isc.org/software/dhcp/ 2010/07/12 19:06:49 :: 2010/07/12 19:06:49 :: Listening on LPF/eth1/00:26:5e:16:8b:47 2010/07/12 19:06:49 :: Sending on LPF/eth1/00:26:5e:16:8b:47 2010/07/12 19:06:49 :: Sending on Socket/fallback 2010/07/12 19:06:50 :: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 6 2010/07/12 19:06:50 :: DHCPOFFER from 192.168.1.2 2010/07/12 19:06:50 :: DHCPREQUEST on eth1 to 255.255.255.255 port 67 2010/07/12 19:06:50 :: DHCPACK from 192.168.1.2 2010/07/12 19:06:50 :: bound to 192.168.1.4 -- renewal in 82027 seconds. 2010/07/12 19:06:50 :: DHCP connection successful 2010/07/12 19:06:50 :: not verifying 2010/07/12 19:06:50 :: Connecting thread exiting. 2010/07/12 19:06:50 :: Sending connection attempt result Success 2010/07/12 19:20:10 :: attempting to set hostname with dhclient 2010/07/12 19:20:10 :: using dhcpcd or another supported client may work better 2010/07/12 19:20:10 :: attempting to set hostname with dhclient 2010/07/12 19:20:10 :: using dhcpcd or another supported client may work better 2010/07/12 19:32:51 :: --------------------------- 2010/07/12 19:32:51 :: wicd initializing... 2010/07/12 19:32:51 :: --------------------------- 2010/07/12 19:32:51 :: wicd is version 1.7.0 552 2010/07/12 19:32:51 :: setting backend to external 2010/07/12 19:32:51 :: trying to load backend external 2010/07/12 19:32:51 :: successfully loaded backend external 2010/07/12 19:32:51 :: trying to load backend external 2010/07/12 19:32:51 :: successfully loaded backend external 2010/07/12 19:32:51 :: Automatically detected wireless interface eth1 2010/07/12 19:32:51 :: setting wireless interface eth1 2010/07/12 19:32:51 :: automatically detected wired interface eth0 2010/07/12 19:32:51 :: setting wired interface eth0 2010/07/12 19:32:51 :: setting wpa driver wext 2010/07/12 19:32:51 :: setting use global dns to False 2010/07/12 19:32:51 :: setting global dns 2010/07/12 19:32:51 :: global dns servers are None None None 2010/07/12 19:32:51 :: domain is None 2010/07/12 19:32:51 :: search domain is None 2010/07/12 19:32:51 :: setting automatically reconnect when connection drops True 2010/07/12 19:32:51 :: Setting dhcp client to 0 2010/07/12 19:32:51 :: Wireless configuration file found... 2010/07/12 19:32:51 :: Wired configuration file found... 2010/07/12 19:32:51 :: chmoding configuration files 0600... 2010/07/12 19:32:51 :: chowning configuration files root:root... 2010/07/12 19:32:51 :: Using wireless interface...eth1 2010/07/12 19:32:51 :: Using wired interface...eth0 2010/07/12 19:32:58 :: Autoconnecting... 2010/07/12 19:32:58 :: No wired connection present, attempting to autoconnect to wireless network 2010/07/12 19:33:03 :: trying to automatically connect to...x-work 2010/07/12 19:33:03 :: Connecting to wireless network x-work 2010/07/12 19:33:03 :: attempting to set hostname with dhclient 2010/07/12 19:33:03 :: using dhcpcd or another supported client may work better 2010/07/12 19:33:04 :: attempting to set hostname with dhclient 2010/07/12 19:33:04 :: using dhcpcd or another supported client may work better 2010/07/12 19:33:06 :: Putting interface down 2010/07/12 19:33:06 :: Releasing DHCP leases... 2010/07/12 19:33:06 :: attempting to set hostname with dhclient 2010/07/12 19:33:06 :: using dhcpcd or another supported client may work better 2010/07/12 19:33:06 :: Setting false IP... 2010/07/12 19:33:06 :: Stopping wpa_supplicant 2010/07/12 19:33:06 :: Flushing the routing table... 2010/07/12 19:33:06 :: Putting interface up... 2010/07/12 19:33:08 :: Generating psk... 2010/07/12 19:33:08 :: Attempting to authenticate... 2010/07/12 19:33:24 :: Running DHCP with hostname dell.laszlo 2010/07/12 19:33:24 :: attempting to set hostname with dhclient 2010/07/12 19:33:24 :: using dhcpcd or another supported client may work better 2010/07/12 19:33:24 :: Internet Systems Consortium DHCP Client 4.1.1-P1 2010/07/12 19:33:24 :: Copyright 2004-2010 Internet Systems Consortium. 2010/07/12 19:33:24 :: All rights reserved. 2010/07/12 19:33:24 :: For info, please visit https://www.isc.org/software/dhcp/ 2010/07/12 19:33:24 :: 2010/07/12 19:33:24 :: Listening on LPF/eth1/00:26:5e:16:8b:47 2010/07/12 19:33:24 :: Sending on LPF/eth1/00:26:5e:16:8b:47 2010/07/12 19:33:24 :: Sending on Socket/fallback 2010/07/12 19:33:24 :: DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 6 2010/07/12 19:33:24 :: DHCPOFFER from 192.168.1.2 2010/07/12 19:33:24 :: DHCPREQUEST on eth1 to 255.255.255.255 port 67 2010/07/12 19:33:24 :: DHCPACK from 192.168.1.2 2010/07/12 19:33:25 :: bound to 192.168.1.4 -- renewal in 78926 seconds. 2010/07/12 19:33:25 :: DHCP connection successful 2010/07/12 19:33:25 :: not verifying 2010/07/12 19:33:25 :: Connecting thread exiting. 2010/07/12 19:33:25 :: Sending connection attempt result Success 2010/07/12 19:34:54 :: trying to load backend external 2010/07/12 19:34:54 :: trying to load backend ioctl 2010/07/12 19:34:54 :: WARNING: python-iwscan not found, falling back to using iwlist scan. 2010/07/12 19:34:54 :: WARNING: python-wpactrl not found, falling back to using wpa_cli. 2010/07/12 19:35:01 :: setting use global dns to 0 2010/07/12 19:35:01 :: setting global dns 2010/07/12 19:35:01 :: global dns servers are 2010/07/12 19:35:01 :: domain is 2010/07/12 19:35:01 :: search domain is 2010/07/12 19:35:01 :: setting wireless interface eth1 2010/07/12 19:35:01 :: setting wired interface eth0 2010/07/12 19:35:01 :: setting wpa driver wext 2010/07/12 19:35:01 :: setting automatically reconnect when connection drops 1 2010/07/12 19:35:01 :: setting backend to external 2010/07/12 19:35:01 :: Setting dhcp client to 0 2010/07/12 19:42:44 :: attempting to set hostname with dhclient 2010/07/12 19:42:44 :: using dhcpcd or another supported client may work better 2010/07/12 19:42:44 :: attempting to set hostname with dhclient 2010/07/12 19:42:44 :: using dhcpcd or another supported client may work better 2010/07/12 19:42:49 :: Autoconnecting... 2010/07/12 19:42:49 :: No wired connection present, attempting to autoconnect to wireless network 2010/07/12 19:42:54 :: trying to automatically connect to...x-work 2010/07/12 19:42:54 :: Connecting to wireless network x-work 2010/07/12 19:42:54 :: attempting to set hostname with dhclient 2010/07/12 19:42:54 :: using dhcpcd or another supported client may work better 2010/07/12 19:42:54 :: attempting to set hostname with dhclient 2010/07/12 19:42:54 :: using dhcpcd or another supported client may work better 2010/07/12 19:42:56 :: Putting interface down 2010/07/12 19:42:56 :: Releasing DHCP leases... 2010/07/12 19:42:56 :: attempting to set hostname with dhclient 2010/07/12 19:42:56 :: using dhcpcd or another supported client may work better 2010/07/12 19:42:56 :: Setting false IP... 2010/07/12 19:42:56 :: Stopping wpa_supplicant 2010/07/12 19:42:56 :: Flushing the routing table... 2010/07/12 19:42:56 :: Putting interface up... 2010/07/12 19:42:58 :: Generating psk... 2010/07/12 19:42:58 :: Attempting to authenticate... 2010/07/12 19:43:33 :: wpa_supplicant authentication may have failed. 2010/07/12 19:43:33 :: connect result is Failed 2010/07/12 19:43:33 :: exiting connection thread 2010/07/12 19:43:34 :: Sending connection attempt result bad_pass 2010/07/12 19:43:34 :: attempting to set hostname with dhclient 2010/07/12 19:43:34 :: using dhcpcd or another supported client may work better 2010/07/12 19:43:34 :: attempting to set hostname with dhclient 2010/07/12 19:43:34 :: using dhcpcd or another supported client may work better 2010/07/12 19:44:17 :: Connecting to wireless network x-work 2010/07/12 19:44:17 :: attempting to set hostname with dhclient 2010/07/12 19:44:17 :: using dhcpcd or another supported client may work better 2010/07/12 19:44:17 :: attempting to set hostname with dhclient 2010/07/12 19:44:17 :: using dhcpcd or another supported client may work better 2010/07/12 19:44:18 :: Putting interface down 2010/07/12 19:44:19 :: Releasing DHCP leases... 2010/07/12 19:44:19 :: attempting to set hostname with dhclient 2010/07/12 19:44:19 :: using dhcpcd or another supported client may work better 2010/07/12 19:44:19 :: Setting false IP... 2010/07/12 19:44:19 :: Stopping wpa_supplicant 2010/07/12 19:44:19 :: Flushing the routing table... 2010/07/12 19:44:19 :: Putting interface up... 2010/07/12 19:44:21 :: Generating psk... 2010/07/12 19:44:21 :: Attempting to authenticate... 2010/07/12 19:44:56 :: wpa_supplicant authentication may have failed. 2010/07/12 19:44:56 :: connect result is Failed 2010/07/12 19:44:56 :: exiting connection thread 2010/07/12 19:44:56 :: Sending connection attempt result bad_pass 2010/07/12 19:44:57 :: attempting to set hostname with dhclient 2010/07/12 19:44:57 :: using dhcpcd or another supported client may work better 2010/07/12 19:44:57 :: attempting to set hostname with dhclient 2010/07/12 19:44:57 :: using dhcpcd or another supported client may work better 2010/07/12 19:46:40 :: setting use global dns to 0 2010/07/12 19:46:40 :: setting global dns 2010/07/12 19:46:40 :: global dns servers are 2010/07/12 19:46:40 :: domain is 2010/07/12 19:46:40 :: search domain is 2010/07/12 19:46:40 :: setting wireless interface eth1 2010/07/12 19:46:40 :: setting wired interface eth0 2010/07/12 19:46:40 :: setting wpa driver wext 2010/07/12 19:46:40 :: setting automatically reconnect when connection drops 1 2010/07/12 19:46:40 :: setting backend to external 2010/07/12 19:46:40 :: Setting dhcp client to 0 2010/07/12 23:57:58 :: attempting to set hostname with dhclient 2010/07/12 23:57:58 :: using dhcpcd or another supported client may work better 2010/07/12 23:57:59 :: attempting to set hostname with dhclient 2010/07/12 23:57:59 :: using dhcpcd or another supported client may work better Proszę o pomoc w rozwiązaniu problemu. Pozdrawiam! EDIT: Dokładna treść komunikatu: Could not connect to wicd's D-Bus interface. Check the wicd log for error messages Edytowane Lipiec 13, 2010 przez WalDo code → codebox. Proszę korzystać przy długich listingach ze znaczników CODEBOX Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Lipiec 13, 2010 Zgłoszenie Share Napisano Lipiec 13, 2010 Gotowa lista rozwiązań :> → http://www.google.pl/search?num=100&hl...q=&gs_rfai= Żadnych alertów SElinux? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
laszjwrz Napisano Lipiec 17, 2010 Autor Zgłoszenie Share Napisano Lipiec 17, 2010 Alertów żadnych. Przeanalizowałem rozwiązania z linku, ale średnio to widzę.. Problem dalej nie rozwiązany. Czy na podstawie sprawdzenia i wykluczenia rozwiązań jesteś/cie w stanie mi pomóc? Napisz/cie tylko co mam zrobić. Serdecznie dziękuję! Pozdrawiam. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
