Listonoszek Napisano Lipiec 27, 2010 Zgłoszenie Share Napisano Lipiec 27, 2010 Cześć! Używam Fedora 13 i co jakiś czas podczas pracy coś(?) - może to ja? wylogowywuje mnie z systemu. Normalnie pracuję jak gdyby nigdy nic a tu nagle czarny ekran, pasek od "ładowania" - ładny napis Fedora, i przenosi mnie do okna logowania. Czym może być to spowodowane? Czy to ja robie coś nie tak? Czy może jakiś pakiet? Program? Dziękuję i pozdrawiam PS. Dodam również, że SELinux czepia się, że Wine chce uzyskać dostęp do pamięci ram przy starcie systemu i nie bardzo wiem, o co chodzi. Czytałem jakiś manual o problemach z Wine, ale nie doszukałem się mojego. Niżej załączam raport z SELinux. Summary: SELinux has prevented wine from performing an unsafe memory operation. Detailed Description: SELinux denied an operation requested by wine-preloader, a program used to run Windows applications under Linux. This program is known to use an unsafe operation on system memory but so are a number of malware/exploit programs which masquerade as wine. If you were attempting to run a Windows program your only choices are to allow this operation and reduce your system security against such malware or to refrain from running Windows applications under Linux. If you were not attempting to run a Windows application this indicates you are likely being attacked by some for of malware or program trying to exploit your system for nefarious purposes. Please refer to http://wiki.winehq.org/PreloaderPageZeroProblem Which outlines the other problems wine encounters due to its unsafe use of memory and solutions to those problems. Allowing Access: If you decide to continue to run the program in question you will need to allow this operation. This can be done on the command line by executing: # setsebool -P mmap_low_allowed 1 Fix Command: /usr/sbin/setsebool -P mmap_low_allowed 1 Additional Information: Source Context unconfined_u:unconfined_r:wine_t:s0-s0:c0.c1023 Target Context unconfined_u:unconfined_r:wine_t:s0-s0:c0.c1023 Target Objects None [ memprotect ] Source wine-preloader Source Path /usr/bin/wine-preloader Port <Unknown> Host listonoszek.localhost Source RPM Packages wine-core-1.2.0-1.fc13 Target RPM Packages Policy RPM selinux-policy-3.7.19-10.fc13 Selinux Enabled True Policy Type targeted Enforcing Mode Enforcing Plugin Name wine Host Name listonoszek.localhost Platform Linux listonoszek.localhost 2.6.33.3-85.fc13.i686 #1 SMP Thu May 6 18:44:12 UTC 2010 i686 i686 Alert Count 20 First Seen Mon 26 Jul 2010 02:44:55 PM CEST Last Seen Mon 26 Jul 2010 02:50:20 PM CEST Local ID 41589c2c-1df6-447c-960e-efa7c100d7ab Line Numbers Raw Audit Messages node=listonoszek.localhost type=AVC msg=audit(1280148620.234:16249): avc: denied { mmap_zero } for pid=9649 comm="wine-preloader" scontext=unconfined_u:unconfined_r:wine_t:s0-s0:c0.c1023 tcontext=unconfined_u:unconfined_r:wine_t:s0-s0:c0.c1023 tclass=memprotect node=listonoszek.localhost type=SYSCALL msg=audit(1280148620.234:16249): arch=40000003 syscall=90 success=no exit=-13 a0=bfbcd970 a1=0 a2=bfbcd970 a3=5a items=0 ppid=1 pid=9649 auid=500 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="wine-preloader" exe="/usr/bin/wine-preloader" subj=unconfined_u:unconfined_r:wine_t:s0-s0:c0.c1023 key=(null) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Lipiec 27, 2010 Zgłoszenie Share Napisano Lipiec 27, 2010 Co do wylogowania nie mam pomysłu - być może to również problemy z SElinux. Czy masz angielską wersję Fedory? Skąd komunikat SElinux po angielsku? Gdyby był po polsku to pewnie łatwiej byłoby Ci odnaleźć "Polecenie naprawy" (ang. Fix Command). Odszukaj w komunikacie, wykonaj i będzie po problemie. Jeśli pojawią się kolejne postępuj analogicznie. Poza tym jako root wykonaj polecenie touch /.autorelabel reboot Po restarcie system będzie się długo podnosił (kilka, kilkanaście minut zależnie od sprzętu, ilości zainstalowanych programów). Potem warto zaktualizować system. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
