Startup Crush Po Zmnianie Nvidii.
donEscopeta
[ 8.490963] [drm] nouveau 0000:02:00.0: Pointer to BIT loadval table invalid
Bug, zgłoszony zresztą w bugzilli:
https://bugzilla.redhat.com/show_bug.cgi?id=630765
Zrób tak jak Ci radzi WalDo.
Mówie o zabawach z pluginami do Firefoxa ,instalacja komercyjnych programów ,postawienie Wine ,kompilacja OpenWrt etc.
Dobra, uruchomilem fedore (wylaczylem nouveau).
Zainstalowalem sterowniki z rpmfusion, zgodnie z howto.
Restart i problemy z X-em.
Xorg.0.log:
[    91.874]
X.Org X Server 1.9.1
Release Date: 2010-10-22
[    91.876] X Protocol Version 11, Revision 0
[    91.877] Build Operating System: x86-13 2.6.32-72.el6.bz634452.x86_64
[    91.877] Current Operating System: Linux MateuszFedora 2.6.35.9-64.fc14.i686 #1 SMP Fri Dec 3 12:35:42 UTC 2010 i686
[    91.878] Kernel command line: ro root=UUID=62098eb5-abcb-401e-84ab-354c712417a3 rd_NO_LUKS rd_NO_LVM rd_NO_MD rd_NO_DM LANG=pl_PL.UTF-8 SYSFONT=latarcyrheb-sun16 KEYTABLE=pl2 rhgb quiet rdblacklist=nouveau nouveau.modeset=0
[    91.880] Build Date: 09 November 2010  08:15:10PM
[    91.880] Build ID: xorg-x11-server 1.9.1-3.fc14
[    91.881] Current version of pixman: 0.18.4
[    91.881] 	Before reporting problems, check http://wiki.x.org
[    91.882] Markers: (--) probed, (**) from config file, (==) default setting,
[    91.885] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Dec 18 11:17:35 2010
[    91.885] (==) Using config file: "/etc/X11/xorg.conf"
[    91.886] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    91.886] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    91.887] (==) ServerLayout "Default Layout"
[    91.887] (**) |-->Screen "Default Screen" (0)
[    91.887] (**) |   |-->Monitor "<default monitor>"
[    91.887] (**) |   |-->Device "Videocard0"
[    91.887] (==) No monitor specified for screen "Default Screen".
Using a default monitor configuration.
[    91.887] (**) |-->Input Device "Keyboard0"
[    91.887] (**) |-->Input Device "Mouse0"
[    91.888] (==) Automatically adding devices
[    91.888] (==) Automatically enabling devices
[    91.888] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[    91.888] (**) ModulePath set to "/usr/lib/xorg/modules/extensions/nvidia,/usr/lib/xorg/modules"
[    91.888] (WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    91.888] (WW) Disabling Keyboard0
[    91.888] (WW) Disabling Mouse0
[    91.888] (II) Loader magic: 0x81fac2c
[    91.888] (II) Module ABI versions:
[    91.888] 	X.Org ANSI C Emulation: 0.4
[    91.888] 	X.Org Video Driver: 8.0
[    91.888] 	X.Org XInput driver : 11.0
[    91.888] 	X.Org Server Extension : 4.0
[    91.890] (--) PCI: (0:1:6:0) 109e:036e:1822:0001 rev 17, Mem @ 0xe6100000/4096, BIOS @ 0x????????/65536
[    91.890] (--) PCI:*(0:2:0:0) 10de:0e22:1458:34fa rev 161, Mem @ 0xe0000000/33554432, 0xd0000000/134217728, 0xd8000000/67108864, I/O @ 0x0000b000/128, BIOS @ 0x????????/524288
[    91.890] (II) LoadModule: "extmod"
[    91.891] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[    91.891] (II) Module extmod: vendor="X.Org Foundation"
[    91.891] 	compiled for 1.9.1, module version = 1.0.0
[    91.891] 	Module class: X.Org Server Extension
[    91.891] 	ABI class: X.Org Server Extension, version 4.0
[    91.891] (II) Loading extension SELinux
[    91.891] (II) Loading extension MIT-SCREEN-SAVER
[    91.891] (II) Loading extension XFree86-VidModeExtension
[    91.891] (II) Loading extension XFree86-DGA
[    91.891] (II) Loading extension DPMS
[    91.891] (II) Loading extension XVideo
[    91.891] (II) Loading extension XVideo-MotionCompensation
[    91.891] (II) Loading extension X-Resource
[    91.891] (II) LoadModule: "dbe"
[    91.892] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[    91.892] (II) Module dbe: vendor="X.Org Foundation"
[    91.892] 	compiled for 1.9.1, module version = 1.0.0
[    91.892] 	Module class: X.Org Server Extension
[    91.892] 	ABI class: X.Org Server Extension, version 4.0
[    91.892] (II) Loading extension DOUBLE-BUFFER
[    91.892] (II) LoadModule: "glx"
[    91.892] (II) Loading /usr/lib/xorg/modules/extensions/nvidia/libglx.so
[    91.918] (II) Module glx: vendor="NVIDIA Corporation"
[    91.918] 	compiled for 4.0.2, module version = 1.0.0
[    91.918] 	Module class: X.Org Server Extension
[    91.918] (II) NVIDIA GLX Module  260.19.21  Thu Nov  4 20:52:05 PDT 2010
[    91.918] (II) Loading extension GLX
[    91.918] (II) LoadModule: "record"
[    91.918] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[    91.919] (II) Module record: vendor="X.Org Foundation"
[    91.919] 	compiled for 1.9.1, module version = 1.13.0
[    91.919] 	Module class: X.Org Server Extension
[    91.919] 	ABI class: X.Org Server Extension, version 4.0
[    91.919] (II) Loading extension RECORD
[    91.919] (II) LoadModule: "dri"
[    91.919] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[    91.919] (II) Module dri: vendor="X.Org Foundation"
[    91.919] 	compiled for 1.9.1, module version = 1.0.0
[    91.919] (II) Loading extension XFree86-DRI
[    91.919] (II) LoadModule: "dri2"
[    91.920] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[    91.920] (II) Module dri2: vendor="X.Org Foundation"
[    91.920] 	compiled for 1.9.1, module version = 1.2.0
[    91.920] 	ABI class: X.Org Server Extension, version 4.0
[    91.920] (II) Loading extension DRI2
[    91.920] (II) LoadModule: "nvidia"
[    91.920] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    91.921] (II) Module nvidia: vendor="NVIDIA Corporation"
[    91.921] 	compiled for 4.0.2, module version = 1.0.0
[    91.921] 	Module class: X.Org Video Driver
[    91.921] (II) NVIDIA dlloader X Driver  260.19.21  Thu Nov  4 20:26:43 PDT 2010
[    91.921] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    91.921] (--) using VT number 7
[    91.943] (II) Loading sub module "fb"
[    91.943] (II) LoadModule: "fb"
[    91.943] (II) Loading /usr/lib/xorg/modules/libfb.so
[    91.944] (II) Module fb: vendor="X.Org Foundation"
[    91.944] 	compiled for 1.9.1, module version = 1.0.0
[    91.944] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    91.944] (II) Loading sub module "wfb"
[    91.944] (II) LoadModule: "wfb"
[    91.944] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    91.944] (II) Module wfb: vendor="X.Org Foundation"
[    91.944] (II) Loading sub module "ramdac"
[    91.945] (II) LoadModule: "ramdac"
[    91.945] (II) Module "ramdac" already built-in
[    91.945] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    91.945] (==) NVIDIA(0): RGB weight 888
[    91.945] (==) NVIDIA(0): Default visual is TrueColor
[    91.945] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    91.945] (**) NVIDIA(0): Enabling RENDER acceleration
[    91.945] (II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
[    91.945] (II) NVIDIA(0):     enabled.
[    92.210] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:2:0:0.  Please
[    92.210] (EE) NVIDIA(0):     check your system's kernel log for additional error
[    92.210] (EE) NVIDIA(0):     messages and refer to Chapter 8: Common Problems in the
[    92.210] (EE) NVIDIA(0):     README for additional information.
[    92.210] (EE) NVIDIA(0): Failed to initialize the NVIDIA graphics device!
[    92.210] (II) UnloadModule: "nvidia"
[    92.210] (II) UnloadModule: "wfb"
[    92.210] (II) UnloadModule: "fb"
[    92.210] (EE) Screen(s) found, but none have a usable configuration.
[    92.210]
Fatal server error:
[    92.210] no screens found
[    92.211]
Please consult the Fedora Project support
 at http://wiki.x.org
for help.
[    92.211] Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    92.211]
Co mówi kernel log?
[ 92.210622] NVRM: RmInitAdapter failed! (0x26:0xffffffff:1028)
[ 92.210636] NVRM: rm_init_adapter(0) failed
Poszukaj cos pod to, troche tego na googlach jest. Poza tym procek Ci sie cos grzeje i kilka innych bledów nie zwiazanych z grafika. Blad ponoc nie wystepuje na x86_64.
Upewnij sie, ze nie masz pliku /etc/X11/xorg.conf, uruchom przy wylaczonych X-ach (mysle tu o init 3 albo najlepiej wystartowaniu systemu od razu na poziomie 3) polecenie
X -configure
i postepuj dalej zgodnie ze wskazówkami na ekranie.
Upewnij sie, ze w /etc/modprobe.d jest plik o nazwie blacklist-nouveau.conf - ewentualnie o innej nazwie ale z zawartoscia
blacklist nouveau
i sprawdz czy modul nouveau na pewno nie jest zaladowany
lsmod | grep nouveau
[EDIT]
Jesli jest zaladowany, to zrób to co zalecaja w komentarzu w pliku blacklist-nouveau.conf
# RPM Fusion blacklist for nouveau driver - you need to run as root:
# dracut -f /boot/initramfs-$(uname -r).img $(uname -r)
# if nouveau is loaded despite this file.
[/EDIT]
[OFFTOPIC]
Jaki problem z pluginami? Wine? A w czym problem jak jest 64-bitowe? Co do OpenWrt to AFAIK w repozytoriach 32-bitowych tez nie ma chyba gotowych paczek. Oczywiscie zrobisz jak zechcesz, ale nie siej defetyzmu :) Masz mocno nieaktualne dane nt. 64-bitowej Fedory.
Biorac jeszcze pod uwage to co napisal powyzej esail, to przemyslalbym przejscie na platforme 64-bitowa.
Edytowane przez WalDo
Mozliwe bo ostatnim razem w wersji 64 bitowej instalowalem fedore 12.
No, to nie takie stare jak sadzilem po Twojej wypowiedzi. U mnie F11 juz ladnie na 64-bitach chodzila, a 64-bitowe wine bylo juz chyba w F12. W kazdym razie projekt istnieje i wydaje stabilne oprogramowanie http://wiki.winehq.org/Wine64
Jakis czas temu nawet flash sie pokazal w wersji 64-bit.
Konczac ten offtopic, to mysle, ze warto spróbowac, jesli wersja 64-bitowa da rade pociagnac Twoja nowa karte.
Ale troche sie bedzie sciagac.
Jesli masz stabilne lacze, to polecam instalacje z obrazu netinst (cos kolo 220-230MB). Wybierzesz tylko te pakiety, które sa potrzebne. Oczywiscie podstawa to stabilne lacze. Wtedy po instalacji nie musisz dociagac paruset MB update'ów, bo sciagasz od razu ich najnowsze wersje.
Minus taki, ze jak cos pójdzie nie tak, to sciagasz od nowa ;)
