Fedora 14 X86_64 Radeon 3650 Błąd Kernel
p1orun
postanowiłem zainstalować zamknięty sterowniki do ATI skorzystałem z tego poradnika i zainstalowałem akmod-catalyst.
Niestety po uruchomieniu systemu wyświetla mi błąd kelnera za każdym razem. co z tym zrobić ?
Uploaded with ImageShack.us
WARNING: at drivers/pci/msi.c:684 pci_enable_msi_block+0x8f/0x236()
Hardware name: M56S-S3
Modules linked in: fglrx(P) ebtable_nat ebtables ipt_MASQUERADE iptable_nat nf_nat bridge stp llc deflate zlib_deflate ctr camellia cast5 rmd160 crypto_null ccm serpent blowfish twofish_x86_64 twofish_common ecb xcbc cbc sha256_generic sha512_generic des_generic cryptd aes_x86_64 aes_generic ah6 ah4 esp6 esp4 xfrm4_mode_beet xfrm4_tunnel tunnel4 xfrm4_mode_tunnel xfrm4_mode_transport xfrm6_mode_transport xfrm6_mode_ro xfrm6_mode_beet xfrm6_mode_tunnel ipcomp ipcomp6 xfrm_ipcomp xfrm6_tunnel tunnel6 af_key sunrpc cpufreq_ondemand powernow_k8 freq_table mperf ip6t_REJECT nf_conntrack_ipv6 ip6table_filter ip6_tables ipv6 fuse kvm_amd kvm uinput snd_hda_codec_atihdmi snd_hda_codec_realtek snd_hda_intel snd_hda_codec isl6421 b2c2_flexcop_pci snd_hwdep ppdev snd_seq snd_seq_device snd_pcm snd_timer b2c2_flexcop snd i2c_nforce2 dvb_core parport_pc parport forcedeth cx24123 cx24113 s5h1420 microcode edac_core k8temp edac_mce_amd soundcore snd_page_alloc pata_acpi ata_generic
firewire_ohci firewire_core usb_storage crc_itu_t pata_amd radeon ttm drm_kms_helper drm i2c_algo_bit i2c_core [last unloaded: scsi_wait_scan]
Pid: 2090, comm: Xorg Tainted: P 2.6.35.10-74.fc14.x86_64 #1
Call Trace:
[<ffffffff8104d999>] warn_slowpath_common+0x85/0x9d
[<ffffffff8104d9cb>] warn_slowpath_null+0x1a/0x1c
[<ffffffff81244ab0>] pci_enable_msi_block+0x8f/0x236
[<ffffffff81105f49>] ? __raw_local_irq_save+0x1d/0x23
[<ffffffffa071fcbd>] KCL_RequestMSI+0x13/0x15 [fglrx]
[<ffffffffa073a766>] IRQMGR_initialize+0x256/0x3b0 [fglrx]
[<ffffffffa073a4b7>] ? IRQMGR_alloc_context+0xb7/0x110 [fglrx]
[<ffffffffa0739b52>] ? irqmgr_wrap_initialize+0x22/0xb0 [fglrx]
[<ffffffffa0739474>] ? firegl_interrupt_control+0x174/0x1a0 [fglrx]
[<ffffffff81057511>] ? capable+0x25/0x44
[<ffffffffa0739300>] ? firegl_interrupt_control+0x0/0x1a0 [fglrx]
[<ffffffffa072b7da>] ? firegl_ioctl+0x1ea/0x250 [fglrx]
[<ffffffff8103c15a>] ? should_resched+0xe/0x2e
[<ffffffffa071e387>] ? ip_firegl_ioctl+0x16/0x18 [fglrx]
[<ffffffff811241e5>] ? vfs_ioctl+0x80/0xa7
[<ffffffff81124afc>] ? do_vfs_ioctl+0x468/0x49b
[<ffffffff81124b85>] ? sys_ioctl+0x56/0x79
[<ffffffff81009cf2>] ? system_call_fastpath+0x16/0x1b
Edytowane przez WalDo
Literówka w temacie
